156-04601
156-04601
    HELLERMAN(海尔曼太通)
156-04601 数据手册
Cable Ties and Fixings Cable Ties With Fixing Elements 1.6 Fixing Ties for Edges EdgeClip-Family These cable ties and EdgeClip assemblies are ideal for use where holes are not acceptable or where due to temperature problems adhesives will fail. Once the cable tie is fastened around the cables the EdgeClip is presented ready for attaching to the panel. Widely used within the automotive and panel building industries these cable ties and EdgeClips save time and money. Features and benefits • Easy assembly, just clip on per hand • For edges of 1 – 3 mm or 3 – 6 mm • Integrated metal clamp holds clip firmly in place • Clamp consists of double tempered steel spring • Ideal for applications where holes or adhesives are not suitable T50ROSEC10 fitted onto a plastic panel to hold a Ø 6 mm harness. One Step to the Web! 1-Piece Fixing Tie T50SOSEC12 can be pushed easily on edges. The silver-grey clamp, the heart of our EdgeClips, consists of doubletempered spring steel in accordance with DIN EN 10132-4 C75S. The spring steel gives the clamp both the necessary rigidity to provide high pull-off forces and also sufficient flexibility for various possible applications. Date of issue: 10/2017 The double coating is applied initially with a zinc plate system followed by inorganic surface sealing. Naturally, no chromium (VI) is used in this process. The clamp therefore complies with the current EU Directive 200/53/EC on end of life vehicles and the prohibition on heavy metals. The refined spring-steel clamp also fulfils the requirements for resistance to salt spray stipulated in DIN EN ISO 9227 NSS (min. 840 h without corrosion of base metal) and DIN EN ISO 6270-Z-CH (min. 720 h without corrosion of base material). This solution has therefore been approved by many OEMs for exposed installation locations, e.g. in engine compartments and the running-gear area. Further information at www.HellermannTyton.com/fixings 121 Cable Ties and Fixings 1.6 Cable Ties With Fixing Elements Fixing Ties for Edges Material specification please see page 26. EdgeClip-Family L EdgeClips are also available on request for panel thickness from 4 - 7 mm. W T50SOSEC12E Width (W) Length (L) Bundle Ø max. Panel Thickness Material Colour Tools Article-No. 4.6 160.0 35.0 150 1.0 - 3.0 PA66HS Black (BK) 2-10 148-00200 4.6 160.0 35.0 150 1.0 - 3.0 PA46 Grey (GY) 2-10 126-00253 T50SOSEC13E 4.6 160.0 35.0 180 1.0 - 3.0 PA66HS Black (BK) 2-10 126-00000 T40XEC5SP-E 4.0 85.0 15.0 178 1.0 - 3.0 PA66HS Black (BK) 2;4-8 133-00059 T50SOSEC34E 4.6 155.0 35.0 180 1.0 - 3.0 PA66HS Black (BK) 2-10 126-00036 T50SOSEC20-E 4.6 161.0 35.0 180 3.0 - 6.0 PA66HS Black (BK) 2-10 126-00235 TYPE Drawing T50SOSEC12E All dimensions in mm. Subject to technical changes. Recommended Tools 2 3 4 5 6 7 8 9 10 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 EVO9 551 551 552 552 554 555 556 557 554 Date of issue: 10/2017 For more information on toolings please refer to the Application Tooling chapter. 122 Further information at www.HellermannTyton.com/fixings Cable Ties and Fixings 1.6 Cable Ties With Fixing Elements 2-Piece Fixing Ties for Edges, 1.0 - 3.0 mm, Top Fixing EdgeClip-Family Features and benefits • Pre-assembled 2-piece fixing tie with EdgeClip • Cable tie head can be moved after bundling • EC9, EC10, EC21 and EC22 are for minimum bundle diameters of 1 mm • For edges of 1 – 3 mm L T50ROSEC10 fitted onto a plastic panel to hold a Ø 6 mm harness. Fixing Tie with EC4 TYPE Drawing Width Length Bundle Ø (W) (L) max. Material Material Cable Tie Foot Part Colour Tools Article-No. T30REC4A 3.6 148.0 33.0 135 PA66HS PA66HIRHS Black (BK) 2;4-6 150-76090 T50SOSEC4A 4.6 150.0 35.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-76093 T50ROSEC4A 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-76099 T50ROSEC4A-W 4.6 200.0 45.0 225 PA66W PA66W Black (BK) 2-10 156-00570 T50REC4A 4.6 202.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-76091 T50RDHEC4A 4.7 210.0 19.0 225 PA66 2-10 156-01721 T30REC4B 3.6 148.0 35.0 135 PA66HS PA66HIRHS Black (BK) 2;4-6;8 150-76080 T50SOSEC4B 4.6 150.0 35.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00109 T50ROSEC4B 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-76079 T18REC10SD 2.5 100.0 22.0 80 PA66HS PA66HIRHS Black (BK) 2;4-6;8 155-38304 T50SOSEC10 4.6 150.0 31.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00015 T50ROSEC10 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-05904 PA66HIRHS Natural (NA), Black (BK) T18REC9SD 2.5 100.0 22.0 80 PA66HS PA66HIRHS Black (BK) 2;4-6;8 155-37104 T50SOSEC9SD 4.6 150.0 31.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00019 T50ROSEC9 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-05903 T50REC9SD 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-01280 Q50REC4A 4.7 210.0 45.0 220 PA66W PA66W Black (BK) 2-10 156-01085 Q50REC4B 4.7 210.0 45.0 220 PA66W PA66W Black (BK) 2-10 156-01086 Date of issue: 10/2017 All dimensions in mm. Subject to technical changes. Further information at www.HellermannTyton.com/fixings 123 Cable Ties and Fixings 1.6 Cable Ties With Fixing Elements 2-Piece Fixing Ties for Edges, 1.0 - 3.0 mm, Side Fixing EdgeClip-Family Features and benefits • Pre-assembled 2-piece fixing tie with EdgeClip • Cable tie head can be moved after bundling • EC9, EC10, EC21 and EC22 are for minimum bundle diameters of 1 mm • For edges of 1 – 3 mm Material specification please see page 26. T50ROSEC23 - the cable bundle runs parallel with the edge. Width (W) Length (L) Bundle Ø max. Material Cable Tie Material Foot Part T30REC5A 3.6 148.0 33.0 Colour Tools Article-No. 135 PA66HS PA66HIRHS Black (BK) 2;4-6 156-00003 T50SOSEC5A 4.6 150.0 31.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-40593 T50ROSEC5A 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-40591 T50SOSEC5B 4.6 150.0 31.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-40583 T50REC5B 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-40582 T50ROSEC5B 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-40581 T18REC21 2.5 100.0 18.0 80 PA66W PA66HIRHS Black (BK) 2;4-6 156-01231 T50SOSEC21 4.6 150.0 35.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00017 T50ROSEC21 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00010 T80REC21 4.7 205.0 55.0 355 PA66HS PA66HIRHS Natural (NA), Black (BK) 2-10 156-01728 T50ROSEC22 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00011 T50REC22 4.6 200.0 45.0 225 PA66W PA66HIRHS Black (BK) 2-10 156-00576 Q50REC5A 4.7 210.0 45.0 220 PA66W PA66W Black (BK) 2-10 156-01087 Q50REC5B 4.7 210.0 45.0 220 PA66W PA66W Black (BK) 2-10 156-01088 TYPE Drawing All dimensions in mm. Subject to technical changes. 2 3 4 5 6 7 8 9 10 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 EVO9 551 551 552 552 554 555 556 557 554 For more information on toolings please refer to the Application Tooling chapter. 124 Further information at www.HellermannTyton.com/fixings Date of issue: 10/2017 Recommended Tools Cable Ties and Fixings 1.6 Cable Ties With Fixing Elements 2-Piece Fixing Ties for Edges, 3.0 - 6.0 mm, Top Fixing EdgeClip-Family Features and benefits • Pre-assembled 2-piece fixing tie with EdgeClip • Cable tie head can be moved after bundling • For minimum bundle diameters of 1 mm • For edges of 3 – 6 mm Pre-assembled 2-piece fixing tie with EdgeClip. Width (W) Length (L) Bundle Ø max. T18ROSEC19 2.5 100.0 20.0 T50SOSEC19 4.6 150.0 T50ROSEC19 4.6 T50SOSEC20 T50ROSEC20 TYPE Drawing Material Cable Tie Material Foot Part Colour Tools Article-No. 80 PA66HS PA66HIRHS Black (BK) 2;4-6 156-04600 35.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-04601 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-04602 4.6 150.0 35.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00016 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00020 All dimensions in mm. Subject to technical changes. Other combinations between cable tie and foot part available on request. 2-Piece Fixing Ties for Edges, 3.0 - 6.0 mm, Side Fixing Width (W) Length (L) Bundle Ø max. T50ROSEC23 4.6 200.0 45.0 T80REC23 4.7 205.0 T50ROSEC24 4.6 200.0 TYPE Drawing Material Cable Tie Material Foot Part Colour Tools Article-No. 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00006 55.0 355 PA66HS PA66HIRHS Natural (NA), Black (BK) 2-10 156-01729 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00007 All dimensions in mm. Subject to technical changes. Date of issue: 10/2017 Recommended Tools 2 3 4 5 6 7 8 9 10 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 EVO9 551 551 552 552 554 555 556 557 554 For more information on toolings please refer to the Application Tooling chapter. Further information at www.HellermannTyton.com/fixings 125 Cable Ties and Fixings 1.6 Cable Ties With Fixing Elements 2-Piece Fixing Ties for Edges, 0.5 - 2.5 mm, Top Fixing EdgeClip-Family for flat and thin edges These cable ties and EdgeClip assemblies are ideal for use where holes are not acceptable or where due to temperature problems adhesives will fail. These assemblies are widely used for fixing and bundling cables, pipes and hoses within the automotive industry, harness making, panel buidling and electrical industry. These EdgeClips are specially designed for applications where space is limited such as in mirrors and headlights. Features and benefits • For flat edges • For thin edges 0.5 - 2.5 mm • Small housing for limited space • Pre-assembled 2-piece fixing tie with EdgeClip • Cable tie head can be moved after bundling TYPE Drawing T30ROSEC0,5-2,5SPV for application on thin edges. The capabilities of our popular Edge Clip family have been enhanced with the introduction of new, smaller clips. These smaller clips allow bundles to run more safely on thin or flat edges. Width Length Bundle Ø (W) (L) max. Panel Material Thickness Cable Tie Material Foot Part Colour Tools Article-No. T30ROSEC0.52.5TP-SD 3.4 145.0 35.0 135 0.5 - 2.5 PA66HS PA66HIRHS Black (BK) 2;4-6 156-01543 T30ROSEC0.52.5TV-SD 3.4 145.0 35.0 135 0.5 - 2.5 PA66HS PA66HIRHS Black (BK) 2;4-6 156-01545 T30ROSEC0.52.5TPVA 3.4 145.0 35.0 135 0.5 - 2.5 PA66HS PA66HIRHS Black (BK) 2;4-6 156-01542 Material Foot Part Colour Tools Article-No. All dimensions in mm. Subject to technical changes. 2-Piece Fixing Ties for Edges, 0.5 - 2.5 mm, Side Fixing TYPE Drawing T30ROSEC0.52.5SP-SVB T30ROSEC052.5SPSVA T30ROSEC0.52.5SPVA Width Length (W) (L) Bundle Ø max. Panel Material Thickness Cable Tie 3.4 145.0 35.0 135 0.5 - 2.5 PA66HS PA66HIRHS Black (BK) 2;4-6 156-01546 3.4 145.0 35.0 133 0.5 - 2.5 PA66HS PA66HIRHS Black (BK) 2;4-6 156-01797 3.4 145.0 35.0 135 0.5 - 2.5 PA66HS PA66HIRHS Black (BK) 2;4-6 156-01544 Recommended Tools 2 4 5 6 MK20 MK3SP MK3PNSP2 EVO7 551 552 552 554 For more information on toolings please refer to the Application Tooling chapter. 126 Further information at www.HellermannTyton.com/fixings Date of issue: 10/2017 All dimensions in mm. Subject to technical changes. Cable Ties and Fixings 1.6 Cable Ties With Fixing Elements 2-Piece Fixing Ties for Edges, twistable EdgeClip-Family These cable ties and Edge Clip assemblies are ideal for use where holes are not acceptable or where due to temperature problems adhesives will fail. These assemblies are widely used for fixing and bundling cables, pipes and hoses within the automotive industry, harness making, panel buidling and electrical industry. Features and benefits • Pre-assembled 2-piece fixing tie with EdgeClip • Easy to assemble by hand • Cable tie head can be moved after bundling • For edges of 1 – 2.5 mm or 1 – 3 mm • Can be rotated to the desired position during mounting EdgeClip CBTO50R, rotatable 90°. L Material specification please see page 26. CBT30MR TYPE Drawing Width Length (W) (L) Bundle Ø max. Panel Material Thickness Cable Tie Material Foot Part Colour Tools Article-No. POM Black (BK) 2;5-6 156-00049 CBT30MR 3.5 160.0 32.0 135 2.5 PA66HS CBTO50R 4.6 202.0 47.0 225 3.0 PA66HS PA66HIRHS Black (BK) 2-10 156-01601 CBTOS50RSTUD5 4.6 200.0 47.0 225 3.0 PA66HS PA66HIRHS Black (BK) 2-10 156-00380 All dimensions in mm. Subject to technical changes. Recommended Tools 2 3 4 5 6 7 8 9 10 MK20 MK21 MK3SP MK3PNSP2 EVO7 MK7HT MK7P MK6 EVO9 551 551 552 552 554 555 556 557 554 Date of issue: 10/2017 For more information on toolings please refer to the Application Tooling chapter. Further information at www.HellermannTyton.com/fixings 127 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Colour** Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Material Properties* E/TFE -80 °C to +170 °C Blue (BU) UL 94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL 94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV- resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL 94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitiv Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL 94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL 94 V2 • High yield strength Polyamide 6.6, glass-fibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL 94 HB • Good resistance to: lubricants, vehicle fuel, salt water and a lot of solvent Polyamide 6.6, heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL 94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL 94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL 94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL 94 HB Polyamide 6.6, high impact modified, ScanBlack PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 V2 • High yield strength • UV-resistant Polyamide 6.6 Polyamide 6.6, UV-resistant Material Specifications • Resistance to radioactivity • UV- resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistanc Ethylene Tetrafluoroethylene (Tefzel®) Polyamide 6, high impact modified 26 Flammability • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Further information at www.HellermannTyton.com/fixings Date of issue: 10/2017 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6, with metal particles Polyamide 6.6 V0 MATERIAL Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL 94 HB • High yield strength • Metal and X-Ray detectable PA66MP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and x-ray detectable PA66V0 -40 °C to +85 °C White (WH) UL 94 V0 • High yield strength • Low smoke emission SP -50 °C to +150 °C Black (BK) halogen free • UV-resistant • Good chemical resistance to: most acids, alkaliks and oils PEEK -55 °C to +240 °C Beige (BGE) UL 94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL 94 HB • Low moisture absorption • Good chemical oilsresistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL 94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL 94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL 94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL 94 HB • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polypropylene with metal particles PPMP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and x-ray detectable Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL 94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) non-burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL 94 HB • High elastic • Good chemical resistance to: acids, bases and oxidizing agents Polyester Polyetheretherketone Polypropylene, Ethylene-PropyleneDien-Terpolymererubber free of Nitrosamine Date of issue: 10/2017 Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®-Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. *These details are only rough guide values. They should not be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. Material Properties* 1.0 Material Specifications **More colours on request. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 27
156-04601 价格&库存
很抱歉,暂时无法提供与“156-04601”相匹配的价格&库存,您可以联系我们找货
  • 500+13.95967500+1.80348
库存:500
