Electrical Installation
Wire Connectors
Connectors - For Solid and Stranded Wires
HelaCon Plus Mini
HelaCon connectors are used for fast, easy and reliable connection and
distribution of cable and conductors in electrical installation applications.
The new generation of HelaCon Plus Mini wire connectors can be
applied tool-free using the push-in technology. HelaCon Plus Mini uses a
double spring which is approved for solid and stranded wires.
Features and benefits
• 40 % smaller – Space saving design
• Low insertion force – Easy to use, saves time on installation
• Easy access to voltage test entry and innovative port shape design
• Correct installation can be visually checked through transparent
housing
• Different colour codes for easy identification of size
• Allows different conductor diameters in each entry
• Safe application, installation and maintenance
W
HelaCon Plus Mini is now available in handy blister box.
MATERIAL
Polycarbonate (PC)
Max Current
24 A
Max Voltage
450 V
Wire Range (VDE) in mm²
0.5 to 2.5 mm² solid wires /
1.0 to 2.5 mm² stranded wires
Stripping Length
11 mm
Flammability
UL 94 V0
Operating Temperature
-30 °C to +85 °C
Now in a handy
blister pack.
L
H
HelaCon Plus Mini
front view
TYPE
HCPM-2-Blister
HelaCon Plus Mini
side view
Height
(H)
Length
(L)
Pack
Cont.
Article-No.
7.7
16.5
20 pcs.
148-90054
HCPM-3-Blister
7.7
16.5
18 pcs.
148-90055
HCPM-4-Blister
7.7
16.5
10 pcs.
148-90056
HCPM-5-Blister
7.7
16.5
10 pcs.
148-90057
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
Please note! Not all products listed on this page may have this approval. Please check our website for latest approvals.
Wire Connectors
Connectors - For Lighting Installation
HelaCon Lux
The typical application is lighting installation, where the solid conductor
from concealed cabling has to be connected to a flexible cable for
lighting or other device. The 2/1 variant allows the looping through of
the supply lines for additional devices.
There are two types of cable insertion port on each side of the HelaCon
Lux connector, one is a conventional push in wire type suitable for solid
cable, whilst the other side is suitable for flexible cable and is inserted by
pressing the locking mechanism and can be released in the same way at
any time. The lighting side can accept any kind of conductor and makes
HelaCon Lux connectors also useful to connect devices that use flexible
connecting cables such as control devices for smart home applications
e.g. for blinds, fans , heating & cooling.
• Best suitable to connect solid with flexible wire
• Combines push-in connector with lock / unlock spring mechanism
• For solid, stranded and fine-stranded conductors at lighting input
from 0.5 to 2.5 mm²
• For solid wires from 0.75 up to 2.5 mm² on the installation side
• Use with typical housing current of 450 V / 24 A
• Either one or two inputs for solid conductor on installation side
• Very flexible application
• Tool-free application for easy, time-saving, safe connection
• Especially for overhead work and when wires are difficult to access
HelaCon Lux is now available in handy blister box
MATERIAL
Polyamide (PA)
Max Current
24 A
Max Voltage
450 V
0.5 mm² - 2.5 mm²
Stripping Length
11 mm
Flammability
UL 94 V2
-5 °C to +100 °C
One Step to the Web!
L
Now in a handy
blister pack.
W
H
HelaCon Lux
side view
TYPE
HECL-2/1-Blister
HelaCon Lux
front view
Height
(H)
Length
(L)
Pack
Cont.
Article-No.
15.8
20.8
10 pcs.
148-90058
CEBEC
approvals.
很抱歉,暂时无法提供与“148-90057”相匹配的价格&库存,您可以联系我们找货
