318-60158
Article Number: 318-60158
Heat Shrink Tubing, 4FT-Stick, Adhesive Lined, 3:1, 1.5", 40.0/13.0 dia., Polyolefin, Black, 6/pkg
Download spec sheet
Base Data
Local Order Number 318-60158
Type TAN33-ST-40/13 BK
Color Black (BK)
Features and Benefits • Adhesive lining provides an excellent seal against moisture and humidity.
• 3 to 1 shrink ratio accommodates a wide range of component shapes and diameters, while thin exterior wall is very
flexible and provides superior insulation.
• Meets UL224 VW-1 specifications making it ideal high heat applications (excludes clear tubing).
• Polyolefin material provides mechanical strength with good resistance to solvents, oils and fuels.
Product Description TAN33 is a flexible, thin wall adhesive lined heat shrink tubing with highly flame retardant properties. The 3 to 1
shrink ratio accommodates a wide range of component shapes and diameters. The adhesive lining begins to activate
as the temperature reaches 176° F (80° C), to create a strong seal against moisture and humidity. 4-foot sticks are
individually labeled for retail.
Short Description Heat Shrink Tubing, 4FT-Stick, Adhesive Lined, 3:1, 1.5", 40.0/13.0 dia., Polyolefin, Black, 6/pkg
Product Dimensions
Length L (Imperial) 4.0 ft
Length L (Metric) 1.22 m
Printable (Yes/No) No
Shrink Ratio 3:1
Tensile Strength (MPa) 12 MPa
Trade Size 1-1/2 "
Variant Thin-Wall
Volume Resistance (Ohm cm) 10¹ Ω cm
Nominal Diameter (Imperial) 1-1/2 "
Nominal Diameter (Metric) 40 mm
Wall Thickness WT (Imperial) 0.094 "
Wall Thickness WT (Metric) 2.40 mm
Recovered Diameter d (metric) 13.0 mm
Recovered Diameter d (imperial) 0.512 "
Supplied Diameter D (imperial) 1.58 "
Supplied Diameter D (metric) 40.0 mm
Logistics and Packaging
Quantity Per pack
Package Quantity 6
Package Quantity (Metric) 6
Material and Specifications
Material Polyolefin, cross-linked (PO-X)
Material Shortcut PO-X
Elongation at break 400%
Halogenfree No
Shrink Temperature +212 °F (+100 °C)
Operating Temperature -67°F to +257°F (-55°C to +125°C)
ROHS Compliant Yes
UL Recognized (US) Yes
© HellermannTyton 2015
很抱歉,暂时无法提供与“318-60158”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 6+221.696906+28.71751
