ERJ-1GNF4530C
ERJ-1GNF4530C
    PANASONICELECTRONICCOMPONENTS
ERJ-1GNF4530C 数据手册
Precision Thick Film Chip Resistors Precision Thick Film Chip Resistors Series: ERJ XG, 1G ERJ 1R, 2R, 3R, 6R ERJ 3E, 6E, 8E, 14, 12, 1T Features ● ● ● ● ● Small size and lightweight High reliability…Metal glaze thick film resistive element and three layers of electrodes Compatible with placement machines … Taping packaging available Suitable for both reflow and flow soldering Low Resistance Tolerance :ERJXG, 1G, 2R, 3E, 6E, 8E, 14, 12, 1T :±1 % ERJ1R, 2R, 3R, 6R :±0.5 % ● Reference Standard … IEC 60115-8,JIS C 5201-8,JEITA RC-2134C ● AEC-Q200 compliant (except ERJXG,ERJ1R) ● RoHS compliant ■ As for Packaging Methods, Land Pattern, Soldering Conditions and Safety Precautions, Please see Data Files Explanation of Part Numbers 1T ERJS02 ~ ERJS1Tシリーズ ● Series ERJ1R, 2R, 3R, 6R, ±0.5 % 1 2 3 4 5 6 7 8 9 10 E R J 3 R B D 1 0 0 Product Code Thick Film Chip Resistors T.C.R.,Marking Size, Power Rating Code inch Power Rating Code T.C.R. 1R 0201   0.05 W H ±50 ×10 /K (1R, 2R) 2R 0402  0.063 W B ±50 ×10–6/K (3R, 6R) 3R 0603    0.1 W K 6R 0805    0.1 W E –6 ±100 ×10–6/K (2R) –6 ±100 ×10 /K (3R, 6R) 11 12 V 2 Packaging Methods Resistance Tolerance Code Tolerance D ±0.5 % Resistance Value The first three digits are significant figures of resistance and the last one denotes number of zeros following. (Ex.) 1002: 10 KΩ Code Packaging Part No. C Pressed Carrier Taping ERJ1R 2 mm pitch, 15,000 pcs X Punched Carrier Taping ERJ2R 2 mm pitch, 10,000 pcs V Punched Carrier Taping ERJ3R 4 mm pitch, 5,000 pcs ERJ6R Design and specifications are each subject to change without notice. Ask factory for the current technical specifications before purchase and/or use. Should a safety concern arise regarding this product, please be sure to contact us immediately. 1-Mar-20 Precision Thick Film Chip Resistors ● Series ERJXGN, 1GN, 2RC, 2RK, 3EK, 6EN, 8EN, 14N, 12N, 12S, 1TN, ±1 % 1 2 3 4 5 6 7 8 9 10 11 12 E R J 8 E N F 1 0 0 2 V Size, Power Rating Product Code Code Thick Film Chip Resistors XGN 1GN 2RC 2RK 3EK 6EN 8EN 14N 12N 12S 1TN Resistance Value Resistance Tolerance inch Power Rating 01005 0.031 W 0201 0.05 W 0402    0.1 W 0402    0.1 W 0603    0.1 W 0805 0.125 W 1206 0.25 W 1210    0.5 W 1812 0.75 W 2010 0.75 W 2512 1W Code Tolerance F ±1 % The first three digits are significant figures of resistance and the last one denotes number of zeros following. Decimal point is expressed by "R". (Ex.)1002: 10 kΩ Packaging Methods Code Packaging Y Pressed Carrier Taping W8P2, 20,000 pcs U Embossed Carrier Taping Part No. ERJXGN W4P1, 40,000 pcs C Pressed Carrier Taping ERJ1GN 2 mm pitch, 15,000 pcs X Punched Carrier Taping ERJ2RC 2 mm pitch, 10,000 pcs ERJ2RK V ERJ3EK Punched Carrier Taping ERJ6EN 4 mm pitch, 5,000 pcs ERJ8EN ERJ14N Embossed Carrier Taping U ERJ12N 4 mm pitch, 5,000 pcs Embossed Carrier Taping 4 mm pitch, 4,000 pcs ERJ12S ERJ1TN Ratings <±0.5 %> Part No. (inch size) Power Rating at 70 °C (W) (1) Limiting Element (2) Voltage (V) Maximum Overload (3) Voltage (V) Resistance Range (Ω) Resistance Tolerance (%) T.C.R. -6 (×10 /K) Category Temperature Range (℃) AECQ200 Grade ERJ1RH (0201) 0.05 15 30 ±0.5 1 k to 1 M (E24,E96) ±50 -55 to +125 - ERJ2RH (0402) 0.063 50 100 ±0.5 100 to 100 k (E24,E96) ±50 -55 to +155 Grade 0 ERJ2RK (0402) 0.063 50 100 ±0.5 10 to 97.6 102 k to 1 M (E24,E96) ±100 -55 to +155 Grade 0 ERJ3RB (0603) 0.1 50 100 ±0.5 100 to 100 k (E24,E96) ±50 -55 to +155 Grade 0 ERJ3RE (0603) 0.1 50 100 ±0.5 10 to 97.6 102 k to 1 M (E24,E96) ±100 -55 to +155 Grade 0 ERJ6RB (0805) 0.1 150 200 ±0.5 100 to 100 k (E24,E96) ±50 -55 to +155 Grade 0 ERJ6RE (0805) 0.1 150 200 ±0.5 10 to 97.6 102 k to 1 M (E24,E96) ±100 -55 to +155 Grade 0 (1) Use it on the condition that the case temperature is below the upper category temperature. (2) Rated Continuous Working Voltage (RCWV) shall be determined from RCWV=√Power Rating × Resistance Value, or Limiting Element Voltage listed above, whichever less. (3) Overload Test Voltage (OTV) shall be determined from OTV=Specified Magnification (refer to performance) × RCWV or Maximum Overload Voltage listed above, whichever less. Design and specifications are each subject to change without notice. Ask factory for the current technical specifications before purchase and/or use. Should a safety concern arise regarding this product, please be sure to contact us immediately. 1-Mar-20 Precision Thick Film Chip Resistors Ratings
ERJ-1GNF4530C
物料型号: - 系列型号包括ERJ XG, 1G, ERJ 1R, 2R, 3R, 6R, 3E, 6E, 8E, 14, 12, 1T等。
器件简介: - 这些电阻器具有小巧轻便、高可靠性的特点,采用金属釉厚膜电阻元件和三层电极结构。 - 兼容贴片机,提供胶带包装。 - 适用于回流焊和波峰焊。 - 符合AEC-Q200标准和RoHS标准。
引脚分配: - 文档中未明确提供引脚分配信息,但通常这类器件为表面贴装元件,具有指定的焊盘间距。
参数特性: - 电阻公差:ERJXG, 1G, 2R, 3E, 6E, 8E, 14, 12, 1T为±1%,ERJ1R, 2R, 3R, 6R为±0.5%。 - 温度系数(T.C.R.):1R, 2R为±50 ×10^–6/K,3R, 6R为±100 ×10^–6/K。 - 功率额定值和尺寸有关,例如0201尺寸的电阻功率额定值为0.05W。
功能详解: - 提供了详细的产品编号解释,包括电阻值、公差、尺寸、功率等级等。 - 强调了设计和规格如有变更,将不另行通知,建议在购买和/或使用前咨询工厂以获取当前技术规格。
应用信息: - 适用于一般电子设备,但对于特殊应用(如飞机、汽车、医疗设备等),需要验证产品规格是否适合。
封装信息: - 提供了不同尺寸的封装信息,包括0201、0402、0603、0805、1206、1210、1812、2010、2512等。
安全警告: - 强调了在特殊应用中使用产品前需要与Panasonic确认规格,并在出现安全问题时立即联系。
ERJ-1GNF4530C 价格&库存
很抱歉,暂时无法提供与“ERJ-1GNF4530C”相匹配的价格&库存,您可以联系我们找货
ERJ-1GNF4530C
  • 15000+0.0747215000+0.00970
  • 30000+0.0690930000+0.00897
  • 45000+0.0663545000+0.00861
  • 75000+0.0633975000+0.00823
  • 105000+0.06169105000+0.00801
  • 150000+0.06009150000+0.00780
库存:22103
ERJ-1GNF4530C
  • 1+0.884501+0.11477
  • 10+0.3879010+0.05033
  • 25+0.2962625+0.03844
  • 50+0.2431950+0.03156
  • 100+0.20184100+0.02619
  • 250+0.16075250+0.02086
  • 500+0.13764500+0.01786
  • 1000+0.119241000+0.01547
  • 5000+0.090165000+0.01170
库存:22103
