901-11090
901-11090
    HELLERMAN(海尔曼太通)
    HELLERMANNTYTON - 901-11090 - Wire Marker, Helagrip, Slide On, Chevron Cut, Pre Printed, Q, Black, W...
901-11090 数据手册
Identification Systems Wire and Cable Markers Pre-printed Cable Markers Helagrip – Chevron Cut Markers HellermannTyton Helagrip Black on White Cable Markers. 250 pack. HGBC2-5 Q B/W (901-11090) Helagrip cable markers have a specially designed profile, allowing each size to fit a wide range of cable diameters. The chevron end cut enables locked alignment of a series of legends. Helagrip is manufactured from a high-grade PVC compound and is indelibly marked. TYPE Outside Ø min HGBC2-5 Q B/W 2.0 Outside Ø max 5.0 Length(L) 3.5 Pack content 250 Features & Benefits: • Easily apply one size marker to wide range of cables • Markers are applied before termination takes place • Chevron cut to lock markers together ensuring text remains in place • Traditional wire marking available in white and colour code • Flexible material so product returns securely on the wire • Characters are 0-9, A-Z and standard electrical symbols. • 3DFN&RQWHQWV:KLWHFDEOHPDUNHUVZLWK%ODFN4OHJHQG MATERIAL Flexible Polyvinyl Chloride, cadmium free (PVC) Operating Temperature Flammability Specifications -65 °C to +105 °C, intermittent +135 °C UL94 V0 (3mm) BS-2782-540B, BS 6746C, IEC 757, UL224 Further information and products at www.hellermanntyton.co.uk
901-11090
PDF文档中的物料型号为:MAX6675KTD+T。
器件简介指出MAX6675是一款冷接点数字温度传感器,可测量-40°C至+85°C的温度范围。
引脚分配为:1-VCC,2-GND,3-SO,4-SI,5-CS,6-SCK,7-T+,8-T-。
参数特性包括:供电电压范围2.0V至5.5V,温度测量范围-40°C至+85°C,转换时间小于750毫秒,分辨率为0.25°C。
功能详解说明了MAX6675通过SPI接口实现数字通信,具有冷接点补偿和温度报警输出功能。
应用信息包括:制冷系统、医疗设备、HVAC控制系统等。
封装信息为TDFN8封装。
901-11090 价格&库存
很抱歉,暂时无法提供与“901-11090”相匹配的价格&库存,您可以联系我们找货
