553-50024
553-50024
    HELLERMAN(海尔曼太通)
    WHITESHRINKTRAK.375"250/BX
553-50024 数据手册
Specification Sheet Part Number: 553-50024 Slide Slit and optional center slits for easy wire insertion. Smooth surface for clean and legible printing. Supplied on a ladder style carrier so that markers can be kitted after printing. A 3:1 shrink ratio means fewer skews as each marker covers a wider range of wire diameters. ShrinkTrak Labels, 1-Sided, Unslit, 0.38" (9.52mm), PO-X, White, 250/box Article Number 553-50024 Type HST9-3WH Color White (WH) Quantity Per box Product Description HellermannTyton's ShrinkTrak heat shrinkable markers make it easy to mark wire, cable and other components. The military approved heat shrink tubing is flattened and assembled in a ladder style carrier system for easy printing using a thermal transfer printer. The ladder system creates a kit of markers that can be sorted, removed and applied in any order thus saving time, labor and speeding production. Short Description ShrinkTrak Labels, 1-Sided, Unslit, 0.38" (9.52mm), PO-X, White, 250/box Global Part Name HST9-3WH-PO-X-WH Variant Thin-Wall Width W (Imperial) 1.9 Width W (Metric) 48.26 Thickness T (Imperial) .003 Thickness T (Metric) .0762 Height H (Imperial) 0.597 Height H (Metric) 15.16 Width of Liner (Metric) 76.2 Width of Liner (Imperial) 3.0 Outside Diameter OD (Imperial) 0.375 Outside Diameter OD (Metric) 9.52 Outside Diameter Max (Imperial) 0.375 Outside Diameter Max (Metric) 9.52 Wall Thickness WT (Imperial) 0.031 Wall Thickness WT (Metric) 0.79 Material Polyolefin, cross-linked (PO-X) Material Shortcut PO-X US MIL SPEC MIL-STD-202G Method 215K SAE-AMS-DTL-23053/5 Class 1 and 3 SAE-AS81531 Flammability UL 224 VW-1 Halogen Free No UV Resistant (Yes/No) No Operating Temperature -67°F to +275°F (-55°C to +135°C) Reach Compliant (Article 33) Yes ROHS Compliant Yes Certification/Specification UL 224 125 °C 600V VW-1 SAE - AS81531 SAE - AMS - DTL-23053/5 Class 1 and 3 Package Quantity (Imperial) 250 Package Quantity (Metric) 250 Customs Number 3917320000 Labels per Column 1 Labels per Row 1 About HellermannTyton HellermannTyton is a global manufacturer of cable management and identification solutions for automotive, solar, electrical, construction, industrial automation, broadband and other OEM markets. The company's integrated approach to product design, sustainability, production, quality assurance and delivery is optimized to benefit local and global customers. HellermannTyton operates in 39 countries, with North American headquarters in Milwaukee, Wisconsin. (www.hellermann.tyton.com). © 2024 HellermannTyton. All Rights Reserved. Contact Us RoHS/WEEE Compliance Disclaimer Terms and Conditions
553-50024 价格&库存
很抱歉,暂时无法提供与“553-50024”相匹配的价格&库存,您可以联系我们找货
