318-60153
318-60153
    HELLERMAN(海尔曼太通)
    HEATSHRNK9/3BK4'
318-60153 数据手册
318-60153 Article Number: 318-60153 Heat Shrink Tubing, 4FT-Stick, Adhesive Lined, 3:1, 3/8", 9.0/3.0 dia., Polyolefin, Black, 15/pkg Download spec sheet Base Data Local Order Number 318-60153 Type TAN33-ST-9/3 BK Color Black (BK) Features and Benefits • Adhesive lining provides an excellent seal against moisture and humidity. • 3 to 1 shrink ratio accommodates a wide range of component shapes and diameters, while thin exterior wall is very flexible and provides superior insulation. • Meets UL224 VW-1 specifications making it ideal high heat applications (excludes clear tubing). • Polyolefin material provides mechanical strength with good resistance to solvents, oils and fuels. Product Description TAN33 is a flexible, thin wall adhesive lined heat shrink tubing with highly flame retardant properties. The 3 to 1 shrink ratio accommodates a wide range of component shapes and diameters. The adhesive lining begins to activate as the temperature reaches 176° F (80° C), to create a strong seal against moisture and humidity. 4-foot sticks are individually labeled for retail. Short Description Heat Shrink Tubing, 4FT-Stick, Adhesive Lined, 3:1, 3/8", 9.0/3.0 dia., Polyolefin, Black, 15/pkg Product Dimensions Length L (Imperial) 4.0 ft Length L (Metric) 1.22 m Printable (Yes/No) No Shrink Ratio 3:1 Tensile Strength (MPa) 12 MPa Trade Size 3/8 " Variant Thin-Wall Volume Resistance (Ohm cm) 10¹ Ω cm Nominal Diameter (Imperial) 3/8 " Nominal Diameter (Metric) 9 mm Wall Thickness WT (Imperial) 0.056 " Wall Thickness WT (Metric) 1.40 mm Recovered Diameter d (metric) 3.0 mm Recovered Diameter d (imperial) 0.118 " Supplied Diameter D (imperial) 0.354 " Supplied Diameter D (metric) 9.0 mm Logistics and Packaging Quantity Per pack Package Quantity 15 Package Quantity (Metric) 15 Material and Specifications Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X Elongation at break 400% Halogenfree No Shrink Temperature +212 °F (+100 °C) Operating Temperature -67°F to +257°F (-55°C to +125°C) ROHS Compliant Yes UL Recognized (US) Yes © HellermannTyton 2015
318-60153 价格&库存
很抱歉,暂时无法提供与“318-60153”相匹配的价格&库存,您可以联系我们找货
    • 1+58.812461+7.61827
    • 2+54.076752+7.00483
    • 3+51.502693+6.67140
    • 5+48.425895+6.27285
    • 7+46.482547+6.02112
    • 10+44.5327910+5.76856
    库存:31
