110-03500
    HELLERMAN(海尔曼太通)
110-03500 数据手册
Application Tooling 6.2 Application Tooling for Cable Ties Manual Tensioning Tool with Metal Housing MK3SP up to 4.8 mm strap width This tough metal tool MK3SP is used by harness makers for the automotive and white goods industries, as well as in aerospace, railway and medical. Features and Benefits • Tough metal tool for HellermannTyton plastic cable ties up to 4.8 mm width • For consistent tensioning and automatically flush cutting • Infinitely adjustable tensioning force • Reliable and low maintenance MK3SP. TYPE Strap Width max. (G) Strap Thickness max. MK3SP 4.8 1.5 0.33 kg 110-03500 - - 0.01 kg 110-03524 SP MK3SP replacement blade Weight Article-No. All dimensions in mm. Subject to technical changes. Pneumatic Tensioning Tool with Metal Housing MK3PNSP2 up to 4.8 mm strap width Features and Benefits • Pneumatic tensioning tool • Tough metal housing • For cable ties up to 4.8 mm width • For consistent tensioning and automatically flush cutting • Infinitely adjustable tension force • High application speed • Reliable and low maintenance MK3PNSP2. MK3PNSP2 Non oiled / oiled Air Pressure (min.) 3 Bar Air Pressure (max.) 6 Bar Hose Internal Diameter 4.0 mm LxHxW approx. 225 x 140 x 40 mm Specifications CE, GS Strap Width max. (G) Strap Thickness max. Article-No. 4.8 1.5 0.56 kg 110-03400 SP compressed air hose - - 0.35 kg 110-30002 SP MK3PNSP2 cutting blade - - 0.01 kg 110-30101 All dimensions in mm. Subject to technical changes. For product specific approvals and specifications please refer to the Appendix. 514 Weight Further information at www.HellermannTyton.com/tools Date of issue: October 2015 TYPE Air Supply
110-03500 价格&库存
很抱歉,暂时无法提供与“110-03500”相匹配的价格&库存,您可以联系我们找货
