151-02737
151-02737
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 151-02737 - Fastener, Ratchet P, Screw Mount Cable Clamp, 36 mm, Nylon 6.6 (Polyam...
151-02737 数据手册
27/11/2019 Ratchet P-Clamp, C-Series : RCC180SM8SS For bundle diameters from 19.4 mm to 36.0 mm, Article number: 151-02737  Add to watchlist  Images (17) Introducing the Ratchet P-… P-… Contact   / P-clamp for a more versati… versati… Features Ratchet P-Clamp C-Series for bundle diameters from 19.4 mm to 36.0 mm One-piece ratchet closure design allows for easy installation during pre- or nal assembly Multiple con gurations handle a wide range of diameters and applications, reducing part inventory Clamp interior is designed to guide and center bundle to reduce pinching Easy release feature allows for quick adjustments and maintenance Impact modi ed, heat and UV stabilized PA66 provides long-term durability, in- and outdoors Steel mounting plate tolerates high torque mounting and is treated to resist chemicals and salt spray Certi cations & Approvals Application The Ratchet P-Clamp family o ers versatility when managing wires, cables and hoses. The robust design and durable materials make it ideal for heavy duty applications, both in- and outdoors. The one-piece adjustable clamp can be closed by hand to the desired diameter. The release feature provides easy and nondestructive removal of cables simply by using a at-head screwdriver. This nondestructive release allows the clamp to be reused without removing or replacing any bolts or screws. The Ratchet P-Clamp is o ered in four sizes and multiple mounting con gurations. For bundle diameters from 19.4 mm to 36.0 mm is suitable for following markets and industries More products in this product group Ratchet P-Clamp, C-Series > Base Data  Colour Black (BK) Fixation Method Screw Mounting Pack Cont. 160 Bag Contact   / Package Quantity per bag PART DESCRIPTION RCC180SM8SS-PA666V0/SS304-BK Product Family For bundle diameters from 19.4 mm to 36.0 mm Product Group Ratchet P-Clamp, C-Series Variant Short Product Dimensions  Angle 180 ° Bundle ∅ max. 36.0 mm Bundle ∅ min. 19.4 mm Fixing Hole Centres (F) 2.45 " Fixing Hole Centres (F) 62.3 mm for Hole ∅ (FH) 8.4 mm Length (L) 156.1 mm Length (L2) 103.0 mm Min.Tensile Strength 445.0 N Stud ∅ M8 Width (W) 34.9 mm Width (W2) 30.0 mm Material and Speci cations  ELV compliant (Article 4 - 2) YES EN 45545-2 Results R22 HL2, R23 HL3 Flammability UL 94 V0 Hazardous good No Material Polyamide 6.6 + Polyamide 6 V0 (PA666V0), Stainless Steel (SS304) Operating Temperature - °C -40 °C to +85 °C Speci cations Speci cations EN 45545-2:2013, NFPA130: 2017 UL Listed (US and Canada) No UL Recognized (US and Canada) No UV-Resistant (Yes/No) Yes Logistics and Packaging More Information   Contact  / ETIM 6.0 EC000127 ETIM 7.0 Key EC000127 UNSPSC Key 39121702  Accessories RCTT 151-01529 Ratchet P-Clamp RCINSERTC 151-01532 Ratchet P-Clamp    Similar products RCC180SM8 151-01474 Ratchet P-Clamp, C-Series  RCC180MM8 151-01477 Ratchet P-Clamp, C-Series  RCC180SM10 151-01475 Ratchet P-Clamp, C-Series  RCC180MM10 151-01478 Ratchet P-Clamp, C-Series  RCC180SM12 151-01476 Ratchet P-Clamp, C-Series  RCC180MM12 151-01479 Ratchet P-Clamp, C-Series  Show all   Contact   / © HellermannTyton 2019 Contact   /
151-02737 价格&库存
很抱歉,暂时无法提供与“151-02737”相匹配的价格&库存,您可以联系我们找货
