321-50013
321-50013
    HELLERMAN(海尔曼太通)
    HEATSHRINK3.5:145MMX1M
321-50013 数据手册
321-50013 Article Number: 321-50013 Heat Shrink Tubing, 4FT Stick, Thick Wall Adhesive Lined, Up to 3.5:1, 1.75", 45/12 dia, Polyolefin, Black, 4/pkg Download spec sheet Base Data Local Order Number 321-50013 Type TREDUX HA47-48ST-45/12 Color Black (BK) Features and Benefits • Tubing is 3.5:1, thick wall adhesive lined. • Toughness and weatherability is ideal for low and medium voltage power applications. • Available in 3.28' (1.0 m) lengths, multiple diameters and 1 color (black). • Conveniently packed in a display carton. Product Description TREDUX HA47 thick wall heat shrink tubing has a adhesive liner that provides good moisture sealing and weather protection suitable for insulation and protection of low and medium voltage power applications. HA47 is tough and the weatherability makes it suitable for exposed applications and underground cable joints. Polyolefin material is pre-cut into 3.28' (1.0m) sticks and stored in a convenient display box. RoHS approved and Halogen free. Short Description Heat Shrink Tubing, 4FT Stick, Thick Wall Adhesive Lined, Up to 3.5:1, 1.75", 45/12 dia, Polyolefin, Black, 4/pkg Product Dimensions Length L (Imperial) 4.0 ft Length L (Metric) 1.0 m Printable (Yes/No) No Shrink Ratio up to 3.5:1 Tensile Strength (MPa) 14 MPa Trade Size 1-3/4 " Variant Thick-Wall Voltage Range Low and Medium Voltage Volume Resistance (Ohm cm) 10¹ Ω cm Nominal Diameter (Imperial) 1-3/4 " Nominal Diameter (Metric) 45 mm Wall Thickness WT (Imperial) 0.161 " Wall Thickness WT (Metric) 4.1 mm Recovered Diameter d (metric) 12.0 mm Recovered Diameter d (imperial) 0.472 " Supplied Diameter D (imperial) 1.772 " Supplied Diameter D (metric) 45.0 mm Logistics and Packaging Quantity Per pieces Package Quantity (Metric) 4 Pieces Weight (Metric) 0.95 kg Weight (imperial) 2.1 Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Adhesive Hot melt adhesive Dielectric Strength (Metric) 20 kV/mm Elongation at break 400% Flammability not flame retardant Halogenfree Yes Shrink Temperature +248 °F (+120 °C) Operating Temperature -67°F to +230°F (-55°C to +110°C) ROHS Compliant Yes UL Listed (US) No UL Recognized (US) No © HellermannTyton 2015
321-50013 价格&库存
很抱歉,暂时无法提供与“321-50013”相匹配的价格&库存,您可以联系我们找货
