175REF
Article Number: 590-01751
Rite-On Self-Laminating Label Refill, .75" X .75" X 3.0", Vinyl, White, 90/RL
Download spec sheet
Base Data
Local Order Number 175REF
Type 175REF
Color White (WH)
Features and Benefits • Compact to easily fit in pants or shirt pockets.
• Dispenser can be reloaded over and over, making it cost effective to use.
• Dispenser edge allows easy removal of label liner.
• Dispenser protects labels from dirt and moisture before use, extending the life and quality of the labels.
Color Marking Field White (WH)
Product Description HellermannTyton’s Rite-On Markers are made from a flexible vinyl film and used to mark wire and cable. The selflaminating labels have a clear tail which seals the legend under clear vinyl, maintaining the quality of the labels. The
Rite-On markers are packaged in a reusable dispenser made from high impact plastic which is resistant to oils and
grease.
Mounting method Identification ETIM Pasting / Stick
Short Description Rite-On Self-Laminating Label Refill, .75" X .75" X 3.0", Vinyl, White, 90/RL
Product Dimensions
Length L (Imperial) 0.75 "
Length L (Metric) 19.05 mm
Fixation Method Pasting / Stick
Self adhesive (Yes/No) Yes
Variant Roller form
Width W (Imperial) 0.75 "
Width W (Metric) 19.05 mm
Height H (Imperial) 0.75 "
Height H (Metric) 19.05 mm
Height H2 (Imperial) 3.0 "
Height H2 (Metric) 76.20 mm
Bundle Diameter Min. (Imperial) 0.33 "
Bundle Diameter Min. (Metric) 8.32 mm
Bundle Diameter Max. (Imperial) 0.7 "
Bundle Diameter Max. (Metric) 17.78 mm
Outside Diameter Min. (Imperial) 0.33 "
Outside Diameter Min. (Metric) 8.38 mm
Outside Diameter Max. (Imperial) 0.7 "
Outside Diameter Max. (Metric) 17.78 mm
Logistics and Packaging
Quantity Per pack
Package Quantity 90
Package Quantity (Metric) 90
Carton Quantity 1 Pieces
Material and Specifications
Material Type 100, Vinyl (PVC), white (WH), self laminating
Material Shortcut 100
Adhesive Acrylic
Adhesive Shortcut Acrylic
Adhesive Operating Temperature -51°F to +200°F (-46°C to +93°C)
ROHS Compliant Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“175REF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+147.110751+19.06836
