333-41511
333-41511
    HELLERMAN(海尔曼太通)
    HEATSHRINK3:19.5MMX4'
333-41511 数据手册
333-41511 Article Number: 333-41511 Heat Shrink Tubing, 4FT-Stick, 3:1, 3/8", 9.5/3.0 dia., Polyolefin, Black, 15/pkg Download spec sheet Base Data Local Order Number 333-41511 Type TFN31-ST-9/3 BK Color Black (BK) Features and Benefits • Thin wall, flexible 3 to 1 shrink ratio material accommodates a wide range of component shapes and diameters. • Meets UL224 VW-1 specifications, making it ideal for high heat applications (excludes clear tubing). • Polyolefin material provides excellent insulation and mechanical strength with good resistance to solvents, oils and fuels. • Available in bulk reels, sticks and convenience bags (HIS-3 bags), for small to large volume applications. Product Description TFN31 series heat shrink tubing features a flexible, thin wall and highly flame retardant polyolefin material with a higher operating temperature range than general-use heat shrink tubing. and offers good resistance to solvents, oils and fuels. The 3 to 1 shrink ratio accommodates a variety of component shapes and sizes. TFN31 tubing is available in bulk reels, sticks and convenience bags (HIS-3 bags), for projects of all sizes. Short Description Heat Shrink Tubing, 4FT-Stick, 3:1, 3/8", 9.5/3.0 dia., Polyolefin, Black, 15/pkg Product Dimensions Length L (Metric) 1.22 m Shrink Ratio 3:1 Tensile Strength (MPa) 14 MPa Trade Size 3/8 " Variant Thin-Wall Volume Resistance (Ohm cm) 10¹ Ω cm Nominal Diameter (Imperial) 3/8 " Nominal Diameter (Metric) 9 mm Wall Thickness WT (Imperial) 0.029 " Wall Thickness WT (Metric) .75 mm Recovered Diameter d (metric) 3.0 mm Recovered Diameter d (imperial) 0.188 " Supplied Diameter D (metric) 9.5 mm Supplied Diameter D (imperial) 0.375 " Logistics and Packaging Quantity Per lengths Package Quantity 15 Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Dielectric Strength (Metric) 20 kV/mm Elongation at break 600% Flammability UL224 VW-1 Halogenfree No Shrink Temperature +212 °F (+100 °C) Operating Temperature -67°F to +275°F (-55°C to +135°C) ROHS Compliant Yes Certification/Specification CSA UL224 125 °C 600V VW-1 UL Recognized (US) Yes © HellermannTyton 2015
333-41511 价格&库存
很抱歉,暂时无法提供与“333-41511”相匹配的价格&库存,您可以联系我们找货
