308-30306
308-30306
    HELLERMAN(海尔曼太通)
    HELLERMANN TYTON  HIS-3-3/1-PEX-BU  HEAT SHRINK, BLUE, 3MM, 10M
308-30306 数据手册
Insulation Heat Shrinkable Tubing 2.1 Heat Shrinkable Tubing 3:1 on a Reel HIS-3 HIS-3 is used in general purpose of electrical insulation with a high level of protection against corrosion and mechanical abrasion. Features and Benefits • Unlined tubing in handly dispenser packs • High shrink ratio (3:1) tubing • Fits highly variable substrate dimensions • Only 6 sizes for application diameter range of 1 mm up to 20 mm, reduce inventory by half HIS-3 can fit highly variable substrate dimensions. Detailed Information about Heatguns please refer to page 529. One Step to the Web! MATERIAL Polyolefin, cross-linked (PO-X) Shrink Ratio 3:1 Operating Temperature -55 °C to +135 °C Minimum Shrink Temperature +100 °C Longitudinal change after shrinkage -5 % max. Dielectric Strength 20 kV/mm according to ASTM D 150 Flammability UL224 VW-1 (except clear) Insulation Class B (VDE 0530) Specifications CSA, SAE - AMS - DTL-23053/5 Class 1 and 3, SAE - AMS - DTL-23053/5 Class 2 (clear), UL224 125 °C 600V VW-1 Heat Shrinkable Tubing 3:1 TYPE HIS-3-1.5/0.5 Date of issue: October 2015 HIS-3-3/1 HIS-3-6/2 Supplied Ø D min. Recov. Ø d max. Wall (WT) Reel Length Colour Article-No. 1.5 0.5 0.45 10 m Black (BK) 308-30150 1.5 0.5 0.45 10 m Blue (BU) 308-30156 1.5 0.5 0.45 10 m Red (RD) 308-30152 1.5 0.5 0.45 10 m Transparent (CL) 308-30153 3.0 1.0 0.55 10 m Black (BK) 308-30300 3.0 1.0 0.55 10 m Blue (BU) 308-30306 3.0 1.0 0.55 10 m Green-Yellow (GNYE) 308-30307 3.0 1.0 0.55 10 m Red (RD) 308-30302 3.0 1.0 0.55 10 m Transparent (CL) 308-30303 6.0 2.0 0.65 5m Black (BK) 308-30600 6.0 2.0 0.65 5m Blue (BU) 308-30606 6.0 2.0 0.65 5m Green-Yellow (GNYE) 308-30607 6.0 2.0 0.65 5m Red (RD) 308-30602 6.0 2.0 0.65 5m Transparent (CL) 308-30603 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/insulation 203 Insulation 2.1 Heat Shrinkable Tubing Heat Shrinkable Tubing 3:1 on a Reel HIS-3 Heat Shrinkable Tubing 3:1 TYPE HIS-3-9/3 HIS-3-12/4 HIS-3-18/6 HIS-3-24/8 Supplied Ø D min. Recov. Ø d max. Wall (WT) Reel Length Colour Article-No. 9.0 3.0 0.75 5m Black (BK) 308-30900 9.0 3.0 0.75 5m Blue (BU) 308-30906 9.0 3.0 0.75 5m Green-Yellow (GNYE) 308-30907 9.0 3.0 0.75 5m Red (RD) 308-30902 9.0 3.0 0.75 5m Transparent (CL) 308-30903 12.0 4.0 0.80 5m Black (BK) 308-31200 12.0 4.0 0.80 5m Blue (BU) 308-31206 12.0 4.0 0.80 5m Green-Yellow (GNYE) 308-31207 12.0 4.0 0.80 5m Red (RD) 308-31202 12.0 4.0 0.80 5m Transparent (CL) 308-31203 18.0 6.0 0.90 4m Black (BK) 308-31800 18.0 6.0 0.90 4m Blue (BU) 308-31806 18.0 6.0 0.90 4m Green-Yellow (GNYE) 308-31807 18.0 6.0 0.90 4m Red (RD) 308-31802 18.0 6.0 0.90 4m Transparent (CL) 308-31803 24.0 8.0 1.20 3m Black (BK) 308-32400 24.0 8.0 1.20 3m Blue (BU) 308-32406 24.0 8.0 1.20 3m Green-Yellow (GNYE) 308-32407 24.0 8.0 1.20 3m Red (RD) 308-32402 24.0 8.0 1.20 3m Transparent (CL) 308-32403 For product specific approvals and specifications please refer to the Appendix. 204 Further information at www.HellermannTyton.com/insulation Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content.
308-30306 价格&库存
很抱歉,暂时无法提供与“308-30306”相匹配的价格&库存,您可以联系我们找货
  • 1+431.583821+56.10450
  • 3+388.468903+50.49970
  • 5+323.709605+42.08120
