211-15110
    HELLERMAN(海尔曼太通)
    Cable Management, P-Clamp Aluminum Alloy/Chloroprene Black Screw Mount 14.3mm
211-15110 数据手册
Cable Ties and Fixings 1.9 Clips, Clamps and Plugs Aluminium P-Clips Alu-P-Clip with / without chloroprene Insert Manufactured from a high quality aluminium, these P-Clips provide flexibility whilst providing a permanent fixing in the most arduous of environments. The addition of a Chloroprene insert provides the cable or pipe bundle with a high degree of protection against vibration, reducing noise and also providing electrical isolation. Features and Benefits • Simple, secure pipe or cable fixing (e. g. caravan construction) • Combine with chloprene insert for vibration resistance (e. g. retain capacitors on PCB) • Ideal for use in high temperatures • Suitable for applications needing strength of metal components P-Clips manufactured in polyamide, aluminium or aluminium with a chloroprene insert. Material specification please see page 24. F3 WT F3 F2 TYPE F2 Alu P-Clip (plan view) Alu P-Clip (side view) Width Width Wall (W) (W2) (WT) Wall Hole Ø (WT2) (FH) Alu P-Clip with chloroprene insert (side view) Fixing Hole Centres (F2) Fixing Hole Centres Bundle (F3) Ø max. Radius (R) Material Colour ALU4 12.7 - 0.80 - 5.2 11.6 5.5 6.4 1.6 AL Natural (NA) 211-10040 ALU5 12.7 - 0.80 - 5.2 12.6 5.5 8.0 1.6 AL Natural (NA) 211-10050 Article-No. ALU6 12.7 - 0.80 - 5.2 13.4 5.5 9.5 1.6 AL Natural (NA) 211-10060 ALU7 12.7 - 0.80 - 5.2 14.2 5.5 11.1 1.6 AL Natural (NA) 211-10070 ALU8 12.7 - 0.80 - 5.2 15.0 5.5 12.7 1.6 AL Natural (NA) 211-10080 ALU10 12.7 - 0.80 - 5.2 16.6 5.5 15.9 1.6 AL Natural (NA) 211-10100 ALU11 12.7 - 1.30 - 5.2 19.1 5.5 17.5 2.8 AL Natural (NA) 211-10110 ALU12 12.7 - 1.30 - 5.2 19.9 5.5 19.1 2.8 AL Natural (NA) 211-10120 ALU13 12.7 - 1.30 - 5.2 20.7 5.5 20.6 2.8 AL Natural (NA) 211-10130 ALU4C 16.3 12.7 3.70 0.8 5.2 11.6 5.5 3.2 1.6 AL, CR Black (BK) 211-15040 ALU5C 16.3 12.7 3.70 0.8 5.2 12.6 5.5 4.8 1.6 AL, CR Black (BK) 211-15050 ALU6C 16.3 12.7 3.70 0.8 5.2 13.4 5.5 6.4 1.6 AL, CR Black (BK) 211-15060 ALU7C 16.3 12.7 3.70 0.8 5.2 14.2 5.5 8.0 1.6 AL, CR Black (BK) 211-15070 ALU8C 16.3 12.7 3.70 0.8 5.2 15.0 5.5 9.5 1.6 AL, CR Black (BK) 211-15080 ALU9C 16.3 12.7 3.70 0.8 5.2 15.8 5.5 11.1 1.6 AL, CR Black (BK) 211-15090 ALU10C 16.3 12.7 3.70 0.8 5.2 16.6 5.5 12.7 1.6 AL, CR Black (BK) 211-15100 All dimensions in mm. Subject to technical changes. 176 Alu P-Clip with chloroprene insert (plan view) Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 R Cable Ties and Fixings 1.9 Clips, Clamps and Plugs Aluminium P-Clips Alu-P-Clip with / without chloroprene Insert R F3 WT F3 F2 TYPE ALU11C Width Width Wall (W) (W2) (WT) 16.3 F2 Alu P-Clip (plan view) Alu P-Clip (side view) 12.7 Wall Hole Ø (WT2) (FH) 4.50 1.3 5.2 Alu P-Clip with chloroprene insert (side view) Fixing Hole Centres (F2) 19.1 Fixing Hole Centres Bundle (F3) Ø max. 5.5 14.3 Alu P-Clip with chloroprene insert (plan view) Radius (R) Material Colour Article-No. 2.8 AL, CR Black (BK) 211-15110 ALU12C 16.3 12.7 4.50 1.3 5.2 19.9 5.5 15.9 2.8 AL, CR Black (BK) 211-15120 ALU13C 16.3 12.7 4.50 1.3 5.2 20.7 5.5 17.5 2.8 AL, CR Black (BK) 211-15130 ALU14C 16.3 12.7 4.50 1.3 5.2 21.5 5.5 19.1 2.8 AL, CR Black (BK) 211-15140 ALU15C 16.3 12.7 4.50 1.3 5.2 22.3 5.5 20.6 2.8 AL, CR Black (BK) 211-15150 ALU16C 16.3 12.7 4.50 1.3 5.2 23.1 5.5 22.2 2.8 AL, CR Black (BK) 211-15160 ALU17C 16.3 12.7 4.50 1.3 5.2 23.9 5.5 23.8 2.8 AL, CR Black (BK) 211-15170 ALU18C 16.3 12.7 4.50 1.3 5.2 24.6 5.5 25.4 2.8 AL, CR Black (BK) 211-15180 ALU19C 16.3 12.7 4.50 1.3 5.2 25.5 5.5 27.0 2.8 AL, CR Black (BK) 211-15190 ALU20C 16.3 12.7 4.50 1.6 5.2 27.0 5.5 28.6 3.2 AL, CR Black (BK) 211-15200 ALU22C 16.3 12.7 4.50 1.6 5.2 28.6 5.5 31.8 3.2 AL, CR Black (BK) 211-15220 ALU23C 16.3 12.7 4.50 1.6 5.2 29.4 5.5 33.3 3.2 AL, CR Black (BK) 211-15230 ALU24C 16.3 12.7 4.50 1.6 5.2 30.2 5.5 34.9 3.2 AL, CR Black (BK) 211-15240 ALU25C 16.3 12.7 4.50 1.6 5.2 30.8 5.5 36.5 3.2 AL, CR Black (BK) 211-15250 ALU26C 16.3 12.7 4.50 1.6 5.2 31.7 5.5 38.1 3.2 AL, CR Black (BK) 211-15260 ALU28C 16.3 12.7 4.50 1.6 5.2 33.3 5.5 41.3 3.2 AL, CR Black (BK) 211-15280 ALU29C 16.3 12.7 4.50 1.6 5.2 34.1 5.5 42.9 3.2 AL, CR Black (BK) 211-15290 ALU30C 16.3 12.7 4.50 1.6 5.2 34.9 5.5 44.5 3.2 AL, CR Black (BK) 211-15300 ALU34C 16.3 12.7 4.50 1.6 5.2 38.1 5.5 50.8 3.2 AL, CR Black (BK) 211-15340 Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Further information at www.HellermannTyton.com/fixings 177 Cable Ties and Fixings 1.0 Material Information Material Specification Overview Material Shortcut Operating Temperature Aluminium-alloy AL -40 °C to +180 °C Natural (NA) • Corrosion resistant • Antimagnetic Chloroprene CR -20 °C to +80 °C Black (BK) • Weather-resistant • High yield strength Ethylene Tetrafluoroethylene E/TFE -80 °C to +170 °C Blue (BU) UL94 V0 Polyacetal POM -40 °C to +90 °C, (+110 °C, 500 h) Natural (NA) UL94 HB Polyamide 11 PA11 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 12 PA12 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Good chemical resistance to: acids, bases, oxidizing agents • UV-resistant Polyamide 4.6 PA46 -40 °C to +150 °C (5000 h), +195 °C (500 h) Natural (NA), Grey (GY) UL94 V2 • Resistance to high temperatures • Very moisture sensitive • Low smoke sensitive Polyamide 6 PA6 -40 °C to +80 °C Black (BK) UL94 V2 • High yield strength PA6HIR -40 °C to +80 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature Polyamide 6.6 PA66 -40 °C to +85 °C, (+105 °C, 500 h) Black (BK), Natural (NA) UL94 V2 • High yield strength Polyamide 6.6, PA66GF13, PA66GF15 -40 °C to +105 °C Black (BK) UL94 HB • Good resistance to: lubricants, vehicle fuel, salt water and many solvents PA66HSW -40 °C to +105 °C Black (BK) UL94 V2 • High yield strength • Modified elevated max. temperature • UV-resistant Polyamide 6.6, heat stabilised PA66HS -40 °C to +105 °C Black (BK), Natural (NA) UL94 V2 • High yield strength • Modified elevated max. temperature Polyamide 6.6, high impact modified PA66HIR -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat and UV stabilised PA66HIRHSW -40 °C to +110 °C Black (BK) UL94 HB Polyamide 6.6, high impact modified, heat stabilised PA66HIRHS -40 °C to +105 °C Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature Polyamide 6.6, high impact modified, scan black PA66HIR(S) -40 °C to +80 °C, (+105 °C, 500 h) Black (BK) UL94 HB • Limited brittleness sensitivity • Higher flexibility at low temperature PA66W -40 °C to +85 °C, (+105 °C, 500 h) Black (BK) UL94 V2 • High yield strength • UV-resistant Polyamide 6, high impact modified glass-fibre reinforced Polyamide 6.6, heat and UV stabilised Polyamide 6.6, UV-resistant Colour** Material Properties* Flammability Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. • Resistance to radioactivity • UV-resistant, not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents • Limited brittleness sensitivity • Flexible at low temperature • Not moisture sensitive • Robust on impacts • Bio-plastic, derived from vegetable oil • Strong impact resistance at low temperature • Very low moisture absorption • Weather-resistant • Good chemical resistance • Limited brittleness sensitivity • Higher flexibility at low temperature • Limited brittleness sensitivity • Higher flexibility at low temperature • Modified elevated max. temperature • High yield strength, UV-resistant **More colours on request. *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances 24 Material Specifications Further information at www.HellermannTyton.com/fixings Date of issue: October 2015 MATERIAL Cable Ties and Fixings Material Information Material Shortcut Operating Temperature Polyamide 6.6, with metal particles PA66MP Polyamide 6.6 V0 MATERIAL Material Properties* Colour** Flammability -40 °C to +85 °C, (+105 °C, 500 h) Blue (BU) UL94 HB • High yield strength • Metal and X-Ray detectable PA66V0 -40 °C to +85 °C White (WH) UL94 V0 • High yield strength • Low smoke emission PA66V0-HOI -40 °C to +85 °C, (+105 °C, 500 h) White (WH) UL94 V0 • High yield strength • Low smoke emissions SP -50 °C to +150 °C Black (BK) Halogen free • UV-resistant • Good chemical resistance to: most acids, alkalis and oils PEEK -55 °C to +240 °C Beige (BGE) UL94 V0 • Resistance to radioactivity • Not moisture sensitive • Good chemical resistance to: acids, bases, oxidizing agents Polyethylene PE -40 °C to +50 °C Black (BK), Grey (GY) UL94 HB • Low moisture absorption • Good chemical resistance to: most acids, alcohol and oils Polyolefin PO -40 °C to +90 °C Black (BK) UL94 V0 • Low smoke emissions Polypropylene PP -40 °C to +115 °C Black (BK), Natural (NA) UL94 HB • Floats in water • Moderate yield strength • Good chemical resistance to: organic acids PP, EPDM -20 °C to +95 °C Black (BK) UL94 HB • Good resistance to high temperatures • Good chemical and abrasion resistance Polyamide 6.6 V0, High Oxygen Index Polyester Polyetheretherketone Polypropylene, EthylenePropylene-DienTerpolymere-rubber free of Nitrosamine Polypropylene with metal particles PPMP -40 °C to +115 °C Blue (BU) UL94 HB • Floats in certain liquids • Metal and X-Ray detectable • Heat resistant • Moderate yield strength • Good chemical resistance Polyvinylchloride PVC -10 °C to +70 °C Black (BK), Natural (NA) UL94 V0 • Low moisture absorption • Good chemical resistance to: acids, ethanol and oil Stainless Steel, Stainless Steel SS304, SS316 -80 °C to +538 °C Natural (NA) Non burning • Corrosion resistant • Antimagnetic • Weather resistant • Outstanding chemical resistance Thermoplastic Polyurethane TPU -40 °C to +85 °C Black (BK) UL94 HB • High elasticity • Good chemical resistance to: acids, bases and oxidizing agents Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers. 1.0 Material Specifications **More colours on request. Date of issue: October 2015 *These details are only rough guide values. They should be regarded as a material specification and are no substitute for a suitability test. Please see our datasheets for further details. HF = Halogenfree LFH = Limited Fire Hazard RoHS = Restriction of Hazardous Substances Further information at www.HellermannTyton.com/fixings 25
211-15110 价格&库存
很抱歉,暂时无法提供与“211-15110”相匹配的价格&库存,您可以联系我们找货
