416-00003
416-00003
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 416-00003 - Heat Shrink Boot, PEC Series Pinched Adhesive Lined, End Cap, 0.188 ",...
416-00003 数据手册
Insulation Products Heat Shrinkable Moulded Shapes 2.2 Pinched End Caps 3:1 with inner adhesive • PEC Features and Benefits The PEC-Series can be applied fast and easy like a standard heat shrink tube. The inner adhesive layer and the adhesive plug provide a good and secure water protection. The optimal shrink ratio of 3:1 and different diameters allow a wide range of application. Other diameters and lenghts are available on request. Application Pinched End Caps can be used for mechanical and environmental protection of stub splices in electrical harnesses. Due to the fast and easy installation, these caps can be used for non-electrical applications as well. The appropriate end cap for every cable diameter, and cable types. Material Data Material Colour Shrink Ratio Minimum Shrink Temperature Operating Temperature Dielectric Strength Flammability Polyolefin, cross-linked (POX) Black (BK) 3:1 +120 °C -45 °C to +125 °C 15 kV/mm according to IEC 60684 P2 self extinguishing in 30 seconds according to SAE-AMS-DTL-23053/4  Inner Wall Adhesive PEC-Series recovered PEC-Series expanded Technical Table Article-No. Type Supplied ØD Recov. Ød Wall (WT) Length (L) Length (L2) 416-00000 PEC-3/1 3.0 1.0 1.0 25.0 20.0 416-00003 PEC-4.8/1.5 4.8 1.5 1.0 30.0 25.0 416-00001 PEC-6/2 6.0 2.0 1.0 30.0 25.0 416-00002 PEC-9/3 9.0 3.0 1.4 35.0 27.0 All dimensions in mm. Subject to technical changes. Date of issue: April 2011 299
416-00003 价格&库存
很抱歉,暂时无法提供与“416-00003”相匹配的价格&库存,您可以联系我们找货
