150-76099
150-76099
    HELLERMAN(海尔曼太通)
150-76099 数据手册
Cable Ties and Fixings 1.6 Cable Ties With Fixing Elements 2-Piece Fixing Ties for Edges, 1.0 - 3.0 mm, Top Fixing EdgeClip-Family These cable ties and EdgeClip assemblies are ideal for use where holes are not acceptable or where due to temperature problems adhesives will fail. These assemblies are widely used for fixing and bundling cables, pipes and hoses within the automotive industry, harness making, panel buidling and electrical industry. Features and Benefits • Pre-assembled 2-piece fixing tie with EdgeClip • Cable tie head can be moved after bundling • EC9, EC10, EC21 and EC22 are for minimum bundle diameters of 1 mm • For edges of 1 – 3 mm T50ROSEC10 fitted onto a plastic panel to hold a Ø 6 mm harness. L Material specification please see page 24. Width (W) Length (L) Bundle Ø max. T30REC4A 3.6 148.0 33.0 T50SOSEC4A 4.6 150.0 T50ROSEC4A 4.6 200.0 T50ROSEC4A-W 4.6 T50REC4A 4.6 TYPE Drawing Material Cable Tie Material Foot Part Colour Tools Article-No. 135 PA66HS PA66HIRHS Black (BK) 2;4-6 150-76090 35.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-76093 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-76099 200.0 45.0 225 PA66W PA66W Black (BK) 2-10 156-00570 202.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-76091 T30REC4B 3.6 148.0 35.0 135 PA66HS PA66HIRHS Black (BK) 2;4-6 150-76080 T50SOSEC4B 4.6 150.0 35.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00109 T50ROSEC4B 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 150-76079 T18REC10SD 2.5 100.0 22.0 80 PA66HS PA66HIRHS Black (BK) 2;4-6 155-38304 T50SOSEC10 4.6 150.0 31.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00015 T50ROSEC10 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-05904 T18REC9SD 2.5 100.0 22.0 80 PA66HS PA66HIRHS Black (BK) 2;4-6 155-37104 T50SOSEC9SD 4.6 150.0 31.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-00019 T50ROSEC9 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-05903 T50REC9SD 4.6 200.0 45.0 225 PA66HS PA66HIRHS Black (BK) 2-10 156-01280 Q50REC4A 4.7 210.0 45.0 220 PA66W PA66W Black (BK) 2-10 156-01085 Q50REC4B 4.7 210.0 45.0 220 PA66W PA66W Black (BK) 2-10 156-01086 All dimensions in mm. Subject to technical changes. 120 Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 Fixing Tie with EC4 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylene Tetrafluoroethylene E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV-resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6, high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6, high impact modified glass-fibre reinforced Polyamide 6.6, heat and UV stabilised Polyamide 6.6, UV-resistant Colour** Material Properties* Flammability Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • Resistance to radioactivity • UV-resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances 24 Material Specifications Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6 V0 MATERIAL Material Properties* Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions SP -50 °C to +150 °C Black (BK) Halogen free • UV-resistant • Good chemical resistance to: most acids, alkalis and oils PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyamide 6.6 V0, High Oxygen Index Polyester Polyetheretherketone Polypropylene, EthylenePropylene-DienTerpolymere-rubber free of Nitrosamine Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL94 HB • Floats in certain liquids • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Non burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL94 HB • High elasticity • Good chemical resistance to: acids, bases and oxidizing agents Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. 1.0 Material Specifications **More colours on request. Date of issue: October 2015 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 25
150-76099 价格&库存
很抱歉,暂时无法提供与“150-76099”相匹配的价格&库存,您可以联系我们找货
