CFPT-9301 FX A 26.0000MHZ
    IQD
    IQD FREQUENCY PRODUCTS - CFPT-9301 FX A 26.0000MHZ - VCTCXO, 26 MHz, 1 ppm, HCMOS, 3.3 V, SMD, 5mm x...
CFPT-9301 FX A 26.0000MHZ 数据手册
IQD Frequency Products TCXO Specification Incorporating IQD FOQ GmbH Model: CFPT-9301 ISSUE 7; April 2013 - RoHS 2011/65/EU Description Surface mount temperature compensated voltage controlled crystal oscillators for medium to high volume applications where small size and high performance are prerequisites. Manufactured for us by Rakon utilising their Pluto™ ASIC technology and capable of sub 0.3ppm performance over an extended temperature range. Its ability to function down to a supply voltage of 2.4V and low power consumption makes it particularly suitable for mobile applications. Option A (standard): Ageing adjustment by means of external Control Voltage applied to pad 1 Range (frequency ≤ 20MHz) ≥ ±5ppm Range (frequency > 20MHz) ≥ ±7ppm Linearity ≤2% Slope Positive Input resistance ≥100kΩ Modulation bandwidth ≥2kHz Standard control voltage range 1.5V±1V Option B: No frequency adjustment Initial Calibration ≤ ±1.0ppm Outline (mm) Frequency Range Frequency 52.00MHz Supply Voltage Voltage 3.3V ±10% Ageing Ageing ±1ppm max in 1st year (see Note 1) Output Compatibility & Load Output Compatibility Drive Capability HCMOS 15pF max Frequency Stabilities Frequency Stability Test Circuit ±0.20ppm Operating Temperature Ranges -20 to 70°C -40 to 85°C Frequency Parameters Load Variation (@ ±5pF change): Frequency 20MHz: ±5ppm max for 10 years (including the 1st year) Supply Voltage Variation (@ ±5% change): Frequency
CFPT-9301 FX A 26.0000MHZ 价格&库存
很抱歉,暂时无法提供与“CFPT-9301 FX A 26.0000MHZ”相匹配的价格&库存,您可以联系我们找货
