CTAM10C2
CTAM10C2
    HELLERMAN(海尔曼太通)
CTAM10C2 数据手册
Materials Information . . . . . . . . . 6-9 Cable Ties . . . . . . . . . . . . . . . 10-54 Grip Ties . . . . . . . . . . . . . . . . 55-57 Cable Tie Mounts . . . . . . . . . . 58-65 Cable Tie Tools . . . . . . . . . . . . 66-80 BUNDLING & SECURING CLAMPING ROUTING AND PROTECTING IDENTIFYING Bundling and Securing C a b l e Ti e s Optimum storage conditions for cable ties made of polyamide (PA) HellermannTyton cable ties and mounts are manufactured from high-quality polyamide (PA). This material is mainly processed using injection molding, but can also be extruded. Polyamide is a hygroscopic material. This means that the material absorbs and loses moisture. For optimum handling of cable ties, it is important that the material is in a condition of equilibrium with a water content of approximately 2.5%. The packaging used by HellermannTyton ensures that the water content in the material remains constant. Therefore, it is important to store the products in their original packaging to preserve the quality of the ties and mounts. Once opened you should use the ties as quickly as possible. Do not expose the product to direct sunlight Store the product away from direct sources of heat Ideal storage conditions: 50 0 ❙❘❘❘❘❙ ❘❘ 10 50% 40 ❘❘❘❙ 100 73 °F 6 ❘❘❘ ❙❘ 30 ❘❘❙❘❘❘❘❙❘❘❘❘❙❘ 70 80 60 ❘ ❘ ❘ ❘ ❙ ❘ ❘ ❘ ❘ ❙ ❘ ❘ ❘ ❘ ❙ ❘❘ ❘❘❙ 90 20 50% relative humidity w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Cable Ties and Tool Systems HellermannTyton's cable tie and tool systems are designed to work together to provide optimal consistency, quality, safety, and overall performance. Wrapping and hand tensioning a high quality cable tie is just the first step in assuring a high quality application. It is necessary to use one of HellermannTyton's cable tie tools to ensure that the cable tie is applied with just the right amount of tension and with a flush cut that won't leave a sharp edge. HellermannTyton leads the world in the development and manufacture of ergonomically designed, high performing cable tie tools in mechanical, power assisted, and automatic versions. With HellermannTyton's automatic cable tie systems, cable ties are applied, tensioned and cut-off to the correct tension in approximately one second. HellermannTyton's mechanical and power assisted tools expertly tension and cut-off hand applied cable ties. AT2000 Automatic Cable Tie Tool — For automatic cable tie tool systems, see page 72. Consistency and Quality By utilizing HellermannTyton's cable ties and tools together, a consistent tension and cut-off is achieved. When using non-approved methods of cutting off a cable tie, wire and cable can be crushed, the strap of the cable tie may be cut-off too deeply causing the tie to disengage, or the cable tie can be applied too loosely which can affect the bundling and securing properties of the application. Safety A flush cut is another benefit of using HellermannTyton's cable tie tools and ties as a system. Worker safety, and resulting reduction of workers' compensation claims, is an increasing priority of most companies. HellermannTyton's cable tie tools are ergonomically designed to reduce worker effort and causes of repetitive motion injuries. When using HellermannTyton's tools and cable ties, a flush cut is achieved, creating a smooth edge. When non- approved methods of applying a cable tie are used, a sharp edge is almost always left at the end of the tie - causing injury to workers and end-customers. All of HellermannTyton's cable tie tool systems offer adjustable tension and cut-off levels to assure optimal tensions and flush cut-offs. MK7P - Power Assisted Cable Tie Tool — For power assisted cable tie tools, see page 69. Overall Performance Used together, HellermannTyton's cable ties and ergonomically designed tool systems assure a high quality installation which prevents damage to wire and cable and potential rework due to inappropriately applied cable ties - all lowering installed costs while improving performance. MK7 and MK9 Mechanical Cable Tie Tools — For mechanical cable tie tools, see page 66. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 7 M A T E R I A L S Bundling and Securing C a b l e Ti e s Materials HellermannTyton has worked very closely with its material suppliers to develop resins that are specifically formulated for fastener and cable tie production. HellermannTyton has spearheaded material advancements in component manufacturing to assure its customers of the finest quality products. Environmental factors can have an adverse effect on fasteners. It is very important to use the most suitable material for each application. HellermannTyton fasteners are available in a variety of materials ranging from polyamides (nylon) to fluoropolymers. Polyamide 6.6 – General Purpose General purpose polyamide 6.6 features light weight, high strength and a wide temperature range. Polyamide 6.6 is hygroscopic, and therefore, absorbs or releases moisture depending on its environment. Thus, the moisture level of the material will affect tensile strength, stiffness and elongation of the product. Polyamide 6.6 – Heat Stabilized With similar properties and benefits as polyamide 6.6, products manufactured with heat stabilized polyamide 6.6 material have a chemical stabilizer added for higher continuous temperature applications. Polyamide 6.6 – UV Resistant Chemical inhibitors are used to give polyamide 6.6 material added properties to fight against premature aging of products due to the effects of ultraviolet rays. Polyamide 6.6 – UV Resistant (2% Carbon for Military Specification) The physical properties of this material include carbon, which acts as a UV stabilizer, prolonging the life of the product under ultraviolet conditions. It also allows HellermannTyton’s black cable ties to meet the particular military specification for cable ties. Polyamide 6.6 – V0 Flame Retardant This material meets UL 94V-0 flammability requirements. Flame retardant additives generally reduce tensile strength when compared to general purpose polyamide 6.6, but this resin has been formulated to minimize such effects. Polyamide 6.6 – Impact Modified, Heat Stabilized and UV Resistant Impact modified polyamide 6.6 offers the increased flexibility, heat resistance and UV resistance of the high impact material with the added feature of greater resistance to vibration, heat and sunlight for mobile applications. Polyamide 6.6 – High Impact Impact modifiers are added to increase flexibility. High impact polyamide 6.6 has stable tensile strength due to its reduced influence from moisture. It is excellent for high vibration applications, as within the aircraft and automobile industries and performs better than polyamide 6.6 against ultraviolet rays. Good for outdoor use. Polyamide 4.6 Polyamide 4.6, like polyamide 6.6, offers light weight and high strength benefits, but offers an even wider temperature range.This material can be used at a higher continuous operating temperature than polyamide 6.6 - heat stabilized. In addition to having excellent heat resistance, polyamide 4.6 has low creep effects and retention of stiffness at elevated temperatures. Polypropylene Polypropylene is used in environments where chemical effects on polyamide are a concern. It is not affected by inorganic acids (hydrochloric), polyhydric alcohols (ethyleneglycol), neutral salts (sodium chloride) and basic salts (sodium bicarbonate). Polypropylene also resists a number of other chemicals with good results, although it has lower tensile strength than polyamide 6.6 (about half). Polypropylene has good UV resistance. Polyamide 12 Although not as strong as polyamide 6.6 (about half), polyamide 12 is extremely flexible, absorbs little moisture, ages better and has better chemical and UV resistance than general purpose polyamide 6.6. Polyamide 12 is good for applications where products are exposed to metal oxides. Ethylenterafluorineethylene - Tefzel Although about two-thirds the strength of polyamide 6.6, Tefzel is resistant to a wide range of chemicals, such as concentrated hydrofluoric and sulfuric acids. It is also a low water absorbing material, therefore, is not adversely affected by water. Tefzel is radiation resistant up to 200 megarads and meets the fire and smoke requirements of IEEE 383. Tefzel also withstands high temperatures and ultraviolet light exposure. Products made from Tefzel material also have non-outgassing properties for zero gravity applications. Polyacetal Polyacetal has excellent dielectric properties, UV and chemical resistance, and a UL94-HB flame rating. It has been tested for excellent weatherability against moisture, sunlight, and other environmental conditions. Halar Halar is similar to Tefzel in performance and benefits. Halar is recognized for its low smoke density attribute when burned. This makes products made out of Halar more desirable for use in areas where smoke generation is a concern,as when bundling wire and cable in air handling spaces. * Halar is a registered trademark of Solvay S.A. For more information on RoHS/WEEE Compliance, go online to: http://www.hellermann.tyton.com/rohs.asp 8 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Material Specifications CONTINUOUS OPERATING TEMPERATURE MATERIAL TENSILE STRENGTH AT 73OF DRY AS MOLDED ASTM D-638 (PSI) UL FLAME RATING OXYGEN INDEX % GAMMA RADIATION RESISTANCE UV RESISTANCE MILITARY, FEDERAL, ASTM AND FDA SPECIFICATIONS MAX. MIN. 185O F 85OC -40O F -40O C 12,000 94V-2 28 1 x 105 Rads Poor ASTM D-4066PA0111 FDA CFR177.1500 Polyamide 6.6221OF Heat Stabilized (PA66HS) 105OC -40O F -40O C 12,000 94V-2 26 1 x 105 Rads Poor ASTM D-4066PA0121 Polyamide 6.6UV resistant (PA66UV) 185oF 85oC -40oF -40oC 12,000 94V-2 26 1 x 105 Rads Good - Polyamide 6.6-2% Carbon 185oF 85oC -40oF -40oC 12,000 94V-2 26 1 x 105 Rads Good UV resistant ASTM D-4066PA0181 MS3367/8 Polyamide 6.6-Flame Retardant (PA66VO) 185oF 85oC -40oF -40oC 10,800 94V-0 34 1 x 105 Rads Poor ASTM D-4066PA0110 Polyamide 6.6-Impact Mod. 230oF Heat Stabilized, UV 110oC Resistant (PA66HIRHS) -40oF 9,500 94-HB N/A N/A Very Good ASTM D-4066PA0161 Polyamide 6.6High Impact (PA66HIR) 230oF 110oC -40oF -40oC 8,800 94-HB 19 1 x 105 Rads Good ASTM D-4066PA0151 Polyamide 4.6- Heat Stabilized (PA46) 275oF 135oC -40oF -40oC 14,400 94V-2 27 9 x 106 Rads Poor ASTM D-4066PA0922 PolypropyleneChemical Resistant (PP) 239oF 115oC -40oF -40oC 3,400 94-HB N/A 1 x 105 Rads Good ASTM D-4101PP0327 Polyamide 12UV resistant (UV) 176oF 80oC -40oF -40oC 5,800 94-HB N/A 1 x 105 Rads Good ASTM D-4066PA411 Ethlenterafluorineethylene 302oF 150oC -112oF -80oC 5,800 94V-0 30 2 x 108 Rads Excellent UL2043 ASTM D-3159 Type 1 Grade 1 Polyacetal (POM) 185oF 85oC -40oF -40oC 6,500 94-HB N/A N/A Excellent - Halar® (PA66HL) 300oF 150oC -104oF -76oC 6,100 94V-0 52 2 x 108Rads Excellent 9 7 8 7 10 2 4 5 5 5 2 2 2 3 2 9 2 1 10 3 10 Flammability 5 5 5 5 10 2 2 5 2 2 10 2 10 UV Resistance 1 1 5 8 1 8 2 1 5 3 10 10 10 Radiation 3 3 3 3 3 3 3 3 6 3 10 3 10 Chemical Resistance 6 6 6 6 6 6 6 6 8 8 10 - 10 - Hydrocarbons - Chlorinated Hydrocarbons 8 8 8 8 8 8 8 8 6 8 10 8 10 6 6 6 6 6 6 6 6 3 8 10 5 5 10 - Acids 2 2 2 2 2 2 2 2 8 5 10 8 - Bases 8 6 6 6 6 6 6 6 8 6 10 8 10 - Salts 3 3 3 3 3 3 3 3 10 8 10 8 10 Low Low Med. Med. Med. Med. Med. Med. Med. Med. High Relative Cost Med. ASTM D-3275 Type CFDA CFR177.1380 HALAR® 8 3 POLYACTAL 8 2 POLYAMIDE 12 UV RESISTANT POLYAMIDE 4.6 HEAT STABILIZED 8 High Temperature POLYPROPYLENE POLYAMIDE 6.6 HIGH IMPACT POLYAMIDE 6.6 FLAME RETARDANT V0 POLYAMIDE 6.6 HEAT STABILIZED Tensile Strength ATTRIBUTE POLYAMIDE 6.6 UV RESISTANT POLYAMIDE 6.6 GENERAL PURPOSE POLYAMIDE 6.6 - 2% CARBON UV RESISTANT Material Performance Guide ETHLENTERAFLUORINEETHYLENE — TEFZEL® Tefzel® (E/TFE) -40oC POLYAMIDE 6.6 IMPACT MODIFIED , HEAT STABILIZED UV RESISTANT Polyamide 6.6General Purpose (PA66) High 10 = Most Recommended 1= Least Recommended w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 9 Bundling and Securing C a b l e Ti e s Standard Cable Ties T18 - T30 Series - Natural and Black Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 File# E64139 Product Selection Article No. T18S Part No. Type US Gov. Designation Min. Tensile Strength Length (L) lbs. in. (N) Max. Ø Bundle (mm) in. (mm) Width (W) in. (mm) 111-02805 T18S9C2 T18S MS3367-4-9 18 lbs (80) 3.27″ (83) .63″ (16) .09″ (2.3) 111-02809 T18S9M4 T18S MS3367-4-9 18 lbs (80) 3.27″ (83) .63″ (16) .09″ (2.3) 111-02810 T18S0C2 T18S * 18 lbs (80) 3.27″ (83) .63″ (16) .09″ (2.3) 111-02811 T18S0M4 T18S * 18 lbs (80) 3.27″ (83) .63″ (16) .09″ (2.3) Color Natural Black Pkg. Qty. 100 1000 100 1000 T18R 112-01819 T18R9C2 T18R MS3367-4-9 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01872 T18R9M4 T18R MS3367-4-9 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-00405 T18R0C2 T18R * 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01841 T18R0M4 T18R * 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-02311 T18I9C2 T18I – 18 lbs (80) 5.51″ (140) 1.38″ (35) .10″ (2.5) 111-02322 T18I9M4 T18I – 18 lbs (80) 5.51″ (140) 1.38″ (35) .10″ (2.5) 111-02308 T18I0C2 T18I – 18 lbs (80) 5.51″ (140) 1.38″ (35) .10″ (2.5) 111-02315 T18I0M4 T18I – 18 lbs (80) 5.51″ (140) 1.38″ (35) .10″ (2.5) 111-02189 T18L9C2 T18L – 18 lbs (80) 8.0″ (205) 2.17″ (55) .10″ (2.5) 111-02026 T18L9M4 T18L – 18 lbs (80) 8.0″ (205) 2.17″ (55) .10″ (2.5) 111-00401 T18L0C2 T18L – 18 lbs (80) 8.0″ (205) 2.17″ (55) .10″ (2.5) 111-02015 T18L0M4 T18L – 18 lbs (80) 8.0″ (205) 2.17″ (55) .10″ (2.5) 112-03019 T30R9C2 T30R MS3367-5-9 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03047 T30R9M4 T30R MS3367-5-9 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-00438 T30R0C2 T30R * 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03034 T30R0M4 T30R * 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03325 T30L9C2 T30L – 30 lbs (135) 7.48″ (190) 1.97″ (50) .14″ (3.5) 111-03327 T30L9M4 T30L – 30 lbs (135) 7.48″ (190) 1.97″ (50) .14″ (3.5) 111-03313 T30L0C2 T30L – 30 lbs (135) 7.48″ (190) 1.97″ (50) .14″ (3.5) 111-03315 T30L0M4 T30L – 30 lbs (135) 7.48″ (190) 1.97″ (50) .14″ (3.5) Natural Black 100 1000 100 1000 T18I Natural Black 100 1000 100 1000 T18L Natural Black 100 1000 100 1000 T30R Natural Black 100 1000 100 1000 T30L Natural Black 100 1000 100 1000 T30LL T30LL – 30 lbs (135) 11.42″ (290) 3.15″ (80) .14″ (3.5) 111-03517 T30LL9M4 T30LL – 30 lbs (135) 11.42″ (290) 3.15″ (80) .14″ (3.5) 111-03501 T30LL0C2 T30LL – 30 lbs (135) 11.42″ (290) 3.15″ (80) .14″ (3.5) 111-03511 T30LL0M4 T30LL – 30 lbs (135) 11.42″ (290) 3.15″ (80) .14″ (3.5) 111-02900 T30XL9C2 T30XL MS3367-5-9 30 lbs (135) 14.37″ (365) 4.13″ (105) .14″ (3.5) 111-02907 T30XL9M4 T30XL MS3367-5-9 30 lbs (135) 14.37″ (365) 4.13″ (105) .14″ (3.5) 111-02901 T30XL0C2 T30XL * 30 lbs (135) 14.37″ (365) 4.13″ (105) .14″ (3.5) 111-02903 T30XL0M4 T30XL * 30 lbs (135) 14.37″ (365) 4.13″ (105) .14″ (3.5) 111-03515 T30LL9C2 Natural Black 100 1000 100 1000 T30XL Natural Black Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. MK9 and MK9P cannot be used with T18S cable ties. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. * Military black available. Contact HellermannTyton for more information. 10 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 100 1000 100 1000 Bundling and Securing C a b l e Ti e s Standard Cable Ties T40 - T50 Series - Natural and Black Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection US Gov. Designation Min. Tensile Strength Length (L) lbs. in. (mm) in. (mm) 112-04019 T40R9C2 T40R(U) – 40 lbs (180) 8.27″ (210) 2.16″ (55) .16″ (4.0) 111-04131 T40R9M4 T40R(U) – 40 lbs (180) 8.27″ (210) 2.16″ (55) .16″ (4.0) 112-04060 T40R0C2 T40R(U) – 40 lbs (180) 8.27″ (210) 2.16″ (55) .16″ (4.0) 111-04122 T40R0M4 T40R(U) – 40 lbs (180) 8.27″ (210) 2.16″ (55) .16″ (4.0) Article No. Part No. T40R Type (N) Max. Ø Bundle File# E64139 Width (W) in. (mm) Color Natural Black Pkg. Qty. 100 1000 100 1000 T40I 111-04609 T40I9C2 T40I – 40 lbs (180) 11.42″ (290) 3.15″ (80) .16″ (4.0) 111-04612 T40I9M4 T40I – 40 lbs (180) 11.42″ (290) 3.15″ (80) .16″ (4.0) 111-04600 T40I0C2 T40I – 40 lbs (180) 11.42″ (290) 3.15″ (80) .16″ (4.0) 111-04604 T40I0M4 T40I – 40 lbs (180) 11.42″ (290) 3.15″ (80) .16″ (4.0) 111-04300 T40L9C2 T40L – 40 lbs (180) 14.4″ (365) 4.13″ (105) .16″ (4.0) 111-04311 T40L9M4 T40L – 40 lbs (180) 14.4″ (365) 4.13″ (105) .16″ (4.0) 111-04301 T40L0C2 T40L – 40 lbs (180) 14.4″ (365) 4.13″ (105) .16″ (4.0) 111-04305 T40L0M4 T40L – 40 lbs (180) 14.4″ (365) 4.13″ (105) .16″ (4.0) 111-05811 T50S9C2 T50S – 50 lbs (225) 5.9″ (150) 1.38″ (35) .18″ (4.6) 111-05813 T50S9M4 T50S – 50 lbs (225) 5.9″ (150) 1.38″ (35) .18″ (4.6) 111-05806 T50S0C2 T50S – 50 lbs (225) 5.9″ (150) 1.38″ (35) .18″ (4.6) 111-05808 T50S0M4 T50S – 50 lbs (225) 5.9″ (150) 1.38″ (35) .18″ (4.6) 112-05019 T50R9C2 T50R MS3367-1-9 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04862 T50R9M4 T50R MS3367-1-9 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04878 T50R0C2 T50R * 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04846 T50R0M4 T50R * 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 112-05219 T50I9C2 T50I MS3367-7-9 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) 111-05230 T50I9M4 T50I MS3367-7-9 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) 111-00444 T50I0C2 T50I * 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) 111-05216 T50I0M4 T50I * 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) 112-05419 T50L9C2 T50L MS3367-2-9 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05449 T50L9M4 T50L MS3367-2-9 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-00445 T50L0C2 T50L * 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-00504 T50L0M4 T50L * 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) Natural Black 100 1000 100 1000 T40L Natural Black 100 1000 100 1000 T50S Natural Black 100 1000 100 1000 T50R Natural Black 100 1000 100 1000 T50I Natural Black 100 1000 100 1000 T50L Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Natural Black 100 1000 100 1000 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. * Military black available. Contact HellermannTyton for more information. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 11 Bundling and Securing C a b l e Ti e s Heavy Duty Cable Ties Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 T120 Series File# E64139 Product Selection Article No. T120S Part No. Type Min. Tensile Strength US Gov. Designation lbs. Length (L) (N) Max. Ø Bundle in. (mm) in. File# E64139 Width (W) (mm) in. (mm) 111-12819 T120S9K2 T120S – 120 lbs (535) 8.85″ (225) 2.17″ (55) .30″ (7.6) 111-12813 T120S9H4 T120S – 120 lbs (535) 8.85″ (225) 2.17″ (55) .30″ (7.6) 111-12803 T120S0K2 T120S – 120 lbs (535) 8.85″ (225) 2.17″ (55) .30″ (7.6) 111-12808 T120S0H4 T120S – 120 lbs (535) 8.85″ (225) 2.17″ (55) .30″ (7.6) Color Pkg. Qty. 50 Natural 500 50 Black 500 T120I 111-12211 T120I9K2 T120I – 120 lbs (535) 11.81″ (300) 3.15″ (80) .30″ (7.6) 111-12213 T120I9H4 T120I – 120 lbs (535) 11.81″ (300) 3.15″ (80) .30″ (7.6) 111-12201 T120I0K2 T120I – 120 lbs (535) 11.81″ (300) 3.15″ (80) .30″ (7.6) 111-12206 T120I0H4 T120I – 120 lbs (535) 11.81″ (300) 3.15″ (80) .30″ (7.6) 50 Natural 500 50 Black 500 T120R 112-12019 T120R9K2 T120R MS3367-3-9 120 lbs (535) 15.24″ (387) 4.13″ (105) .30″ (7.6) 111-12036 T120R9H4 T120R MS3367-3-9 120 lbs (535) 15.24″ (387) 4.13″ (105) .30″ (7.6) 112-12060 T120R0K2 T120R * 120 lbs (535) 15.24″ (390) 4.13″ (105) 30″ (7.6) 111-12013 T120R0H4 T120R * 120 lbs (535) 15.24″ (387) 4.13″ (105) .30″ (7.6) 50 Natural 500 50 Black 500 T120L 111-12419 T120L9K2 T120L MS3367-6-9 120 lbs (535) 30.0″ (760) 8.85″ (225) .30″ (7.6) Natural 50 111-12405 T120L0K2 T120L 120 lbs (535) 30.0″ (760) 8.85″ (225) .30″ (7.6) Black 50 * Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. *Military black available. Contact HellermannTyton for more information. T150 Series File# E64139 Product Selection Min. Tensile Strength Type US Gov. Designation 111-15203 T150R9X2 T150R(U) – 175 lbs 111-15200 T150R0X2 T150R(U) – 175 lbs 111-15619 T150M9X2 T150M – 111-00124 T150M0X2 T150M – 111-15419 T150L9X2 T150L 111-15405 T150L0X2 T150L 111-15719 T150LL9X2 111-15700 T150LL0X2 Article No. T150R Part No. lbs. (N) Length (L) Max. Ø Bundle Width (W) (mm) Color Pkg. Qty. in. (mm) in. (mm) in. (780) 15.35″ (390) 4.13″ (105) .35″ (8.8) Natural 25 (780) 15.35″ (390) 4.13″ (105) .35″ (8.8) Black 25 175 lbs (780) 21.00″ (530) 5.91″ (150) .35″ (8.9) Natural 25 175 lbs (780) 21.00″ (530) 5.91″ (150) .35″ (8.9) Black 25 – 175 lbs (780) 32.28″ (820) 9.65″ (245) .35″ (8.9) Natural 25 – 175 lbs (780) 32.28″ (820) 9.65″ (245) .35″ (8.9) Black 25 T150LL – 175 lbs (780) 36.42″ (925) 10.83″ (275) .35″ (8.9) Natural 25 T150LL – 175 lbs (780) 36.42″ (925) 10.83″ (275) .35″ (8.9) Black 25 111-15519 T150XL9X2 T150XL – 175 lbs (780) 43.11″ (1095) 13.00″ (330) .35″ (8.9) Natural 25 111-15500 T150XL0X2 T150XL – 175 lbs (780) 43.11″ (1095) 13.00″ (330) .35″ (8.9) Black 25 111-15304 T150XLL9X2 T150XLL – 175 lbs (780) 52.17″ (1325) 15.95″ (405) .35″ (8.9) Natural 25 111-15300 T150XLL0X2 T150XLL – 175 lbs (780) 52.17″ (1325) 15.95″ (405) .35″ (8.9) Black 25 T150M T150L T150LL T150XL T150XLL Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 12 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Wide Strap Heavy Duty Cable Ties The wide strap cable tie minimizes pinching on soft bundles and features a low profile head to provide compact bundling. A thinner strap provides increased flexibility for improved ergonomics. – Wide strap is designed to minimize pinching of soft hoses and convoluted tubing – Low profile head – Clamping rails on the bottom of head to increase grip on round bundles – Accommodates a large range of bundle diameters: .375” - 4.125” (9.5mm - 104.7mm) – Flexible strap – Bent tip for quick insertion into mounts Material Data Material Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Operating Temperature -40 °F to +230 °F (-40 °C to +110 °C) continuous Flammability UL94 HB Product Selection Article No. Part No. Type Min. Tensile Strength Length (L) Max. Ø Bundle Width (W) lbs. (N) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. WSS 111-12303 111-12303 WSS 120 lbs (534) 9.1″ (231.14) 2.25″ (57.15) .5″ (12.7) Black 60 111-12300 111-12300 WSS 120 lbs (534) 9.1″ (231.14) 2.25″ (57.15) .5″ (12.7) Black 300 111-12304 111-12304 WSI 120 lbs (534) 12.1″ (307.34) 3.25″ (82.55) .5″ (12.7) Black 60 111-12301 111-12301 WSI 120 lbs (534) 12.1″ (307.34) 3.25″ (82.55) .5″ (12.7) Black 300 WSI WSR 111-12305 111-12305 WSR 120 lbs (534) 15.1″ (383.54) 4.125″ (104.78) .5″ (12.7) Black 60 111-12302 111-12302 WSR 120 lbs (534) 15.1″ (383.54) 4.125″ (104.78) .5″ (12.7) Black 300 Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 13 Bundling and Securing C a b l e Ti e s Heavy Duty Cable Ties T250 Series These cable ties offer a high minimum tensile strength and have a buckle feature which allows the end of the cable tie to be tucked away if necessary. The buckle also snaps into HellermannTyton LTM, lashing tie mounts. T250 heavy duty cable tie and lashing tie mount application Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Min. Tensile Strength Article No. T250S Part No. Type lbs. (N) Length (L) in. Max. Ø Bundle (mm) in. (mm) Width (W) in. (mm) Color Pkg. Qty. 111-24702 T250S9X2 T250S 250 lbs (1115) 9.05″ (230) 2.17″ (55) .49″ (12.5) Natural 25 111-24700 T250S0X2 T250S 250 lbs (1115) 9.05″ (230) 2.17″ (55) .49″ (12.5) Black 25 111-24803 T250R9X2 T250R 250 lbs (1115) 20.47″ (520) 5.71″ (145) .49″ (12.5) Natural 25 111-24801 T250R0X2 T250R 250 lbs (1115) 20.47″ (520) 5.71″ (145) .49″ (12.5) Black 25 111-25002 T250M9X2 T250M 250 lbs (1115) 22.24″ (565) 5.90″ (150) .49″ (12.5) Natural 25 111-25001 T250M0X2 T250M 250 lbs (1115) 22.24″ (565) 5.90″ (150) .49″ (12.5) Black 25 T250R T250M T250I 111-25219 T250I9X2 T250I 250 lbs (1115) 28.54″ (725) 8.00″ (203) .49″ (12.5) Natural 25 111-00507 T250I0X2 T250I 250 lbs (1115) 28.54″ (725) 8.00″ (203) .49″ (12.5) Black 25 111-00436 T250L9X2 T250L 250 lbs (1115) 34.65″ (880) 10.00″ (254) .49″ (12.5) Natural 25 111-24601 T250L0X2 T250L 250 lbs (1115) 34.65″ (880) 10.00″ (254) .49″ (12.5) Black 25 T250L T250XL 111-00466 T250XL9X2 T250XL 250 lbs (1115) 40.55″ (1030) 12.00″ (305) .49″ (12.5) Natural 25 111-25200 T250XL0X2 T250XL 250 lbs (1115) 40.55″ (1030) 12.00″ (305) .49″ (12.5) Black 25 Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 14 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Heavy Duty Cable Ties T255 Series HellermannTyton’s T255 series heavy duty cable ties are ideal for bundles requiring a strong cable tie that may also require a higher temperature rating than the T250 series. These ties have a tensile strength of 250 lbs. Material Data Material Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Operating Temperature -40 °F to +230 °F (-40 °C to +110 °C) continuous Flammability UL94 HB File# E64139 Product Selection Min. Tensile Strength Article No. (N) Length (L) Max. Ø Bundle (mm) Width (W) Part No. Type lbs. in. (mm) in. in. (mm) Color Pkg. Qty. 111-25500 T255S0HIRX2 T255S 250 lbs (1115) 8.86″ (225) 2.16″ (55) .49″ (12.5) Black 25 111-25400 T255R0HIRX2 T255R 250 lbs (1115) 20.28″ (520) 5.71″ (145) .49″ (12.5) Black 25 111-25300 T255M0HIRX2 T255M 250 lbs (1115) 22.05″ (565) 6.30″ (160) .49″ (12.5) Black 25 Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 15 Bundling and Securing C a b l e Ti e s Standard Cable Ties T18R and T30R Series - Colors Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Min. Tensile Strength Article No. T18R Part No. Type lbs. (N) Length (L) in. (mm) Max. Ø Bundle in. (mm) File# E64139 Width (W) in. (mm) 116-01811 T18R1C2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01849 T18R1M4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01880 T18R2C2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01882 T18R2M4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 116-01813 T18R3C2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01877 T18R3M4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01896 T18R4C2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01898 T18R4M4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01853 T18R5C2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01855 T18R5M4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01842 T18R6C2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01845 T18R6M4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 116-01817 T18R7C2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01888 T18R7M4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01857 T18R8C2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01859 T18R8M4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 116-01819 T18R10C2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 111-01892 T18R10M4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) 116-03011 T30R1C2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03038 T30R1M4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 116-03012 T30R2C2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03056 T30R2M4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 116-03013 T30R3C2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03052 T30R3M4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 116-03014 T30R4C2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03065 T30R4M4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 116-03015 T30R5C2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03041 T30R5M4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) Color Brown Red Orange Yellow Green Blue Purple Gray White Pkg. Qty. 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 T30R 116-03016 T30R6C2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03036 T30R6M4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 116-03017 T30R7C2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03062 T30R7M4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 116-03018 T30R8C2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03061 T30R8M4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 111-03019 T30R10C2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) 116-03064 T30R10M4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) Brown Red Orange Yellow Green Blue Purple Gray White Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. MK9 and MK9P tools cannot be used to install T18S cable ties. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 16 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 Bundling and Securing C a b l e Ti e s Standard Cable Ties T50R and T50L Series - Colors Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Min. Tensile Strength Article No. T50R Part No. Type lbs. (N) Length (L) in. (mm) Max. Ø Bundle File# E64139 Width (W) in. (mm) in. (mm) 116-05011 T50R1C2 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04852 T50R1M4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 116-05012 T50R2C2 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04868 T50R2M4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 116-05013 T50R3C2 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04865 T50R3M4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 116-05014 T50R4C2 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04892 T50R4M4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 116-05015 T50R5C2 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04854 T50R5M4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 116-05016 T50R6C2 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04849 T50R6M4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 116-05017 T50R7C2 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04877 T50R7M4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04870 T50R8C2 T50R 50 lbs (225) 7.9″ (202) 1.97″ (50) .18″ (4.6) 111-04872 T50R8M4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 116-05019 T50R10C2 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-04879 T50R10M4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) 111-05443 T50L1C2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05444 T50L1M4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05457 T50L2C2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05458 T50L2M4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05451 T50L3C2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05454 T50L3M4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05467 T50L4C2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05468 T50L4M4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05445 T50L5C2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-00502 T50L5M4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) Color Brown Red Orange Yellow Green Blue Purple Gray White Pkg. Qty. 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 T50L 111-05431 T50L6C2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05434 T50L6M4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05464 T50L7C2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-00503 T50L7M4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05461 T50L8C2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05462 T50L8M4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05466 T50L10C2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) 111-05465 T50L10M4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) Brown Red Orange Yellow Green Blue Purple Gray White 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 100 1000 Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 17 Bundling and Securing C a b l e Ti e s Standard Cable Ties- Specialty Materials T18 -T120 Series - Heat Stabilized HellermannTyton's heat stabilized cable ties provide excellent resistance when exposed to high heat applications. Material Data Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 File# E64139 File# E64139 Product Selection Min. Tensile Strength Article No. T18S Part No. Type lbs. 111-02815 T18S0HSM4 T18S 18 lbs 111-01905 T18R0HSC2 T18R 111-00476 T18R0HSM4 T18R T18I0HSM4 111-00403 111-00404 (N) Length (L) Max. Ø Bundle in. (mm) in. (mm) (80) 3.27″ (83) .63″ (16) 18 lbs (80) 4″ (100) .87″ 18 lbs (80) 4″ (100) .87″ T18I 18 lbs (80) 5.5″ (140) T18L0HSC2 T18L 18 lbs (80) 8.0″ T18L0HSM4 T18L 18 lbs (80) 8.0″ Width (W) in. (mm) Color Pkg. Qty. .09″ (2.3) Black 1000 (22) .10″ (2.5) Black 100 (22) .10″ (2.5) Black 1000 1.38″ (35) .10″ (2.5) Black 1000 (205) 2.17″ (55) .10″ (2.5) Black 100 (205) 2.17″ (55) .10″ (2.5) Black 1000 T18R T18I 111-02305 T18L T30R 111-03067 T30R0HSC2 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) Black 100 111-03068 T30R0HSM4 T30R 30 lbs (135) 5.9″ (150) 1.38″ (35) .14″ (3.5) Black 1000 T50R 111-04900 T50R0HSC2 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) Black 100 111-04901 T50R0HSM4 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) Black 1000 111-05248 T50I0HSC2 T50I 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) Black 100 111-05251 T50I0HSM4 T50I 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) Black 1000 111-05470 T50L0HSC2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) Black 100 111-05471 T50L0HSM4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) Black 1000 111-12061 T120R0HSK2 T120R 120 lbs (535) 15.24″ (387) 4.13″ (105) .30″ (7.6) Black 50 111-12058 T120R0HSH4 T120R 120 lbs (535) 15.24″ (387) 4.13″ (105) .30″ (7.6) Black 500 T50I T50L T120R Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. (MK9, MK9HT, and MK9P tools cannot be used with T18S cable tie) Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 18 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Standard Cable Ties- Specialty Materials T18 -T50 Series - Flame Retardant HellermannTyton's flame retardant cable ties meet the UL 94V0 flammability requirements. Material Data Material Polyamide 6.6 V0 (PA66V0) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V0 File# E64139 File# E64139 Product Selection Min. Tensile Strength Article No. T18R Part No. Type lbs. (N) Length (L) in. Max. Ø Bundle (mm) Width (W) in. (mm) in. (mm) Color Pkg. Qty. 111-01834 T18R9VOC2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) White 100 111-01835 T18R9VOM4 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) White 1000 111-01833 T18R0VOC2 T18R 18 lbs (80) 4″ (100) .87″ (22) .10″ (2.5) Black 100 T18I9VOM4 T18I 18 lbs (80) 5.5″ (144) 1.38″ (35) .10″ (2.5) White 1000 111-02045 T18L9VOC2 T18L 18 lbs (80) 7.95″ (202) 2.17″ (55) .10″ (2.5) White 100 111-02046 T18L9VOM4 T18L 18 lbs (80) 7.95″ (202) 2.17″ (55) .10″ (2.5) White 1000 111-02044 T18L0VOC2 T18L 18 lbs (80) 7.95″ (202) 2.17″ (55) .10″ (2.5) Black 100 111-03073 T30R9VOC2 T30R 30 lbs (135) 5.83″ (148) 1.38″ (35) .14″ (3.6) White 100 111-03074 T30R9VOM4 T30R 30 lbs (135) 5.83″ (148) 1.38″ (35) .14″ (3.6) White 1000 111-03072 T30R0VOC2 T30R 30 lbs (135) 5.83″ (148) 1.38″ (35) .14″ (3.6) Black 100 111-04909 T50R9VOC2 T50R 50 lbs (225) 7.95″ (202) 1.97″ (50) .18″ (4.6) White 100 111-04911 T50R9VOM4 T50R 50 lbs (225) 7.95″ (202) 1.97″ (50) .18″ (4.6) White 1000 111-04887 T50R0VOC2 T50R 50 lbs (225) 7.95″ (202) 1.97″ (50) .18″ (4.6) Black 100 111-04908 T50R0VOM4 T50R 50 lbs (225) 7.95″ (202) 1.97″ (50) .18″ (4.6) Black 1000 111-05254 T50I9VOC2 T50I 50 lbs (225) 11.82″ (300) 3.35″ (85) .18″ (4.6) White 100 111-05255 T50I9VOM4 T50I 50 lbs (225) 11.82″ (300) 3.35″ (85) .18″ (4.6) White 1000 111-05258 T50I0VOC2 T50I 50 lbs (225) 11.82″ (300) 3.35″ (85) .18″ (4.6) Black 100 111-05438 T50L9VOC2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .19″ (4.7) White 100 111-05476 T50L9VOM4 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .19″ (4.7) White 1000 111-05475 T50L0VOC2 T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .19″ (4.7) Black 100 T18I 111-02304 T18L T30R T50R T50I T50L Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 19 Bundling and Securing C a b l e Ti e s Standard Cable Ties- Specialty Materials T18 -T120 Series - Polypropylene HellermannTyton's polypropylene cable ties offer added resistance to most chemicals. Material Data Material Polypropylene (PP) Operating Temperature -40 °F to +239 °F (-40 °C to +115 °C) continuous Flammability UL94 HB Product Selection Min. Tensile Strength Article No. T18R Part No. Type lbs. (N) Length (L) in. Max. Ø Bundle (mm) in. (mm) Width (W) in. (mm) Color Pkg. Qty. 111-01921 T18R9PPC2 T18R 11 lbs (49) 4″ (100) .75″ (19) .10″ (2.5) Natural 100 111-01922 T18R9PPM4 T18R 11 lbs (49) 4″ (100) .75″ (19) .10″ (2.5) Natural 1000 111-01917 T18R0PPC2 T18R 11 lbs (49) 4″ (100) .75″ (19) .10″ (2.5) Black 100 111-01918 T18R0PPM4 T18R 11 lbs (49) 4″ (100) .75″ (19) .10″ (2.5) Black 1000 T30R9PPC2 T30R 20 lbs (89) 5.83″ (148) 1.26″ (32) .14″ (3.6) Natural 100 111-04931 T50R9PPC2 T50R 30 lbs (133) 8.0″ (203.8) 1.75″ (44.5) .19″ (4.7) Natural 100 111-04928 T50R0PPC2 T50R 30 lbs (133) 8.0″ (203.8) 1.75″ (44.5) .19″ (4.7) Black 100 111-04929 T50R0PPM4 T50R 30 lbs (133) 8.0″ (203.8) 1.75″ (44.5) .19″ (4.7) Black 1000 T50I9PPM4 T50I 30 lbs (133) 11.8″ (300) 3.35″ (85) .18″ (4.6) Natural 1000 111-05483 T50L9PPM4 T50L 30 lbs (133) 15.35″ (390) 4.33″ (110) .18″ (4.7) Natural 1000 111-05482 T50L0PPC2 T50L 30 lbs (133) 15.35″ (390) 4.33″ (110) .18″ (4.7) Black 100 T30R 111-03017 T50R T50I 111-05262 T50L T120R 111-12067 T120R0PPK2 T120R 60 lbs (267) 15.35″ (390) 4.13″ (105) .30″ (7.6) Black 50 111-12066 T120R0PPH4 T120R 60 lbs (267) 15.35″ (390) 4.13″ (105) .30″ (7.6) Black 500 Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 20 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Cable Ties for Plenum Applications HellermannTyton halar and U.L. Listed cable ties meet NEC regulations and can be used in applications where low smoke and low flame are a concern in air handling spaces. Halar Cable Ties The raw material used to manufacture HellermannTyton halar cable ties is UL 94V0 rated. The halar ties come in a distinct color of red for easy identification. Material Data Material PA66HL Operating Temperature -104 °F to +300 °F (-76 °C to +150 °C) continuous Flammability UL94 V0 Product Selection Min. Tensile Strength Article No. Part No. Type lbs. Length (L) (N) in. Max. Ø Bundle (mm) Width (W) in. (mm) in. (mm) Color Pkg. Qty. 111-01900 T18R2HALC2 T18R 14 lbs (80) 4″ (100) .87″ (22) .10″ (2.45) Red 100 111-01902 T18R2HALM4 T18R 14 lbs (80) 4″ (100) .87″ (22) .10″ (2.45) Red 1000 111-04895 T50R2HALC2 T50R 40 lbs (177.9) 8.0″ (203.2) 1.75″ (44.45) .176″ (4.5) Red 100 111-04897 T50R2HALM4 T50R 40 lbs (177.9) 8.0″ (203.2) 1.75″ (44.45) .176″ (4.5) Red 1000 111-12056 T120R2HALK2 T120R 80 lbs (355.9) 15.5″ (394.4) 4.0″ (101.6) .31″ (7.8) Red 50 111-12055 T120R2HALH4 T120R 80 lbs (355.9) 15.5″ (394.4) 4.0″ (101.6) .31″ (7.8) Red 500 Note: Halar ties are also available in natural color. Contact HellermannTyton for availability. Halar is a registered trademark of Solvay S.A. Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Type for specification purposes. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Material Data UL Rated Cable Ties Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Min. Tensile Strength Article No. Part No. Type lbs. 111-00508 T18R9C2UL T18R 18 lbs 111-00509 T18R9M4UL T18R 18 lbs 111-00510 T18R2C2UL T18R 111-00511 T18R2M4UL T18R 111-00512 T50R9C2UL 111-00513 T50R9M4UL 111-00514 111-00515 (N) Length (L) Max. Ø Bundle File# E64139 Width (W) (mm) in. (mm) in. (mm) (80) 4″ (100) .86″ (22) .10″ (2.5) Natural 100 (80) 4″ (100) .86″ (22) .10″ (2.5) Natural 1000 18 lbs (80) 4″ (100) .86″ (22) .10″ (2.5) Red 100 18 lbs (80) 4″ (100) .86″ (22) .10″ (2.5) Red 1000 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) Natural 100 T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) Natural 1000 T50R2C2UL T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) Red 100 T50R2M4UL T50R 50 lbs (225) 7.9″ (200) 1.97″ (50) .18″ (4.6) Red 1000 111-00516 T50I9C2UL T50I 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) Natural 100 111-00517 T50I9M4UL T50I 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) Natural 1000 111-00518 T50I2C2UL T50I 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) Red 100 111-00519 T50I2M4UL T50I 50 lbs (225) 11.8″ (300) 3.35″ (85) .18″ (4.6) Red 1000 111-00520 T50L9C2UL T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) Natural 100 111-00521 T50L9M4UL T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) Natural 1000 111-00522 T50L2C2UL T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) Red 100 111-00523 T50L2M4UL T50L 50 lbs (225) 15.35″ (390) 4.33″ (110) .18″ (4.6) Red 1000 Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Type for specification purposes. Color Pkg. Qty. in. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 21 Bundling and Securing C a b l e Ti e s Tefzel® Cable Ties Tefzel ties provide excellent protection against radiation, ultraviolet light, and a wide range of chemicals. They are also rated for low outgassing applications. HellermannTyton’s Tefzel ties come in a standard color of blue for easy identification. Material Data Material Ethylenterafluorineethylene Tefzel (E/TFE) Operating Temperature -112 °F to +302 °F (-80 °C to +150 °C) continuous Flammability UL94 V0 Product Selection Min. Tensile Strength Article No. Part No. Length (L) (N) in. Max. Ø Bundle (mm) Width (W) Type lbs. in. (mm) in. (mm) Color 111-01923 T18R6TZC2 T18R(U) 9.0 lbs (40) 4″ (100) .87″ (22) .10″ (2.5) Blue Pkg. Qty. 100 111-01924 T18R6TZM4 T18R(U) 9.0 lbs (40) 4″ (100) .87″ (22) .10″ (2.5) Blue 1000 111-05026 T50R6TZC2 T50R(U) 35.5 lbs (158) 8″ (200) 1.75″ (50) .18″ (4.6) Blue 100 111-04933 T50R6TZM4 T50R(U) 35.5 lbs (158) 8″ (200) 1.75″ (50) .18″ (4.6) Blue 1000 111-12026 T120R6TZK2 T120R 70 lbs (311) 15″ (380) 4.0″ (100) .30″ (7.6) Blue 50 Tefzel is a registered trademark of E.I. DuPont Corporation. Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Outside Serrated Cable Ties The outside serrated cable ties are for specific applications where thin walled or soft insulation is used (such as in aircraft, trains, etc.) and for applications that are very sensitive to the amount of force applied to the cable. Material Data Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 Outside serrated cable ties are also available in natural. Contact HellermannTyton for more information. Product Selection Min. Tensile Strength Article No. Part No. Type lbs. (N) Max. Ø Bundle Width (W) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. 118-04700 118-04700 T18ROS 18 lbs (80) 3.94″ (100) .79″ (20) .10″ (2.5) Black 100 118-04800 118-04800 T30ROS 30 lbs (135) 5.71″ (145) 1.34″ (35) .13″ (3.4) Black 100 118-04900 118-04900 T30LOS 30 lbs (135) 7.87″ (200) 2.0″ (50) .13″ (3.4) Black 100 118-05850 118-05850 T50SOS 50 lbs (225) 5.9″ (150) 1.38″ (35) .18″ (4.6) Black 100 118-05050 118-05050 T50ROS 50 lbs (225) 8″ (200) 1.95″ (50) .18″ (4.6) Black 100 118-05900 118-05900 T50LOS 50 lbs (225) 15″ (384) 4.29″ (110) .18″ (4.6) Black 100 Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Type for specification purposes. 22 Length (L) Dimensions are approximate and subject to technical changes. Use Part No. for ordering and w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Releasable Ties The extended pawl allows for simple and quick release of the ties. Perfect for prototype construction and service requiring the addition of wires on existing harnesses. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 RT50S and RT50LL RT40R File# E64139 Product Selection Min. Tensile Strength Article No. RT40R Part No. Type lbs. (N) Length (L) in. Max. Ø Bundle (mm) Width (W) in. (mm) in. (mm) 115-06219 RT40R9C2 RT40R 34 lbs (150) 8.46″ (215) 2.0″ (51) .16″ (4.0) 115-06204 RT40R9M4 RT40R 34 lbs (150) 8.46″ (215) 2.0″ (51) .16″ (4.0) 115-06200 RT40R0C2 RT40R 34 lbs (150) 8.46″ (215) 2.0″ (51) .16″ (4.0) 115-06202 RT40R0M4 RT40R 34 lbs (150) 8.46″ (215) 2.0″ (51) .16″ (4.0) Color Natural Black Pkg. Qty. 100 1000 100 1000 RT50S 115-06319 RT50S9C2 RT50S 50 lbs (225) 6.5″ (165) 1.38″ (35) .18″ (4.6) 115-06304 RT50S9M4 RT50S 50 lbs (225) 6.5″ (165) 1.38″ (35) .18″ (4.6) 115-06300 RT50S0C2 RT50S 50 lbs (225) 6.5″ (165) 1.38″ (35) .18″ (4.6) 115-00035 RT50S0M4 RT50S 50 lbs (225) 6.5″ (165) 1.38″ (35) .18″ (4.6) Natural Black 100 1000 100 1000 RT50LL 115-06102 RT50LL9C2 RT50LL 50 lbs (225) 15″ (380) 3.98″ (101) .18″ (4.6) 115-06104 RT50LL9M4 RT50LL 50 lbs (225) 15″ (380) 3.98″ (101) .18″ (4.6) 115-00039 RT50LL0C2 RT50LL 50 lbs (225) 15″ (380) 3.98″ (101) .18″ (4.6) 115-06101 RT50LL0M4 RT50LL 50 lbs (225) 15″ (380) 3.98″ (101) .18″ (4.6) Natural Black 100 1000 100 1000 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 23 Bundling and Securing C a b l e Ti e s REL Releasable Ties Ideal for use in applications where there is the need to repeatedly open and close the tie. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Min. Tensile Strength Article No. Part No. Type lbs. (N) Length (L) Max. Ø Bundle in. (mm) in. (mm) Width (W) in. (mm) Color Pkg. Qty. REL50R 115-00503 REL50R9C2 REL50R 50 lbs (225) 5.5″ (140) 1.38″ (35) .29″ (7.4) 115-00505 REL50R9L4 REL50R 50 lbs (225) 5.5″ (140) 1.38″ (35) .29″ (7.4) 115-00500 REL50R0C2 REL50R 50 lbs (225) 5.5″ (140) 1.38″ (35) .29″ (7.4) 115-00502 REL50R0L4 REL50R 50 lbs (225) 5.5″ (140) 1.38″ (35) .29″ (7.4) 115-00605 REL50L9C2 REL50L 50 lbs (225) 9.84″ (250) 2.76″ (70) .29″ (7.4) 115-00607 REL50L9L4 REL50L 50 lbs (225) 9.84″ (250) 2.76″ (70) .29″ (7.4) 115-00600 REL50L0C2 REL50L 50 lbs (225) 9.84″ (250) 2.76″ (70) .29″ (7.4) 115-00602 REL50L0L4 REL50L 50 lbs (225) 9.84″ (250) 2.76″ (70) .29″ (7.4) Natural Black 100 200 100 200 REL50L Natural Black 100 200 100 200 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Pinch Releasable Ties Patented pinch release mechanism for easy handling allows tie to be released using one hand. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Min. Tensile Strength Article No. Part No. Type lbs. (N) Length (L) in. Max. Ø Bundle Width (W) (mm) in. (mm) in. (mm) Color Pkg. Qty. 115-40200 REZ200.NB3P REZ200 30 lbs (135) 7.88″ (200) 1.97″ (50) .19″ (4.7) Black 100 115-40300 REZ300.NB3P REZ300 30 lbs (135) 12.00″ (305) 3.15″ (80) .19″ (4.7) Black 100 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 24 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Heavy Duty Releasable Cable Ties The RT150 and RT250 heavy duty releasable cable ties feature an extended pawl which allows for simple and quick release of the ties. Material Data RT150 Heavy Duty Releasable Cable Ties Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Min. Tensile Strength (mm) in. (mm) Color Pkg. Qty. 175 lbs (780) 15.35″ (390) 4″ (105) .346″ (8.8) Black 25 115-00037 RT150MEP0X2 RT150MEP 175 lbs (780) 21.06″ (535) 5.90″ (150) .346″ (8.8) Black 25 115-00038 RT150LEP0X2 RT150LEP 175 lbs (780) 32.28″ (820) 9.65″ (245) .346″ (8.8) Black 25 Type in. (mm) in. Width (W) RT150REP Part No. (N) Max. Ø Bundle 115-00036 RT150REP0X2 Article No. lbs. Length (L) Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. RT250 Heavy Duty Releasable Cable Ties Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Min. Tensile Strength Article No. Part No. Type lbs. (N) Length (L) in. (mm) Max. Ø Bundle in. (mm) Width (W) in. (mm) Color Pkg. Qty. RT250S 131-75819 RT250S9X2 RT250S 250 lbs (1115) 9.05″ (230) 2.17″ (55) .49″ (12.5 ) Natural 25 115-41800 RT250S0X2 RT250S 250 lbs (1115) 9.05″ (230) 2.17″ (55) .49″ (12.5 ) Black 25 RT250R 131-75019 RT250R9X2 RT250R 250 lbs (1115) 20.47″ (520) 5.71″ (145) .49″ (12.5) Natural 25 115-41300 RT250R0X2 RT250R 250 lbs (1115) 20.47″ (520) 5.71″ (145) .49″ (12.5 ) Black 25 RT250M 131-75619 RT250M9X2 RT250M 250 lbs (1115) 22.24″ (565) 5.90″ (150) .49″ (12.5 ) Natural 25 131-75610 RT250M0X2 RT250M 250 lbs (1115) 22.24″ (565) 5.90″ (150) .49″ (12.5 ) Black 25 RT250I 131-75219 RT250I9X2 RT250I 250 lbs (1115) 28.54″ (725) 8.00″ (203) .49″ (12.5 ) Natural 25 115-41401 RT250I0X2 RT250I 250 lbs (1115) 28.54″ (725) 8.00″ (203) .49″ (12.5 ) Black 25 131-75419 RT250L9X2 RT250L 250 lbs (1115) 34.65″ (880) 10.00″ (254) .49″ (12.5) Natural 25 115-41500 RT250L0X2 RT250L 250 lbs (1115) 34.65″ (880) 10.00″ (254) .49″ (12.5 ) Black 25 RT250L RT250XL 131-75519 RT250XL9X2 RT250XL 250 lbs (1115) 40″ (1016.0) 12″ (304.8) .49″ (12.5 ) Natural 25 131-75510 RT250XL0X2 RT250XL 250 lbs (1115) 40″ (1016.0) 12″ (304.8) .49″ (12.5 ) Black 25 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 25 Bundling and Securing C a b l e Ti e s Heavy Duty Releasable Cable Ties RT255 Heavy Duty Releasable Ties Material Data Material Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Operating Temperature -40 °F to +230 °F (-40 °C to +110 °C) continuous Flammability UL94 HB Product Selection Min. Tensile Strength Article No. Part No. Type lbs. Length (L) (N) Max. Ø Bundle Width (W) in. (mm) in. (mm) in. Color Pkg. Qty. 115-01200 RT255S0HIRX2 RT255S 250 lbs (1112) 8.86″ (225) 2.16″ (55) .49″ (12.5) (mm) Black 25 115-01300 RT255R0HIRX2 RT255R 250 lbs (1112) 20.28″ (515) 5.71″ (145) .49″ (12.5) Black 25 115-01400 RT255M0HIRX2 RT255M 250 lbs (1112) 22.05″ (560) 6.30″ (160) .49″ (12.5) Black 25 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. SR255 Heavy Duty Sub-Releasable Ties Material Data The SR255 series releasable heavy duty cable tie offers a release that is lower than the head of the cable tie, facilitating easy installation with the use of a HellermannTyton cable tie tool. Material Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Operating Temperature -40 °F to +230 °F (-40 °C to +110 °C) continuous Flammability UL94 HB Product Selection Min. Tensile Strength Width (W) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. SR255S 250 lbs (1112) 8.86″ (225) 2.16″ (50) .49″ (12.5) Black 25 115-42101 SR255X0HIHSUVX2 SR255X 250 lbs (1112) 14″ (372) 3.94″ (100) .49″ (12.5) Black 25 Part No. Type (N) Max. Ø Bundle 115-42002 SR255S0HIHSUVX2 Article No. lbs. Length (L) Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 26 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Speedy Tie An entirely new design in cable management, the SpeedyTie is a fully re-usable, easily releasable lashing tie. The SpeedyTie’s unique design allows it to be released with one hand. - Just one click to tie and untie Fully re-usable Once applied, the tail can be neatly tucked away for added safety Highly visible yellow color — also available in black, high impact modified material Versatile design allows use for multiple applications The SpeedyTie is a versatile tool for countless applications: - Electrical Contractors - Heating & Ventilation Contractors - Residential Construction - General and Heavy Industry - Packaging - Tubing and Pipe Bundling - An “Extra Hand” for Overhead Installations - In Plant Transfer of Products Speedy Tie is particularly suited for SpeedyTie - Quick and easy. temporary but safe bundling or fixing. Packaging Configurations Material Data Material Color Polyamide 6.6 (PA66) Yellow , Red Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Distributor Packs - Printed bag with a hang hole - Display box - 60 SpeedyTies - 12 bags of 5 OEM Packs - Plain bag (no hang hole) - Standard box - 300 SpeedyTies - 12 bags of 25 Distributor Pack - point of purchase display for the SpeedyTie. Product Selection Min. Tensile Strength Article No. Part No. Type 115-00001 RTT750HR.NX900 RTT750HR 115-00000 RTT750HR.NX1P RTT750HR Description lbs. (N) Distributor Pack - order 200 lbs (888) in carton qty. only OEM Pack - order in carton qty. only 200 lbs (888) Max. Ø Bundle Width (W) (mm) in. (mm) in. (mm) 29.52″ (750) 8.27″ (210) .51″ 29.52″ (750) 8.27″ (210) .51″ Length (L) in. Pkg. Qty. Carton Qty. (13) 5 60 (13) 25 300 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 27 Bundling and Securing C a b l e Ti e s Clamp Ties The clamp tie has triangular shaped tabs extending beneath the head, allowing for optimal surface contact and complete circumferential compression to 360 degrees. The clamps are recommended for soft rubber hose applications including fuel, water, and air vacuum lines. Material Data Color Natural Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Material Data Color Black Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Min. Tensile Strength Article No. CTT20R Part No. Type lbs. Length (L) (N) in. Max. Ø Bundle (mm) in. (mm) Width (W) in. (mm) 112-51919 CTT20R9C2 CTT20R 20 lbs (90) 4″ (100) .50″ (13) .10″ (2.5) 112-51904 CTT20R9M4 CTT20R 20 lbs (90) 4″ (100) .50″ (13) .10″ (2.5) 112-51905 CTT20R0HSC2 CTT20R 20 lbs (90) 4″ (100) .50″ (13) .10″ (2.5) 112-51960 CTT20R0HSM4 CTT20R 20 lbs (90) 4″ (100) .50″ (13) .10″ (2.5) Color Natural Black Pkg. Qty. 100 1000 100 1000 CTT60R 112-52104 CTT60R9C2 CTT60R 60 lbs (265) 8″ (205) 1.77″ (45) .19″ (4.7) 112-52106 CTT60R9M4 CTT60R 60 lbs (265) 8″ (205) 1.77″ (45) .19″ (4.7) 112-52112 CTT60R0HSC2 CTT60R 60 lbs (265) 8″ (205) 1.77″ (45) .19″ (4.7) 112-52114 CTT60R0HSM4 CTT60R 60 lbs (265) 8″ (205) 1.77″ (45) .19″ (4.7) Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Type for specification purposes. 28 Natural Black 100 1000 100 1000 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Double Head Ties Designed to harness two bundles simultaneously. The second loop may also serve as a positioning device for a single bundle. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Min. Tensile Strength Article No. Part No. Type lbs. (N) Length (L) in. (mm) Width (W) in. (mm) Color Pkg. Qty. T50SDH 117-00016 117-00016 T50SDH 50 lbs (225) 6.26″ (159) .19″ (4.7) 117-00017 117-00017 T50SDH 50 lbs (225) 6.26″ (159) .19″ (4.7) 117-00018 117-00018 T50SDH 50 lbs (225) 6.26″ (159) .19″ (4.7) 117-00019 117-00019 T50SDH 50 lbs (225) 6.26″ (159) .19″ (4.7) 117-05006 T50RDH9C2 T50RDH 50 lbs (225) 8.25″ (210) .19″ (4.7) 117-05008 T50RDH9M4 T50RDH 50 lbs (225) 8.25″ (210) .19″ (4.7) Natural Black 100 1000 100 1000 T50RDH 117-05004 T50RDH0C2 T50RDH 50 lbs (225) 8.25″ (210) .19″ (4.7) 117-05005 T50RDH0M4 T50RDH 50 lbs (225) 8.25″ (210) .19″ (4.7) 117-05302 T50IDH9C2 T50IDH 50 lbs (225) 12″ (305) .19″ (4.7) 117-05303 T50IDH9M4 T50IDH 50 lbs (225) 12″ (305) .19″ (4.7) 117-05362 T50IDH0C2 T50IDH 50 lbs (225) 12″ (305) .19″ (4.7) 117-05300 T50IDH0M4 T50IDH 50 lbs (225) 12″ (305) .19″ (4.7) Natural Black 100 1000 100 1000 T50IDH Natural Black 100 1000 100 1000 T50LDH 117-05402 T50LDH9C2 T50LDH 50 lbs (225) 15.5″ (395) .19″ (4.7) 117-05461 T50LDH9M4 T50LDH 50 lbs (225) 15.5″ (395) .19″ (4.7) 117-05400 T50LDH0C2 T50LDH 50 lbs (225) 15.5″ (395) .19″ (4.7) 117-05401 T50LDH0M4 T50LDH 50 lbs (225) 15.5″ (395) .19″ (4.7) Natural Black 100 1000 100 1000 Maximum bundle diameter is variable due to double loops. Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 29 Bundling and Securing C a b l e Ti e s Identification Ties Tie and identify bundles of cable in one operation. Large flat area for imprinting or writing the required information. Hot stamping available, which is subject to minimums and lead times. IT50RD IT18R IT18FL IT50RT IT50R IT50L Material Data Material HellermannTyton offers marking pens for use with the identification ties, see page 179. Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Article No. IT18R Part No. Type Min. Tensile Strength US Gov. Designation lbs. (N) Length (L) Max. Ø Bundle Width (W) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. 100 Marking Pad Size: .98″″ x .32″″ (25 x 8) 111-81819 IT18R9C2 IT18R MS3368-5-9E 18 lbs (80) 3.94″ (100) .75″ (22.0) .09″ (2.3) Natural 111-81808 IT18R9L4 IT18R MS3368-5-9E 18 lbs (80) 3.94″ (100) .75″ (22.0) .09″ (2.3) Natural 200 111-81801 IT18R0C2 IT18R * 18 lbs (80) 3.94″ (100) .75″ (22.0) .09″ (2.3) Black 100 111-81803 IT18R0L4 IT18R * 18 lbs (80) 3.94″ (100) .75″ (22.0) .09″ (2.3) Black 200 100 IT18FL Marking Pad Size: .81″″ x .35″″ (20.5 x 9) 111-81919 IT18FL9C2 IT18FL – 18 lbs (80) 4.33″ (110) .75″ (19.0) .10″ (2.5) Natural 111-81907 IT18FL9L4 IT18FL – 18 lbs (80) 4.33″ (110) .75″ (19.0) .10″ (2.5) Natural 200 111-81910 IT18FL0C2 IT18FL – 18 lbs (80) 4.33″ (110) .75″ (19.0) .10″ (2.5) Black 100 111-81903 IT18FL0L4 IT18FL – 18 lbs (80) 4.33″ (110) .75″ (19.0) .10″ (2.5) Black 200 IT50R Marking Pad Size: 1.10″″ x .51″″ (28 x 12.9) 111-85019 IT50R9C2 IT50R MS3368-1-9A 50 lbs (225) 7.99″ (203) 1.75″ (44.5) .18″ (4.6) Natural 100 111-85020 IT50R9M4 IT50R MS3368-1-9A 50 lbs (225) 7.99″ (203) 1.75″ (44.5) .18″ (4.6) Natural 1000 111-85011 IT50R0C2 IT50R * 50 lbs (225) 7.99″ (203) 1.75″ (44.5) .18″ (4.6) Black 100 111-85013 IT50R0M4 IT50R * 50 lbs (225) 7.99″ (203) 1.75″ (44.5) .18″ (4.6) Black 1000 IT50RD Marking Pad Size: 1.14″″ x 1.04″″ (46 x 26.3) 111-85219 IT50RD9K2 IT50RD MS3368-3-9C 50 lbs (225) 8.07″ (205) 1.73″ (44.0) .19″ (4.7) Natural 50 111-85201 IT50RD0K2 IT50RD 50 lbs (225) 8.07″ (205) 1.73″ (44.0) .19″ (4.7) Black 50 IT50RT * Marking Pad Size: 1.18″″ x 1.04″″ (46 x 26.3) 111-85119 IT50RT9K2 IT50RT MS3368-4-9D 50 lbs (225) 8.07″ (205) 1.73″ (44.0) .19″ (4.7) Natural 50 111-85100 IT50RT0K2 IT50RT * 50 lbs (225) 8.07″ (205) 1.73″ (44.0) .19″ (4.7) Black 50 IT50L Marking Pad Size: .5″″ x 2.20″″ (12.8 x 56) 111-85319 IT50L9C2 IT50L MS3368-2-9A 50 lbs (225) 15.35″ (390) 3.94″ (100) .19″ (4.7) Natural 100 111-85306 IT50L9M4 IT50L MS3368-2-9A 50 lbs (225) 15.35″ (390) 3.94″ (100) .19″ (4.7) Natural 1000 Installation tools - MK7, MK7P, MK7HT, MK9. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. * Military black available. Contact HellermannTyton for more information. 30 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Screw Mount Ties One-piece, all plastic ties for quick, simple cable mounting. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Article No. T18MR Part No. Type Mounting Min. Tensile Strength lbs. (N) Length (L) in. (mm) Max. Ø Bundle in. (mm) Width (W) in. (mm) Color Pkg. Qty. 113-00026 T18MR9C2 T18MR 18 lbs (80) 4.33″ (110) .79″ (20) .10″ (2.5) Natural 100 113-00028 T18MR9M4 T18MR 18 lbs (80) 4.33″ (110) .79″ (20) .10″ (2.5) Natural 1000 113-00022 T18MR0C2 T18MR 18 lbs (80) 4.33″ (110) .79″ (20) .10″ (2.5) Black 100 113-00024 T18MR0M4 T18MR 18 lbs (80) 4.33″ (110) .79″ (20) .10″ (2.5) Black 1000 113-03019 T30MR9C2 T30MR 30 lbs (135) 6.30″ (160) 1.26″ (32) .14″ (3.5) Natural 100 113-00036 T30MR9M4 T30MR 30 lbs (135) 6.30″ (160) 1.26″ (32) .14″ (3.5) Natural 1000 113-03010 T30MR0C2 T30MR 30 lbs (135) 6.30″ (160) 1.26″ (32) .14″ (3.5) Black 100 113-03011 T30MR0M4 T30MR 30 lbs (135) 6.30″ (160) 1.26″ (32) .14″ (3.5) Black 1000 113-05004 T50MR9C2 T50MR 48 lbs (215) 8.46″ (215) 1.77″ (45) .18″ (4.6) Natural 100 113-05007 T50MR9M4 T50MR 48 lbs (215) 8.46″ (215) 1.77″ (45) .18″ (4.6) Natural 1000 113-05000 T50MR0C2 T50MR 48 lbs (215) 8.46″ (215) 1.77″ (45) .18″ (4.6) Black 100 113-05002 T50MR0M4 T50MR 48 lbs (215) 8.46″ (215) 1.77″ (45) .18″ (4.6) Black 1000 50 lbs (225) 8.47″ (215) 1.77″ (45) .19″ (4.7) Natural 100 50 lbs (225) 8.47″ (215) 1.77″ (45) .19″ (4.7) Natural 1000 50 lbs (225) 8.47″ (215) 1.77″ (45) .19″ (4.7) Black 100 50 lbs (225) 8.47″ (215) 1.77″ (45) .19″ (4.7) Black 1000 # 4 screw T30MR # 8 screw T50MR # 10 screw T50MRT 113-05101 T50MRT9C2 T50MRT 113-05102 T50MRT9M4 T50MRT 113-05100 T50MRT0C2 T50MRT #6-32 tap thru screw 113-00037 T50MRT0M4 T50MRT T50MI 113-00032 T50MI9C2 T50MI 50 lbs (225) 12.40″ (315) 3.35″ (85) .19″ (4.7) Natural 100 113-00033 T50MI9M4 T50MI 50 lbs (225) 12.40″ (315) 3.35″ (85) .19″ (4.7) Natural 1000 113-00038 T50MI0C2 T50MI 50 lbs (225) 12.40″ (315) 3.35″ (85) .19″ (4.7) Black 100 113-00031 T50MI0M4 T50MI 50 lbs (225) 12.40″ (315) 3.35″ (85) .19″ (4.7) Black 1000 113-05419 T50ML9C2 T50ML 50 lbs (225) 15.35″ (390) 4.00″ (100) .18″ (4.6) Natural 100 113-05403 T50ML9M4 T50ML 50 lbs (225) 15.35″ (390) 4.00″ (100) .18″ (4.6) Natural 1000 113-00007 T50ML0C2 T50ML 50 lbs (225) 15.35″ (390) 4.00″ (100) .18″ (4.6) Black 100 113-00035 T50ML0M4 T50ML 50 lbs (225) 15.35″ (390) 4.00″ (100) .18″ (4.6) Black 1000 120 lbs (535) 15.55″ (395) 4.02″ (102) .30″ (7.6) Natural 50 120 lbs (535) 15.55″ (395) 4.02″ (102) .30″ (7.6) Natural 500 120 lbs (535) 15.55″ (395) 4.02″ (102) .30″ (7.6) Black 50 120 lbs (535) 15.55″ (395) 4.02″ (102) .30″ (7.6) Black 500 # 10 screw T50ML # 10 screw T120MR 113-12029 T120MR9K2 T120MR 113-00018 T120MR9H4 T120MR 113-12020 T120MR0K2 T120MR 113-00011 T120MR0H4 T120MR #1/4″ screw Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. and Type for specification purposes. Dimensions are approximate and subject to technical changes. Use Part No. for ordering w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 31 Bundling and Securing C a b l e Ti e s Fir Tree Mount and Cable Tie Assemblies HellermannTyton's fir tree mounts provide a secure grip in a mounting hole and protect against dirt and other impurities. The mount can slide along the strap of the tie for proper orientation. The fir tree mounts are designed to provide a low insertion force and high extraction force. These mounts are sold as an assembly with the cable tie. Material Data - All Cable Ties/ FT7, FT8 and FT10 Mounts Material Operating Temperature Color Material Data - FT5, FT6 and FT6LG Mounts Polyamide 6.6 heat stabilized (PA66HS) Material -40 °F to +221 °F (-40 °C to +105 °C) Operating Temperature Black Color Flammability Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) -40 °F to +230 °F (-40 °C to +110 °C) Black UL94 V2 Flammability UL94 HB Product Selection Cable Tie Article No. Part No. Type Min. Tensile Strength lbs. (N) Max. Ø Length (L) Bundle in. in. (mm) (mm) Mount Width (W) in. (mm) Disc Ø in. (mm) Length (L2) in. (mm) Length (L3) in. (mm) Width (W3) in. (mm) Height (H2) in. (mm) .52 ″ (13.2) .52 ″ (13.2) .20 ″ (5) .20 ″ (5) .27 ″ (6.9) .27 ″ (6.9) .54 ″ (13.8) .54 ″ (13.8) .54 ″ (13.8) .54 ″ (13.8) .20 ″ (5) .20 ″ (5) .20 ″ (5) .20 ″ (5) .295 ″ (7.5) .295 ″ (7.5) .295 ″ (7.5) .295 ″ (7.5) Pkg. Qty. FT5 - Mounting Hole Ø: .177″″ - .197″″ (4.5-5.0mm) - Panel Thickness: .028″″ - .193″″ (0.7 - 3.0mm) 150-55850 150-55850 T30RFT5 156-00025 156-00025 T50RFT5 30 lbs (135) 50 lbs (225) 1.38 ″ (35) 1.75 ″ (44.5) 5.8 ″ (148) 8″ (203.2) .14 ″ (3.6) .18 ″ (4.6) .63 ″ (16.0) .63 ″ (16.0) .46 ″ (11.6) .46 ″ (11.6) 500 500 FT6 - Mounting Hole Ø: .252″″ - .28″″ (6.4-7.1mm) - Panel Thickness: .028″″ - .193″″ (0.75 - 3.0mm) 150-77940 150-77940 T30RFT6 156-00156 156-00156 T50SFT6 156-00157 156-00157 T50RFT6 156-00066 156-00066 T50LFT6 30 lbs (135) 50 lbs (225) 50 lbs (225) 50 lbs (225) Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Type for specification purposes. 32 1.38 ″ (35) 1.38 ″ (35) 1.75 ″ (44.5) 4″ (101.6) 5.8 ″ (148) 6.3 ″ (160) 8″ (203.2) 15 ″ (380) .14 ″ (3.6) .18 ″ (4.6) .18 ″ (4.6) .18 ″ (4.7) .63 ″ (16.0) .63 ″ (16.0) .63 ″ (16.0) .63 ″ (16) .46 ″ (11.6) .46 ″ (11.6) .46 ″ (11.6) .46 ″ (11.6) 500 500 500 500 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Fir Tree Mount and Cable Tie Assemblies continued Product Selection Cable Tie Article No. Part No. Type Max. Ø Min. Tensile Bundle in. Strength (mm) lbs. (N) Length (L) in. (mm) Width (W) in. (mm) Mount Disc Ø in. (mm) Length (L2) in. (mm) Length (L3) in. (mm) Width Height (H2) (W3) in. in. (mm) (mm) Pkg. Qty. FT6LG - Mounting Hole Ø: .256″″ - .276″″ (6.4-7.1mm) - Panel Thickness: .03″″ - .24″″ (0.75 - 6.0mm) 150-31090 150-31090 T30RFT6LG 30 lbs (135) 1.38 ″ (35) 5.8 ″ (148) .14 ″ (3.6) .63 ″ (16) .46 ″ (11.6) .69 ″ (17.5) .19 ″ (5) .44 ″ (11.1) 500 150-31093 150-31093 T50SFT6LG 50 lbs (225) 1.38 ″ (35) 6.3 ″ (160) .18 ″ (4.6) .63 ″ (16) .46 ″ (11.6) .69 ″ (17.5) .19 ″ (5) .44 ″ (11.1) 500 150-31091 150-31091 T50RFT6LG 50 lbs (225) 1.75 ″ (44) 8″ (203.2) .18 ″ (4.6) .63 ″ (16) .46 ″ (11.6) .69 ″ (17.5) .19 ″ (5) .44 ″ (11.1) 500 156-00054 156-00054 T50IFT6LG 50 lbs (225) 3.35 ″ (85) 11.8 ″ (300) .18 ″ (4.6) .63 ″ (16) .46 ″ (11.6) .69 ″ (17.5) .19 ″ (5) .44 ″ (11.1) 500 FT7 - Mounting Hole Ø: .256″″ - .276″″ (6.5-7.0mm) - Panel Thickness: .031″″ - .276″″ (0.8 - 7.0mm) 156-00057 156-00057 T30RFT7 30 lbs (135) 1.38 ″ (35) 5.8 ″ (148) .14 ″ (3.6) .63 ″ (16) .46 ″ (11.6) .75 ″ (19) .20 ″ (5) .5 ″ (12.7) 500 156-00056 156-00056 T50SFT7 50 lbs (225) 1.38 ″ (35) 6.3 ″ (160) .18 ″ (4.6) .63 ″ (16) .46 ″ (11.6) .75 ″ (19) .20 ″ (5) .5 ″ (12.7) 500 111-85871 111-85871 T50RFT7 50 lbs (225) 1.75 ″ (44) 8″ (203.2) .18 ″ (4.6) .63 ″ (16) .46 ″ (11.6) .75 ″ (19) .20 ″ (5) .5 ″ (12.7) 500 111-05350 111-05350 T50IFT7 50 lbs (225) 3.35 ″ (85) 11.8 ″ (300) .18 ″ (4.6) .63 ″ (16) .46 ″ (11.6) .75 ″ (19) .20 ″ (5) .5 ″ (12.7) 500 156-00055 156-00055 T50LFT7 50 lbs (225) 4.33 ″ (110) 15 ″ (380) .18 ″ (4.7) .63 ″ (16) .46 ″ (11.6) .75 ″ (19) .20 ″ (5) .5 ″ (12.7) 500 FT8 - Mounting Hole Ø: .3″″ - .31″″ (7.7-8.0mm) - Panel Thickness: .03″″ - .31″″ (0.8 - 8.0mm) 156-00058 156-00058 T30RFT8 30 lbs (135) 1.38 ″ (35) 5.8 ″ (148) .14 ″ (3.6) .63 ″ (16) .47 ″ (12.0) .7 ″ (17.8) .35 ″ (9) .45 ″ (11.5) 500 156-00158 156-00158 T50RFT8 50 lbs (225) 1.75 ″ (44) 8″ (203.2) .18 ″ (4.6) .63 ″ (16) .47 ″ (12.0) .7 ″ (17.8) .35 ″ (9) .45 ″ (11.5) 500 156-00060 156-00060 T50IFT8 50 lbs (225) 3.35 ″ (81) 11.8 ″ (300) .18 ″ (4.6) .63 ″ (16) .47 ″ (12.0) .7 ″ (17.8) .35 ″ (9) .45 ″ (11.5) 500 156-00061 156-00061 T50LFT8 50 lbs (225) 4.33 ″ (110) 15 ″ (380) .18 ″ (4.7) .63 ″ (16) .47 ″ (12.0) .7 ″ (17.8) .35 ″ (9) .45 ″ (11.5) 500 FT10 - Mounting Hole Ø: .38″″ - .39″″ (9.7-10.0mm) - Panel Thickness: .031″″ - .236″″ (0.8 - 5.0mm) 156-00089 156-00089 T30RFT10 30 lbs (135) 1.38 ″ (35) 5.8 ″ (148) .14 ″ (3.6) .71 ″ (18) .75 ″ (18.6) .26 ″ (6.5) .20 ″ (5) .48 ″ (12.1) 500 156-00090 156-00090 T50SFT10 50 lbs (225) 1.38 ″ (35) 6.3 ″ (160) .18 ″ (4.6) .71 ″ (18) .75 ″ (18.6) .26 ″ (6.5) .20 ″ (5) .48 ″ (12.1) 500 156-00091 156-00091 T50RFT10 50 lbs (225) 1.75 ″ (44) 8″ (203.2) .18 ″ (4.6) .71 ″ (18) .75 ″ (18.6) .26 ″ (6.5) .20 ″ (5) .48 ″ (12.1) 500 156-00092 156-00092 T50IFT10 50 lbs (225) 3.35 ″ (81) 11.8 ″ (300) .18 ″ (4.6) .71 ″ (18.0) .75 ″ (18.6) .26 ″ (6.5) .20 ″ (5) .48 ″ (12.1) 500 156-00093 156-00093 T50LFT10 50 lbs (225) 4.33 ″ (110) 15 ″ (380) .18 ″ (4.7) .71 ″ (18) .75 ″ (18.6) .26 ″ (6.5) .20 ″ (5) .48 ″ (12.1) 500 Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 33 Bundling and Securing C a b l e Ti e s Fir Tree Push Mount Ties Fir tree design grips to the inside of a hole. They can be used on sheet metal, wood, and cast iron. Type T50RTM25E has a longer fir tree for larger panel thicknesses. Material Data Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 Product Selection Min. Tensile Strength Mounting Hole Ø Panel Thickness Length (L) Max. Ø Bundle in. (mm) in. (mm) in. (mm) in. (mm) lbs. 126-03501 T50RTM250HSM4 T50RTM25 50 lbs (225) .25″ - .26″ .052″ - .28″ 8.27″ (210) 1.97″ (50.0) .19″ (4.7) (6.5 - 6.6) (1.32 - 7.0) Black 1000 157-01400 T50RTM25E8HSM4 T50RTM25E 50 lbs (225) .25″ - .26″ .09″ - .55″ 8.43″ (214) 1.97″ (50.0) .19″ (4.7) (6.5 - 6.6) (2.3 - 13.94) Gray 1000 Part No. Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. and Type for specification purposes. in. (mm) Color Pkg. Qty. Type Article No. (N) Width (W) Dimensions are approximate and subject to technical changes. Use Part No. for ordering Fir Tree Mount with Disc Tie This fir tree mount tie provides a low insertion force with a high extraction force. The outside serrations present a smooth surface to the cables preventing damage to the insulation. The unique head design allows the cable tie to firmly hold bundles as small as .06” diameter and the disc offers added water protection. Material Data Material Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Operating -40 °F to +230 °F (-40 °C to +110 °C) continuous Temperature Flammability UL94 HB Product Selection Min. Tensile Strength Article No. Part No. Type 155-05800 155-05800 T50SOSFT6E lbs. 50 lbs (N) (225) Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. ordering and Type for specification purposes. 34 Mounting Hole Ø Panel Thickness Length (L) Max. Ø Bundle in. (mm) in. (mm) in. (mm) in. (mm) .26″ - .28″ (6.5-7.0) .03″ - .12″ (0.75 - 3.0) 6.30″ (160) 1.38″ (35) Width (W) in. (mm) Color Pkg. Qty. .18″ (4.6) 500 Black Dimensions are approximate and subject to technical changes. Use Part No. for w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Domed Fir Tree Mount The domed head tie provides a tight, rattle-free installation and the outside serrated strap has ribs designed for convoluted tubing. The dome also acts as a seal to keep out dust and liquid. Material Data Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 Product Selection Article No. Part No. Type Min. Tensile Strength Mounting Hole Ø Panel Thickness lbs. (N) in. (mm) in. (mm) .25″ - .28″ (6.3-7.0) .03″ - .28″ (0.8 - 7.0) 157-01100 T50SDP6.HB6P T50SDP6 45 lbs (200) Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. ordering and Type for specification purposes. Length (L) in. (mm) 6.69″ (170) Max. Ø Bundle Width (W) in. (mm) in. (mm) 1.22″ (31) .20″ (5.1) Color Pkg. Qty. Black 500 Dimensions are approximate and subject to technical changes. Use Part No. for Domed Push Mount Tie The domed head tie provides a tight, rattle-free installation and the outside serrated strap has ribs designed for convoluted tubing. The dome also acts as a seal to keep out dust and liquid. Material Data Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 Product Selection Min. Tensile Strength Article No. Part No. Type lbs. (N) 111-85350 111-85350 T50SD6 50 lbs (225) Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. ordering and Type for specification purposes. Mounting Hole Ø Panel Thickness Length (L) Max. Ø Bundle Width (W) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) .25″ - .30″ (6.3-7.5) .023″ - .047″ (0.6 - 1.2) 6.30″ (160) 1.22″ (31) .20″ (5.1) Color Pkg. Qty. Black 500 Dimensions are approximate and subject to technical changes. Use Part No. for w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 35 Bundling and Securing C a b l e Ti e s Push Mount Ties One-piece, all plastic ties for quick, simple cable mounting. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Min. Tensile Strength Article No. T30RSF Mounting Hole Ø Panel Thickness Length (L) Max. Ø Bundle Width (W) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. 6.34″ (161) 1.25″ (31.8) .14″ (3.6) Natural 100 .04″ - .09″ (0.9-2.36) 6.34″ (161) 1.25″ (31.8) .14″ (3.6) Natural 1000 .19″ - .22″ (4.76-5.59) .04″ - .09″ (0.9-2.36) 6.34″ (161) 1.25″ (31.8) .14″ (3.6) Black 100 (135) .19″ - .22″ (4.76-5.59) .04″ - .09″ (0.9-2.36) 6.34″ (161) 1.25″ (31.8) .14″ (3.6) Black 1000 50 lbs (225) .25″ - .28″ (6.4-7.1) .04″ - .14″ (1.0-3.56) 6.26″ (159) 1.38″ (35) .19″ (4.7) Natural 100 T50SSF 50 lbs (225) .25″ - .28″ (6.4-7.1) .04″ - .14″ (1.0-3.56) 6.26″ (159) 1.38″ (35) .19″ (4.7) Natural 1000 126-00045 126-00045 T50SSF 50 lbs (225) .25″ - .28″ (6.4-7.1) .04″ - .14″ (1.0-3.56) 6.26″ (159) 1.38″ (35) .19″ (4.7) Black 100 126-00046 126-00046 T50SSF 50 lbs (225) .25″ - .28″ (6.4-7.1) .04″ - .14″ (1.0-3.56) 6.26″ (159) 1.38″ (35) .19″ (4.7) Black 1000 111-85789 T50RSF9C2 T50RSF(U) 50 lbs (225) .25″ - .28″ (6.4-7.1) .04″ - .14″ (1.0-3.56) 8.27″ (210) 1.73″ (44) .19″ (4.7) Natural 100 126-01011 T50RSF9M4 T50RSF(U) 50 lbs (225) .25″ - .28″ (6.4-7.1) .04″ - .14″ (1.0-3.56) 8.27″ (210) 1.73″ (44) .19″ (4.7) Natural 1000 126-01003 T50RSF0C2 T50RSF(U) 50 lbs (225) .25″ - .28″ (6.4-7.1) .04″ - .14″ (1.0-3.56) 8.27″ (210) 1.73″ (44) .19″ (4.7) Black 100 126-01004 T50RSF0M4 T50RSF(U) 50 lbs (225) .25″ - .28″ (6.4-7.1) .04″ - .14″ (1.0-3.56) 8.27″ (210) 1.73″ (44) .19″ (4.7) Black 1000 Part No. Type lbs. (N) 111-85603 T30RSF9C2 T30RSF(U) 30 lbs (135) .19″ - .22″ (4.76-5.59) .04″ - .09″ (0.9-2.36) 126-00704 T30RSF9M4 T30RSF(U) 30 lbs (135) .19″ - .22″ (4.76-5.59) 126-00700 T30RSF0C2 T30RSF(U) 30 lbs (135) 126-00702 T30RSF0M4 T30RSF(U) 30 lbs 126-00043 126-00043 T50SSF 126-00044 126-00044 T50SSF T50RSF Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. and Type for specification purposes. 36 Dimensions are approximate and subject to technical changes. Use Part No. for ordering w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Wing Push Mount Ties Material Data Wing design helps stabilize the tie in high vibration applications. They can be used on sheet metal, wood, and cast iron. Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Article No. T18RWPM Part No. 126-00041 126-00041 Type Min. Tensile Strength Mounting Hole Ø Panel Thickness Length (L) Max. Ø Bundle Width (W) Disc Ø lbs. (N) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) .19″ - .22″ (4.76-5.59) .07″ - .13″ (1.85 - 3.18) 4.45″ (113) .87″ (22) .10″ (2.5) .52″ (13.1) .19″ - .22″ (4.76-5.59) .07″ - .13″ (1.85 - 3.18) 4.45″ (113) T18RWPM 18 lbs (80) 126-00603 T18RWPM9M4 T18RWPM 18 lbs (80) Color Pkg. Qty. 100 Natural .87″ (22) .10″ (2.5) .52″ (13.1) 1000 T50SL6 111-85469 T50SL6.NN6P T50SL6 50 lbs (225) .24″ - .26″ (6.1-6.5) .03″ - .10″ (0.8 - 2.5) 6.50″ (165) 1.34″ (34) .18″ (4.6) .73″ (18.5) Natural 500 T50SL7 50 lbs (225) .27″ - .28″ (6.9-7.1) .03″ - .10″ (0.8 - 2.5) 6.50″ (165) 1.34″ (34) .18″ (4.6) .73″ (18.5) Natural 500 T50SL7 111-85479 T50SL7.NN6P Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. * UL recognition applies to T18RWPM ties. Arrowhead Mount Ties This tie has an arrowhead design which offers a positive, low insertion force and a high extraction force. Part No. 126-03100 features a foam rubber seal which provides additional protection against moisture, dirt and other impurities. Material Data Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 Product Selection Min. Tensile Mounting Panel Strength Hole Ø Thickness Length (L) Article No. Part No. Type lbs. (N) in. (mm) in. (mm) in. (mm) Max. Ø Bundle Width (W) in. (mm) in. (mm) Color Pkg. Qty. 126-03100 126-03100 T50SOSSFT6.5E-MD 50 lbs (225) .25″ - .26″ .02″ - .07″ 6.30″ (160) 1.38″ (35) .18″ (4.6) (6.3-6.7) (0.6 - 1.8) Green 500 126-03101 126-03101 T50SOSSFT6.5E 50 lbs (225) .25″ - .26″ .02″ - .07″ 6.30″ (160) 1.38″ (35) .18″ (4.6) (6.3-6.7) (0.6 - 1.8) Black 500 Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. ordering and Type for specification purposes. Dimensions are approximate and subject to technical changes. Use Part No. for w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 37 Bundling and Securing C a b l e Ti e s Center Mount, Domed Push Mount Ties The center mount, domed push mount tie centers the mount on all bundle diameters. The mount is molded in a stationary position for easy assembly. A tab extends beyond the head for easy strap insertion. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Article No. Part No. 150-35930 150-35930 Type T50RSP Min. Tensile Strength Mounting Hole Ø Panel Thickness Length (L) Max. Ø Bundle Width (W) lbs. (N) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. .24″ - .26″ (6.0-6.5) .03″ - .05″ (0.75 - 1.3) 1.77″ (45) .18″ (4.6) Black 1000 50 lbs (222) Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. ordering and Type for specification purposes. 7.48″ (190) Dimensions are approximate and subject to technical changes. Use Part No. for Ladder Style Push Mount Ties The unique ladder style design eliminates the need for various sizes of clamps and allows for easy re-entry to access bundle. Wings on the side of the tie provide stabilization. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Type Mounting Hole Ø Panel Thickness in. (mm) in. (mm) Max. Ø Bundle Width (W) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. .03″ - .15″ (0.7 - 3.9) 4.53″ (115) 1.06″ (27) .40″ (10) Black 500 .26″ - .25″ (6.3-6.7) .03″ - .15″ (0.7 - 3.9) 6.30″ (160) 1.65″ (42) .40″ (10) Black 500 .26″ - .25″ (6.3-6.7) .03″ - .15″ (0.7 - 3.9) 7.87″ (200) 2.09″ (53) .40″ (10) Black 500 Article No. Part No. 150-26100 FBS1000H4 FBS100 .25″ - .26″ (6.3-6.7) 150-26140 FBS1400H4 FBS140 150-26180 FBS1850H4 FBS185 Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. ordering and Type for specification purposes. 38 Length (L) Dimensions are approximate and subject to technical changes. Use Part No. for w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Wide Strap Heavy Duty Stud Mount Cable Ties The wide strap stud mount cable tie minimizes pinching on soft bundles and features a low profile head to provide compact bundling. A thinner strap provides increased flexibility for improved ergonomics. Available with a 1/4” and 3/8″ stud mount, the wide strap tie utilizes a strong hinge between the stud mount and head to provide superior holding ability on a threaded stud. – – – – – – Wide strap to minimize pinching of soft hoses and convoluted tubing Clamping rails to increase grip on round bundles Wide variation of bundle diameters: .375” - 4.125” (9.5mm - 104.7mm) Flexible strap Flexible hinge Mount provides low insertion and high extraction forces Material Data Material Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Operating Temperature -40 °F to +230 °F (-40 °C to +110 °C) continuous Flammability UL94 HB Product Selection Article No. Part No. Type Wide Strap Ties with 1/4″″ Stud Mount Min. Tensile Strength Length (L) Max. Ø Bundle Width (W) lbs. (N) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. 157-00400 157-00400 WSS250 120 lbs (534) 9.7″ (246.38) 2.25″ (57.15) .5″ (12.7) Black 300 157-00401 157-00401 WSI250 120 lbs (534) 12.7″ (322.58) 3.25″ (82.55) .5″ (12.7) Black 300 157-00402 157-00402 WSR250 120 lbs (534) 15.7″ (398.78) 4.125″ (104.78) .5″ (12.7) Black 300 Wide Strap Ties with 3/8″″ Stud Mount WSS38 157-00406 157-00406 WSS380 120 lbs (534) 9.7″ (246.38) 2.25″ (57.15) .5″ (12.7) Black 60 157-00403 157-00403 WSS380 120 lbs (534) 9.7″ (246.38) 2.25″ (57.15) .5″ (12.7) Black 300 WSI38 157-00407 157-00407 WSI380 120 lbs (534) 12.7″ (322.58) 3.25″ (82.55) .5″ (12.7) Black 60 157-00404 157-00404 WSI380 120 lbs (534) 12.7″ (322.58) 3.25″ (82.55) .5″ (12.7) Black 300 WSR38 157-00408 157-00408 WSR380 120 lbs (534) 15.7″ (398.78) 4.125″ (104.78) .5″ (12.7) Black 60 157-00405 157-00405 WSR380 120 lbs (534) 15.7″ (398.78) 4.125″ (104.78) .5″ (12.7) Black 300 Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 39 Bundling and Securing C a b l e Ti e s Stud Mount Ties The stud mount tie mounts and secures a cable bundle in one component. The stud mount tie is designed for use on a 1/4″ - 20 UNC threaded stud or the exposed threads of a machine screw. Material Data Material Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Operating Temperature -40 °F to +230 °F (-40 °C to +110 °C) continuous Flammability UL94 HB Product Selection Stud Ø Article No. Part No. Type 157-01300 T120RSM0HIRK2 in. (mm) .25 ″ (6.25) T120RSM Min. Tensile Strength lbs. Length (L) (N) 120 lbs (535) in. (mm) 15.94″ (405) Max. Ø Bundle in. Width (W) (mm) in. 3.98″ (101) .30″ (mm) Color Pkg. Qty. (7.6) Black 50 Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Standoff Stud Mount Tie This tie is easily mounted on the top of the stud, the additional height gained by this design gives the bundle added clearance from the panel. Material Data Material Operating Polyamide 6.6 heat stabilized (PA66HS) -40 °F to +221 °F (-40 °C to +105 °C) continuous Temperature Flammability UL94 V2 Product Selection Stud Ø Article No. Part No. 155-30602 155-30602 Type T50SSBS50TE in. .20 ″ (mm) (5) Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. ordering and Type for specification purposes. 40 Min. Tensile Strength lbs. 45 lbs (N) (200) Length (L) in. (mm) 6.30″ (160) Max. Ø Bundle in. (mm) 1.38″ (35) Width (W) (mm) Color Pkg. Qty. .181″ (4.6) Black 500 in. Dimensions are approximate and subject to technical changes. Use Part No. for w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Oval Shaped Variable Stud Mount Ties The special oval shape provides for an approximate .20” (5.5mm) lateral adjustment, allowing for any misalignment of the stud or incorrect positioning of the tie on the cables. The “soft push” mount allows it to be installed onto a weld stud without the use of any tools. T50SOSSB5HEC Material Data Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 T50SOSSB6HE Product Selection Article No. Part No. Type Stud Ø Min. Tensile Strength in. (mm) lbs. (N) Max. Ø Bundle Length (L) in. (mm) in. (mm) Width (W) in. (mm) Color Pkg. Qty. 155-05400 155-05400 T50SOSSB5HEC .20 ″ (5) 38 lbs (170) 6.30″ (160) 1.38″ (35) .18″ (4.6) Black 500 155-46302 155-46302 T50SOSSB6HE .24 ″ (6) 38 lbs (170) 6.30″ (160) 1.38″ (35) .18″ (4.6) Black 500 Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. ordering and Type for specification purposes. Dimensions are approximate and subject to technical changes. Use Part No. for Stud Mount Tie with Outside Serrations Providing an especially secure hold and the ability to mount the cables very close to the stud, this tie is outside serrated preventing damage to the insulation of the cable. T50SOSSBS5E Material Data Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 Product Selection Stud Ø Article No. Part No. 155-12300 155-12300 Type T50SOSSBS5E in. .20 ″ (mm) (5) Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Type for specification purposes. Min. Tensile Strength lbs. (N) 50 lbs (225) Length (L) Max. Ø Bundle Width (W) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. 6.30″ (160) 1.38″ (35) .18″ (4.6) Black 500 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 41 Bundling and Securing C a b l e Ti e s Ladder Style Stud Mount Ties Ladder style tie mounts easily onto #10-24″ (5 mm) stud. Unique latch allows for easy re-entry to bundles. L W Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Stud Ø Article No. Part No. Type in. 150-28100 150-28100 FBB100 150-28140 150-28140 FBB140 150-28180 150-28180 FBB185 # 10-24″ Length (L) (mm) (5) Max. Ø Bundle Width (W) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. 4″ (110) .91″ (23) .40″ (10) Black 500 5.59″ (142) 1.50″ (38) .40″ (10) Black 500 7.87″ (200) 1.97″ (50) .40″ (10) Black 500 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Flexible Head Stud Mount Tie Flexible head wraps around cable bundle for easy installation. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Stud Ø Article No. 111-07110 Part No. Type in. 111-07110 T50RS5 #10 - 24″ (mm) (5) Min. Tensile Strength lbs. 50 lbs (N) (225) Max. Ø Bundle Length (L) in. (mm) in. 7.48″ (190) 1.58″ (mm) (40) Width (W) in. .18″ (mm) Color Pkg. Qty. (4.6) Black 100 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 42 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Cable Ties and Edge Clips HellermannTyton’s edge clips are designed specifically to route bundles by securing them to the edge of a plastic or metal sheet without the need for a mounting hole. The clip is easy to secure and the extraction force is high due to the integrated metal clamp that holds the edge clip in place. Edge clips are available in three configurations: a two piece clip and tie assembly, a one piece clip and tie combination and a edge clip and tape bar combination. When noted (*), cable ties are outside serrated which can reduce bundle chafing. Two Piece Edge Clip and Cable Tie Assemblies Material Data- Cable Tie Material Polyamide 6.6 heat stabilized (PA66HS) Color Black Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 V2 Material Data - Edge Clip Material T50ROSEC4A - the cable bundle runs parallel with Color the edge. Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Black Operating Temperature -40 °F to +230 °F (-40 °C to +110 °C) continuous Flammability UL94 HB Product Selection Min. Tensile Strength Article No. Part No. Type Panel Thickness, — .039″″ - .117″″ (1-3mm) 150-76090 150-76090 150-76093 150-76093 * lbs. (N) Max. Ø Bundle Length (L) in. (mm) in. (mm) Pkg. Qty. T30REC4A 30 lbs (135) 5.9″ (150) 1.3″ (33) 500 T50SOSEC4A 50 lbs (225) 5.9″ (150) 1.2″ (31) 500 T50REC4A 50 lbs (225) 8″ (202) 1.8″ (45) 500 T50ROSEC4A 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 T30REC4B 50 lbs (135) 5.9″ (150) 1.3″ (33) 500 156-00109 * T50SOSEC4B 50 lbs (225) 6.5″ (165) 1.2″ (31) 500 150-76079 150-76079 * T50ROSEC4B 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 150-40593 150-40593 * T50SOSEC5A 50 lbs (225) 5.9″ (150) 1.2″ (31) 500 500 150-76091 150-76091 150-76099 150-76099 * 150-76080 150-76080 156-00109 150-40592 150-40592 T50REC5A 50 lbs (225) 8″ (202) 1.8″ (45) 150-40591 150-40591 T50ROSEC5A 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 156-01007 156-01007 T50RDHEC5A 50 lbs (225) 8.3″ (210) 1.8″ (45) 500 156-05000 156-05000 150-40583 150-40583 * 150-40582 150-40582 150-40581 150-40581 * 155-37104 155-37104 156-00019 156-00019 * 156-05903 T30REC5B 30 lbs (135) 5.9″ (150) 1.3″ (33) 500 T50SOSEC5B 50 lbs (225) 5.9″ (150) 1.2″ (31) 500 T50REC5B 50 lbs (225) 8.0″ (202) 1.8″ (45) 500 T50ROSEC5B 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 T18REC9 18 lbs (80) 3.9″ (100) .75″ (19) 500 T50SOSEC9SD 50 lbs (225) 5.9″ (150) 1.2″ (31) 500 156-05903 T50ROSEC9 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 155-38304 155-38304 T18R-EC10 18 lbs (80) 3.9″ (100) .79″ (20) 500 156-05904 156-05904 * T50ROSEC10 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 156-00017 156-00017 T50SOSEC21 50 lbs (225) 5.9″ (150) 1.3″ (33) 500 156-00010 156-00010 T50ROSEC21 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 156-00018 156-00018 T50SOSEC22 50 lbs (225) 5.9″ (150) 1.3″ (33) 500 156-00011 156-00011 T50ROSEC22 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Drawing * outside serrated cable tie Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 43 Bundling and Securing C a b l e Ti e s Two Piece Edge Clip and Cable Tie Assemblies continued Product Selection Article No. Part No. Type Panel Thickness — .117″″ - .234″″ (3-6 mm) Min. Tensile Strength Length (L) lbs. (N) in. (mm) in. (mm) Pkg. Qty. 500 Max. Ø Bundle 156-04600 156-04600 T18ROSEC19 18 lbs (80) 3.9″ (100) .79″ (20) 156-04601 156-04601 T50SOSEC19 50 lbs (225) 5.9″ (150) 1.2″ (31) 500 156-04602 156-04602 T50ROSEC19 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 156-00016 156-00016 T50SOSEC20 50 lbs (225) 5.9″ (150) 1.3″ (33) 500 156-00020 156-00020 T50ROSEC20 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 156-00006 156-00006 T50ROSEC23 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 156-00007 156-00007 T50ROSEC24 50 lbs (225) 7.9″ (200) 1.8″ (45) 500 Drawing Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. One Piece Edge Clip and Cable Tie Combinations Material Data Material The plastic area of the edge clips and the cable ties are molded together. Polyamide 6.6 heat stabilized (PA66HS) Color Black Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Flammability UL94 HB Product Selection Min. Tensile Strength Article No. Part No. Type Panel Thickness — .039″″ - .117″″ (1-3 mm) lbs. (N) Max. Ø Bundle Length (L) in. (mm) in. (mm) Pkg. Qty. 133-00059 133-00059 T40XEC5SP-E 40 lbs (178) 4.05″ (103) .59″ (15) 500 148-00200 148-00200 T50SOSEC12E 50 lbs (225) 6.30″ (160) 1.38″ (35) 500 126-00000 126-00000 T50SOSEC13E 50 lbs (225) 6.30″ (160) 1.38″ (35) 500 Drawing Installation tools - MK7, MK7HT, MK7P, MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 44 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Edge Clip and Tape Clip Combination These clips can be secured to cables with cable ties or tape. Material Data - Cable Tie and Tape Clip Combination Material Color Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Black Operating Temperature -40 °F to +230 °F (-40 °C to +110 °C) continuous Flammability UL94 HB Product Selection Article No. Part No. Type Panel Thickness — .039″″ - .117″″ (1-3 mm) Length (L) Width (W) in. in. (mm) (mm) Pkg. Qty. 151-03404 151-03404 EC14 1.57″ (40.0) .39″ (10.0) 500 151-03401 151-03401 EC15 1.57″ (40.0) .39″ (10.0) 500 151-03402 151-03402 EC16 1.57″ (40.0) .39″ (10.0) 500 151-03403 151-03403 EC17 1.57″ (40.0) .39″ (10.0) 500 Drawing Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 45 Bundling and Securing C a b l e Ti e s Button Head Ties The button head tie is a two piece tie providing for parallel entry and exit through the head. The strap contains serrations on both sides and has two opposed pawls recessed within a domed head. This design allows the strap to be directed clockwise or counter-clockwise prior to insertion into the head, enabling bi-directional looping. New and Improved Features The button head tie offers many new and improved features for added durability and installation ease. Standoff tabs — prevent tie head from seating in button during strap insertion Pilot bushing - protects the strap from abrasion on the mounting hole edge Ribs - increased ribs added to the bottom of the button head for added durability Strap - more radiused edges for added flexibility Serrations - redesigned serrations and wedge design provide optimal strength when seated in the head Retainers — lower retainers on BT130 help prevent the strap from backing out of the mounting hole and holds HellermannTyton’s saddle mounts in place during assembly. 46 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Button Head Ties continued Material Data Cable Tie Material Polyamide 6.6 high impact modified, heat stabilized (PA66HIRHS) Button Head Material Polyamide 6.6 heat stabilized (PA66HS) Operating Temperature -40 °F to +221 °F (-40 °C to +105 °C) continuous Color Flammability Black UL94 HB Product Selection Min. Tensile Strength Article No. Part No. BT105 Button Head Ties Type lbs. (N) Length (L) in. Max. Ø Bundle (mm) Width (W) in. (mm) in. (mm) Color Pkg. Qty. 132-00010 132-00010 BT105R 105 lbs (467) 9.63″ (244.4) 2.62″ (66.7) .22″ (5.6) Black 50 132-00011 132-00011 BT105L 105 lbs (467) 15″ (381.5) 4.33″ (110) .22″ (5.6) Black 50 BT105 Button Head Ties with Pilot Bushings 132-00006 132-00006 BT105RP 105 lbs (467) 9.63″ (244.4) 2.62″ (66.7) .22″ (5.6) Black 50 132-00007 132-00007 BT105LP 105 lbs (467) 15″ (381.5) 4.33″ (110) .22″ (5.6) Black 50 BT130 Button Head Ties with Retainers and Pilot Bushings 132-00008 132-00008 BT130RDP 130 lbs (578) 10.51″ (267.0) 2.87″ (73) .30″ (7.6) Black 50 132-00009 132-00009 BT130LDP 130 lbs (578) 15″ (381.5) 4.33″ (110) .30″ (7.6) Black 50 Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 47 Bundling and Securing C a b l e Ti e s EL-TY (Extended Length Ties) HellermannTyton’s El-Ty is a high strength strapping system used for supporting, securing, fastening, and spacing cables, as well as a variety of other applications requiring extra-long, extremely durable strapping. The El-Ty consists of a smooth strap and a separate, compact plastic head which encloses a stainless steel gripper. The stackable spacer accepts cable ties up to 1/2” wide for a versatile, easy to install spacing system. Material Data- Strap and Head Material Color Polyacetal (POM) Black Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) Flammability UL94 HB Material Data- Spacer Material Color Polypropylene, UV-resistant (PP) Black Operating Temperature -40 °F to +239 °F (-40 °C to +115 °C) continuous Flammability UL94 HB slits for El-TY strap El-Ty Spacer El-Ty Strap and Locking Head Product Selection Article No. Type Description Color 111-30000 TELS-1 Part No. TELS1 1 - 50 ft reel of strap and 30 heads Black 1 111-31000 TELS-H TELSH Double entry and locking heads Black 25 111-32108 TELS-13 TELS-13 10 - 13.5″ straps and 10 double locking heads Black 1 111-32110 TELS-27 TELS-27 10 - 27″ straps and 10 double locking heads Black 1 111-32111 TELS-5K TELS-5K 5 - 50 ft. reels and 150 heads Black 1 111-32107 TELS-10K TELS-10K 10 - 50 ft. reels and 300 heads Black 1 111-32000 TELS-SPK2 TELS-SPK2 EL-TY Spacer Black 50 111-32106 TELS-SPOOL TELS-SPOOL 50 ft. reel of strap Black 1 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 48 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Pkg. Qty. Cable_final.qxp 2/17/2006 11:10 AM Page 49 Bundling and Securing C a b l e Ti e s Aerial Support Spacer Ties Aerial support spacer ties are two piece ties designed for standard spacing applications. The strap is molded from special high impact polyamide 6.6. The support spacer and head are made from a high density outdoor black polypropylene. Both materials offer resistance to sunlight, saltwater, and harsh chemical environments. Material Data- Strap Material Color Polyamide 6.6 high impact modified (PA66HIR) Black Operating Temperature -40 °F to +230 °F (-40 °C to +110 °C) continuous Flammability UL94 HB Material Data-Spacer/Head Material Color Polypropylene, UV-resistant (PP) Black Operating Temperature -40 °F to +239 °F (-40 °C to +115 °C) continuous Flammability UL94 HB Product Selection Min. Tensile Strength Article No. Part No. Type lbs. Length (L) (N) in. Max. Ø Bundle in. (mm) Color Pkg. Qty. 111-98501 TAS100RWS TAS100RWS 100 lbs (445) 8.25″ (209.6) 1.75″ (44.5) .50″ (12.7) Black 100 111-98500 TAS100MWS TAS100MWS 100 lbs (445) 10.7″ (272.3) 2.75″ (70) .50″ (12.7) Black 100 148-00022 TAS100LWS TAS100LWS 100 lbs (445) 4.5″ (115) .50″ (12.7) Black 100 16″ (mm) Width (W) (420) in. (mm) Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Installation tools - MK9, MK9HT, MK9P. Kabelrap Bundling System The patented Kabelrap bundling system offers a very high bundling strength and is particularly resistant to salt water, oils, greases, and hydraulic fluids. Special hand tool required for installation. Material Data Material Required Tool - 121-00680 Polyamide 6.6 UV-resistant (PA66UV) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Kabelrap Application W Product Selection Min. Tensile Strength Type lbs. (N) Length (L) in. Max. Ø Bundle Width (W) Article No. Part No. (mm) in. (mm) in. (mm) Color Pkg. Qty. 121-61860 121-61860 KR6/18 110 lbs (490) 7.25″ (183) 1.5″ (39) .24″ (6) Black 50 121-63560 121-63560 KR6/35 110 lbs (490) 14″ (356) 3.75″ (93) .25″ (6) Black 50 121-82160 121-82160 KR8/21 175 lbs (785) 8.25″ (210) 1.75″ (47) .31″ (8) Black 50 121-83360 121-83360 KR8/33 175 lbs (785) 13.25″ (337) 3.37″ (86) .31″ (8) Black 50 Required Installation Tool - 121-00680. Black is the standard color. Natural is available based upon minimums, custom terms and lead times. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 49 Bundling and Securing C a b l e Ti e s Parallel Entry Ties The parallel entry tie features a very low profile head, which enables the installed tie to lie flat on the bundle. Its sleek design enhances safety and fulfills the requirements of many diverse applications. The parallel entry tie features outside serrations to allow the smooth side of the tie to rest on a bundle, reducing any potential of wear due to abrasion from vibrations or movement. The parallel entry tie also offers an optional custom designed feature for foam applications, such as playground equipment. With child safety in mind, the patented retainer bumps on the strap allow the tie to grip into foam padded equipment eliminating slippage. The retainers also contain the tail of the tie eliminating the need to cut any excess material. This feature eliminates the potential for any sharp edges. Only a smooth surface is evident. The “PER” designation in the part number indicates the retainer feature. Material Data Material Polyamide 6.6 UV-resistant (PA66UV) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Retainer Retainer (PER) Version No Retainer Product Selection Min. Tensile Strength Article No. PE130S Part No. Type lbs. (N) Length (L) in. Max. Ø Bundle (mm) in. (mm) Width (W) in. (mm) Color Pkg. Qty. 112-00700 PE130S0UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Black 100 112-00701 PE130S14UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Watermelon 100 112-00702 PE130S20UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Custom Blue 100 112-00703 PE130S22UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Lavender 100 112-00704 PE130S23UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Raspberry 100 112-00705 PE130S35UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Candy 100 112-00706 PE130S36UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Caramel 100 112-00707 PE130S37UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Cobalt Blue 100 112-00708 PE130S38UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Forest Green 100 112-00709 PE130S39UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Grape 100 112-00710 PE130S40UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Rose Pink 100 112-00711 PE130S41UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Lemon Yellow 100 112-00712 PE130S42UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Sky Blue 100 112-00713 PE130S43UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Charcoal 100 112-00714 PE130S4UVC2 PE130S 130 lbs (578.3) 13.5″ (342.9) 4.0″ (101.6) .36″ (9.1) Yellow 100 Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 50 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Parallel Entry Ties continued Retainer Material Data Material Polyamide 6.6 UV-resistant (PA66UV) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 No Retainer Product Selection Min. Tensile Strength Article No. PE130R Part No. Type lbs. (N) Length (L) in. (mm) Max. Ø Bundle in. (mm) Width (W) in. (mm) Color Pkg. Qty. 100 112-00600 PE130R0UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Black 112-00601 PE130R14UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Watermelon 100 112-00602 PE130R17UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Tan 100 100 112-00603 PE130R1AUVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Chocolate 112-00604 PE130R20UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Custom Blue 100 112-00605 PE130R21UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Custom Green 100 100 112-00606 PE130R22UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Lavender 112-00607 PE130R23UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Raspberry 100 112-00608 PE130R31UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Aquamarine 100 112-00609 PE130R35UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Candy 100 112-00610 PE130R36UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Caramel 100 112-00611 PE130R37UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Cobalt Blue 100 112-00612 PE130R38UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Forest Green 100 112-00613 PE130R39UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Grape 100 112-00614 PE130R40UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Rose Pink 100 112-00615 PE130R41UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Lemon Yellow 100 112-00616 PE130R42UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Sky Blue 100 112-00617 PE130R43UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Charcoal 100 112-00618 PE130R4UVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Yellow 100 112-00619 PE130R8AUVC2 PE130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .36″ (9.0) Light Grey 100 Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 51 Bundling and Securing C a b l e Ti e s Parallel Entry Ties continued Material Data Material Polyamide 6.6 UV-resistant (PA66UV) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Retainer No Retainer Product Selection Min. Tensile Strength Article No. PER130R Part No. Type lbs. (N) Length (L) in. Max. Ø Bundle (mm) in. (mm) Width (W) in. (mm) Color Pkg. Qty. 112-00800 PER130R0UVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Black 100 112-00802 PER130R14UVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Watermelon 100 112-00803 PER130R20UVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Custom Blue 100 112-00804 PER130R21UVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Custom Green 100 112-00805 PER130R23UVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Raspberry 100 112-00806 PER130R31UVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Aquamarine 100 112-00807 PER130R4UVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Yellow 100 112-00808 PER130R6AUVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Light Blue 100 112-00809 PER130R7UVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Purple 100 112-00810 PER130R8AUVC2 PER130R 130 lbs (578.3) 16.25″ (413.0) 4.84″ (123.0) .49″ (12.4) Light Grey 100 100 PE130I 112-00500 PE130I0UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Black 112-00501 PE130I10UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) White 100 112-00502 PE130I14UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Watermelon 100 100 112-00503 PE130I17UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Tan 112-00504 PE130I20UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Custom Blue 100 112-00505 PE130I21UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Custom Green 100 100 112-00506 PE130I22UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Lavender 112-00507 PE130I23UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Raspberry 100 112-00508 PE130I31UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Aquamarine 100 112-00509 PE130I32UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Butterscotch 100 112-00510 PE130I4UVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Yellow 100 112-00511 PE130I6AUVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Light Blue 100 112-00512 PE130I8AUVC2 PE130I 130 lbs (578.3) 21″ (533.0) 6.22″ (158.0) .35″ (9.0) Light Grey 100 Installation tools - MK9, MK9HT, MK9P. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 52 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e s Stainless Steel Cable Ties HellermannTyton’s stainless steel ties are designed to secure hoses, cables, poles, pipes, and more when harsh environmental conditions may adversely affect the bundling application. Used where corrosion, vibration, weathering, radiation, and temperature extremes are a concern, HellermannTyton’s stainless steel ties can be used in virtually any indoor, outdoor, and underground application. MK9SST Stainless Steel Cable Tie Installation Tool Product Selection Article No. Part No. Type Description Adapted for use with stainless steel ties, the MK9 Stainless Steel tool retains the same design features as the MK9 series. The MK9SST accommodates all 110-95000 MK9SST MK9SST HellermannTyton stainless steel ties. Comes standard with padded foam grips for comfort and control and a hook for hanging on a belt or tether. Cable Tie Series Pkg. Qty. All MBT Series for both 304 and 316 materials 1 304 Material Grade 304 material is commonly used for stainless steel bundling applications and suits most general purpose requirements. It features the ability to withstand most environmental conditions, particularly in applications where vibration, general weathering, radiation and temperature extremes are a concern. • Self locking, ball bearing mechanism for quick and easy installation, either by hand or by tensioning tool • Fully enclosed head does not allow dirt or grit to interfere with locking mechanism • High tensile strength option for added strength and safety on heavy duty applications HellermannTyton's MK9SST tool is durable and lightweight offering superior stainless steel cable tie installation. Material Data Material Operating Temperature Stainless Steel Type SS304 (SS304) -112 °F to +1000 °F (-80 °C to +538 °C) Product Selection Min. Tensile Strength Article No. Part No. Type lbs. (N) Length (L) in. (mm) Max. Ø Bundle in. Width (W) (mm) in. (mm) Pkg. Qty. 150 lb. Stainless Steel Ties 111-93058 MBT5S-S MBT5SS 150 lbs (670) 5.0″ (127) 1″ (25) .18″ (4.6) 111-93088 MBT8S-S MBT8SS 150 lbs (670) 7.9″ (201) 2″ (50) .18″ (4.6) 100 111-93148 MBT14S-S MBT14SS 150 lbs (670) 14.3″ (362) 4″ (102) .18″ (4.6) 100 100 111-93208 MBT20S-S MBT20SS 150 lbs (670) 20.5″ (521) 6″ (152) .18″ (4.6) 100 111-93278 MB27S-S MBT27SS 150 lbs (670) 26.8″ (681) 8″ (203) .18″ (4.6) 100 111-93338 MBT33S-S MBT33SS 150 lbs (670) 33″ (838) 10″ (254) .18″ (4.6) 100 250 lb. Stainless Steel Ties 111-94088 MBT8H-S MBT8HS 250 lbs (1115) 7.9″ (201) 2″ (50) .31″ (7.9) 50 111-94148 MBT14H-S MBT14HS 250 lbs (1115) 14.3″ (362) 4″ (102) .31″ (7.9) 50 111-94208 MBT20H-S MBT20HS 250 lbs (1115) 20.5″ (521) 6″ (152) .31″ (7.9) 50 111-94278 MBT27H-S MBT27HS 250 lbs (1115) 26.8″ (681) 8″ (203) .31″ (7.9) 50 111-94338 MBT33H-S MBT33HS 250 lbs (1115) 33″ (838) 10″ (254) .31″ (7.9) 50 Installation tools for the above cable ties - MK9SST Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Stainless steel ties and materials should be tested thoroughly under end use conditions to determine suitability for the application. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 53 Bundling and Securing C a b l e Ti e s Stainless Steel Cable Ties continued 316 Material Grade 316 material is highly resistant to corrosion and widely used in marine environments where chemicals, salts, acids, and temperature extremes may affect the bundling application. MBT stainless steel ties in 316 steel material are also available with a nylon 11 protective coating. This coating creates a barrier and protectant from chemical reactions of dissimilar metals. • Self locking, ball bearing mechanism for quick and easy installation, either by hand or by tensioning tool • Fully enclosed head does not allow dirt or grit to interfere with locking mechanism • High tensile strength option available for added strength and safety on heavy duty applications Material Data Material Stainless Steel Type SS316 (SS316) Operating Temperature -112 °F to +1000 °F (-80 °C to +538 °C) Product Selection Min. Tensile Strength Article No. Part No. Type lbs. (N) Length (L) in. Max. Ø Bundle (mm) in. (mm) Width (W) in. (mm) Pkg. Qty. 150 lb. Stainless Steel Ties 111-93959 MBT5S MBT5S 150 lbs (670) 5.0″ (127) 1.0″ (25.4) .18″ (4.6) 100 111-93089 MBT8S MBT8S 150 lbs (670) 7.9″ (201) 2.0″ (50) .18″ (4.6) 100 111-93149 MBT14S MBT14S 150 lbs (670) 14.3″ (362) 4.0″ (102) .18″ (4.6) 100 111-93209 MBT20S MBT20S 150 lbs (670) 20.5″ (521) 6.0″ (152) .18″ (4.6) 100 111-93279 MBT27S MBT27S 150 lbs (670) 26.8″ (681) 8.0″ (203) .18″ (4.6) 100 111-93339 MBT33S MBT33S 150 lbs (670) 33.0″ (838) 10.0″ (254) .18″ (4.6) 100 250 lb. Stainless Steel Ties 111-94089 MBT8H MBT8H 250 lbs (1115) 7.9″ (201) 2.0″ (50.8) .31″ (7.9) 50 111-94149 MBT14H MBT14H 250 lbs (1115) 14.3″ (362) 4.0″ (102) .31″ (7.9) 50 111-94209 MBT20H MBT20H 250 lbs (1115) 20.5″ (521) 6.0″ (152) .31″ (7.9) 50 111-94279 MBT27H MBT27H 250 lbs (1115) 26.8″ (681) 8.0″ (203) .31″ (7.9) 50 111-94339 MBT33H MBT33H 250 lbs (1115) 33.0″ (838) 10.0″ (254) .31″ (7.9) 50 Installation tools for the above cable ties - MK9SST Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Stainless steel ties and materials should be tested thoroughly under end use conditions to determine suitability for the application. 54 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing G r i p Ti e s Grip Tie Straps The Grip Tie is a low profile, one piece fastening device. Constructed of polyethylene hook and nylon loop and laminated back to back, the Grip Tie features quick release for repetitive access to cable and wire. It can be opened and closed numerous times without failure. The Grip Tie is reusable, adjustable, releasable, and easy to install. Available in rolls and straps in 6″, 8″, 11″ and 15″ sizes. Grip Ties are available in a variety of colors and are versatile enough for applications ranging from network installations to bundling power cords. Grip Ties are also customizable with your company name (minimum quantities apply). L2 W W2 L Product Selection Min. Tensile Strength Article No. 6″″ Grip Ties Part No. Type lbs. (N) Length (L) Max. Ø Bundle Width (W) Width (W2) Length (L2) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) 854-44316 GT.375X60C2 GT.375X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) 854-44339 GT.50X60P2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44336 GT.50X60C2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Color .375″ (9.525) .75″ (19.05) 1.5″ (38.1) 854-44342 GT.50X62P2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44341 GT.50X62C2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44344 GT.50X63P2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44343 GT.50X63C2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44346 GT.50X64P2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44345 GT.50X64C2 GT.50x6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44348 GT.50X65P2 GT.50x6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44347 GT.50X65C2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44350 GT.50X66P2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44349 GT.50X66C2 GT.50X6 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44355 GT.50X80P2 GT.50x8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44353 GT.50X80C2 GT.50x8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44358 GT.50X82P2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44357 GT.50X82C2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44360 GT.50X83P2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44359 GT.50X83C2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44362 GT.50X84P2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44361 GT.50X84C2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Pkg. Qty. 100 Black 10 100 Red Orange Yellow Green Blue 10 100 10 100 10 100 10 100 10 100 8″″ Grip Ties 854-44364 GT.50X85P2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44363 GT.50X85C2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44366 GT.50X86P2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44365 GT.50X86C2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Black Red Orange Yellow Green Blue 10 100 10 100 10 100 10 100 10 100 10 100 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 55 Bundling and Securing G r i p Ti e s Grip Tie Straps continued L2 W W2 L Product Selection Min. Tensile Strength Article No. 11″″ Grip Ties Part No. Type lbs. (N) Length (L) in. (mm) Max. Ø Bundle in. (mm) Width (W) Width (W2) Length (L2) in. (mm) in. (mm) in. (mm) 854-44320 GT.50X110P2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44317 GT.50X110C2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44323 GT.50X112P2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44322 GT.50X112C2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44325 GT.50X113P2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44324 GT.50X113C2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44327 GT.50X114P2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44326 GT.50X114C2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44329 GT.50X115P2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44328 GT.50X115C2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44331 GT.50X116P2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) 854-44330 GT.50X116C2 GT.50X11 40 lbs (177.93) 11″ (279.4) 2.63″ (66.802) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Color Black Red Orange Yellow Green Blue Pkg. Qty. 10 100 10 100 10 100 10 100 10 100 10 100 15″″ Grip Ties 854-44371 GT.75X150P2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44369 GT.75X150C2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44374 GT.75X152P2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44373 GT.75X152C2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44376 GT.75X153P2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44375 GT.75X153C2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44377 GT.75X154C2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44378 GT.75X154P2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44380 GT.75X155P2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44379 GT.75X155C2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44382 GT.75X156P2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) 854-44381 GT.75X156C2 GT.75X15 50 lbs (222.41) 15″ (381) 3.88″ (98.552) .75″ (19.05) 1.5″ (38.1) 2.5″ (63.5) Black Red Orange Yellow Green Blue 10 100 10 100 10 100 100 10 10 100 10 100 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Grip Tie Rolls For custom-cut lengths, HellermannTyton offers the hook and loop strap on a five yard and 25 yard roll. Ideal for job site applications, desired lengths can be cut on the spot. Product Selection Width (W) Article No. Part No. Type in. (mm) Color Pkg. Qty. 854-44384 GT.75X1800 GT.75X180 .75″ (19.05) Black 180″ (5 yds.) 854-44388 GT.75X1802 GT.75X180 .75″ (19.05) Red 180″ (5 yds.) 854-44389 GT.75X1803 GT.75X180 .75″ (19.05) Orange 180″ (5 yds.) 854-44390 GT.75X1804 GT.75X180 .75″ (19.05) Yellow 180″ (5 yds.) 854-44391 GT.75X1805 GT.75X180 .75″ (19.05) Green 180″ (5 yds.) 854-44392 GT.75X1806 GT.75X180 .75″ (19.05) Blue 180″ (5 yds.) 854-44395 GT.75X6000 GT.75X600 .75″ (19.05) Black 600″ (16.6 yds.) 854-44396 GT.75X9000 GT.75X900 .75″ (19.05) Black 900″ (25 yds.) 854-44397 GT.75X9004 GT.75X900 .75″ (19.05) Yellow 900″ (25 yds.) Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 56 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing G r i p Ti e s Write-on Grip Ties In situations where instant identification is needed, HellermannTyton provides Grip Ties with a white write-on area. This smudge-free surface is ideal for fast and easy identification with a ballpoint pen or felt-tip marker. The write-on area is approximately 3/8″(H) x 1-1/4″(W). It is positioned in the center of the black 6″, 8″ and 11″ straps, as well as spaced every 12″ on the Grip Tie rolls. L2 W W2 L Product Selection Article No. Part No. Min. Tensile Strength Length (L) Max. Ø Bundle Width (W) Width (W2) Length (L2) lbs. (N) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) Type Color Pkg. Qty. 854-44340 GT.50X60P2W GT.50X6W 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Black 10 854-44338 GT.50X60C2W GT.50X6W 40 lbs (177.93) 6″ (152.4) 1″ (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Black 100 854-44356 GT.50X80P2W GT.50X8W 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Black 10 854-44354 GT.50X80C2W GT.50X8W 40 lbs (177.93) 8″ (203.2) 1.75″ (44.45) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Black 100 854-44321 GT.50X110P2W GT.50X11W 40 lbs (177.93) 11″ (279.4) 2.63″ (66.8) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Black 10 854-44319 GT.50X110C2W GT.50X11W 40 lbs (177.93) 11″ (279.4) 2.63″ (66.8) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Black 10 854-44386 GT.75X1800W GT.75X180W - 180″ (5 Yds.) - - .75″ (19.05) - - - - - Black 180″ Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Grip Ties for Plenum Applications HellermannTyton offers UL94V-2 flame rated Grip Ties for use in air handling spaces. These Grip Ties are UL Listed in accordance with the National Electrical Code regulations. They are available in three lengths as well as a 180″ roll. L2 W W2 L Product Selection Min. Tensile Strength Article No. Part No. Type lbs. (N) Length (L) in. Max. Ø Bundle (mm) in. (mm) 1″ Width (W) Width (W2) Length (L2) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. 854-44352 GT.50X6MP2V2 GT.50X6 40 lbs (177.93) 6″ (152.4) (25.4) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Maroon 10 854-44368 GT.50X8MP2V2 GT.50X8 40 lbs (177.93) 8″ (203.2) 1.91″ (48.5) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Maroon 10 854-44334 GT.50X12MP2V2 GT.50X12 40 lbs (177.93) 12″ (304.8) 3.18″ (80.7) .5″ (12.7) 1″ (25.4) 1.5″ (38.1) Maroon 10 854-44394 GT.75X180MV2 GT.75X180 - - - - – – .75″ (19.05) - - - - Maroon 180” Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 57 Bundling and Securing C a b l e Ti e M o u n t s Cable Tie Mounts HellermannTyton offers a wide variety of mounting bases suited for many applications. Mounting bases are used in conjunction with cable ties to stabilize and secure wiring bundles, both indoors and outdoors. These mounting bases can be secured to a surface using rubber based adhesive, acrylic adhesive, or also can be screw mounted. Cable Tie Mounting Bases HellermannTyton’s 4-way mounting bases are available in four sizes to accommodate T18 through T150 series cable ties. Insertion of ties can be made from all four sides. Each mount may be secured with two screws (four screws for the MB2.5 mount), with adhesive backing, or both, for ease of application and stability. Adhesive mounts are supplied in pairs connected together on an adhesive liner. Material Data Material For applications where higher temperatures, certain chemicals, or UV radiation are a concern and an adhesive is the preferred method for securing, the acrylic adhesive 4-way mounting bases are recommended. The 2-way mounting bases may be secured with one screw, with adhesive backing, or both, and allow ties to be inserted from two sides. Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 (excluding adhesive) 2-way mount 4-way, MB2.5 mount 4-way, MB3, MB4 and MB5 mounts Cable Tie Mounting Bases - Screw Mount File# E64139 Product Selection Article No. Part No. 2- Way Screw Mount Type Cable Tie Series Mounting Length (L) Width (W) Height (H) in. in. in. (mm) (mm) (mm) Color Pkg. Qty. 100 151-29104 MB4SH10C2 MB4SH 1.115″ (28.32) 1.115″ (28.32) .202″ (5.13) White 151-00323 MB4SH10H4 MB4SH 1.115″ (28.32) .202″ (5.13) White 500 1.115″ (28.32) .202″ (5.13) Black 100 1.115″ (28.32) .202″ (5.13) Black 500 151-29100 MB4SH0C2 MB4SH # 6 Screw 1.115″ (28.32) 1.115″ (28.32) 151-29101 MB4SH0H4 MB4SH 1.115″ (28.32) T18 - T50 4- Way Screw Mount 151-28901 MB2.510C2 MB2.5 .625″ (15.88) .625″ (15.88) .130″ (3.3) White 100 151-28902 MB2.510M4 MB2.5 .625″ (15.88) .625″ (15.88) .130″ (3.3) White 1000 151-00285 MB2.50C2 MB2.5 .625″ (15.88) .625″ (15.88) .130″ (3.3) Black 100 151-00286 MB2.50M4 MB2.5 .625″ (15.88) .625″ (15.88) .130″ (3.3) Black 1000 T18 # 3 Screw 151-28302 MB310C2 MB3 .75″ (19.0) .75″ (19.0) .15″ (3.8) White 100 151-28305 MB310M4 MB3 .75″ (19.0) .75″ (19.0) .15″ (3.8) White 1000 151-00136 MB30C2 MB3 .75″ (19.0) .75″ (19.0) .15″ (3.8) Black 100 151-28301 MB30M4 MB3 .75″ (19.0) .75″ (19.0) .15″ (3.8) Black 1000 151-28802 MB410C2 MB4 1.12″ (28.5) 1.12″ (28.5) .19″ (4.8) White 100 151-00319 MB410H4 MB4 1.12″ (28.5) 1.12″ (28.5) .19″ (4.8) White 500 151-00320 MB40C2 MB4 1.12″ (28.5) 1.12″ (28.5) .19″ (4.8) Black 100 (28.5) 1.12″ T18, T30 T18 - T50 #4 Screw #8 Screw 151-28801 MB40H4 MB4 1.12″ (28.5) .19″ (4.8) Black 500 151-00324 MB510C2 MB5 1.485″ (37.7) 1.485″ (37.7) .245″ (6.2) White 100 151-28504 MB510F4 MB5 1.485″ (37.7) 1.485″ (37.7) .245″ (6.2) White 250 151-28500 MB50C2 MB5 1.485″ (37.7) 1.485″ (37.7) .245″ (6.2) Black 100 151-28501 MB50F4 MB5 1.485″ (37.7) 1.485″ (37.7) .245″ (6.2) Black 250 T18 - T150 #8 Screw Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 58 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e M o u n t s Cable Tie Mounting Bases continued 2-way mount 4-way, MB3, MB4 and MB5 mounts 4-way, MB2.5 mount Cable Tie Mounting Bases - Rubber-Based Adhesive File# E64139 Product Selection Cable Tie Article No. Part No. Type Series 2- Way Mount with Rubber - Based Adhesive Mounting Length (L) Width (W) Height (H) in. in. (mm) in. (mm) (mm) Color Pkg. Qty. 100 1.115″ (28.32) 1.115″ (28.32) .232″ (5.89) White Adhesive 1.115″ (28.32) 1.115″ (28.32) .232″ (5.89) White 500 1.115″ (28.32) 1.115″ (28.32) .232″ (5.89) Black 100 MB2.5A .625″ (15.88) .625″ (15.88) .160″ (4.1) White 100 151-00298 MB2.5A10M4 MB2.5A .625″ (15.88) .625″ (15.88) .160″ (4.1) White 1000 .625″ (15.88) .625″ (15.88) .160″ (4.1) Black 100 .625″ (15.88) .625″ (15.88) .160″ (4.1) Black 1000 151-29203 MB4SHA10C2 MB4SHA 151-29206 MB4SHA10H4 MB4SHA 151-29200 MB4SHA0C2 T18 - T50 MB4SHA 4- Way Mount with Rubber - Based Adhesive 151-29002 MB2.5A10C2 151-29000 MB2.5A0C2 MB2.5A 151-29001 MB2.5A0M4 MB2.5A T18 Adhesive 151-28718 MB3A10C2 MB3A .75″ (19.0) .75″ (19.0) .18″ (4.6) White 100 151-28721 MB3A10M4 MB3A .75″ (19.0) .75″ (19.0) .18″ (4.6) White 1000 151-28710 MB3A0C2 MB3A .75″ (19.0) .75″ (19.0) .18″ (4.6) Black 100 151-28713 MB3A0M4 MB3A .75″ (19.0) .75″ (19.0) .18″ (4.6) Black 1000 151-28421 MB4A10C2 MB4A 1.12″ (28.0) 1.12″ (28.0) .22″ (5.6) White 100 151-00321 MB4A10H4 MB4A 1.12″ (28.0) 1.12″ (28.0) .22″ (5.6) White 500 151-28403 MB4A0C2 MB4A 1.12″ (28.0) 1.12″ (28.0) .22″ (5.6) Black 100 (28.0) 1.12″ T18, T30 T18 - T50 Adhesive Adhesive 151-28406 MB4A0H4 MB4A 1.12″ (28.0) .22″ (5.6) Black 500 151-28529 MB5A10C2 MB5A 1.485″ (37.7) 1.485″ (37.7) .275″ (6.9) White 100 151-00427 MB5A10F4 MB5A 1.485″ (37.7) 1.485″ (37.7) .275″ (6.9) White 250 151-28602 MB5A0C2 MB5A 1.485″ (37.7) 1.485″ (37.7) .275″ (6.9) Black 100 151-28605 MB5A0F4 MB5A 1.485″ (37.7) 1.485″ (37.7) .275″ (6.9) Black 250 Color Pkg. Qty. 100 T18 - T150 Adhesive Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Cable Tie Mounting Bases - Acrylic Adhesive Product Selection Article No. Part No. Type Cable Tie Series Mounting 4 - Way Screw Mount Acrylic Adhesive Length (L) Width (W) Height (H) in. (mm) in. (mm) in. (mm) 151-00331 MB3A10A2C2 MB3A .75″ (19.0) .75″ (19.0) .18″ (4.6) White 151-28717 MB3A10A2H4 MB3A .75″ (19.0) .75″ (19.0) .18″ (4.6) White 500 .75″ (19.0) .75″ (19.0) .18″ (4.6) Black 100 151-28711 MB3A0A2C2 MB3A 151-28709 MB3A0A2H4 T18, T30 Adhesive MB3A .75″ (19.0) .75″ (19.0) .18″ (4.6) Black 500 151-28420 MB4A10A2C2 MB4A 1.12″ (28.5) 1.12″ (28.5) .23″ (5.9) White 100 151-00322 MB4A10A2H4 MB4A 1.12″ (28.5) 1.12″ (28.5) .23″ (5.9) White 500 1.12″ (28.5) 1.12″ (28.5) .23″ (5.9) Black 100 1.12″ (28.5) 1.12″ 151-28402 MB4A0A2C2 MB4A 151-28405 MB4A0A2H4 MB4A T18 - T50 Adhesive 151-28607 MB5A10A2C2 MB5A 151-28610 MB5A10A2F4 MB5A 151-28600 MB5A0A2C2 MB5A 151-28604 MB5A10A2F4 MB5A T18 - T150 Adhesive (28.5) .23″ (5.9) Black 500 1.485″ (37.7) 1.485″ (37.7) .275″ (6.9) White 100 1.485″ (37.7) 1.485″ (37.7) .275″ (6.9) White 250 1.485″ (37.7) 1.485″ (37.7) .275″ (6.9) Black 100 1.485″ (37.7) 1.485″ (37.7) .275″ (6.9) Black 250 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 59 Bundling and Securing C a b l e Ti e M o u n t s Cable Tie Mounts The CTM series is designed to provide stability to wire bundles. These mounts can accommodate miniature, intermediate, or standard cross-section cable ties. Each mount is secured with a single screw. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Length (L) Article No. Part No. in. (mm) in. (mm) Color .578″ (14.68) .375″ (9.52) .266″ (6.76) White 100 151-30305 CTM010M4 .578″ (14.68) .375″ (9.52) .266″ (6.76) White 1000 .578″ (14.68) .375″ (9.52) .266″ (6.76) Black 100 .578″ (14.68) .375″ (9.52) .266″ (6.76) Black 1000 .579″ (14.71) .370″ (9.40) .266″ (6.76) White 100 .579″ (14.71) .370″ (9.40) .266″ (6.76) White 1000 .579″ (14.71) .370″ (9.40) .266″ (6.76) Black 100 .579″ (14.71) .370″ (9.40) .266″ (6.76) Black 1000 .857″ (21.77) .605″ (15.37) .372″ (9.45) White 100 .857″ (21.77) .605″ (15.37) .372″ (9.45) White 1000 CTM0 151-30301 CTM00M4 151-30400 CTM10C2 # 6 Screw CTM1 151-30402 CTM10M4 # 8 Screw 151-30504 CTM210C2 151-30506 CTM210M4 Mounting T18 - T50 151-30404 CTM110C2 151-30406 CTM110M4 Cable Tie Series CTM2 in. (mm) Height (H) 151-30303 CTM010C2 151-30300 CTM00C2 Type Width (W) .857″ (21.77) .605″ (15.37) .372″ (9.45) Black 100 151-30501 CTM20M4 .857″ (21.77) .605″ (15.37) .372″ (9.45) Black 1000 151-30605 CTM310C2 .858″ (21.79) .609″ (15.47) .374″ (9.50) White 100 151-30607 CTM310M4 .858″ (21.79) .609″ (15.47) .374″ (9.50) White 1000 151-30500 CTM20C2 CTM3 T18 -T120 #10 Screw .858″ (21.79) .609″ (15.47) .374″ (9.50) Black 100 151-30603 CTM30M4 .858″ (21.79) .609″ (15.47) .374″ (9.50) Black 1000 151-30703 CTM410C2 .864″ (21.95) .616″ (15.65) .372″ (9.45) White 100 151-30705 CTM410M4 .864″ (21.95) .616″ (15.65) .372″ (9.45) White 1000 .864″ (21.95) .616″ (15.65) .372″ (9.45) Black 100 .864″ (21.95) .616″ (15.65) .372″ (9.45) Black 1000 151-30600 CTM30C2 151-30700 CTM40C2 151-30702 CTM40M4 CTM4 .25″ Screw Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 60 Pkg. Qty. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e M o u n t s Low Profile Cable Tie Mounts Material Data Low profile mounts are intended for use in securing bundles where space is limited. Each mount is fastened with a single screw. Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Length (L) Article No. Part No. Type Cable Tie Series Mounting Width (W) in. (mm) Height (H) in. (mm) in. (mm) Color Pkg. Qty. .500″ (12.70) .312″ (7.92) .130″ (3.30) Natural 100 .500″ (12.70) .312″ (7.92) .130″ (3.30) Natural 1000 .500″ (12.70) .312″ (7.92) .130″ (3.30) Black 100 .500″ (12.70) .312″ (7.92) .130″ (3.30) Black 1000 151-00227 MB29C2 .807″ (20.50) .490″ (12.45) .130″ (3.30) Natural 100 151-00297 MB29M4 .807″ (20.50) .490″ (12.45) .130″ (3.30) Natural 1000 .807″ (20.50) .490″ (12.45) .130″ (3.30) Black 100 .807″ (20.50) .490″ (12.45) .130″ (3.30) Black 1000 151-00226 MB19C2 151-00294 MB19M4 151-00295 MB10C2 MB1 #2 Screw T18 151-00296 MB10M4 151-28210 MB20C2 MB2 T18 - T50 # 8 Screw 151-28202 MB20M4 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Low Profile Rivet Mounts Material Data Material The low profile rivet mount is designed to secure wiring bundles and fastens with the drive rivet through a predrilled hole. This mount is ideal for use in applications where space is limited. Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Article No. Part No. Type 151-27000 LKCRF19C2 LKCRF1 151-27009 LKCRF19H4 LKCRF1 Cable Tie Series T18 T50 Mounting Hole Ø Max. Panel Thickness Length (L) Width (W) Height (H) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. .250″ (6.35) .134″ (3.4) .938″ (23.82) .470″ (11.94) .157″ (3.99) Natural 100 .250″ (6.35) .134″ (3.4) .938″ (23.82) .470″ (11.91) .157″ (3.99) Natural 500 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 61 Bundling and Securing C a b l e Ti e M o u n t s Push Mounts Material Data Intended for use in a predrilled hole, this push mount accepts T18 through T50 series cable ties. Once inserted through the hole, the mount locks into place. Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Article No. Part No. Type 151-40106 TM1SF10C2 TM1SF 151-00328 TM1SF10M4 TM1SF 151-40100 TM1SF0C2 TM1SF 151-40101 TM1SF0M4 TM1SF Cable Tie Series T18 T50 Mounting Hole Ø Max. Panel Thickness Length (L) Width (W) Height (H) in. (mm) in. (mm) in. (mm) in. (mm) in. (mm) Color Pkg. Qty. .25″ (6.3) .134″ (3.4) .616″ (15.65) .401″ (10.19) .181″ (4.60) White 100 .25″ (6.3) .134″ (3.4) .616″ (15.65) .401″ (10.19) .181″ (4.60) White 1000 .25″ (6.3) .134″ (3.4) .616″ (15.65) .401″ (10.19) .181″ (4.60) Black 100 .25″ (6.3) .134″ (3.4) .616″ (15.65) .401″ (10.19) .181″ (4.60) Black 1000 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Push Button Mounts Material Data Material The push button mounts are used where the back of the panel is accessible. Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Article No. Part No. 151-00230 PBM10C2 Cable Tie Type Series PBM 151-00231 PBM10M4 PBM 151-00228 PBM0C2 PBM 151-00229 PBM0M4 PBM T18 T50 Mounting Hole Ø in. (mm) Max. Panel Thickness in. (mm) Width (W) in. (mm) Height (H) in. (mm) Height (H2) in. (mm) Color .25″ (6.4) .122″ (3.1) .26″ (6.60) .40″ (10.16) .08″ (2.03) White 100 .25″ (6.4) .122″ (3.1) .26″ (6.60) .40″ (10.16) .08″ (2.03) White 1000 .25″ (6.4) .122″ (3.1) .26″ (6.60) .40″ (10.16) .08″ (2.03) Black 100 .25″ (6.4) .122″ (3.1) .26″ (6.60) .40″ (10.16) .08″ (2.03) Black 1000 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 62 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Pkg. Qty. Bundling and Securing C a b l e Ti e M o u n t s Cable Tie Anchor Mounts Cable ties may be inserted from any of the four sides of the CTAM. This feature allows the mount to be placed either parallel or perpendicular to the wires. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Width (W) Article No. Part No. Type Cable Tie Series Mounting Length (L) in. (mm) Height (H) in. (mm) in. (mm) Color Pkg. Qty. CTAM1 .400″ (10.16) .800″ (20.32) .200″ (5.08) White 100 151-31106 CTAM110M4 CTAM1 .400″ (10.16) .800″ (20.32) .200″ (5.08) White 1000 .400″ (10.16) .800″ (20.32) .200″ (5.08) Black 100 .400″ (10.16) .800″ (20.32) .200″ (5.08) Black 1000 .400″ (10.16) .800″ (20.32) .200″ (5.08) White 100 .400″ (10.16) .800″ (20.32) .200″ (5.08) White 1000 .400″ (10.16) .800″ (20.32) .200″ (5.08) Black 100 .400″ (10.16) .800″ (20.32) .200″ (5.08) Black 1000 151-31103 CTAM110C2 151-31101 CTAM10C2 CTAM1 151-00287 CTAM10M4 CTAM1 151-31203 CTAM210C2 CTAM2 #8 screw T18 - T50 151-31205 CTAM210M4 CTAM2 151-31201 CTAM20C2 CTAM2 151-31202 CTAM20M4 CTAM2 #10 screw Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Cable Tie Anchor Plates These plates have slotted mounting holes to provide for easier alignment of mount and bundles. Once aligned, they are fastened securely by tightening the applied screw. The CTAP2 allows an additional screw for maximum stability. Both plates are used perpendicularly to the wire bundle. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 File# E64139 Product Selection Width (W) Article No. Part No. Type Cable Tie Series in. (mm) Color CTAP1 .50″ (12.7) 1.34″ (34.04) .15″ (3.81) White 100 151-00288 CTAP110M4 CTAP1 .50″ (12.7) 1.34″ (34.04) .15″ (3.81) White 1000 151-00289 CTAP10C2 CTAP1 .50″ (12.7) 1.34″ (34.04) .15″ (3.81) Black 100 151-00290 CTAP10M4 CTAP1 .50″ (12.7) 1.34″ (34.04) .15″ (3.81) Black 1000 151-30200 CTAP210C2 CTAP2 .50″ (12.7) 2.13″ (54.1) .14″ (3.5) White 100 151-00308 CTAP210H4 CTAP2 .50″ (12.7) 2.13″ (54.1) .14″ (3.5) White 500 151-00291 CTAP20C2 CTAP2 .50″ (12.7) 2.13″ (54.1) .14″ (3.5) Black 100 151-00292 CTAP20M4 CTAP2 .50″ (12.7) 2.13″ (54.1) .14″ (3.5) Black 500 #10 screw in. (mm) in. (mm) Height (H) 151-30100 CTAP110C2 T18 - T50 Mounting Length (L) Pkg. Qty. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 63 Bundling and Securing C a b l e Ti e M o u n t s Lashing Tie Mounts The lashing tie mount is designed to snap into the T250 lashing tie. The tie head is assembled perpendicular to the mount. The strap is parallel to the mount when inserted into the head. The lashing tie mount is recommended for indoor or outdoor wall mount cable applications. Material Data Material Polyamide 6.6 UV-resistant (PA66UV) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Width (W) Article No. Part No. Type 151-00358 LTM2500C2 LTM250 151-00293 LTM2500H4 LTM250 Cable Tie Series Mounting T250 .25″ screw in. Length (L) (mm) in. Height (H) (mm) Color Pkg. Qty. .733″ (18.62) 1.46″ (37.08) (mm) .378″ (9.60) in. Black 100 .733″ (18.62) 1.46″ (37.08) .378″ (9.60) Black 500 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Masonry Mounts Masonry mounts provide a permanent method of attaching wire and cable to masonry surfaces. HellermannTyton’s masonry mounts simply tap into predrilled holes and can be used for indoor and outdoor applications. Material Data Material Polyamide 6.6 (PA66) Operating Temperature -40 °F to +185 °F (-40 °C to +85 °C) continuous Flammability UL94 V2 Product Selection Article No. Part No. Type Cable Tie Series Mounting Hole Ø in. (mm) Min. Depth in. (mm) Length (L) in. Width (W) (mm) in. (mm) Width (W2) in. (mm) Width (W3) in. (mm) Pkg. Qty. 151-29800 MMB00C2 MMB0 .188″ (4.7) 1.185″ (30.1) .355″ (9.02) .218″ (5.54) .236″ (5.99) Black 100 151-00325 MMB00M4 MMB0 .188″ (4.7) 1.185″ (30.1) .355″ (9.02) .218″ (5.54) .236″ (5.99) Black 1000 151-00116 MMB.50C2 MMB.5 1.244″ (31.60) .375″ (9.53) .220″ (5.59) .308″ (7.82) Black 100 1.244″ (31.60) .375″ (9.53) .220″ (5.59) .308″ (7.82) Black 1000 151-30001 MMB.50M4 MMB.5 T18 T50 .25″ (6.25) 1.0 ″ (25.4) .25″ (6.25) 151-00326 MMB10C2 MMB1 .312″ (8.0) 151-00327 MMB10H4 MMB1 .312″ (8.0) 1.5″ (38.10) 1.71″ (43.49) .508″ (12.9) .374″ (9.50) .362″ (9.19) Black 100 1.71″ (43.49) .508″ (12.9) .374″ (9.50) .362″ (9.19) Black 500 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 64 Color w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e Ti e M o u n t s Cable Tie Mounting Plates Allowing multiple cables to be run in parallel, these mounting plates are secured with two screws. The cables are attached to the mounting plate by using a cable tie through any combination of the available slots. Material Data Material Operating Temperature Color Flammability Polyamide 6.6 (PA66) -40 °F to +185 °F (-40 °C to +85 °C) continuous Natural UL94 V2 Product Selection Width (W) Article No. Part No. Type Cable Tie Series Mounting Length (L) Height (H) in. (mm) 154-00000 MP1M3.NN3P MP1M3 # 6 (M3) screw .50″ (12.7) 1.75″ in. (mm) (44.4) .125″ in. (mm) (3.2) Pkg. Qty. 154-00100 MP1M5.NN3P MP1M5 #10 (M5) screw .50″ (12.7) 1.75″ (44.4) .125″ (3.2) 100 151-24219 MP2M3.NN3P MP2M3 # 6 (M3) screw .50″ (12.7) 3.00″ (76.2) .125″ (3.2) 100 100 154-00300 MP2M5.NN3P MP2M5 #10 (M5) screw .50″ (12.7) 3.00″ (76.2) .125″ (3.2) 100 151-24319 MP3M3.NN3P MP3M3 # 6 (M3) screw .50″ (12.7) 4.25″ (108.0) .125″ (3.2) 100 154-00500 MP3M5.NN3P MP3M5 #10 (M5) screw .50″ (12.7) 4.25″ (108.0) .125″ (3.2) 100 151-24419 MP4M3.NN3P MP4M3 # 6 (M3) screw .50″ (12.7) 5.50″ (139.8) .125″ (3.2) 100 154-00700 MP4M5.NN3P MP4M5 #10 (M5) screw .50″ (12.7) 5.50″ (139.8) .125″ (3.2) 100 151-24519 MP5M3.NN3P MP5M3 # 6 (M3) screw .50″ (12.7) 6.75″ (171.6) .125″ (3.2) 100 154-00900 MP5M5.NN3P MP5M5 #10 (M5) screw .50″ (12.7) 6.75″ (171.6) .125″ (3.2) 100 T18 - T50 154-00018 MSMP5/69C2 MSMP5/6 # 6 (M3) screw .618″ (15.7) 8.08″ (205.3) .21″ (5.33) 100 154-01200 MSMP5/109C2 MSMP5/10 #10 (M5) screw .618″ (15.7) 8.08″ (205.3) .21″ (5.33) 100 154-01302 MSMP6/69C2 MSMP6/7 # 6 (M3) screw .618″ (15.7) 9.58″ (243.3) .21″ (5.33) 100 154-01300 MSMP6/109C2 MSMP6/10 #10 (M5) screw .618″ (15.7) 9.58″ (243.3) .21″ (5.33) 100 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 65 Bundling and Securing C a b l e T i e To o l s Mechanical Cable Tie Tools T150 T250 TWT1 TWT2 MK9 Ranging from the high performance Mark 7 and Mark 9 series tools to pocket-sized twist tools, HellermannTyton offers a range of mechanical tools which can be used with any HellermannTyton cable tie. When using these tools, the cable tie is hand applied and then manually tensioned and cut-off, without the use of an extraneous power source. MK7 MK9HT MK7HT MARK 7 AND MARK 9 TOOLS Specifically developed for maximum ergonomic and performance values, the Mark 7 and Mark 9 series tools combine reduced hand effort and durable components to ensure efficient assembly and a longer life cycle. The Mark 7 tools are used with T18 through T50 series HellermannTyton cable ties. The Mark 9 tools can be used with nearly every HellermannTyton cable tie. Able to accommodate ties to .530″ in width, the Mark 9 is used with HellermannTyton's T18 series cable ties to the heavy duty ties, including the T250 series, Wide Strap series and EL-TY. High tension versions of both the Mark 7 and Mark 9 tools (MK7HT and MK79HT) offer the same design features as their standard counterparts but with higher cut-off tension capabilities. The Mark 9 and Mark 7 high tension tools both offer a 5/8″ stroke. MK7 & MK9 66 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e T i e To o l s Mark 7 and Mark 9 Features – An easy to read display speeds adjustment and verification. – Thumb tab on larger tension knob for easy adjustment. – On the Mark 7, a larger knob sets the three variable tension levels (minimum,intermediate, and standard). The smaller knob fine tunes within the tension range. – The larger knob on the Mark 9 sets to two variable tension levels (standard and heavy).The smaller knob fine tunes the tension setting. – Housings are manufactured from a high impact, glass reinforced nylon. – A double wall linkage adds more strength. – Tough chromium steel components ensure longevity. – MK7 & MK9 are military specified. – Single and dual lock-out features available for tensioning ranges. – Cable tie tension and cut-off tools reduce operator fatigue and speed assembly. – The Mark 7 features a one inch stroke, while the Mark 9 has a 5/8 inch stroke. Both reduce trigger cycles required to install cable ties. – Ergonomic design on both tools ideally fit the operator’s hand. Removable padded hand grips further reduce impact to the hand. – Low friction bearing mechanisms reduce hand effort and provide a smooth stroke. – Extremely light, the Mark 7 weighs only 10 ounces. The Mark 9 weighs just 13 ounces. – Quick tension adjustability for flush cut-off. Mark 7 Tool MK7 Product Selection Article No. Part No. 110-07500 MK7 Type MK7 Description Durable and lightweight, the Mark 7 tool is user friendly and adjustable, with top-of-the-line design features. Cable Tie Series Pkg. Qty. T18 thru T50 Series CTT20 thru CTT60 Series 1 110-07000 MK7HT MK7HT The Mark 7 High Tension tool has the same design features as T30 thru T50 Series the MK7, although this tool offers an increased tension range. CTT20 thru CTT60 Series 1 110-08000 MK7LK MK7LK The Mark 7 Lock-Out tool has the same design features as the T30 thru T50 Series MK7, although this tool offers complete lock-out of tension CTT20 thru CTT60 Series settings. 1 Service kit for MK7 tool includes replacement blade, screw for nose piece, and instruction card. 1 Replacement blade for MK7 series tools. 1 110-00448 MK7BLADEKIT 110-00449 MK7-449 MK7BLADEKIT MK7-449 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Minimum order quantity for the MK7-449 is 5. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 67 Bundling and Securing C a b l e T i e To o l s Mark 9 Tool MK9 MK9SST Product Selection Article No. Part No. Pkg. Qty. Type Description Cable Tie Series MK9 The Mark 9 tool has the same design features as the MK7 series tools. The MK9 accommodates heavy duty cable ties. T18* thru T250 Series CTT20 thru CTT175 Series EL-TY Series Wide Strap Series 1 110-09000 MK9HT MK9HT The Mark 9 High Tension tool has the same design features as the MK9, but offers an increased tension range. T18* thru T250 Series CTT20 thru CTT175 Series EL-TY Series Wide Strap Series 1 110-09700 MK9RE MK9RE The MK9 Rounded Edge tool has the same design features as the MK9 although it has a special nose piece that leaves a 2mm round tail. T18* thru T250 Series CTT20 thru CTT175 Series EL-TY Series Wide Strap Series 1 110-09600 MK9REF MK9REF The Mark 9 Reduced Effort tool has a reduced effort trigger mechanism for operators with small hands. It has a shorter pawl stroke. T18* thru T250 Series CTT20 thru CTT175 Series EL-TY Series Wide Strap Series 1 110-95000 MK9SST MK9SST Adapted for use with stainless steel ties, the MK9 Stainless Steel tool retains the same design features as the MK9 series. The MK9SST accommodates all HellermannTyton stainless steel ties. All MBT Series for both 304 and 316 materials 1 110-09500 MK9 Service kit for the MK9 tool includes replacement blade, screw for nose piece, and instruction card. 1 MK9-221 Replacement blade for MK9 series 1 MK9SS-114 Replacement blade for MK9SST series tools 1 110-00220 MK9BLADEKIT MK9BLADEKIT 110-00221 MK9-221 110-05114 MK9SS-114 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. * Does not include T18S series ties .08″ wide. Other Mechanical Cable Tie Tools Product Selection Article No. Part No. Type Description Cable Tie Series Pkg. Qty. 110-21000 TWT1 TWT The TytonTwyster is a lightweight and economical twist tool. Offers speed and efficiency. Fits into a pocket. (Color Orange) T18 thru T50 Series CTT20 thru CTT60 Series 1 110-22000 TWT2 TWT The TytonTwyster is a lightweight and economical twist tool. Offers speed and efficiency. Fits into a pocket. (Color Blue) T120 thru T150 Series CTT175 Series 1 110-11150 T150 The T150 Tool is a heavy duty installer controlled tool for use in the field. Pliers T150 action provides mechanical advantage. Padded foam grip handles provide comfort and control. T150 Series CTT175 Series 1 110-11250 T250 T250 T150 thru T250 Series CTT175 Series 1 The T250 has the same design features as the T150 Tool, but can tension and cutoff a wider tie. Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 68 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e T i e To o l s Power Assisted Cable Tie Tools HellermannTyton's Mark 7 and Mark 9 power assisted (MK7P & MK9P) tools utilize pneumatic power to tension and cut-off HellermannTyton cable ties. The MK7P and MK9P tools feature an ergonomic design while offering time/labor savings and ease of use benefits derived from pneumatic power. These tools feature a non-slip, comfortable grip, soft touch trigger, and one touch tensioning/cut-off capability. HellermannTyton’s pneumatic cable tie tools are lightweight, high performance, and suited for extended use. Product Features - Ergonomic The ergonomic design of the pneumatic cable tie tools incorporates a comfortable grip, low weight, and easy trigger depression to reduce installer effort and strain while installing cable ties. MK9P - Operation MK7P & MK9P speed assembly. Just one pulse of the soft touch trigger assembly actuates an immediate tension and cut-off of the cable tie. - Cable tie waste is ejected to the side after the cable tie is applied,ensuring smooth operation of the tool. Uses dry or lubricated air. Operates between 90 PSI and 105 PSI maximum. Supplied with a 6 inch lead which comes with a male quick connect fitting with a female coupler for 1/8″ flow. - Design HellermannTyton's pneumatic tools are manufactured with tough, chromium steel components and high impact, glass reinforced nylon housings for maximum durability. - Tensioning An easy to read indicator verifies tension settings. The tools feature an easy dial-in tension adjustment, along with a lockout capability. The tension adjustment on the MK7P and the MK9P is designed with an operator friendly, positive ″click″ design for easy use. The tension can readily be locked out to allow the tension adjustment to remain at a constant setting that can only be changed by approved personnel. The fine adjust tension knob has an unique lever feature used to reduce adjustment torque. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 69 Bundling and Securing C a b l e T i e To o l s Mark 7 Pneumatic The Mark 7 Pneumatic (MK7P) is built to perform in demanding production and manufacturing environments. Heavy duty precision parts ensure repeatability in the tensioning process. The MK7P fits comfortability in the operator's hand, reducing hand, arm and wrist fatigue. Due to its ergonomic features, HellermannTyton's MK7P makes it easier for the installer to consistently apply cable ties while maintaining correct tension and flush cut-off. Safety is enhanced, as the MK7P can eliminate sharp edges of a cut-off cable tie. MK7P Material Data Power Supply Dry or lubricated air Cycle Time 4 strokes per second Weight Pawl Travel Stroke Tension Force 16oz 1.0″″ (2.54 cm) 60 to 170 N, adjustable Product Selection Article No. Part No. Type 110-07101 MK7P MK7P Description Cable Tie Series Includes Mark 7 Pneumatic tool and quick connect fittings. T18 thru T50 Series Ergonomic tool uses pneumatic power and accomplishes rapid CTT20 thru CTT60 Series tension and cut-off with one trigger depression. 110-07111 MK7P-342 Replacement Blade MK7P Replacement Blade Minimum order quantity for MK7P-342 is 5. w w w . h e l l e r m a n n . t y t o n . c o m | 1 1 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. 70 Pkg. Qty. 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e T i e To o l s MK9 Pneumatic The Mark 9 Pneumatic (MK9P) is constructed with heavy duty parts to ensure that it performs optimally in demanding environments. It is ideally designed to apply heavy-duty ties (T50-T250), clamp and button head ties. Like the MK7P, HellermannTyton's MK9P incorporates the next level of ergonomic improvement with its low weight, comfortable grip and easy trigger depression. Very durable, the pneumatic MK9P features adjustable, easy to read tension settings. Lock-out features are available. MK9PUA (Upper Air) The MK9P is available with lower air attachment (standard) or can be ordered with an upper air attachment. Material Data Power Supply Dry or Lubricated Air Cycle Time 2 strokes per second Weight Pawl Travel Stroke Tension Force 32oz 1.25″″ (3.175 cm) MK9P 60 to 170 N, adjustable Product Selection Article No. Part No. Type Description Cable Tie Series Pkg. Qty. MK9P Includes Mark 9 Pneumatic tool and quick connect fittings. Included is a 1/8″ flow quick disconnect fitting and a 10″ whip and 1/8″ make fitting. Ergonomic tool uses pneumatic power and accomplishes rapid tension and cut-off with one trigger depression. T50 thru T250 Series CTT20 thru CTT175 Series EL-TY Series Button Head Ties 1 110-09112 MK9PUA MK9P Includes Mark 9 Pneumatic tool with upper air option for top air T50 thru T250 Series connection. Supplied with a 1/8″ flow quick disconnect fitting and a CTT20 thru CTT175 Series 10″ whip and 1/8″ quick disconnect fitting. Includes a hanger for EL-TY Series an optional overhead tool balancer (not included). Ergonomic tool Button Head Ties uses pneumatic power and accomplishes rapid tension and cut-off with one trigger depression. 1 110-09111 MK9P-109 MK9P-109 110-09101 MK9P MK9P Replacement Blade 1** Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. **Minimum order quantity of MK9P-109 is 5. Common Accessories for MK7P and MK9P HellermannTyton offers a portable kit that incorporates carbon dioxide (CO2) as the primary air source. This unique feature will allow for greater flexibility and the elimination of air line to the tool. Product Selection Article No. Part No. 110-09002 MKPCOKIT 110-09003 MKPCOTANK Type Description Pkg. Qty. MKPCOKIT MKPC0KIT is a complete kit that includes the belt, holster, hose/regulator, pouch and 16oz air tank. 1 MKPCOTANK Standard 16oz air tank for C02 air supply to tool. 1 110-09004 MKPCOTANK20 MKPCOTANK20 Special 20oz canister tank for C02 feature. 1 110-09005 MKPCOHOSE MKPCOHOSE Hose attachment from air tank to the tool with regulator. 1 110-09006 MKPCOBELT MKPCOBELT Adjustable belt for air tank and pouch and tool holster for MK7P or MK9P tools. 1 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 71 Bundling and Securing C a b l e T i e To o l s Automatic Cable Tie Systems HellermannTyton's automatic cable tie tool systems are compact, fast, reliable, and versatile, accommodating a variety of wiring harness, and bundling and securing requirements. These tool systems are designed to provide significant labor and cost savings through process improvements, lower installed costs and greater consistency, quality and ergonomic benefits. Product Features - Fast Cable ties are installed quickly with one easy trigger depression, increasing productivity while decreasing labor costs. - Reliable HellermannTyton's automatic cable tie systems have been tested to perform extremely consistently without interruption to work flow. - Ergonomic The ergonomic design of the automatic cable tie tool systems feature a comfortable grip, low weight, and easy trigger depression to reduce installer effort and strain while installing cable ties. - Easy to Use - Providing Valuable Operator Feedback Equipped with a self-diagnostic LED information panel, the automatic cable tie systems easily guide the user through the cycles of cable tie installations. ATS3080 - Automation The automatic cable tie systems can be implemented into fully automated applications to further increase productivity and decrease labor costs. - Flexible Manufacturing/Versatility HellermannTyton's automatic cable tie tool systems support principles of flexible manufacturing requirements and environments. The systems can be used in handheld, bench mount and overhead assembly configurations. The versatile overhead assembly option provides the ultimate integration to the customer's manufacturing area. HellermannTyton's automatic tools are powered by a standard 110 AC 24V (AT2000) and 110 AC 27 V (AT2060) electrical outlet that converts to a low DC voltage to the tool. All power systems offer the installer the mobility needed to tackle different harnessing requirements. Product Selection - Uniform Fastening Quality HellermannTyton's automatic cable tie systems feature adjustable tension control to deliver consistent levels of cable tie fastening. Article No. - Range HellermannTyton offers the widest range of automatic cable tie tool systems which cover cable tie tensile strengths of 18, 30, and 50 pounds with bundle diameters between 1/16″ to over 3″. 72 w w w . h e l l e r m a n n . t y t o n . c o m | An LED panel shows the status of the tool. Part No. Max. Ø Bundle 120-00000 AT2000 .75″ (20 mm) 103-00000 AT2060 1.25″ (31 mm) 102-00000 ATS3080 3.14″ (80 mm) 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e T i e To o l s AT2000 For bundles up to 3/4” HellermannTyton's AT2000 completely installs cables ties on bundles up to 3/4″ in diameter. This automatic cable tie tool is highly reliable and offers ergonomic benefits including low weight, easy trigger depression, a comfortable hand grip and correct balance—all which reduce operator strain. The AT2000 possesses an LED panel which makes it easier to maintain and operate the tool. AT2000 Cable Tie Specifications Operating Temperature Natural Polyamide 6.6 AT2000 Technical Specifications Power Supply Electrical, with Power Pack or Battery Pack Cycle Time Heat stabilized, black 0.8 s Weight 2.6lbs Installation Handheld, bench mount or overhead Tension Force -40 °F to +185 °F (-40 °C to +85 °C) continuous -40 °F to +221 °F (-40 °C to +105 °C) Polyamide 6.6 continuous Natural, Stanyl Polyamide 4.6 -40 °F to +275 °F (-40 °C to +135 °C) .10” (2.5) .14” (3.6) .19” (4.8) 4” (101) continuous Adjustable Reel Diameter 17.7 ″ (450) Reel Width 5.20 ″ (132) AT2000 Cable Ties File# E64139 Product Selection Article No. Part No. Min. Tensile Strength Max. Ø Bundle lbs. (N) in. (mm) Type Description Autotool 2000 Includes AT2000 tool, power supply, power cord, tool cord, and manual 1 Control Box Control Box for linking AT2000 to automation 1 T18RA50-N66-NA Cable ties on bandolier for use with the AT2000 18 lbs (80) .75″ (20) 20,000 per carton includes: 50 per bandolier 500 per package 120-46009 T18RA3500 T18RA3500-N66-NA Cable ties on reel for use with the AT2000 18 lbs (80) .75″ (20) 14,000 per carton includes: 3,500 per reel 4 reels per carton 120-05009 T18RA5000 T18RA5000-N66-NA Cable ties on reel for use with the AT2000 18 lbs (80) .75″ (20) 10,000 per carton includes: 5,000 per reel 2 reels per carton Cable ties on bandolier for use with the AT2000 18 lbs (80) .75″ (20) 20,000 per carton includes: 50 per bandolier 500 per package Cable ties on reel for use with the AT2000 18 lbs (80) .75″ (20) 10,000 per carton includes: 5,000 per reel 2 reels per carton Cable ties on reel for use with the AT2000 18 lbs (80) .75″ (20) 10,000 per carton includes: 5,000 per reel 2 reels per carton 120-00000 AT2000 120-00060 120-00060 Pkg. Qty. Natural Cable Ties 120-40009 T18RA50 Black, Heat Stabilized Cable Ties 120-40010 T18RA50HSW T18RA50-HSW-BK 120-05010 T18RA5000HSW T18RA5000-HSW-BK Natural, Stanyl Cable Ties 120-04609 T18RA5000HR T18RA5000HR-N46 V/O rated ties can be made available for the AT2000. Various tie colors available upon request (Contact HellermannTyton for lead time). Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. For information on AT2000's Bench Mount System and Overhead Suspension Assembly see page 75–76. For information on Wire Retainers for Harness Boards and AT2000's battery pack see page 77. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 73 Bundling and Securing C a b l e T i e To o l s AT2060 HellermannTyton's AT2060 automatically installs cable ties for bundles up to 1-1/4″. The many ergonomic benefits include easy trigger depression and low weight that reduces operator effort and strain. Operation and maintenance of the tool are enhanced by the self-diagnostic LED panel located on the AT2060. AT2060 Technical Specifications Power Supply AT2060 Cable Tie Specifications Operating Temperature Electrical Cycle Time 1.2 seconds Weight Natural Polyamide 6.6 3.9lbs Pawl Travel Stroke 1.25″″ (3.175 cm) Tension Force Adjustable Heat stabilized, black, Polyamide 6.6 Reel Diameter Reel Width Reel Weight -40 °F to +185 °F (-40 °C to +85 °C) .18” (4.6) .14” (3.6) -40 °F to +221 °F (-40 °C to +105 °C) .23” (5.8) 17.7 ″ (450) 7.197 ″ (182.8) 6” (152) 7 lbs Product Selection Article No. Part No. 103-00000 AT2060 Min. Tensile Strength Max. Ø Bundle lbs. (N) in. (mm) Type Description AT2060 Includes AT2060 tool, power supply, power cord, tool cord, and maintenance and operation manual. Pkg. Qty. T30RA Cable ties on a bandolier for use with the AT2060 tool 30 lbs (133.44) 1.25″ (31) 6,000 per carton includes: 30 per bandolier 600 per bag T30RA3000 Cable ties on a reel for use with the AT2060 tool 30 lbs (133.44) 1.25″ (31) 6,000 per carton includes: 3,000 per reel 2 reels per carton T30RA Cable ties on a bandolier for use with the AT2060 tool 30 lbs (133.44) 1.25″ (31) 6,000 per carton includes: 30 per bandolier 600 per bag T30RA Cable ties on a reel for use with the AT2060 tool 30 lbs (133.44) 1.25″ (31) 6,000 per carton includes: 3,000 per reel 2 reels per carton 1 Natural Cable Ties 103-00002 T30RA30 103-00001 T30RA3000 Black, Heat Stabilized Cable Ties 103-00003 T30RA300HS 103-00004 T30RA30000HS Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. V/O rated ties and 4/6 ties for high temperatures can be made available for the AT2060. Various colors available upon request (Contact HellermannTyton for lead time). For information on AT2060's Bench Mount System and Overhead Suspension Assembly see page 75–76 For information on Wire Retainers for Harness Boards see page 77 74 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e T i e To o l s AT2000 & AT2060 Bench Mount System HellermannTyton offers a portable bench mount system which works with the AT2000 and AT2060 tool systems. It is extremely easy to set up and use. Within seconds, the AT2000 or the AT2060 can be converted from a handheld tool to a bench mount system. With the touch of the foot pedal, the cable tie is applied. AT2000 and AT2060 Bench Mount System Product Selection Article No. 120-00040 Part No. AT2BENCHMOUNT Type Description Pkg. Qty. Bench Mount Kit Includes foot pedal, tie reel stand and tool mounting stand 1 Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 75 Bundling and Securing C a b l e T i e To o l s AT2000 or AT2060 Overhead Suspension Assembly HellermannTyton’s overhead suspension assembly system holds the AT2000 or AT2060, reel of cable ties, and power source. The overhead assembly is available in several configurations in a variety of mounting options and is easily integrated into various manufacturing environments. The modular design allows for easy additions or modifications of the system design. The overhead assembly system provides additional ergonomic advantages to the AT2000 and AT2060. The system features overhead hanging, a trolley slide which allows for mobility within the frame, and an adjustable counter balance. These features allow for low operator strain and easy use. Since the assembly integrates the automatic cable tie systems and reel of ties, continuous feed is achieved. Reloading of cable ties is greatly reduced, further optimizing efficiencies. The picture shows just one configuration of an overhead assembly. The HellermannTyton team of tool systems specialists will assist in the custom design of a system to specially accommodate individual manufacturing sites and production needs. The modular features and inherent ergonomic benefits improve production and make operation more efficient. Contact HellermannTyton for more information. Fasteners for unit assembly are included. Permanent mounting fasteners are not included. Mobile Trolley Unit Configuration 76 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e T i e To o l s AT2000 Battery Pack HellermannTyton’s battery pack powers the AT2000 and is worn by the operator, allowing for complete mobility. Product Selection Article No. Type Description 120-00030 AT06500030 Part No. Battery Pack Battery with belt clip and connector cord Pkg. Qty. 1 120-00010 AT06500020 Battery Charger Charging unit for battery 1 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Wire Retainer for Harness Boards Designed for use in harness board assemblies, these wire retainers stand-off wire and cable bundles for easier cable tie application. Wires are individually inserted, and bundles are preformed, making harnessing easier. Wire Retainer for Harness Boards Product Selection Height (H) Article No. 120-00080 Part No. HH-20 Type Description HH20 Harness Board Assembly in. (mm) 2.12 ″ Width (W) Max. Ø Bundle in. (mm) (54) 1.22″ (31) in. (mm) .83″ (20) Pkg. Qty. 25 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 77 Bundling and Securing C a b l e T i e To o l s AutoTool System 3080 For bundles up to 3.14” HellermannTyton's ATS3080 automatically installs cable ties for bundles up to 3.14″ in diameter with one trigger depression. This innovative system utilizes strap and closures (ordered separately) to achieve a waste free system. The ATS3080 uses only the required strap length required for the diameter. The strap is outside serrated so that it will not damage sensitive wire and cable bundles. This well balanced tool has ergonomic benefits that include low weight and a comfortable hand grip which reduces operator strain and injury while installing cable ties. The ATS3080 possesses a LED panel that provides critical operational feedback that makes it easier to maintain and operate the tool. The ATS3080 has three jaw diameters available; 1.18″ (30mm), 1.96″ (50mm), and 3.14″ (80mm). The jaws are easily interchanged and further tool adjustment between the three jaw diameters is unnecessary. ATS3080 Technical Specifications Power Supply Cycle Time Weight Installation Tension Force Electrical approx. 1.3 sec. (50 mm jaw) 3.2lbs Mobile, bench mount or overhead Adjustable ATS3080 Cable Tie Specifications Material Polyamide 6.6 high impact modified, heat and UV stabilized (PA66HIRHSUV) Temperature Operating -40 °C to +95 °C continuous, (+105 °C for 5000 h) Flammability UL94 HB Strap Reel Dimensions Closures and strap for ATS3080 Reel Diameter 15.25″″ (387 mm) Reel Width 3.5″″ (88.9 mm) Reel Weight 6lbs (2.72 kg) Closure Reel Dimensions Reel Diameter 78 w w w . h e l l e r m a n n . t y t o n . c o m | 15.25″″ (387 mm) Reel Width 3.5″″ (88.9 mm) Reel Weight 3.5lbs (1.58 kg) 1 - 8 0 0 - 5 3 7 - 1 5 1 2 Bundling and Securing C a b l e T i e To o l s ATS3080 with bench mount ATS3080 with mobile trolley unit ATS3080 with overhead .354” (9) .047” (1.2) .314” (8) .212” (5.4) .177” (4.5) Strap ATS3080 Closures ATS3080 Product Selection Article No. Part No. 102-00000 ATS3080 102-00010 ATS10200010 Min Tensile Unlocking Strength (lbs) Pkg. Qty. ft. (m) Type Description ATS3080 Includes ATS3080 tool, power cord, tool cord, and maintenance and operation manual. Does not include power supply. 1 Power Pack ATS3080 Power Supply Unit for ATS3080 Input: 230/115 VAC, 50-60 Hz Output: 48 VDC, max. 50W 1 Strap Natural ATS3080 ATS3080 Strap 50 lbs 1640 ft. (500) ATS3080 Closure 50 lbs 5000 pcs ATS3080 Strap 50 lbs 1640 ft. (500) ATS3080 Closures 50 lbs 5000 pcs Natural Strap and Closures 102-66109 ATS10266109 102-66209 ATS10266209 Closures Natural ATS3080 Black Strap and Closures 102-66110 ATS10266110 Strap Black ATS3080 102-66210 ATS10266210 Closures Black ATS3080 102-00040 ATS10200040 Bench Mount Kit Bench Mount Kit for ATS 3080 Integrated pneumatic system that coordinates tool and reels. Foot pedal application, other actuation options available 1 102-00050 ATS10200050 Overhead Suspender Overhead Suspender ATS 3080 1 102-00030 ATSTROLLEY Trolley ATS 3080 Trolley 1 Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2 79 Bundling and Securing C a b l e T i e To o l s Quick Tool HellermannTyton's Quick Tool is an automatic bench mount system suited for high volume cable tie applications. This air powered tool accommodates a reel of 5,000 ties and, like HellermannTyton's other automated systems, can be integrated into further automation as well as fully incorporated into conveyor or assembly line applications. Product Features - The system is a one piece, bench top unit which increases efficiency through quick and reliable fastening. - It can be installed where a 110 VAC electrical outlet and pneumatic air source are available. - Provides consistent fastening tension. - Controls fastening tension. - Ties are available in two styles: standard and heat stabilized. - Custom colors for Quick Tool ties are also available. Contact HellermannTyton for more information. QS101 Cable Tie Specifications QS101 Technical Specifications Operating Temperature Natural Polyamide 6.6 Heat stabilized, black, Polyamide 6.6 Reel Diameter Max. Ø Bundle Wattage -40 °F to +185 °F (-40 °C to +85 °C) Power Supply Cycle Time 0.630″″ (16.00 mm) 70W Electrical/Pneumatic Power 1.2 Seconds -40 °F to +221 °F (-40 °C to +105 °C) 18″″ (457 mm) Reel Width 5.20″″ (132 mm) Reel Weight 4.8 lbs (2.18 kg) Weight 40 lbs. Installation Bench Tension Force Adjustable (9.92 lbs - 19.84 lbs) Product Selection Article No. Part No. 105-00000 QS101 Max. Ø Bundle Width (W) Length (L) Min Tensile Unlocking Strength in. in. in. (lbs) (mm) (mm) (mm) Pkg. Qty. Type Description QS101 Includes Quick Tool, power cord, maintenance and operation manual and foot pedal. QTTIE9 Cable ties on reel for use with the Quick Tool. 18 .63 ″ (16) .10 ″ (2.5) 4.0 ″ (101) 10,000 per carton: 5,000 per reel 2 reels per carton Cable ties on reel for use with the Quick Tool. 18 .63 ″ (16) .10 ″ (2.5) 4.0 ″ (101) 10,000 per carton: 5,000 per reel 2 reels per carton 1 Natural Cable Ties 105-00006 QTTIE9 Black Heat Stabilized Cable Ties 105-00001 QTTIEOHS QTTIE0HS Dimensions are approximate and subject to technical changes. Use Part No. for ordering and Type for specification purposes. Various colored cable ties available upon request. Contact HellermannTyton for more information and lead times. 80 w w w . h e l l e r m a n n . t y t o n . c o m | 1 - 8 0 0 - 5 3 7 - 1 5 1 2
CTAM10C2 价格&库存
很抱歉,暂时无法提供与“CTAM10C2”相匹配的价格&库存,您可以联系我们找货
