111-08290
111-08290
    HELLERMAN(海尔曼太通)
111-08290 数据手册
Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties for outdoor use (UV-resistant) T-Series in PA66W black These inside serrated cable ties are made of UV resistant Polyamide 6.6 (PA66W) and thus suitable for outdoor applications. UV stabilised cable ties resist UV radiation for a considerably longer period compared to standard PA66 cable ties. They can easily be used for bundling and securing cables, pipes and hoses especially in outdoor areas. Features and benefits • UV resistant black cable tie available in a wide range of sizes • Made from 100 % high quality plastic, allows for good recycling • Inside serration for a strong hold onto bundles • Easy application either manually or with a processing tool • Simple to insert due to bent tail UV-resistant T-Series cable ties (PA66W). L Specific part numbers according to EN45545 available on request. W T-Series L Material specification please see page 26. W T250-series Width (W) Length (L) Bundle Ø max. Material Colour Pack Cont. Article-No. T18R 2.5 100.0 22.0 80 PA66W Black (BK) 100 pcs. 2;4-6 111-01960 T18I 2.5 145.0 35.0 80 PA66W Black (BK) 100 pcs. 2;4-6 111-02360 T18L 2.5 205.0 55.0 80 PA66W Black (BK) 100 pcs. 2;4-6 111-02160 T25LL 2.8 330.0 95.0 110 PA66W Black (BK) 100 pcs. 2;4-6 111-02660 T30R 3.5 150.0 35.0 135 PA66W Black (BK) 100 pcs. 2;4-6 111-03260 T30L 3.5 198.0 50.0 135 PA66W Black (BK) 100 pcs. 2;4-6 111-03460 T30LL 3.5 290.0 80.0 135 PA66W Black (BK) 100 pcs. 2;4-6 111-03570 T40R 4.0 175.0 40.0 180 PA66W Black (BK) 100 pcs. 2;4-8 111-01625 T50S 4.6 150.0 35.0 225 PA66W Black (BK) 100 pcs. 2-10 111-05860 T50R 4.6 200.0 50.0 225 PA66W Black (BK) 100 pcs. 2-10 111-04889 T50M 4.6 245.0 65.0 225 PA66W Black (BK) 100 pcs. 2-10 111-06206 T50I 4.6 300.0 85.0 225 PA66W Black (BK) 100 pcs. 2-10 111-05260 T50L 4.6 390.0 110.0 225 PA66W Black (BK) 100 pcs. 2-10 111-05440 T50LL 4.6 445.0 130.0 225 PA66W Black (BK) 100 pcs. 2-10 111-06000 T80R 4.7 210.0 55.0 355 PA66W Black (BK) 100 pcs. 2-12 111-05060 T80I 4.7 300.0 85.0 355 PA66W Black (BK) 100 pcs. 2-12 111-08290 T80L 4.7 390.0 110.0 355 PA66W Black (BK) 100 pcs. 2-12 111-05460 T120S 7.6 225.0 55.0 535 PA66W Black (BK) 50 pcs. 3;9-12 111-12830 T120I 7.6 300.0 80.0 535 PA66W Black (BK) 100 pcs. 3;9-12 111-12230 T150R(H) 7.6 365.0 100.0 670 PA66W Black (BK) 100 pcs. 3;9-12 111-14860 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. For product specific approvals and specifications please refer to the Appendix. 44 Tools Further information at www.HellermannTyton.co.uk/fixings Date of issue: January 2019 TYPE Cable Ties and Fixings 1.1 Cable Ties Inside Serrated Cable Ties for outdoor use (UV-resistant) T-Series in PA66W black L W T-Series L W T250-series Width (W) TYPE Length (L) Bundle Ø max. Material Pack Cont. Colour Tools Article-No. T120R(E) 7.6 387.0 100.0 535 PA66W Black (BK) 100 pcs. 3;9-12 111-12060 T120M 7.6 460.0 125.0 535 PA66W Black (BK) 100 pcs. 3;9-12 111-12660 T120L 7.6 760.0 225.0 535 PA66W Black (BK) 50 pcs. 3;9-12 111-12430 T150M 8.9 530.0 150.0 780 PA66UV Black (BK) 25 pcs. 9-12 111-15660 T150L 8.9 820.0 243.8 780 PA66UV Black (BK) 25 pcs. 9-12 111-15460 T150XL 8.9 1,095.0 330.2 780 PA66UV Black (BK) 25 pcs. 9-12 111-15502 T150XLL 8.9 1,325.0 406.4 780 PA66UV Black (BK) 25 pcs. 9-12 111-15305 T250R 12.4 515.0 124.5 1,115 PA66HIRHSUV Black (BK) 25 pcs. 11-12 111-24805 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 2 3 4 5 6 7 8 9 10 11 12 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 EVO9 EVO9HT MK9P 545 545 546 546 548 549 550 551 549 549 552 Date of issue: January 2019 For more information on toolings please refer to the Application Tooling chapter. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.co.uk/fixings 45 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Colour** Aluminium alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene rubber CR -20 °C to +80 °C Black (BK) • Weather resistant • High yield strength Ethylene Tetrafluoroethylene (Tefzel®) E/TFE -80 °C to +170 °C Blue (BU) UL 94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL 94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Good chemical resistance to acids, bases, oxidizing agents • UV resistant Polyamide 4.6 PA46 -40 °C to +130 °C, Natural (NA), (+150 °C, 5000 h; Grey (GY) +195 °C, 500 h) UL 94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitivity Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL 94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL 94 V2 • High yield strength Polyamide 6.6 glass-fibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL 94 HB • Good resistance to lubricants, fuels, salt water and solvents Polyamide 6.6 heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL 94 V2 • High yield strength • Modified elevated maximum temperature • UV resistant Polyamide 6.6 heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL 94 V2 • High yield strength • Modified elevated maximum temperature Polyamide 6.6 high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB PA66HIRHSW -40 °C to +110 °C Black (BK) UL 94 HB Polyamide 6 high impact modified Polyamide 6.6 Polyamide 6.6 high impact modified, heat and UV stabilised Material Properties* Material Specifications • Resistance to radioactivity • UV resistant, not moisture sensitive • Good chemical resistance to acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impact • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature • High yield strength, UV resistant • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature Polyamide 6.6 high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL 94 HB Polyamide 6.6 high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 V2 • High yield strength • UV resistant Polyamide 6.6 UV resistant 26 Flammability Further information at www.HellermannTyton.co.uk/fixings Date of issue: January 2019 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6 with metal particles PA66MP Polyamide 6.6 with metal particles Polyamide 6.6 V0 MATERIAL Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL 94 HB • High yield strength • Metal and X-Ray detectable PA66MP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL 94 V0 • High yield strength • Low smoke emission SP -50 °C to +150 °C Black (BK) PEEK -55 °C to +240 °C Beige (BGE) UL 94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to acids, bases, oxidising agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL 94 HB • Low moisture absorption • Good chemical resistance to most acids, bases, alcohol, oils Polyolefin PO -40 °C to +90 °C Black (BK) UL 94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL 94 HB • Floats in water • Moderate yield strength • Good chemical resistance to acids, bases and solvents PP, EPDM -20 °C to +95 °C Black (BK) UL 94 HB • Good resistance to high temperature • Good chemical and abrasion resistance Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL 94 HB • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polypropylene with metal particles PPMP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) Polyester Polyetheretherketone Polypropylene, Ethylene Propylene Diene Terpolymer rubber free of Nitrosamine Material Properties* 1.0 Material Specifications • UV resistant • Good chemical resistance to most acids, bases and oils • Low moisture absorption • Good chemical resistance to acids, bases, salts, alcohol, oils • Corrosion resistant • Antimagnetic • Weather resistant Non burning • Chemical resistance • SS316 also resistant against seawater, salt spray and anorganic acids UL 94 V0 UL 94 HB Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton also uses equivalent E/TFE raw material from other suppliers. • High elasticity • Good chemical resistance to acids, bases and oxidising agents **Further colours available on request. Date of issue: January 2019 *These details are only guide values. They should not be regarded as a exhaustive material specification and are no substitute for suitability tests. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.co.uk/fixings 27
111-08290 价格&库存
很抱歉,暂时无法提供与“111-08290”相匹配的价格&库存,您可以联系我们找货
