151-01908
151-01908
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 151-01908 - Cable Tie Mount, Self Fixing Cradle, Push Barb, 6.3 mm, Natural, Nylon...
151-01908 数据手册
Cable Securing Systems CABLE TIE MOUNT - LKCRF1 When a low profile mount is required for fixing cable harnesses, the LKCRF1 is ideal. For use with standard or releasable ties up to 4.8mm wide. Simply knock in the rivet peg for a simple yet secure fixing. Panel Thickness - 3mm max. Hole Diameter - 6.5mm Material: Nylon Colour: Black SELF FIXING CRADLES - SFC1/SFC2/SFC3 A simple fixing method for use in pre drilled or punched holes. Once inserted through the hole, the cradle locks into place. Ideal for areas where access is limited to one side only. SFC1 & SFC2 - Will accept cable ties up to 4.8mm wide. Material - Nylon 6.6. Colour - Natural SCF3 - Will accept cable ties up to 8mm wide. Material - Nylon 6.6. Colour - Black Reference A (mm) B (mm) C (mm) Hole Dia. (mm) Panel Thickness (mm) 8 18.0 6.0 6.0 3.2 SFC2 9 14.5 6.0 6.0 1.0 SFC3 22 15.7 7.3 6.4 1.8 SFC1 Cable Fixing Accessories Designed to secure cables or harnesses where fixing holes are undesirable or impractical. The RA Range of self adhesive clips keeps labour costs to a minimum and can be applied to most smooth, clean and dry surfaces. The circular design of the clips makes them ideal for single cables or pipes. Reference A mm 13.0 19.0 19.0 25.0 28.5 RA3 RA6 RA9 RA13 RA18 B mm 13.0 19.0 19.0 25.0 28.5 2/15 B h H ll (P ) L d C mm 5.0 5.0 7.5 10.0 10.0 D mm 5.0 9.0 12.5 16.5 23.0 E mm 3.0 6.0 9.0 13.0 18.0
151-01908 价格&库存
很抱歉,暂时无法提供与“151-01908”相匹配的价格&库存,您可以联系我们找货
