Cable Ties and Fixings
Cable Ties, Releasable
1.4
Cable Ties outside serrated for marking
LR55-Series
These releasable and reusable ties are ideal where temporary installation
or the addition or removal of cables is required, e.g. logistic identification
(colour coding), packaging industries or cable harness manufacturing.
Features and Benefits
• Releasable and reusable cable tie available in various colours
• Extended trigger for quick and easy release of ties
• Various colours ideal for applications that require colour coding
• Outside serration, minimising the risk of cable insulation damage
The LR55 cable ties are reusable and ideal for colour coding.
L
W
Material specification
please see page 24.
LR55 Series
TYPE
LR55R
Width
(W)
Length
(L)
Bundle
Ø max.
4.7
195.0
50.0
245
Material
Colour
Pack
Cont.
Article-No.
PA66
Blue (BU)
25 pcs.
115-00006
4.7
195.0
50.0
245
PA66
Green (GN)
25 pcs.
115-00005
4.7
195.0
50.0
245
PA66
Natural (NA)
25 pcs.
115-00008
4.7
195.0
50.0
245
PA66
Red (RD)
25 pcs.
115-00003
4.7
195.0
50.0
245
PA66
Yellow (YE)
25 pcs.
115-00004
4.7
195.0
50.0
245
PA66HS
Black (BK)
25 pcs.
115-00002
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available.
Date of issue: October 2015
Application video: LR55
Further information at www.HellermannTyton.com/fixings
77
1.0
Material Information
Material Specification Overview
Material
Shortcut
Operating
Temperature
Aluminium-alloy
AL
-40 °C to +180 °C
Natural
(NA)
• Corrosion resistant
• Antimagnetic
Chloroprene
CR
-20 °C to +80 °C
Black (BK)
• Weather-resistant
• High yield strength
Ethylene
Tetrafluoroethylene
E/TFE
-80 °C to +170 °C
Blue (BU)
UL94 V0
Polyacetal
POM
-40 °C to +90 °C,
(+110 °C, 500 h)
Natural
(NA)
UL94 HB
Polyamide 11
PA11
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
Polyamide 12
PA12
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
• Good chemical resistance to:
acids, bases, oxidizing agents
• UV-resistant
Polyamide 4.6
PA46
-40 °C to +150 °C
(5000 h), +195 °C
(500 h)
Natural
(NA),
Grey (GY)
UL94 V2
• Resistance to high temperatures
• Very moisture sensitive
• Low smoke sensitive
Polyamide 6
PA6
-40 °C to +80 °C
Black (BK)
UL94 V2
PA6HIR
-40 °C to +80 °C
Black (BK)
UL94 HB
• Limited brittleness sensitivity
• Higher flexibility at low temperature
Polyamide 6.6
PA66
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK),
Natural
(NA)
UL94 V2
Polyamide 6.6,
PA66GF13,
PA66GF15
-40 °C to +105 °C
Black (BK)
UL94 HB
• Good resistance to: lubricants, vehicle
fuel, salt water and many solvents
PA66HSW
-40 °C to +105 °C
Black (BK)
UL94 V2
• Modified elevated max. temperature
• UV-resistant
Polyamide 6.6,
heat stabilised
PA66HS
-40 °C to +105 °C
Black (BK),
Natural
(NA)
UL94 V2
• Modified elevated
max. temperature
Polyamide 6.6,
high impact modified
PA66HIR
-40 °C to +80 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
Polyamide 6.6,
high impact modified, heat
and UV stabilised
PA66HIRHSW
-40 °C to +110 °C
Black (BK)
UL94 HB
Polyamide 6.6,
stabilised
PA66HIRHS
-40 °C to +105 °C
Black (BK)
UL94 HB
Polyamide 6.6,
high impact modified, scan
black
PA66HIR(S)
-40 °C to +80 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
PA66W
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 V2
• UV-resistant
Polyamide 6,
glass-fibre reinforced
Polyamide 6.6,
heat and UV stabilised
Polyamide 6.6,
UV-resistant
Colour**
Material
Properties*
Flammability
Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers.
• Resistance to radioactivity
• UV-resistant, not moisture sensitive
• Flexible at low temperature
• Not moisture sensitive
• Robust on impacts
• Bio-plastic, derived from vegetable oil
• Strong impact resistance at low
temperature
• Very low moisture absorption
• Weather-resistant
temperature
• High yield strength, UV-resistant
**More colours on request.
*These details are only rough guide values. They should be regarded as a material specification and are no substitute for a
suitability test. Please see our datasheets for further details.
HF = Halogenfree
LFH = Limited Fire Hazard
RoHS = Restriction of Hazardous Substances
24
Material
Specifications
MATERIAL
Material
Shortcut
Operating
Temperature
Polyamide 6.6,
with metal particles
PA66MP
Polyamide 6.6 V0
MATERIAL
Material
Properties*
Colour**
Flammability
-40 °C to +85 °C,
(+105 °C, 500 h)
Blue (BU)
UL94 HB
• Metal and X-Ray detectable
PA66V0
-40 °C to +85 °C
White (WH)
UL94 V0
• Low smoke emission
PA66V0-HOI
-40 °C to +85 °C,
(+105 °C, 500 h)
White (WH)
UL94 V0
• Low smoke emissions
SP
-50 °C to +150 °C
Black (BK)
Halogen free
• UV-resistant
most acids, alkalis and oils
PEEK
-55 °C to +240 °C
Beige (BGE)
UL94 V0
Polyethylene
PE
-40 °C to +50 °C
Black (BK),
Grey (GY)
UL94 HB
• Low moisture absorption
• Good chemical resistance to: most
acids, alcohol and oils
Polyolefin
PO
-40 °C to +90 °C
Black (BK)
UL94 V0
Polypropylene
PP
-40 °C to +115 °C
Black (BK),
Natural
(NA)
UL94 HB
• Floats in water
• Moderate yield strength
organic acids
PP, EPDM
-20 °C to +95 °C
Black (BK)
UL94 HB
• Good resistance to high temperatures
• Good chemical and abrasion
resistance
Polyamide 6.6 V0,
High Oxygen Index
Polyester
Polyetheretherketone
Polypropylene, EthylenePropylene-DienTerpolymere-rubber
free of Nitrosamine
Polypropylene
PPMP
-40 °C to +115 °C
Blue (BU)
UL94 HB
• Floats in certain liquids
• Heat resistant
Polyvinylchloride
PVC
-10 °C to +70 °C
Black (BK),
Natural
(NA)
UL94 V0
acids, ethanol and oil
Stainless Steel,
Stainless Steel
SS304,
SS316
-80 °C to +538 °C
Natural
(NA)
Non burning
• Antimagnetic
• Weather resistant
• Outstanding chemical resistance
Thermoplastic
Polyurethane
TPU
-40 °C to +85 °C
Black (BK)
UL94 HB
• High elasticity
acids, bases and oxidizing agents
1.0
Material
Specifications
HF = Halogenfree
25
