EEH-ZE1J820V
EEH-ZE1J820V
    PANASONICELECTRONICCOMPONENTS
    EEH-ZE1J820V
EEH-ZE1J820V 数据手册
Conductive Polymer Hybrid Aluminum UPGRADE Electrolytic Capacitors High temperature lead-free reflow Hybrid Surface Mount Type ZE series V type Features ● ● ● ● Endurance: 2000 h at 145 ℃ (High temperature / Long life) Low ESR and high ripple current (85 % over, Lower ESR than current V-TP) High-withstand voltage ( to 63 V.DC), Low LC (0.01 CV or 3 μA) Equivalent to conductive polymer type aluminum electrolytic capacitor (There are little characteristics change by temperature and frequency) ● Vibration-proof product is available upon request. (φ8 mm and larger) ● AEC-Q200 compliant ● RoHS compliant Specifications Size code Category temp. range Rated voltage range Nominal cap.range Capacitance tolerance DC leakage current Dissipation factor (tan δ) Endurance 1 Endurance 2 Shelf life Damp heat (Load) Resistance to soldering heat F G –55 ℃ to +145 ℃ 25 V.DC to 63 V.DC 33 μF to 220 μF 56 μF to 330 μF ±20 % (120 Hz / +20 ℃) I ≦ 0.01 CV or 3 (μA) After 2 minutes (whichever is greater) Please see the attached characteristics list +145 ℃ ± 2 ℃, 2000 h, apply the rated ripple current without exceeding the rated voltage Capacitance change Within ±30% of the initial value Dissipation factor (tan δ) ≦ 200 % of the initial limit E.S.R. ≦ 200 % of the initial limit DC leakage current Within the initial limit +135 ℃ ± 2 ℃, 4000 h, apply the rated ripple current without exceeding the rated voltage Capacitance change Within ±30% of the initial value Dissipation factor (tan δ) ≦ 200 % of the initial limit E.S.R. ≦ 200 % of the initial limit DC leakage current Within the initial limit After storage for 1000 hours at +145 ℃ ± 2 ℃ with no voltage applied and then being stabilized at +20 ℃, capacitors shall meet the limits specified in endurance 1. (With voltage treatment) 85 ℃ ± 2 ℃, 85 % to 90 %, 2000 h, rated voltage applied Capacitance change Within ±30% of the initial value Dissipation factor (tan δ) ≦ 200 % of the initial limit E.S.R. ≦ 200 % of the initial limit DC leakage current Within the initial limit After reflow soldering and then being stabilized at +20 ℃, capacitors shall meet the following limits. Capacitance change Within ±10% of the initial value Dissipation factor (tan δ) Within the initial limit DC leakage current Within the initial limit Marking Dimensions (not to scale) (P) F L W Pressure relief (φ10 ≦) G φD L A, B 8.0 10.2±0.3 8.3 Unit:mm H max. 10 I W P K 3.4 0.90±0.2 3.1 0.70±0.2 12.0 3.5 0.90±0.2 4.6 0.70±0.2 10.0 10.2±0.3 10.3 K R (S) H φD±0.5 Rated voltage code A±0.2 F (P) [Vibration-proof product] (I) ( ) Reference size B±0.2 Lot number L R. voltage code E 25 V 35 Size code φD H 50 F 8.0 J 63 G 10.0 Pressure relief (φ10 ≦) Unit:V.DC T W Supportive terminals (I) 220 E ZE Size code (I) Series identification B±0.2 H Capacitance (μF) φD±0.5 Negative polarity marking (–) A±0.2 0.3 max. K (I) [Standard] Example : 25 V.DC 220 μF Marking color : BLACK ( ) Reference size Unit:mm F I W P 10.5±0.3 8.3 H max. 10.0 0 to +0.15 3.4 1.2±0.2 3.1 0.70±0.2 0.70±0.2 5.3 1.3±0.2 10.5±0.3 10.3 12.0 0 to +0.15 3.5 1.2±0.2 4.6 0.70±0.2 0.70±0.2 6.9 1.3±0.2 L A, B K R S T · The dimensions of the vibration-proof products, please refer to the page of the mounting specification. Design and specifications are each subject to change without notice. Ask factory for the current technical specifications before purchase and/or use. Should a safety concern arise regarding this product, please be sure to contact us immediately. 23-Oct-19 Conductive Polymer Hybrid Aluminum Electrolytic Capacitors ZE series Characteristics list Endurance 1 : 145 ℃ 2000 h Endurance 2 : 135 ℃ 4000 h Case size Specification (mm) Rated Capacitance voltage (±20 %) (V.DC) 25 35 (μF) φD Vibration Standard -proof Size code Ripple current *1 (mA rms) Endurance 1 Endurance 2 (+145℃) (+135℃) 700 1600 packaging q'ty ESR *2 (mΩ) tan δ*3 Vibration-proof product Standard product Taping (pcs) 220 8.0 10.2 10.5 F 330 10.0 10.2 10.5 G 900 2000 20 0.14 EEHZE1E331P EEHZE1E331V 500 150 8.0 10.2 10.5 F 700 1600 27 0.12 EEHZE1V151P EEHZE1V151V 500 270 10.0 10.2 10.5 G 900 2000 20 0.12 EEHZE1V271P EEHZE1V271V 500 68 50 L Min. Part number NEW 0.14 EEHZE1E221P EEHZE1E221V 500 8.0 10.2 10.5 F 600 1250 30 0.10 EEHZE1H680P EEHZE1H680V 500 10.0 10.2 10.5 G 800 1600 28 0.10 EEHZE1H101P EEHZE1H101V 500 33 8.0 10.2 10.5 F 600 1100 40 0.08 EEHZE1J330P EEHZE1J330V 500 56 10.0 10.2 10.5 G 800 1400 30 0.08 EEHZE1J560P EEHZE1J560V 500 82 10.0 10.2 10.5 G 800 1400 30 0.08 EEHZE1J820P EEHZE1J820V 500 100 63 27 *1: Ripple current (100 kHz / +145 ℃ or+135℃) *2: ESR (100 kHz / +20 ℃) *3: tan δ (120 Hz / +20 ℃) ◆ Please refer to the page of “Reflow profile” and “The taping dimensions”. ◆ The dimensions of the vibration-proof products, please refer to the page of the mounting specification. Frequency correction factor for ripple current Rated capacitance(C) Frequency (f) 100 Hz ≦ f < 200 Hz C < 47 μF 47 μF ≦ C < 150 μF 150 μF ≦ C 47 μF ≦ C < 150 μF 150 μF ≦ C 300 Hz ≦ f < 500 Hz 500 Hz ≦ f < 1 kHz 0.10 0.15 0.20 0.15 0.20 0.25 0.30 0.15 0.25 0.25 0.30 1 kHz ≦ f < 2 kHz 2 kHz ≦ f < 3 kHz 3 kHz ≦ f < 5 kHz 5 kHz ≦ f < 10 kHz 0.30 0.40 0.45 0.50 0.40 0.45 0.55 0.60 0.45 0.50 0.60 0.65 Correction factor Rated capacitance(C) Frequency (f) C < 47 μF 200 Hz ≦ f < 300 Hz 0.10 Correction factor Rated capacitance(C) Frequency (f) 10 kHz ≦ f < 15 kHz C < 47 μF 47 μF ≦ C < 150 μF 150 μF ≦ C Correction factor 15 kHz ≦ f < 20 kHz 20 kHz ≦ f < 30 kHz 30 kHz ≦ f < 40 kHz 0.60 0.65 0.70 0.75 0.70 0.75 0.80 0.80 0.75 0.80 0.85 0.85 Rated capacitance(C) Frequency (f) 40 kHz ≦ f < 50 kHz C < 47 μF 47 μF ≦ C < 150 μF 150 μF ≦ C Correction factor 50 kHz ≦ f < 100 kHz 100 kHz ≦ f < 500 kHz 500 kHz ≦ f 0.80 0.85 1.00 1.05 0.85 0.90 1.00 1.00 0.85 0.90 1.00 1.00 After endurance ESR(100 kHz、-40℃) Size φ8xL10.2 φ10xL10.2 ESR(Ω) 0.4 0.3 Design and specifications are each subject to change without notice. Ask factory for the current technical specifications before purchase and/or use. Should a safety concern arise regarding this product, please be sure to contact us immediately. 23-Oct-19 *XLGHOLQHVDQGSUHFDXWLRQVUHJDUGLQJWKH WHFKQLFDOLQIRUPDWLRQDQGXVHRIRXUSURGXFWV GHVFULEHGLQWKLVRQOLQHFDWDORJ ‫ٹ‬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‫ٹ‬7KHTXDOLW\DQGSHUIRUPDQFHRIRXUSURGXFWVDVGHVFULEHGLQWKLVRQOLQHFDWDORJRQO\DSSO\ WRRXUSURGXFWVZKHQXVHGLQLVRODWLRQ7KHUHIRUHSOHDVHHQVXUH\RXHYDOXDWHDQGYHULI\ RXUSURGXFWVXQGHUWKHVSHFLILFFLUFXPVWDQFHVLQZKLFKRXUSURGXFWVDUHDVVHPEOHGLQ\RXU RZQSURGXFWVDQGLQZKLFKRXUSURGXFWVZLOODFWXDOO\EHXVHG ‫ٹ‬,I\RXXVHRXUSURGXFWVLQHTXLSPHQWWKDWUHTXLUHVDKLJKGHJUHHRIUHOLDELOLW\UHJDUGOHVV RIWKHDSSOLFDWLRQLWLVUHFRPPHQGHGWKDW\RXVHWXSSURWHFWLRQFLUFXLWVDQGUHGXQGDQF\ FLUFXLWVLQRUGHUWRHQVXUHVDIHW\RI\RXUHTXLSPHQW ‫ٹ‬7KHSURGXFWVDQGSURGXFWVSHFLILFDWLRQVGHVFULEHGLQWKLVRQOLQHFDWDORJDUHVXEMHFWWR FKDQJHIRULPSURYHPHQWZLWKRXWSULRUQRWLFH7KHUHIRUHSOHDVHEHVXUHWRUHTXHVWDQG FRQILUPWKHODWHVWSURGXFWVSHFLILFDWLRQVZKLFKH[SODLQWKHVSHFLILFDWLRQVRIRXUSURGXFWVLQ GHWDLOEHIRUH\RXILQDOL]HWKHGHVLJQRI\RXUDSSOLFDWLRQVSXUFKDVHRUXVHRXUSURGXFWV ‫ٹ‬7KHWHFKQLFDOLQIRUPDWLRQLQWKLVRQOLQHFDWDORJSURYLGHVH[DPSOHVRIRXUSURGXFWV  W\SLFDORSHUDWLRQVDQGDSSOLFDWLRQFLUFXLWV:HGRQRWJXDUDQWHHWKHQRQLQIULQJHPHQWRI WKLUGSDUW\ VLQWHOOHFWXDOSURSHUW\ULJKWVDQGZHGRQRWJUDQWDQ\OLFHQVHULJKWRULQWHUHVW LQRXULQWHOOHFWXDOSURSHUW\ ‫ٹ‬,IDQ\RIRXUSURGXFWVSURGXFWVSHFLILFDWLRQVDQGRUWHFKQLFDOLQIRUPDWLRQLQWKLVRQOLQH FDWDORJLVWREHH[SRUWHGRUSURYLGHGWRQRQUHVLGHQWVWKHODZVDQGUHJXODWLRQVRIWKH H[SRUWLQJFRXQWU\HVSHFLDOO\ZLWKUHJDUGWRVHFXULW\DQGH[SRUWFRQWUROVKDOOEHREVHUYHG 5HJDUGLQJWKH&HUWLILFDWHRI&RPSOLDQFHZLWK WKH(85R+6'LUHFWLYH5($&+5HJXODWLRQV! ‫ٹ‬7KHVZLWFKRYHUGDWHIRUFRPSOLDQFHZLWKWKH5R+6'LUHFWLYH5($&+5HJXODWLRQVYDULHV GHSHQGLQJRQWKHSDUWQXPEHURUVHULHVRIRXUSURGXFWV ‫ٹ‬:KHQ\RXXVHWKHLQYHQWRU\RIRXUSURGXFWVIRUZKLFKLWLVXQFOHDUZKHWKHUWKRVHSURGXFWV DUHFRPSOLDQWZLWKWKH5R+6'LUHFWLYH5($&+5HJXODWLRQSOHDVHVHOHFW6DOHV,QTXLU\LQWKH ZHEVLWHLQTXLU\IRUPDQGFRQWDFWXV :HGRQRWWDNHDQ\UHVSRQVLELOLW\IRUWKHXVHRIRXUSURGXFWVRXWVLGHWKHVFRSHRIWKH VSHFLILFDWLRQVGHVFULSWLRQVJXLGHOLQHVDQGSUHFDXWLRQVGHVFULEHGLQWKLVRQOLQHFDWDORJ 2FW 1RWLFHV,WHPVWREHREVHUYHG 1RWLFHV ‫ٹ‬$SSOLFDEOHODZVDQGUHJXODWLRQV 嵣7KLVSURGXFWFRPSOLHVZLWKWKH5R+6'LUHFWLYH 5HVWULFWLRQRIWKHXVHRIFHUWDLQKD]DUGRXVVXEVWDQFHVLQ HOHFWULFDODQGHOHFWURQLFHTXLSPHQW ',5(&7,9((8DQG‫(ق‬8   嵣1R2]RQH'HSOHWLQJ&KHPLFDOV 2'& V FRQWUROOHGXQGHUWKH0RQWUHDO3URWRFRO$JUHHPHQWDUHXVHGLQ SURGXFLQJWKLVSURGXFW 岜:HGRQRWXVH3%%VRU3%'(VDVEURPLQDWHGIODPHUHWDUGDQWV 嵣([SRUWSURFHGXUHZKLFKIROORZHGH[SRUWUHODWHGUHJXODWLRQVVXFKDVIRUHLJQH[FKDQJHDQGDIRUHLJQWUDGH PHWKRGRQWKHRFFDVLRQRIH[SRUWRIWKLVSURGXFW 嵣7KHVHSURGXFWVDUHQRWGDQJHURXVJRRGVRQWKHWUDQVSRUWDWLRQDVLGHQWLILHGE\81 8QLWHG1DWLRQV QXPEHUV RU81FODVVLILFDWLRQ ‫ٹ‬/LPLWHGDSSOLFDWLRQV 嵣7KLVFDSDFLWRULVGHVLJQHGWREHXVHGIRUHOHFWURQLFVFLUFXLWVVXFKDVDXGLRYLVXDOHTXLSPHQWKRPH DSSOLDQFHVFRPSXWHUVDQGRWKHURIILFHHTXLSPHQWRSWLFDOHTXLSPHQWPHDVXULQJHTXLSPHQW 嵣+LJKUHOLDELOLW\DQGVDIHW\DUHUHTXLUHG>EHDSRVVLELOLW\WKDWLQFRUUHFWRSHUDWLRQRIWKLVSURGXFWPD\GRKDUP 岜WRDKXPDQOLIHRUSURSHUW\@PRUH:KHQXVHLVFRQVLGHUHGE\WKHXVHWKHGHOLYHU\VSHFLILFDWLRQVZKLFKVXLWHG WKHXVHVHSDUDWHO\QHHGWREHH[FKDQJHG ‫ٹ‬,QWHOOHFWXDOSURSHUW\ULJKWVDQGOLFHQVHV 嵣7KHWHFKQLFDOLQIRUPDWLRQLQWKLVVSHFLILFDWLRQSURYLGHVH[DPSOHVRIRXUSURGXFWV W\SLFDORSHUDWLRQVDQGDSSOLFDWLRQ FLUFXLWV:HGRQRWJXDUDQWHHWKHQRQLQIULQJHPHQWRIWKLUGSDUW\ VLQWHOOHFWXDOSURSHUW\ULJKWVDQGZHGRQRWJUDQW DQ\OLFHQVHULJKWRULQWHUHVWLQRXULQWHOOHFWXDOSURSHUW\ ,WHPVWREHREVHUYHG ‫)ٹ‬RUVSHFLILFDWLRQ 嵣7KLVVSHFLILFDWLRQJXDUDQWHHVWKHTXDOLW\DQGSHUIRUPDQFHRIWKHSURGXFWDVLQGLYLGXDOFRPSRQHQWV 7KHGXUDELOLW\GLIIHUVGHSHQGLQJRQWKHHQYLURQPHQWDQGWKHFRQGLWLRQVRIXVDJH %HIRUHXVHFKHFNDQGHYDOXDWHWKHLUFRPSDWLELOLW\ZLWKDFWXDOFRQGLWLRQVZKHQLQVWDOOHGLQWKHSURGXFWV :KHQVDIHW\UHTXLUHPHQWVFDQQRWEHVDWLVILHGLQ\RXUWHFKQLFDOH[DPLQDWLRQLQIRUPXVLPPHGLDWHO\ 嵣'RQRWXVHWKHSURGXFWVEH\RQGWKHVSHFLILFDWLRQVGHVFULEHGLQWKLVGRFXPHQW ‫ٹ‬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‫&ٹ‬RQGLWLRQVRIXVH 嵣%HIRUHXVLQJWKHSURGXFWVFDUHIXOO\FKHFNWKHHIIHFWVRQWKHLUTXDOLW\DQGSHUIRUPDQFHDQGGHWHUPLQHG 岜ZKHWKHURUQRWWKH\FDQEHXVHG7KHVHSURGXFWVDUHGHVLJQHGDQGPDQXIDFWXUHGIRUJHQHUDOSXUSRVHDQG 岜VWDQGDUGXVHLQJHQHUDOHOHFWURQLFHTXLSPHQW7KHVHSURGXFWVDUHQRWLQWHQGHGIRUXVHLQWKHIROORZLQJVSHFLDO 岜FRQGLWLRQV  ,QOLTXLGVXFKDV:DWHU2LO&KHPLFDOVRU2UJDQLFVROYHQW  ,QGLUHFWVXQOLJKWRXWGRRUVRULQGXVW  ,QYDSRUVXFKDVGHZFRQGHQVDWLRQZDWHURIUHVLVWLYHHOHPHQWRUZDWHUOHDNDJHVDOW\DLURUDLUZLWKD KLJKFRQFHQWUDWLRQFRUURVLYHJDVVXFKDV&O+61+62RU12[  ,QDQHQYLURQPHQWZKHUHVWURQJVWDWLFHOHFWULFLW\RUHOHFWURPDJQHWLFZDYHVH[LVW  0RXQWLQJRUSODFLQJKHDWJHQHUDWLQJFRPSRQHQWVRULQIODPPDEOHVVXFKDVYLQ\OFRDWHGZLUHVQHDU WKHVHSURGXFWV  6HDOLQJRUFRDWLQJRIWKHVHSURGXFWVRUDSULQWHGFLUFXLWERDUGRQZKLFKWKHVHSURGXFWVDUHPRXQWHG ZLWKUHVLQDQGRWKHUPDWHULDO  8VLQJUHVROYHQWZDWHURUZDWHUVROXEOHFOHDQHUIRUIOX[FOHDQLQJDJHQWDIWHUVROGHULQJ ,QSDUWLFXODU ZKHQXVLQJZDWHURUDZDWHUVROXEOHFOHDQLQJDJHQWEHFDUHIXOQRWWROHDYHZDWHUUHVLGXHV  8VLQJLQWKHDWPRVSKHUHZKHUHVWUD\VDFLGRUDONDOLQH  8VLQJLQWKHDWPRVSKHUHZKHUHWKHUHDUHH[FHVVLYHYLEUDWLRQDQGVKRFN 嵣3OHDVHDUUDQJHFLUFXLWGHVLJQIRUSUHYHQWLQJLPSXOVHRUWUDQVLWLRQDOYROWDJH 岜'RQRWDSSO\YROWDJHZKLFKH[FHHGVWKHIXOOUDWHGYROWDJHZKHQWKHFDSDFLWRUVUHFHLYHLPSXOVHYROWDJH 岜LQVWDQWDQHRXVKLJKYROWDJHKLJKSXOVHYROWDJHHWF 嵣2XUSURGXFWVWKHUHLVDSURGXFWDUHXVLQJDQHOHFWURO\WHVROXWLRQ7KHUHIRUHPLVXVHFDQUHVXOWLQUDSLG 岜GHWHULRUDWLRQRIFKDUDFWHULVWLFVDQGIXQFWLRQVRIHDFKSURGXFW(OHFWURO\WHOHDNDJHGDPDJHVSULQWHGFLUFXLWDQG DIIHFWVSHUIRUPDQFHFKDUDFWHULVWLFVDQGIXQFWLRQVRIFXVWRPHUV\VWHP 2FW &RQGXFWLYH3RO\PHU+\EULG$OXPLQXP(OHFWURO\WLF&DSDFLWRUV 岜岜$SSOLFDWLRQJXLGHOLQHV‫ق‬+\EULG‫ك‬ 岜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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¼ / / 7 7  ‫*؟‬XDUDQWHHGOLIH K DWWHPSHUDWXUH7& ‫[(؟‬SHFWHGOLIH K DWWHPSHUDWXUH7& ‫؟‬8SSHUFDWHJRU\WHPSHUDWXUHWHPSHUDWXUHULVHGXHWRUDWHGULSSOHFXUUHQW & ‫؟‬$FWXDORSHUDWLQJWHPSHUDWXUHDPELHQWWHPSHUDWXUHWHPSHUDWXUHULVHGXHWRULSSOHFXUUHQW &  3OHDVHXVHDFFRUGLQJWRWKHOLIHWLPHDVQRWHGLQWKLVVSHFLILFDWLRQ8VLQJSURGXFWVEH\RQGHQGRIWKH 岜岜OLIHWLPHPD\FKDQJHFKDUDFWHULVWLFVUDSLGO\VKRUWFLUFXLWRSHUDWHSUHVVXUHUHOLHIYHQWRUOHDNHOHFWURO\WH &RPPRQDSSOLFDWLRQFRQGLWLRQVWRDYRLG 7KHIROORZLQJPLVDSSOLFDWLRQORDGFRQGLWLRQVZLOOFDXVHUDSLGGHWHULRUDWLRQRIDFDSDFLWRUb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‫̷ۺ‬PP &DSDFLWRUVZLWKFDVHPRXQWHGSUHVVXUHUHOLHIUHTXLUHVXIILFLHQWFOHDUDQFHWRDOORZIRUSURSHUSUHVVXUH UHOLHIRSHUDWLRQ 7KHPLQLPXPFOHDUDQFHDUHGHSHQGHQWRQFDSDFLWRUGLDPHWHUVDVIROORZV 嵣‫̷ۺ‬PPPPPLQLPXP  :LULQJQHDUWKHSUHVVXUHUHOLHI ‫̷ۺ‬PP $YRLGORFDWLQJKLJKYROWDJHRUKLJKFXUUHQWZLULQJRUFLUFXLWERDUGSDWKVDERYHWKHSUHVVXUHUHOLHI )ODPPDEOHKLJKWHPSHUDWXUHJDVWKDWH[FHHGV&PD\EHUHOHDVHGZKLFKFRXOGGLVVROYHWKHZLUH LQVXODWLRQDQGLJQLWH  &LUFXLWERDUGSDWWHUQVXQGHUWKHFDSDFLWRU $YRLGFLUFXLWERDUGUXQVXQGHUWKHFDSDFLWRUDVDQHOHFWULFDOVKRUWFDQRFFXUGXHWRDQHOHFWURO\WHOHDNDJH (OHFWULFDOLVRODWLRQRIWKHFDSDFLWRU &RPSOHWHO\LVRODWHWKHFDSDFLWRUDVIROORZV w%HWZHHQWKHFDWKRGHDQGWKHFDVHDQGEHWZHHQWKHDQRGHWHUPLQDODQGRWKHUFLUFXLWSDWKV &DSDFLWRUFRDWLQJ 7KHODPLQDWHFRDWLQJLVLQWHQGHGIRUPDUNLQJDQGLGHQWLILFDWLRQSXUSRVHVDQGLVQRWPHDQWWRHOHFWULFDOO\ LQVXODWHWKHFDSDFLWRU &DSDFLWRUKDQGOLQJWHFKQLTXHV &RQVLGHUDWLRQVEHIRUHXVLQJ  &DSDFLWRUVKDYHDILQLWHOLIH'RQRWUHXVHRUUHF\FOHFDSDFLWRUVIURPXVHGHTXLSPHQW  7UDQVLHQWUHFRYHU\YROWDJHPD\EHJHQHUDWHGLQWKHFDSDFLWRUGXHWRGLHOHFWULFDEVRUSWLRQ ,IUHTXLUHGWKLVYROWDJHFDQEHGLVFKDUJHGZLWKDUHVLVWRUZLWKDYDOXHRIDERXWN̚  &DSDFLWRUVVWRUHGIRUDORQJSHULRGRIWLPHPD\H[KLELWDQLQFUHDVHLQOHDNDJHFXUUHQW 7KLVFDQEHFRUUHFWHGE\JUDGXDOO\DSSO\LQJUDWHGYROWDJHLQVHULHVZLWKDUHVLVWRURIDSSUR[LPDWHO\N̚  ,IFDSDFLWRUVDUHGURSSHGWKH\FDQEHGDPDJHGPHFKDQLFDOO\RUHOHFWULFDOO\$YRLGXVLQJGURSSHG FDSDFLWRUV  'HQWHGRUFUXVKHGFDSDFLWRUVVKRXOGQRWEHXVHG 7KHVHDOLQWHJULW\FDQEHGDPDJHGDQGORVVRIHOHFWURO\WHVKRUWHQHGOLIHFDQUHVXOW &DSDFLWRULQVHUWLRQ  9HULI\WKHFRUUHFWFDSDFLWDQFHDQGUDWHGYROWDJHRIWKHFDSDFLWRU  9HULI\WKHFRUUHFWSRODULW\RIWKHFDSDFLWRUEHIRUHLQVHUWLRQ  9HULI\WKHFRUUHFWWHUPLQDOGLPHQVLRQDQGODQGSDWWHUQVL]HEHIRUHPRXQWWRDYRLGVWUHVVRQWKHWHUPLQDOV  ([FHVVLYHPRXQWLQJSUHVVXUHFDQFDXVHKLJKOHDNDJHFXUUHQWVKRUWFLUFXLWRUGLVFRQQHFWLRQ 5HIORZVROGHULQJ  6XUIDFHPRXQWW\SHFDSDFLWRUDUHH[FOXVLYHO\IRUUHIORZVROGHULQJ 岜:KHQUHIORZVROGHULVXVHGDQDPELHQWKHDWFRQGLWLRQV\VWHPVXFKDVWKHVLPXOWDQHRXVXVHRILQIUDUHG 岜DQGKRWDLULVUHFRPPHQGHG  2EVHUYHSURSHUVROGHULQJFRQGLWLRQV WHPSHUDWXUHWLPHHWF 'RQRWH[FHHGWKHVSHFLILHGOLPLWV ,IWKHSHDNWHPSHUDWXUHLVKLJKRULIWKHKHDWLQJWLPHLVORQJLWPD\FDXVHGHWHULRUDWLRQRIWKHHOHFWULFDO FKDUDFWHULVWLFVDQGOLIHFKDUDFWHULVWLFV 5HFRPPHQGHGVROGHULQJFRQGLWLRQLVDJXLGHOLQHIRUHQVXULQJWKHEDVLFFKDUDFWHULVWLFVRIWKHFRPSRQHQWV EXWQRWIRUWKHVWDEOHVROGHULQJFRQGLWLRQV&RQGLWLRQVIRUSURSHUVROGHULQJVKRXOGEHVHWXSDFFRUGLQJWR LQGLYLGXDORQGLWLRQV 岜名7KH7HPSHUDWXUHRQ&DSDFLWRUWRSVKDOOEHPHDVXUHGE\XVLQJWKHUPDOFRXSOHWKDWLVIL[HGILUPO\E\ HSR[\JOXH  ,QFDVHRIXVHLQWLPHVUHIORZQGUHIORZPXVWEHGRQHZKHQWKHFDSDFLWRUbVWHPSHUDWXUHUHWXUQEDFN 岜WRQRUPDOOHYHO  ,QRXUUHFRPPHQGHGUHIORZFRQGLWLRQWKHFDVHGLVFRORUDWLRQDQGWKHFDVHVZHOOLQJPLJKWEHVOLJKWO\ 岜JHQHUDWHG%XWSOHDVHDFNQRZOHGJHWKDWWKHVHWZRSKHQRPHQDGRQRWLQIOXHQFHWKHUHOLDELOLW\RIWKHSURGXFW  7KHFUDFNRQWRSPDUNLQJPLJKWEHRFFXUUHGE\UHIORZKHDWVWUHVV 岜%XWSOHDVHDFNQRZOHGJHWKDWLWGRHVQRWLQIOXHQFHWKHUHOLDELOLW\RIWKHSURGXFW  936 9DSRU3KDVH6ROGHULQJ UHIORZFDQFDXVHVLJQLILFDQWFKDUDFWHULVWLFVFKDQJHDQGRUPRXQWLQJIDLOXUH 岜GXHWRGHIRUPDWLRQE\DFXWHWHPSHUDWXUHULVH 岜936LVDFFHSWDEOHSURYLGHGWKDWWKHSURFHVVGRHVQRWH[FHHGUHFRPPHQGHGUHIORZSURILOHDQG 岜WHPSHUDWXUHULVHLVOHVVWKDQGHJ&VHF岜3OHDVHFRQWDFW3DQDVRQLFIRUGHWDLOHGFRQGLWLRQV 2FW &RQGXFWLYH3RO\PHU+\EULG$OXPLQXP(OHFWURO\WLF&DSDFLWRUV 0DQXDOVROGHULQJ  2EVHUYHWHPSHUDWXUHDQGWLPHVROGHULQJVSHFLILFDWLRQVRUGRQRWH[FHHGWHPSHUDWXUHRI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&PD[LPXPWHPSHUDWXUHV7KHERDUGVVKRXOGEHWKRURXJKO\ULQVHGDQGGULHG 7KHXVHRIR]RQHGHSOHWLQJFOHDQLQJDJHQWVLVQRWUHFRPPHQGHGIRUWKHSXUSRVHRISURWHFWLQJRXU HQYLURQPHQW 岧7DUJHWVROYHQW岨 3LQH$OSKD676$TXD&OHDQHU6(3&OHDQWKUX+/06XQHOHF% 6XQHOHF%&ROG&OHDQHU37HFKQR&OHDQHU'.%HFOHDU&: 7HOSHQH&OHDQHU(&57HFKQRFDUH)5:)5:)59  $YRLGXVLQJWKHIROORZLQJVROYHQWJURXSVXQOHVVVSHFLILFDOO\DOORZHGLQWKHVSHFLILFDWLRQ D +DORJHQDWHGFOHDQLQJVROYHQWV‫؟‬H[FHSWIRUVROYHQWUHVLVWDQWFDSDFLWRUW\SHVKDORJHQDWHGVROYHQWVFDQ SHUPHDWHWKHVHDODQGFDXVHLQWHUQDOFDSDFLWRUFRUURVLRQDQGIDLOXUH )RUVROYHQWUHVLVWDQWFDSDFLWRUVFDUHIXOO\IROORZWKHWHPSHUDWXUHDQGWLPHUHTXLUHPHQWVEDVHGRQWKH VSHFLILFDWLRQWULFKORURHWKDQHVKRXOGQHYHUEHXVHGRQDQ\DOXPLQXPHOHFWURO\WLFFDSDFLWRU E $ONDOLQHVROYHQWV ‫؟‬FRXOGUHDFWDQGGLVVROYHWKHDOXPLQXPFDVH F 3HWUROHXPEDVHGVROYHQWV ‫؟‬GHWHULRUDWLRQRIWKHUXEEHUVHDOFRXOGUHVXOW G ;\OHQH ‫؟‬GHWHULRUDWLRQRIWKHUXEEHUVHDOFRXOGUHVXOW H $FHWRQH ‫؟‬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‫پ‬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b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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&WR& DQGKXPLGLW\ WR ZKHUH GLUHFWVXQVKLQHGRHVQ WUHDFK  (QYLURQPHQWDOFRQGLWLRQV 'RQRWVWRUHXQGHUFRQGLWLRQRXWVLGHWKHDUHDGHVFULEHGLQWKHVSHFLILFDWLRQDQGDOVRXQGHUFRQGLWLRQV OLVWHGEHORZ D ([SRVXUHWRWHPSHUDWXUHVDERYHWKHXSSHUFDWHJRU\RUEHORZWKHORZHUFDWHJRU\WHPSHUDWXUHRIWKH FDSDFLWRU E 'LUHFWFRQWDFWZLWKZDWHUVDOWZDWHURURLO F +LJKKXPLGLW\FRQGLWLRQVZKHUHZDWHUFRXOGFRQGHQVHRQWKHFDSDFLWRU G ([SRVXUHWRWR[LFJDVHVVXFKDVK\GURJHQVXOILGHVXOIXULFDFLGQLWULFDFLGFKORULQH&KORULQHFRPSRXQG %URPLQH%URPLQHFRPSRXQGRUDPPRQLD H ([SRVXUHWRR]RQHUDGLDWLRQRUXOWUDYLROHWUD\V I 9LEUDWLRQDQGVKRFNFRQGLWLRQVH[FHHGLQJVSHFLILHGUHTXLUHPHQWV &DSDFLWRUGLVSRVDO :KHQGLVSRVLQJFDSDFLWRUVXVHRQHRIWKHIROORZLQJPHWKRGV  ,QFLQHUDWHDIWHUFUXVKLQJWKHFDSDFLWRURUSXQFWXULQJWKHFDQZDOO WRSUHYHQWH[SORVLRQGXHWRLQWHUQDO SUHVVXUHULVH   'LVSRVHDVVROLGZDVWH 127(/RFDOODZVPD\KDYHVSHFLILFGLVSRVDOUHTXLUHPHQWVZKLFKPXVWEHIROORZHG 7KHSUHFDXWLRQVLQXVLQJDOXPLQXPHOHFWURO\WLFFDSDFLWRUVIROORZWKH6DIHW\DSSOLFDWLRQ JXLGHIRUWKHXVHLQIL[HGDOXPLQXPHOHFWURO\WLFFDSDFLWRUVIRUHOHFWURQLFHTXLSPHQW 5&5'LVVXHGE\-(,7$LQ2FWREHU 3OHDVHUHIHUWRWKHDERYHDSSOLFDWLRQJXLGHIRUGHWDLOV 名,QWHOOHFWXDOSURSHUW\ULJKW :H3DQDVRQLF*URXSDUHSURYLGLQJWKHSURGXFWDQGVHUYLFHWKDWFXVWRPHUVFDQXVHZLWKRXWDQ[LHW\DQGDUH ZRUNLQJSRVLWLYHO\RQWKHSURWHFWLRQRIRXUSURGXFWVXQGHULQWHOOHFWXDOSURSHUW\ULJKWV 5HSUHVHQWDWLYHSDWHQWVUHODWLQJWR&RQGXFWLYH3RO\PHU+\EULG$OXPLQXP(OHFWURO\WLF&DSDFLWRUVDUHDVIROORZV 863DWHQW 1R1R1R -33DWHQW 1R (33DWHQW 1R 2FW
EEH-ZE1J820V 价格&库存
很抱歉,暂时无法提供与“EEH-ZE1J820V”相匹配的价格&库存,您可以联系我们找货
EEH-ZE1J820V
  • 1+26.225101+3.39162
  • 10+17.4926610+2.26228
  • 50+13.8704850+1.79383
  • 100+12.72612100+1.64584
库存:589
EEH-ZE1J820V
  • 500+10.56169500+1.36592
  • 1000+9.954251000+1.28736
  • 1500+9.647871500+1.24774
  • 2500+9.306492500+1.20359
  • 3500+9.105803500+1.17763
  • 5000+8.912055000+1.15257
库存:589
