450-20012
450-20012
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 450-20012 - Adhesive Lined Heat Shrink Tubing, Cable Repair Sleeve, 4.5:1, 2.05 ",...
450-20012 数据手册
Insulation Heat Shrinkable Tubing 2.1 Heat Shrinkable Cable Repair Sleeves RMS RMS wrap-around sleeves are easy to install. Features and Benefits • Fast, moisture proof and permanent repair of cable jackets • Only 6 sizes for a wide range of cable diameters: from 10 mm up to 160 mm • Available in 4 standard lengths, custom lengths available on request • Each RMS kit is ready for use and comes with instruction sheet, abrasive strip and cleaning sachet • Weather resistant and halogen free • TCP (thermo-chromatic paint) spots indicate the sleeve has been sufficiently heated RMS wrap-around sleeves for rapid and secure cable repair on site. Application video: RMS MATERIAL Polyolefin, Chemically cross-linked (PO-X) Shrink Ratio up to 4.5:1 Operating Temperature -40 °C to +120 °C Minimum Shrink Temperature +110 °C Softening Point Adhesive +105 °C Longitudinal change after shrinkage -10 % max. Dielectric Strength 30 kV/mm Flammability not flame retarded RMS: Repair sleeve, steel closure, abrasive strip, cleaning sachet, instruction sheet. INFO Cable Repair Sleeve RMS with adhesive TYPE RMS 43-10 Date of issue: October 2015 RMS 52-15 RMS 76-22 RMS 100-30 Supplied Ø D min. Recov. Ø d max. Wall (WT) Suitable for Cable Ø from/to Length (L) Colour Article-No. 43 10.0 2.30 15 - 35 250.0 Black (BK) 450-20000 43 10.0 2.30 15 - 35 500.0 Black (BK) 450-20001 43 10.0 2.30 15 - 35 750.0 Black (BK) 450-20004 43 10.0 2.30 15 - 35 1,000.0 Black (BK) 450-20002 52 15.0 2.30 20 - 45 250.0 Black (BK) 450-20010 52 15.0 2.30 20 - 45 500.0 Black (BK) 450-20011 52 15.0 2.30 20 - 45 750.0 Black (BK) 450-20014 52 15.0 2.30 20 - 45 1,000.0 Black (BK) 450-20012 76 22.0 2.50 28 - 65 500.0 Black (BK) 450-20021 76 22.0 2.50 28 - 65 750.0 Black (BK) 450-20024 76 22.0 2.50 28 - 65 1,000.0 Black (BK) 450-20022 100 30.0 2.54 35 - 85 500.0 Black (BK) 450-20030 100 30.0 2.54 35 - 85 1,000.0 Black (BK) 450-20031 RMS 139-38 139 38.0 2.77 45 - 120 1,000.0 Black (BK) 450-20041 RMS 185-55 185 55.0 2.74 65 - 160 1,000.0 Black (BK) 450-20050 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Further information at www.HellermannTyton.com/insulation 229
450-20012 价格&库存
很抱歉,暂时无法提供与“450-20012”相匹配的价格&库存,您可以联系我们找货
