531-07731
    HELLERMAN(海尔曼太通)
531-07731 数据手册
Identification Systems Wire and Cable Markers 5.1 Pre-printed Cable Markers Ovalgrip, slide on, straight cut Ideally suited to panel building, mass transit, utilities, telecommunications and electrical contracting. These markers are supplied continuous on a reel (HODS). Markers are available as standard in yellow material marked in black and international resistor colour code. Characters are 0-9, A-Z and standard electrical symbols. White material marked in black available on special request. AT1 Arrowtags will fit 7 size 50 markers. AT2 Arrowtags will fit 8 size 85 markers. AT3 Arrowtags will fit 14 size 85 markers. A simple idea for complex marking needs. Features and Benefits • Oval shaped markers designed to fit AT1, AT2 or AT3 (depends on Ovalgrip size) • Ideal for use in maintenance and repair and fixed with cable ties • Direct application to wire and cable before termination is also recommended • Traditional wire marking available in yellow, white and colour code MATERIAL Flexible Polyvinyl Chloride, cadmium free (PVC) Operating Temperature -65 °C to +105 °C, intermittent +135 °C Flammability UL94 V0 (3mm) Specifications BS-2782-540B, BS-6746C, IEC 304, IEC 757, UL224 For details on Arrowtags please see page 458. L Ovalgrip straight cut. Bundle Ø min. Bundle Ø max. Length (L) Pack Cont. For Size HODS50 1.7 3.6 4.0 1,000 pcs. AT1 HODS85 1.8 6.3 4.5 1,000 pcs. AT2/AT3 TYPE Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/identification 447 5.1 Identification Systems Wire and Cable Markers Pre-printed Cable Markers Ovalgrip, slide on, straight cut HODS50 Article-No. HODS50 Article-No. HODS85 Article-No. HODS85 Article-No. 531-15014 531-15274 531-07935 531-07925 531-15024 531-15284 531-07936 531-07926 531-15034 531-15294 531-07937 531-07927 531-15044 531-15304 531-07938 531-07928 531-15054 531-15314 531-07939 531-07732 531-15064 531-15324 531-07940 531-07930 531-15074 531-15334 531-07941 531-07931 531-15084 531-15344 531-07942 531-07932 531-15094 531-15354 531-07943 531-07933 531-15104 531-15364 531-07944 531-07934 531-15114 531-00174 531-07945 531-00384 531-15124 531-00175 531-07946 531-07961 531-15134 531-00176 531-07947 531-00386 531-15144 531-00451 531-07948 531-07924 531-15154 531-00452 531-07949 531-07923 531-15164 531-15365 531-07950 531-07728 531-15174 531-15366 531-07951 531-07729 531-15184 531-15367 531-07952 531-07730 531-15194 531-15368 531-07953 531-07731 531-15204 531-15314 531-07954 531-07732 531-15214 531-15370 531-07955 531-07733 531-15224 531-15371 531-07956 531-07734 531-15234 531-15372 531-07957 531-07735 531-15244 531-15373 531-07958 531-07736 531-15254 531-15374 531-07959 531-07737 531-07960 For product specific approvals and specifications please refer to the Appendix. 448 Further information at www.HellermannTyton.com/identification Date of issue: October 2015 531-15264
531-07731 价格&库存
很抱歉,暂时无法提供与“531-07731”相匹配的价格&库存,您可以联系我们找货
