ALU10C-ALUCR-NABK-C1 数据手册
Cable Ties and Fixings
1.9
Clips, Clamps and Plugs
Aluminium P-Clips
Alu-P-Clip with / without chloroprene Insert
Manufactured from a high quality aluminium, these P-Clips provide
flexibility whilst providing a permanent fixing in the most arduous of
environments. The addition of a Chloroprene insert provides the cable or
pipe bundle with a high degree of protection against vibration, reducing
noise and also providing electrical isolation.
Features and Benefits
• Simple, secure pipe or cable fixing (e. g. caravan construction)
• Combine with chloprene insert for vibration resistance
(e. g. retain capacitors on PCB)
• Ideal for use in high temperatures
• Suitable for applications needing strength of metal components
P-Clips manufactured in polyamide, aluminium or aluminium with a chloroprene
insert.
Material specification
please see page 24.
F3
WT
F3
F2
TYPE
F2
Alu P-Clip (plan view)
Alu P-Clip (side view)
Width Width Wall
(W)
(W2) (WT)
Wall Hole Ø
(WT2)
(FH)
Alu P-Clip with
chloroprene insert (side view)
Fixing
Hole
Centres
(F2)
Fixing Hole
Centres
Bundle
(F3)
Ø max.
Radius
(R)
Material
Colour
ALU4
12.7
0.80
5.2
11.6
5.5
6.4
1.6
AL
Natural (NA)
211-10040
ALU5
12.7
0.80
5.2
12.6
5.5
8.0
1.6
AL
Natural (NA)
211-10050
Article-No.
ALU6
12.7
0.80
5.2
13.4
5.5
9.5
1.6
AL
Natural (NA)
211-10060
ALU7
12.7
0.80
5.2
14.2
5.5
11.1
1.6
AL
Natural (NA)
211-10070
ALU8
12.7
0.80
5.2
15.0
5.5
12.7
1.6
AL
Natural (NA)
211-10080
ALU10
12.7
0.80
5.2
16.6
5.5
15.9
1.6
AL
Natural (NA)
211-10100
ALU11
12.7
1.30
5.2
19.1
5.5
17.5
2.8
AL
Natural (NA)
211-10110
ALU12
12.7
1.30
5.2
19.9
5.5
19.1
2.8
AL
Natural (NA)
211-10120
ALU13
12.7
1.30
5.2
20.7
5.5
20.6
2.8
AL
Natural (NA)
211-10130
ALU4C
16.3
12.7
3.70
0.8
5.2
11.6
5.5
3.2
1.6
AL, CR
Black (BK)
211-15040
ALU5C
16.3
12.7
3.70
0.8
5.2
12.6
5.5
4.8
1.6
AL, CR
Black (BK)
211-15050
ALU6C
16.3
12.7
3.70
0.8
5.2
13.4
5.5
6.4
1.6
AL, CR
Black (BK)
211-15060
ALU7C
16.3
12.7
3.70
0.8
5.2
14.2
5.5
8.0
1.6
AL, CR
Black (BK)
211-15070
ALU8C
16.3
12.7
3.70
0.8
5.2
15.0
5.5
9.5
1.6
AL, CR
Black (BK)
211-15080
ALU9C
16.3
12.7
3.70
0.8
5.2
15.8
5.5
11.1
1.6
AL, CR
Black (BK)
211-15090
ALU10C
16.3
12.7
3.70
0.8
5.2
16.6
5.5
12.7
1.6
AL, CR
Black (BK)
211-15100
All dimensions in mm. Subject to technical changes.
176
Alu P-Clip with
chloroprene insert (plan view)
Further information at www.HellermannTyton.com/fixings
Date of issue: October 2015
R
1.9
Aluminium P-Clips
R
F3
WT
F3
F2
TYPE
ALU11C
Width Width Wall
(W)
(W2) (WT)
16.3
F2
12.7
Wall Hole Ø
(WT2)
(FH)
4.50
1.3
5.2
Alu P-Clip with
Fixing
Hole
Centres
(F2)
19.1
Fixing Hole
Centres
Bundle
(F3)
Ø max.
5.5
14.3
Alu P-Clip with
Radius
(R)
Material
Colour
Article-No.
2.8
AL, CR
Black (BK)
211-15110
ALU12C
16.3
12.7
4.50
1.3
5.2
19.9
5.5
15.9
2.8
AL, CR
Black (BK)
211-15120
ALU13C
16.3
12.7
4.50
1.3
5.2
20.7
5.5
17.5
2.8
AL, CR
Black (BK)
211-15130
ALU14C
16.3
12.7
4.50
1.3
5.2
21.5
5.5
19.1
2.8
AL, CR
Black (BK)
211-15140
ALU15C
16.3
12.7
4.50
1.3
5.2
22.3
5.5
20.6
2.8
AL, CR
Black (BK)
211-15150
ALU16C
16.3
12.7
4.50
1.3
5.2
23.1
5.5
22.2
2.8
AL, CR
Black (BK)
211-15160
ALU17C
16.3
12.7
4.50
1.3
5.2
23.9
5.5
23.8
2.8
AL, CR
Black (BK)
211-15170
ALU18C
16.3
12.7
4.50
1.3
5.2
24.6
5.5
25.4
2.8
AL, CR
Black (BK)
211-15180
ALU19C
16.3
12.7
4.50
1.3
5.2
25.5
5.5
27.0
2.8
AL, CR
Black (BK)
211-15190
ALU20C
16.3
12.7
4.50
1.6
5.2
27.0
5.5
28.6
3.2
AL, CR
Black (BK)
211-15200
ALU22C
16.3
12.7
4.50
1.6
5.2
28.6
5.5
31.8
3.2
AL, CR
Black (BK)
211-15220
ALU23C
16.3
12.7
4.50
1.6
5.2
29.4
5.5
33.3
3.2
AL, CR
Black (BK)
211-15230
ALU24C
16.3
12.7
4.50
1.6
5.2
30.2
5.5
34.9
3.2
AL, CR
Black (BK)
211-15240
ALU25C
16.3
12.7
4.50
1.6
5.2
30.8
5.5
36.5
3.2
AL, CR
Black (BK)
211-15250
ALU26C
16.3
12.7
4.50
1.6
5.2
31.7
5.5
38.1
3.2
AL, CR
Black (BK)
211-15260
ALU28C
16.3
12.7
4.50
1.6
5.2
33.3
5.5
41.3
3.2
AL, CR
Black (BK)
211-15280
ALU29C
16.3
12.7
4.50
1.6
5.2
34.1
5.5
42.9
3.2
AL, CR
Black (BK)
211-15290
ALU30C
16.3
12.7
4.50
1.6
5.2
34.9
5.5
44.5
3.2
AL, CR
Black (BK)
211-15300
ALU34C
16.3
12.7
4.50
1.6
5.2
38.1
5.5
50.8
3.2
AL, CR
Black (BK)
211-15340
177
1.0
Material Information
Material Specification Overview
Material
Shortcut
Operating
Temperature
Aluminium-alloy
AL
-40 °C to +180 °C
Natural
(NA)
• Corrosion resistant
• Antimagnetic
Chloroprene
CR
-20 °C to +80 °C
Black (BK)
• Weather-resistant
• High yield strength
Ethylene
Tetrafluoroethylene
E/TFE
-80 °C to +170 °C
Blue (BU)
UL94 V0
Polyacetal
POM
-40 °C to +90 °C,
(+110 °C, 500 h)
Natural
(NA)
UL94 HB
Polyamide 11
PA11
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
Polyamide 12
PA12
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
• Good chemical resistance to:
acids, bases, oxidizing agents
• UV-resistant
Polyamide 4.6
PA46
-40 °C to +150 °C
(5000 h), +195 °C
(500 h)
Natural
(NA),
Grey (GY)
UL94 V2
• Resistance to high temperatures
• Very moisture sensitive
• Low smoke sensitive
Polyamide 6
PA6
-40 °C to +80 °C
Black (BK)
UL94 V2
PA6HIR
-40 °C to +80 °C
Black (BK)
UL94 HB
• Limited brittleness sensitivity
• Higher flexibility at low temperature
Polyamide 6.6
PA66
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK),
Natural
(NA)
UL94 V2
Polyamide 6.6,
PA66GF13,
PA66GF15
-40 °C to +105 °C
Black (BK)
UL94 HB
• Good resistance to: lubricants, vehicle
fuel, salt water and many solvents
PA66HSW
-40 °C to +105 °C
Black (BK)
UL94 V2
• Modified elevated max. temperature
• UV-resistant
Polyamide 6.6,
heat stabilised
PA66HS
-40 °C to +105 °C
Black (BK),
Natural
(NA)
UL94 V2
• Modified elevated
max. temperature
Polyamide 6.6,
high impact modified
PA66HIR
-40 °C to +80 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
Polyamide 6.6,
high impact modified, heat
and UV stabilised
PA66HIRHSW
-40 °C to +110 °C
Black (BK)
UL94 HB
Polyamide 6.6,
stabilised
PA66HIRHS
-40 °C to +105 °C
Black (BK)
UL94 HB
Polyamide 6.6,
high impact modified, scan
black
PA66HIR(S)
-40 °C to +80 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
PA66W
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 V2
• UV-resistant
Polyamide 6,
glass-fibre reinforced
Polyamide 6.6,
heat and UV stabilised
Polyamide 6.6,
UV-resistant
Colour**
Material
Properties*
Flammability
Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers.
• Resistance to radioactivity
• UV-resistant, not moisture sensitive
• Flexible at low temperature
• Not moisture sensitive
• Robust on impacts
• Bio-plastic, derived from vegetable oil
• Strong impact resistance at low
temperature
• Very low moisture absorption
• Weather-resistant
temperature
• High yield strength, UV-resistant
**More colours on request.
*These details are only rough guide values. They should be regarded as a material specification and are no substitute for a
suitability test. Please see our datasheets for further details.
HF = Halogenfree
LFH = Limited Fire Hazard
RoHS = Restriction of Hazardous Substances
24
Material
Specifications
MATERIAL
Material
Shortcut
Operating
Temperature
Polyamide 6.6,
with metal particles
PA66MP
Polyamide 6.6 V0
MATERIAL
Material
Properties*
Colour**
Flammability
-40 °C to +85 °C,
(+105 °C, 500 h)
Blue (BU)
UL94 HB
• Metal and X-Ray detectable
PA66V0
-40 °C to +85 °C
White (WH)
UL94 V0
• Low smoke emission
PA66V0-HOI
-40 °C to +85 °C,
(+105 °C, 500 h)
White (WH)
UL94 V0
• Low smoke emissions
SP
-50 °C to +150 °C
Black (BK)
Halogen free
• UV-resistant
most acids, alkalis and oils
PEEK
-55 °C to +240 °C
Beige (BGE)
UL94 V0
Polyethylene
PE
-40 °C to +50 °C
Black (BK),
Grey (GY)
UL94 HB
• Low moisture absorption
• Good chemical resistance to: most
acids, alcohol and oils
Polyolefin
PO
-40 °C to +90 °C
Black (BK)
UL94 V0
Polypropylene
PP
-40 °C to +115 °C
Black (BK),
Natural
(NA)
UL94 HB
• Floats in water
• Moderate yield strength
organic acids
PP, EPDM
-20 °C to +95 °C
Black (BK)
UL94 HB
• Good resistance to high temperatures
• Good chemical and abrasion
resistance
Polyamide 6.6 V0,
High Oxygen Index
Polyester
Polyetheretherketone
Polypropylene, EthylenePropylene-DienTerpolymere-rubber
free of Nitrosamine
Polypropylene
PPMP
-40 °C to +115 °C
Blue (BU)
UL94 HB
• Floats in certain liquids
• Heat resistant
Polyvinylchloride
PVC
-10 °C to +70 °C
Black (BK),
Natural
(NA)
UL94 V0
acids, ethanol and oil
Stainless Steel,
Stainless Steel
SS304,
SS316
-80 °C to +538 °C
Natural
(NA)
Non burning
• Antimagnetic
• Weather resistant
• Outstanding chemical resistance
Thermoplastic
Polyurethane
TPU
-40 °C to +85 °C
Black (BK)
UL94 HB
• High elasticity
acids, bases and oxidizing agents
1.0
Material
Specifications
HF = Halogenfree
25
