111-01670
111-01670
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 111-01670 - CABLE TIE, 149.9MM, PAEK, 100LB, BEIGE
111-01670 数据手册
111-01670 Article Number: 111-01670 Description: High-Temp. Cable Tie, 5.9" Long, 100lb Tensile Strength, PAEK, Beige, 100/pkg Base Data Local Order Number 111-01670 Type PAT100R Color Beige (BGE) Features and benefits ‡Very high heat resistance up to 200°C (392°F). ‡PAEK material has 2X higher tensile strength than nylon. ‡PAEK material offers very good chemical resistance against hydrocarbons. Quantity Per bag Product Description HellermannTyton PAEK cable ties offer very high temperature resistance for use in demanding applications such as in engine compartments, near exhaust, and in enclosed industrial cabinets. The PAEK ties are inside serrated and feature a high performance design that, along with the material, offer extremely high tensile strength for tough applications. Short Description High-Temp. Cable Tie, 5.9" Long, 100lb Tensile Strength, PAEK, Beige, 100/pkg Minimum Tensile Strength (Imperial) 100.0lbs Minimum Tensile Strength (Metric) 445.0N Length L (Imperial) 5.9" Length L (Metric) 149.9mm Width W (Imperial) 0.33" Width W (Metric) 8.0mm Bundle Diameter Min. (Imperial) 0.06" Bundle Diameter Min. (Metric) 1.5mm Bundle Diameter Max. (Imperial) 1.38" Bundle Diameter Max. (Metric) 35.0mm Material Polyaryletherketone (PAEK) Material Shortcut PAEK Product Dimensions Material and Specifications generated on: 5/9/2017 111-01670 Material and Specifications Flammability UL 94 V0 Operating Temperature -67°F to +392°F (-55°C to +200°C) ROHS Compliant Yes Package Quantity (Imperial) 100 Package Quantity (Metric) 100 Customs Number(Schedule B) 3926909987 Logistic and Packaging generated on: 5/9/2017
111-01670 价格&库存
很抱歉,暂时无法提供与“111-01670”相匹配的价格&库存,您可以联系我们找货
