151-40119
    HELLERMAN(海尔曼太通)
151-40119 数据手册
Cable Ties and Fixings 1.8 Fixing Elements Cable Fixing Cradle TM1SF for cable ties width up to 5.0 mm Offering simple and easy methods of securing cables or pipes, these fixing accessories have many applications within a wide range of industries. Features and benefits • Ideal mount for space-saving applications with restricted access • Arrowhead for very secure fixing TM1SF for secure fixing of cables into pre-drilled or pre-punched holes. Material specification please see page 26. TM1SF Fixing Base TYPE Hole Ø (FH) Panel Thickness Width (W) Length (L) Height (H) Height (H2) Strap Width max. (G) Material Colour Article-No. TM1SF 6.35 3.3 - 3.4 10.2 15.8 4.6 4.6 5.0 PA66 White (WH) 151-40119 All dimensions in mm. Subject to technical changes. Arrowhead Cradle SFC-Series Offering simple and easy methods of securing cables or pipes, these fixing accessories have many applications within a wide range of industries. Features and benefits • Arrowhead fixing for use in pre-drilled or punched holes • SFC and SFC2 for ties up to 5.3 mm wide • SFC3 for ties up to 8.6 mm wide W The SFC3 series for securely fixing and to route cables and pipes. Date of issue: January 2019 SFC SFC2 SFC3 Width (W) Length (L) Strap Width max. (G) Material Colour Article-No. 0.8 - 1.0 6.0 14.5 5.3 PA66 Natural (NA) 151-02000 3.0 - 3.2 11.0 18.0 5.3 PA66 Natural (NA) 151-01600 6.3 0.8 - 1.8 22.0 15.5 8.6 PA66 Black (BK) 151-01907 6.3 0.8 - 1.8 22.0 15.5 8.6 PA66 Natural (NA) 151-01909 Hole Ø (FH) Panel Thickness SFC2 6.0 SFC 6.0 TYPE SFC3 All dimensions in mm. Subject to technical changes. Further information at www.HellermannTyton.co.uk/fixings 165 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Colour** Aluminium alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene rubber CR -20 °C to +80 °C Black (BK) • Weather resistant • High yield strength Ethylene Tetrafluoroethylene (Tefzel®) E/TFE -80 °C to +170 °C Blue (BU) UL 94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL 94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Good chemical resistance to acids, bases, oxidizing agents • UV resistant Polyamide 4.6 PA46 -40 °C to +130 °C, Natural (NA), (+150 °C, 5000 h; Grey (GY) +195 °C, 500 h) UL 94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitivity Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL 94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL 94 V2 • High yield strength Polyamide 6.6 glass-fibre reinforced PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL 94 HB • Good resistance to lubricants, fuels, salt water and solvents Polyamide 6.6 heat and UV stabilised PA66HSW -40 °C to +105 °C Black (BK) UL 94 V2 • High yield strength • Modified elevated maximum temperature • UV resistant Polyamide 6.6 heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL 94 V2 • High yield strength • Modified elevated maximum temperature Polyamide 6.6 high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB PA66HIRHSW -40 °C to +110 °C Black (BK) UL 94 HB Polyamide 6 high impact modified Polyamide 6.6 Polyamide 6.6 high impact modified, heat and UV stabilised Material Properties* Material Specifications • Resistance to radioactivity • UV resistant, not moisture sensitive • Good chemical resistance to acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impact • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature • High yield strength, UV resistant • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated maximum temperature Polyamide 6.6 high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL 94 HB Polyamide 6.6 high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL 94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL 94 V2 • High yield strength • UV resistant Polyamide 6.6 UV resistant 26 Flammability Further information at www.HellermannTyton.co.uk/fixings Date of issue: January 2019 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6 with metal particles PA66MP Polyamide 6.6 with metal particles Polyamide 6.6 V0 MATERIAL Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL 94 HB • High yield strength • Metal and X-Ray detectable PA66MP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL 94 V0 • High yield strength • Low smoke emission SP -50 °C to +150 °C Black (BK) PEEK -55 °C to +240 °C Beige (BGE) UL 94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to acids, bases, oxidising agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL 94 HB • Low moisture absorption • Good chemical resistance to most acids, bases, alcohol, oils Polyolefin PO -40 °C to +90 °C Black (BK) UL 94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL 94 HB • Floats in water • Moderate yield strength • Good chemical resistance to acids, bases and solvents PP, EPDM -20 °C to +95 °C Black (BK) UL 94 HB • Good resistance to high temperature • Good chemical and abrasion resistance Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL 94 HB • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polypropylene with metal particles PPMP+ -40 °C to +85 °C Blue (BU) not flame retardant • High yield strength • Metal and X-Ray detectable Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) Polyester Polyetheretherketone Polypropylene, Ethylene Propylene Diene Terpolymer rubber free of Nitrosamine Material Properties* 1.0 Material Specifications • UV resistant • Good chemical resistance to most acids, bases and oils • Low moisture absorption • Good chemical resistance to acids, bases, salts, alcohol, oils • Corrosion resistant • Antimagnetic • Weather resistant Non burning • Chemical resistance • SS316 also resistant against seawater, salt spray and anorganic acids UL 94 V0 UL 94 HB Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton also uses equivalent E/TFE raw material from other suppliers. • High elasticity • Good chemical resistance to acids, bases and oxidising agents **Further colours available on request. Date of issue: January 2019 *These details are only guide values. They should not be regarded as a exhaustive material specification and are no substitute for suitability tests. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.co.uk/fixings 27
151-40119 价格&库存
很抱歉,暂时无法提供与“151-40119”相匹配的价格&库存,您可以联系我们找货
