161-60001
161-60001
    HELLERMAN(海尔曼太通)
    1/4" HELAWRAP APP TOOL BLU 10/PK
161-60001 数据手册
Specification Sheet Part Number: 161-60001 Designed to glide smoothly through the Helawrap sleeve for easy insertion of cable bundles There is no need to disassemble wire harness when using the Helawrap Application Tool Tool is designed for post-installation applications, allowing for unplanned engineering changes to be corrected with ease Helawrap, Application Tool for HWPP08 and HWPA6V08, 5/16", Blue, 10/pkg Article Number 161-60001 Type HAT8 Color Blue (BU) Quantity Per bag Product Description The Helawrap Applicator Tool enables the user to bundle cable rapidly and effortlessly. The applicator tool has been optimized to glide smoothly and securely through the cover and therefore allow easy insertion of cable into Helawrap. The unique design also allows individual cables to be separated from the applicator tool and branched off through the cover apertures. A tool is included with each Helawrap box. Additional tools can be purchased separately. Short Description Helawrap, Application Tool for HWPP08 and HWPA6V08, 5/16", Blue, 10/pkg Global Part Name HAT8-PA66-BU Nominal Diameter (Imperial) 0.31 Nominal Diameter (Metric) 8 Material Polyamide 6.6 (PA66) Material Shortcut PA66 Halogen Free Yes Reach Compliant (Article 33) Yes ROHS Compliant Yes Package Quantity (Imperial) 10 Package Quantity (Metric) 10 Customs Number 8205599000 © 2021 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
161-60001
- 物料型号:161-60001 - 器件简介:Helawrap Applicator Tool,用于快速轻松地捆绑电缆,优化设计以平滑且安全地穿过护套,允许将电缆轻松插入Helawrap。独特的设计还允许通过护套孔将个别电缆从应用工具上分离并分支出去。 - 引脚分配:文档中未提供引脚分配信息。 - 参数特性: - 型号:HAT8 - 颜色:蓝色 (BU) - 公称直径(英制):0.31 - 公称直径(公制):8 - 材料:聚酰胺 6.6 (PA66) - 无卤素:是 - 符合REACH法规(第33条):是 - 符合ROHS:是 - 包装数量(英制):10 - 包装数量(公制):10 - 海关编号:8205599000 - 功能详解:文档中未提供详细的功能解释。 - 应用信息:该工具设计用于安装后的应用,允许轻松纠正计划外的工程变更。 - 封装信息:Helawrap, Application Tool for HWPP08 and HWPA6V08, 5/16", Blue, 10/pkg
161-60001 价格&库存
很抱歉,暂时无法提供与“161-60001”相匹配的价格&库存,您可以联系我们找货
    • 1+19.633991+2.53120
    • 3+17.442703+2.24870
    • 5+14.900805+1.92100
    库存:21
