Cable Protection Systems
3.5
Protective Tubing and Spiral Binding
Flexible Cable Support
Heladuct Flex
Heladuct flexible cable supports are commonly used in switching
cabinets. They are also used in the furniture industry, where cables need
to be routed rapidly and attractively.
Features and Benefits
• Space-saving wiring system
• Highly flexible, can be installed at angles of 90° and higher
• Cable clearly open to view
• Rapid mounting with screws or adhesive strip with high-quality foam
bonding layer
Heladuct Flex- clearly and space-saving arrangement of wiring, even at angles
above 90°.
TYPE
Nominal
Ø
MATERIAL
Polypropylene (PP)
Operating Temperature
-20 °C to +70 °C
Adhesive
Synthetic rubber with base of
polyethylene foam
Flammability
UL94 V0 (excluding adhesive)
Max. load on
a length of
500 mm at
70 °C (g)
No. of Wires
Colour
Length
(L)
Article-No.
Heladuct Flex10
10
9 x 0.75 mm²
6 x 1.50 mm²
4 x 2.50 mm²
100
White (WH)
500.0
164-11008
Heladuct Flex20
32 x 0.75 mm²
22 x 1.50 mm²
14 x 2.50 mm²
300
White (WH)
500.0
164-21008
Heladuct Flex30
30
67 x 0.75 mm²
50 x 1.50 mm²
34 x 2.50 mm²
650
White (WH)
500.0
164-31008
Heladuct Flex40
40
81 x 1.50 mm²
60 x 2.50 mm²
1,100
White (WH)
500.0
164-41008
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
TYPE
Nominal
Ø
No. of Wires
Max. load on
a length of
500 mm at
70 °C (g)
Colour
Length
(L)
Article-No.
Heladuct Flex10SK
10
9 x 0.75 mm²
6 x 1.50 mm²
4 x 2.50 mm²
100
White (WH)
500.0
164-11108
Heladuct Flex20SK
32 x 0.75 mm²
22 x 1.50 mm²
14 x 2.50 mm²
300
White (WH)
500.0
164-21108
Heladuct Flex30SK
30
67 x 0.75 mm²
50 x 1.50 mm²
34 x 2.50 mm²
500
White (WH)
500.0
164-31108
Heladuct Flex40SK
40
81 x 1.50 mm²
60 x 2.50 mm²
400
White (WH)
500.0
164-41108
320
Further information at www.HellermannTyton.com/protection
Date of issue: October 2015
Heladuct Flex with Adhesive
很抱歉,暂时无法提供与“164-21008”相匹配的价格&库存,您可以联系我们找货
