391-90002
391-90002
    HELLERMAN(海尔曼太通)
391-90002 数据手册
Application Tooling 6.2 Application Tooling for Heat Shrinkable Tubing Gas powered Hot Air Tool • E4500 The E4500 hot-air gun Starter Kit is ideal for working in cramped spaces or where there is no power supply. The Kit includes a E4500 Hot Air Tool with protective spring, gas cartridge P445, Reflector Nozzle Z2 and Flat Nozzle Z3. The Hot Air Tool is suitable for shrinking all types of heat shrink products including tubing, shapes and cable repair sleeves. It can also be used for the bending and shaping of PVC pipes, soft soldering of copper pipes, drying, defrosting (of locks) , heating and paint stripping. Features and Benefits • Cordless hot air gun works with special gas cartridge • Does not need any power supply • Suitable for outdoor use • Designed for heat shrink tubing, end caps and moulded shapes • Supplied with protective spring, two nozzles and a gas cartridge • Allows precise working in any position even in restricted spaces • Can be operated on its stand for hands free use • Light weight tool • Operating time of cartridige: approx. 1.5 hours • With easy Piezo ignition One Step to the Web! TYPE E4500-H with heat protecting spring. Practical hot air gun kit E4500 with accessories. Gas cartridge P445. Description Article-No. E4500 GAS-HEATGUN4500 Hot air gun with protective spring incl. gas cartridge, reflector nozzle Z2 and flat nozzle Z3 391-90002 P445 P445 P445 Refill Gas Cartridge (Methyl Acetylene Propadiene, Butane, Propane) 391-90101 Z2 Deflector Nozzle Z2 Deflector Nozzle 391-90300 Z3 Reduction Nozzle Z3 Reduction Nozzle 391-90001 318 Further information and products at www.HellermannTyton.co.uk/a318 Date of issue: January 2014 Subject to technical changes.
391-90002 价格&库存
很抱歉,暂时无法提供与“391-90002”相匹配的价格&库存,您可以联系我们找货
