118-04700
Article Number: 118-04700
Outside Serrated Cable Tie, 4" Long, 18lb Tensile Strength, PA66HS, Black, 100/pkg
Download drawing
Download spec sheet
Base Data
Local Order Number 118-04700
Type T18ROS
Color Black (BK)
Features and Benefits • Outside serrations minimize damage to cables, while still providing high tensile strength and low insertion force.
• Contour style head design provides additional space in constrained areas.
• Heat stabilized material provides excellent resistance to high heat exposures.
Product Description HellermannTyton outside serrated cable ties are designed with a smooth inside surface to help minimize indentation
or damage to wire and cable insulation, while offering high tensile strength and low insertion force. The contour style
head takes up less space than traditional style cable ties making it ideal for space constrained areas. For high
volume applications, tensioning tools are available to ensure consistent and safe installation.
Short Description Outside Serrated Cable Tie, 4" Long, 18lb Tensile Strength, PA66HS, Black, 100/pkg
Product Dimensions
Minimum Tensile Strength (Imperial) 18.0 lbs
Minimum Tensile Strength (Metric) 80.0 N
Length L (Imperial) 4.0 "
Length L (Metric) 100.0 mm
Fixation Method None
Identification Plate Position none
Releasable Closure No
Tie Closure plastic pawl
Variant Outside Serrated
Width W (Imperial) 0.1 "
Width W (Metric) 2.5 mm
Height H (Imperial) 0.039 "
Height H (Metric) 1 mm
Bundle Diameter Min. (Imperial) 0.06 "
Bundle Diameter Min. (Metric) 1.6 mm
Bundle Diameter Max. (Imperial) 0.79 "
Bundle Diameter Max. (Metric) 20.0 mm
Thickness T (Imperial) 0.039 "
Cable Tie Head Length (Imperial) 0.2 "
Cable Tie Head Width (Imperial) 0.2 "
Thickness T (Metric) 1 mm
Logistics and Packaging
Quantity Per bag
Package Quantity (Metric) 100 Pieces
Carton Quantity 25000 Pieces
Weight (Metric) 0.28 kg
Material and Specifications
Material Polyamide 6.6 heat stabilized (PA66HS)
Material Shortcut PA66HS
Flammability UL94 V2
Halogenfree Yes
Operating Temperature -40°F to +221°F (-40°C to +105°C)
ROHS Compliant Yes
Certification/Specification PAN6481
© HellermannTyton 2015
很抱歉,暂时无法提供与“118-04700.”相匹配的价格&库存,您可以联系我们找货
