Cable Ties and Fixings
1.4
Cable Ties, Releasable
Cable Tie with quick release mechanism
Speedy-Click
SpeedyTie®
The versatility of the SpeedyTie® means that it is suitable for a multitude
of applications, such as electrical installations, heating and ventilation,
construction, exhibitions and trade fairs. Whether it is used for
permanent or temporary solutions, the SpeedyTie® provides a helping
hand in every situation.
Features and Benefits
• Releasable cable tie
• Removable, patented 'Speedy-Click' rapid closure
• Bears loads of up to 888 N (approx. 90 kg)
• 750 mm long for use in a wide variety of applications
• Easy to handle when wearing protective gloves
• Available in signal yellow and black
Patented quick release mechanism for quick and easy application.
Patented
Excess Tails can be neatly tucked away.
Application video:
SpeedyTie®
SpeedyTie® – Quick and easy.
SpeedyTie® is particularly suited for
temporary but safe bundling or fixing.
L
W
TYPE
SpeedyTie (RTT750HR)
Width
(W)
Length
(L)
Bundle
Ø max.
Material
Colour
Pack
Cont.
13.0
752.0
210.0
888
Article-No.
PA66
Yellow (YE), Red (RD)
5 pcs.
115-00001
13.0
752.0
210.0
13.0
752.0
210.0
888
PA66
25 pcs.
115-00000
888
PA66HIR(S)
Black (BK)
5 pcs.
115-00030
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content. Other packaging options may also be available.
80
Further information at www.HellermannTyton.com/fixings
Date of issue: October 2015
SpeedyTie®
1.0
Material Information
Material Specification Overview
Material
Shortcut
Operating
Temperature
Aluminium-alloy
AL
-40 °C to +180 °C
Natural
(NA)
• Corrosion resistant
• Antimagnetic
Chloroprene
CR
-20 °C to +80 °C
Black (BK)
• Weather-resistant
• High yield strength
Ethylene
Tetrafluoroethylene
E/TFE
-80 °C to +170 °C
Blue (BU)
UL94 V0
Polyacetal
POM
-40 °C to +90 °C,
(+110 °C, 500 h)
Natural
(NA)
UL94 HB
Polyamide 11
PA11
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
Polyamide 12
PA12
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
• Good chemical resistance to:
acids, bases, oxidizing agents
• UV-resistant
Polyamide 4.6
PA46
-40 °C to +150 °C
(5000 h), +195 °C
(500 h)
Natural
(NA),
Grey (GY)
UL94 V2
• Resistance to high temperatures
• Very moisture sensitive
• Low smoke sensitive
Polyamide 6
PA6
-40 °C to +80 °C
Black (BK)
UL94 V2
PA6HIR
-40 °C to +80 °C
Black (BK)
UL94 HB
• Limited brittleness sensitivity
• Higher flexibility at low temperature
Polyamide 6.6
PA66
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK),
Natural
(NA)
UL94 V2
Polyamide 6.6,
PA66GF13,
PA66GF15
-40 °C to +105 °C
Black (BK)
UL94 HB
• Good resistance to: lubricants, vehicle
fuel, salt water and many solvents
PA66HSW
-40 °C to +105 °C
Black (BK)
UL94 V2
• Modified elevated max. temperature
• UV-resistant
Polyamide 6.6,
heat stabilised
PA66HS
-40 °C to +105 °C
Black (BK),
Natural
(NA)
UL94 V2
• Modified elevated
max. temperature
Polyamide 6.6,
high impact modified
PA66HIR
-40 °C to +80 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
Polyamide 6.6,
high impact modified, heat
and UV stabilised
PA66HIRHSW
-40 °C to +110 °C
Black (BK)
UL94 HB
Polyamide 6.6,
stabilised
PA66HIRHS
-40 °C to +105 °C
Black (BK)
UL94 HB
Polyamide 6.6,
high impact modified, scan
black
PA66HIR(S)
-40 °C to +80 °C,
(+105 °C, 500 h)
Black (BK)
UL94 HB
PA66W
-40 °C to +85 °C,
(+105 °C, 500 h)
Black (BK)
UL94 V2
• UV-resistant
Polyamide 6,
glass-fibre reinforced
Polyamide 6.6,
heat and UV stabilised
Polyamide 6.6,
UV-resistant
Colour**
Material
Properties*
Flammability
Tefzel® is a registered trademark of DuPont. General linguistic usage for cable ties made from raw material E/TFE is Tefzel®Tie. In additon to Tefzel® from DuPont HellermannTyton is also using equivalent E/TFE raw material from other suppliers.
• Resistance to radioactivity
• UV-resistant, not moisture sensitive
• Flexible at low temperature
• Not moisture sensitive
• Robust on impacts
• Bio-plastic, derived from vegetable oil
• Strong impact resistance at low
temperature
• Very low moisture absorption
• Weather-resistant
temperature
• High yield strength, UV-resistant
**More colours on request.
*These details are only rough guide values. They should be regarded as a material specification and are no substitute for a
suitability test. Please see our datasheets for further details.
HF = Halogenfree
LFH = Limited Fire Hazard
RoHS = Restriction of Hazardous Substances
24
Material
Specifications
MATERIAL
Material
Shortcut
Operating
Temperature
Polyamide 6.6,
with metal particles
PA66MP
Polyamide 6.6 V0
MATERIAL
Material
Properties*
Colour**
Flammability
-40 °C to +85 °C,
(+105 °C, 500 h)
Blue (BU)
UL94 HB
• Metal and X-Ray detectable
PA66V0
-40 °C to +85 °C
White (WH)
UL94 V0
• Low smoke emission
PA66V0-HOI
-40 °C to +85 °C,
(+105 °C, 500 h)
White (WH)
UL94 V0
• Low smoke emissions
SP
-50 °C to +150 °C
Black (BK)
Halogen free
• UV-resistant
most acids, alkalis and oils
PEEK
-55 °C to +240 °C
Beige (BGE)
UL94 V0
Polyethylene
PE
-40 °C to +50 °C
Black (BK),
Grey (GY)
UL94 HB
• Low moisture absorption
• Good chemical resistance to: most
acids, alcohol and oils
Polyolefin
PO
-40 °C to +90 °C
Black (BK)
UL94 V0
Polypropylene
PP
-40 °C to +115 °C
Black (BK),
Natural
(NA)
UL94 HB
• Floats in water
• Moderate yield strength
organic acids
PP, EPDM
-20 °C to +95 °C
Black (BK)
UL94 HB
• Good resistance to high temperatures
• Good chemical and abrasion
resistance
Polyamide 6.6 V0,
High Oxygen Index
Polyester
Polyetheretherketone
Polypropylene, EthylenePropylene-DienTerpolymere-rubber
free of Nitrosamine
Polypropylene
PPMP
-40 °C to +115 °C
Blue (BU)
UL94 HB
• Floats in certain liquids
• Heat resistant
Polyvinylchloride
PVC
-10 °C to +70 °C
Black (BK),
Natural
(NA)
UL94 V0
acids, ethanol and oil
Stainless Steel,
Stainless Steel
SS304,
SS316
-80 °C to +538 °C
Natural
(NA)
Non burning
• Antimagnetic
• Weather resistant
• Outstanding chemical resistance
Thermoplastic
Polyurethane
TPU
-40 °C to +85 °C
Black (BK)
UL94 HB
• High elasticity
acids, bases and oxidizing agents
1.0
Material
Specifications
HF = Halogenfree
25
