Weldy Hot Air Tool
The Weldy Pro and Plus are compact, lightweight heat guns. They are designed for use
with all types of heatshrinkable tubing and
shapes. The Weldy Pro has an adjustable
temperature range from 100°C to 550°C,
whilst the Weldy Plus gives a maximum
650°C. For ease-of-use the Plus also includes a handy LCD display to show air temperature and application.
The Triac-S is specifically designed for long
running bench work. It features a high temperature element protected by thermal cutoff and a stay cool nozzle. The temperature
range is from ambient to 600°C. Nozzle
accessories are avaliable upon request.
Weldy Pro.
Weldy Plus.
Triac S Hot Air Tool.
Technical Table
Article-No.
Type
391-00407 Triac-S
Air Flow
l/min
Temp. °C
Wattage
Operational
Voltage
Weight (Kg)
230 max.
20-700
1600 W
230-240 V
391-00409 Sieve reflector 50mm
391-00410 Sieve reflector 35mm
391-00411 Solder sleeve reflector
1.3
391-00501 Weldy Plus
200-550
80-650
2000 W
230-240 V
0.62
391-00502 Weldy Pro
0.57
250-500
100-550
1800 W
230-240 V
391-00503 Overlap welding nozzle
391-00504 Reduction nozzle
391-00505 Reflector nozzle
391-00506 Wide slot nozzle
391-00507 Solder sleeve reflector
391-00508 Welding nozzle
1
很抱歉,暂时无法提供与“990-805”相匹配的价格&库存,您可以联系我们找货
