151-01472
151-01472
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 151-01472 - Cable Tie Mount, RFID Cradle with High Frequency Transponder, 13.56 MH...
151-01472 数据手册
Identification Systems RFID Cable Ties and Accessories 5.4 Accessories with RFID transponder CRADLE – High Frequency (HF) The CRADLE equipped with a HF transponder can be used with standard HellermannTyton cable ties. All RFID products can be used for securing, serialisation, tracking and identification of products in the areas of resource management, electrical inspection, inventory, distribution and rental services as well as for easy management of maintenance and repair routines. Features and benefits • Cable tie slot to suit HellermannTyton's standard cable ties up to 7.9 mm wide • Made from durable TPU and is suitable to be used in salt water conditions • Flexible, contactless data communication • Clear identification of objects through unique numbering • Faster data management compared to paper solution • More accurate documentation processes – prevention of human errors • Robust and resistant to harsh environments and cleaning processes • Date on RFID chip can be reprogrammed (HF) – no waste • Yellow colour for easy visual detection • Other colours and frequencies are available on request • High frequency (HF – 13.56 MHz) • Rewritable RFID CRADLE – Can be used with a standard HellermannTyton cable tie. MATERIAL Thermoplastic Polyurethane (TPU) Frequency 13.56 MHz (HF) Idle Temperature -40 °C to +85 °C Operating Temperature -25 °C to +85 °C Flammability UL 94 V2 G W R15 L CRADLE (front view) CRADLE (rear view) Frequency Width (W) Length (L) Strap Width max. (G) Colour Pack Cont. Tools Article-No. 13.56 MHz (HF) 19.8 27.9 7.9 Yellow (YE) 100 pcs. 52-53 151-01472 TYPE RFID CRADLE CRADLE (side view) All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available. Recommended Tools 52 53 RFID-DT22-HF RFID-HS9BT-HF 521 520 Date of issue: 10/2017 For more information on toolings please refer to the Application Tooling chapter. Further information at www.HellermannTyton.com/identification 519
151-01472 价格&库存
很抱歉,暂时无法提供与“151-01472”相匹配的价格&库存,您可以联系我们找货
库存:87
