151-01567
Article Number:
151-01567
Description:
Wedge Clip, ±Panel Thickness, PA66HSGF30,
Black/Gray, 200/bag
Base Data
Local Order Number
151-01567
Type
BCCLGA
Color
Black (BK)
Gray (GY)
Features and benefits
Two-piece ratcheting wedge design allows for easy, positive-locking size
adjustment.
Peel and stick 3MVHBadhesive inside clip increases grip and enables onehand installation.
Heat-stabilized, glass-filled PA66 assembly delivers remarkable extraction force
without drilling.
Three sizes cover a wide range of mounting thicknesses, reducing part inventory.
4-way, wide slot accommodates our heavy-duty and Wide-Strap Series Cable Ties.
Quantity Per
bag
Product Description
The Wedge Clip, paired with any HellermannTyton heavy duty Cable Tie, routes
cables along a frame or rail in vertical or horizontal applications. A robust design and
durable materials make it ideal for extreme-duty applications. The integrated wedge
mechanism slides along a stepped grade until snug against the mounting surface.
Inside the clip is a 3MVHB(Very High Bond) adhesive pad, which actually
builds strength over time. This holds the clip to the work surface instantly, enabling
installers to place it into position without worrying about it falling off prior to
fastening. The combination of adhesive and the clip¶s vice-like compression result in
incredible extraction force without the need to drill holes. The Wedge Clip is offered
in three sizes.
GLOBAL PART NAME (auto set)
BCCLGA-PA66HSGF30-BK/GY
Short Description
Wedge Clip, ±Panel Thickness, PA66HSGF30, Black/Gray, 200/bag
Length L (Imperial)
1.21"
Length L (Metric)
30.8mm
Length L2 (Imperial)
1.06"
Length L2 (Metric)
27.0mm
Width W (Imperial)
1.13"
Width W (Metric)
28.6mm
Height H (Imperial)
1.70"
Height H (Metric)
43.10mm
Product
Dimensions
generated on:
12/12/2017
151-01567
Product
Dimensions
Height H2 (Imperial)
0.49"
Height H2 (Metric)
12.50mm
Panel Thickness Max. (Imperial)
0.51"
Panel Thickness Max. (Metric)
13.0mm
Panel Thickness Min. (Imperial)
0.31"
Panel Thickness Min. (Metric)
8.0mm
Material
Polyamide 6.6, heat stabilized, glass fiber reinforced (PA66HSGF30%)
Material Shortcut
PA66HSGF30
Adhesive
Acrylic foam
Flammability
UL 94 HB
Operating Temperature
-40°F to +284°F (-40°C to +140°C)
ROHS Compliant
Yes
Package Quantity (Imperial)
200
Package Quantity (Metric)
200
Weight (Metric)
4.03697kg
Weight (imperial)
8.9lbs
Material and
Specifications
Logistic and
Packaging
generated on:
12/12/2017
很抱歉,暂时无法提供与“151-01567”相匹配的价格&库存,您可以联系我们找货
