151-28705
151-28705
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 151-28705 - Cable Tie Mount, 4 Way Entry, Adhesive, Screw, 3.1 mm, Natural, Nylon ...
151-28705 数据手册
Cable Ties and Fixings 1.7 Cable Tie Mounts Self Adhesive, Screw Fixing Cable Tie Mounts Where speed, simplicity and a firm fixing base are required these self adhesive clips are ideal. Particularly suitable for use in control cabinets, telecoms equipment or domestic appliances where the use of holes, screws or nuts and bolts are impractical or undesirable. Features and Benefits • Screw or self-adhesive versions • Simple to install with a screw or bolt • Excellent security, particularly in areas of high vibration • Maximum adhesive surface area to achieve high pull-off force • 4-way entry for cable tie for quicker and more flexible installation Cable Tie Mounts MB and TY. For more information on the types of adhesive please see page 73. Cable Tie Mounts MB2A Cable Tie Mounts MB3-5(A) Cable Tie Mounts MB4CA Cable Tie Mounts MB3A • MB-Series Square-Cut, self adhesive, screwable TYPE Width (W) Length (L) Height (H) Hole Ø (FH) Strap Width max. (G) Material Colour Adhesive Pack Cont. Article-No. MB2A 13.0 13.0 4.1 - 2.7 PA66 Natural (NA) Synthetic rubber 100 151-01802 MB3A MB4A3 MB4A 19.0 19.0 3.8 3.1 4.1 PA66 Black (BK) Synthetic rubber 100 151-28320 19.0 19.0 3.8 3.1 4.1 PA66 Natural (NA) Synthetic rubber 100 151-28349 28.0 28.0 4.7 4.0 5.4 PA66 Black (BK) Acrylate 100 151-28430 28.0 28.0 4.7 4.0 5.4 PA66 Black (BK) Synthetic rubber 100 151-28412 28.0 28.0 4.7 4.0 5.4 PA66 Natural (NA) Synthetic rubber 100 151-28469 MB4CAS 29.0 29.0 5.7 4.2 5.4 PA66 Natural (NA) Synthetic rubber 100 151-28449 MB4CA 29.0 29.0 5.7 4.2 5.4 PA66 Natural (NA) Synthetic rubber 100 151-28459 MB5A 37.7 37.7 7.1 4.8 8.9 PA66 White (WH) Synthetic rubber 100 151-28529 MB5A3 38.0 38.0 6.4 4.7 10.0 PA66 Black (BK) Acrylate 100 151-28530 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. • MB-Series Square-Cut, screwable Date of issue: January 2014 TYPE Width (W) Length (L) Height (H) Hole Ø (FH) Strap Width max. (G) Material Colour Pack Cont. Article-No. MB3 19.0 19.0 3.8 3.1 4.1 PA66 Natural (NA) 100 151-28359 MB4 28.0 28.0 4.7 4.0 5.4 PA66 Natural (NA) 100 151-28479 MB5 37.7 37.7 6.2 4.8 8.9 PA66 White (WH) 100 151-00324 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Please note! Not all products listed on this page may have this approval. For product specific approvals please refer to the Appendix. Further information and products at www.HellermannTyton.co.uk/a75 75 Cable Ties and Fixings 1.1 Material Information Materi a Propert l ies* ability Flamm Colour* * Opera tin Tempe g rature ut Shortc Materi al Material Specification Overview Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylenterafluorineethylen E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 • Resistance to radioactivity • UV- resistant, not moisture sentitive • Good chemical resistance to: • acids, bases, oxidizing agents Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: • acids, bases, oxidizing agents • UV- resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, Glassfibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents Polyamide 6.6 heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6 Heat Stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6 High Imp. Mod., Heat Stab. PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6 High Imp. Mod. scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 High Impact Modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®-Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. 22 Further information and products at www.HellermannTyton.co.uk/a22 Date of issue: January 2014 = Minimum Tensile Strength Cable Ties and Fixings 1.1 Material Information Materi a Propert l ies* ability Flamm Colour* * Opera tin Tempe g rature ut Shortc Materi al Material Specification Overview Polyamide 6.6 high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant Polyamide 6.6 UV Resistant PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6.6 V0 PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission Polyamide 6.6 V0 High Oxygen Index PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions Polyamide 6.6 with metal particles PA66MP -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength Polyamide 6 high impact modified PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature SP -50 °C to +150 °C Black (BK) PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids Polypropylene, Ethylene-Propylene-Dien-Terpolymere-rubber free of Nitrosamine PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol, oil Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) Polyester Polyetheretherketone • UV-resistant • Good chemical resistance to: most acids, alkalis and oils • Corrosion resistant • Antimagnetic UL94 HB Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®-Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • High elastic • Good chemical resistance to: • acids, bases, oxidizing agents **More colours on request. Date of issue: January 2014 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. Further information and products at www.HellermannTyton.co.uk/a23 = Minimum Tensile Strength 23
151-28705 价格&库存
很抱歉,暂时无法提供与“151-28705”相匹配的价格&库存,您可以联系我们找货
