897-90000
    HELLERMAN(海尔曼太通)
897-90000 数据手册
Electrical Installation 4.3 Cable Rods Cable Installation System - Cable Scout+ Cable Scout+ Rod Sets Cable Scout+ is a professional cable routing tool which enables installers to easily route cables, saving time, even with the most challenging installations. The rods are manufactured from high quality Glass Reinforced Plastic (GRP), which enables a load carrying capacity of up to 200 kg. Cable Scout+ offers a range of features which allows the installer to illuminate, grip, inspect and retrieve by using the range of accessories. Cable Scout+ is supplied in a useful durable bag which contains the rods and accessories all in one place. Features and Benefits • Professional cable installation tool • Enables time savings to be achieved even with challenging installations • Rods manufactured from high quality Glass Reinforced Plastic (GRP) • Load carrying capacity of 200 kg • Range of accessories enabling the installer to illuminate, grip inspect and retrieve. • Rods & accessories contained in a useful durable storage bag All components stored neat and tidy with the Cable Scout+ Deluxe set. Basic Set. Handy Set. Application video: Cable Scout+ Content Rods Rod Capacity (m) Content Accessories ArticleNo. Basic Set: designed to perform basic cable installation 10 rods x 1 m (white) 10.0 m 15 cm white flexi lead, gender changer, tuff hook, mini eye 897-90000 CS-SD Deluxe Set: the most comprehensive set aimed for carrying out larger installations 2 rods x 1 m (white) 6 rods x 1 m (red) 2 rods x 1 m (blue) 10.0 m 15 cm white flexi lead, split ring, gender changer, tuff hook, mini eye, domed bullet, flat bullet, beam, single magnet 897-90001 CS-SH Handy Set: made up for fitting in a tool box 1 rod x 40 cm (white) 2 rods x 40 cm (red) 1 rod x 40 cm (blue) 1.6 m 40 cm white flexi lead, domed bullet, mini hook, mini eye 897-90003 TYPE Description CS-SB Subject to technical changes. Cable Scout+ Rod Pairs TYPE Content Rods Flexibility ØD Article-No. CS-P6 One pair of 1 m blue rods strong 6.0 897-90007 CS-PN One pair of 1 m nylon rods fully flexible 5.0 897-90008 CS-P5 One pair of 1 m red rods medium 5.0 897-90006 CS-P4 One pair of 1 m white rods flexible 4.0 897-90005 All dimensions in mm. Subject to technical changes. 376 Further information at www.HellermannTyton.com/installation Overview on Cable Scout+ marginal bending radii. Date of issue: October 2015 Overview of the rods selection. Electrical Installation 4.3 Cable Rods Cable Installation System - Cable Scout+ Cable Scout+ Accessories Cable Scout+ is supplied with a range of useful standard accessories. Additional accessories can be purchased separately. Cable Grips are designed to grip objects and provide reliable and time saving method of securing cables & pipes to the rods. Just open the grip by compressing the braid, push the grip over the cable or pipe and release the grip, which will contract and establish a tight grip on the cable or pipe to the rod set. Features and Benefits • Accessory kit includes a lot of useful tools • User can inspect, illuminate and retrieve • Cable grips allows a very fast way to pull cables • Whisk glides smoothly over obstacles • LED Beam brings light into the dark • Strong magnet lifts metallic tools up to 2.5 kg weight Cable Grips are available in five different sizes to attach a wide range of cable diameters. The Cable Scout+ Beam - a perfect tool for seeing into cavities. The whisk allows the rod to glide over obstructions easily. The strong magnet lifts a metallic tool of up to 2.5 kg. TYPE Drawing Description Article-No. Accessory Kit: Includes a 15 cm long flexi lead, gender changer, mini hook, tuff hook, mini eye, split ring, round bullet, flat bullet, single magnet, chain 897-90004 CS-ACG1630 Cable Grip: Suitable for diameter 1.6 - 3.0 cm 897-90027 CS-ACG0415 Cable grips: Suitable for diameters 0.4 - 1.5 cm 897-90026 CS-AW Whisk: Enables cables to glide over rough and uneven surfaces. 897-90018 CS-AB Beam: Useful LED torch enables inspection of working area. Uses 1 x AAA Battery. 897-90016 Strong Magnet: Enables positioning or retrieval of items weighing up to 2.5 kg. 897-90015 Date of issue: October 2015 CS-SA CS-AMG2 Subject to technical changes. Further information at www.HellermannTyton.com/installation 377
897-90000 价格&库存
很抱歉,暂时无法提供与“897-90000”相匹配的价格&库存,您可以联系我们找货
    • 1+629.70742
    库存:2
    897-90000
      • 1+861.93581
      库存:1
