100SXV27M
100SXV27M
    PANASONICELECTRONICCOMPONENTS
    100SXV27M
100SXV27M 数据手册
Conductive Polymer Aluminum Solid Capacitors Surface Mount Type Series: SXV UPGRADE Features ● Super high voltage (100 V.DC max.) ● RoHS compliance, Halogen free Specifications Size code E7 F8 Category temp. range Rated voltage range Nominal cap.range E12 F12 –55 ℃ to +125 ℃ 63 V.DC to 100 V.DC 6.8 μF to 18 μF 15 μF to 39 μF 15 μF to 56 μF Capacitance tolerance ±20 % (120 Hz / +20 ℃) DC leakage current Please see the attached characteristics list Dissipation factor (tan δ) Please see the attached characteristics list 18 μF to 100 μF +125 ℃, 1000 h, rated voltage applied Capacitance change Within ±20 % of the initial value Dissipation factor (tanδ) ≦ 200 % of the initial limit Endurance DC leakage current Within the initial limit +60 ℃, 90 % to 95 %, 1000 h, No-applied voltage Capacitance change Within ±20 % of the initial value Dissipation factor (tanδ) ≦ 150 % of the initial limit DC leakage current Marking Within the initial limit (after voltage processing) Dimensions (not to scale) 0.2 max Polarity marking W ⊖ R. voltage (V.DC) R. capacitance (μF) Size φD±0.5 code E7 8.0 F8 10.0 E12 8.0 F12 10.0 L P ⊕ L +0.1 -0.4 6.9 7.9 11.9 12.6 C H Series φD Lot No. R Unit:mm W±0.2 H±0.2 C±0.2 R P±0.2 8.3 10.3 8.3 10.3 8.3 10.3 8.3 10.3 9.0 11.0 9.0 11.0 0.6 to 0.8 3.2 4.6 3.2 4.6 0.6 to 0.8 0.8 to 1.1 0.8 to 1.1 Design and specifications are each subject to change without notice. Ask factory for the current technical specifications before purchase and/or use. Should a safety concern arise regarding this product, please be sure to contact us immediately. 25-Apr-19 Conductive Polymer Aluminum Solid Capacitors Characteristics list Rated vol. (V.DC) Rated cap. (±20 %) (μF) 18 33 63 39 56 68 NEW 100 12 NEW 80 NEW NEW 27 33 47 56 6.8 15 100 NEW NEW 18 22 27 Case size (mm) φD L Specifications Size code Ripple *1 current (mA r.m.s.) 8.0 8.0 8.0 10.0 8.0 10.0 10.0 8.0 8.0 10.0 8.0 10.0 10.0 8.0 10.0 8.0 10.0 8.0 10.0 10.0 6.9 11.9 11.9 7.9 11.9 12.6 12.6 6.9 11.9 7.9 11.9 12.6 12.6 6.9 7.9 11.9 12.6 11.9 12.6 12.6 E7 E12 E12 F8 E12 F12 F12 E7 E12 F8 E12 F12 F12 E7 F8 E12 F12 E12 F12 F12 340 930 930 690 930 1030 1030 340 780 660 780 980 980 340 630 730 940 730 940 940 Allowable ripple *1 current Standard(Reel size : φ380) ESR*2 (mΩ) tan δ*3 60 25 25 50 25 25 25 60 35 55 35 28 28 60 60 40 30 40 30 30 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 LC*4 (μA) Part number 56 104 122 122 176 214 315 48 108 108 132 980 224 34 75 75 90 90 110 135 63SXV18M 63SXV33M 63SXV39M 63SXV39MX 63SXV56M 63SXV68M 63SXV100M 80SXV12M 80SXV27M 80SXV27MX 80SXV33M 80SXV47M 80SXV56M 100SXV6R8M 100SXV15MX 100SXV15M 100SXV18M 100SXV18MX 100SXV22M 100SXV27M Q'ty (pcs) (mA r.m.s.) 1100 2950 2950 2190 2950 3280 3280 1100 2490 2080 2490 3100 3100 1100 2000 2350 3000 2350 3000 3000 Min. Packaging 1000 400 400 500 400 400 400 1000 400 500 400 400 400 1000 500 400 400 400 400 400 *1: Ripple current (100 kHz / +105 °C < Tx ≦ +125 °C) /Allowable ripple current (100 kHz / Tx ≦ +105 °C) *2: ESR(100 kHz to 300 kHz / +20 ℃) *3: tan δ (120 Hz / +20 ℃) *4: After 2 minutes ・ Please refer to each page in this catarog for “Reflow conditions” and “Taping specifications”. Frequency correction factor for ripple current Frequency(f) 120 Hz ≦ f< 1 kHz Coefficient 0.05 1 kHz ≦ f< 10 kHz 0.3 10 kHz ≦ f< 100 kHz 100 kHz ≦ f< 500 kHz 0.7 1 Design and specifications are each subject to change without notice. Ask factory for the current technical specifications before purchase and/or use. Should a safety concern arise regarding this product, please be sure to contact us immediately. 25-Apr-19 Guidelines and precautions regarding the technical information and use of our products described in this online catalog. ■ If you want to use our products described in this online catalog for applications requiring special qualities or reliability, or for applications where the failure or malfunction of the products may directly jeopardize human life or potentially cause personal injury (e.g. aircraft and aerospace equipment, traffic and transportation equipment, combustion equipment, medical equipment, accident prevention, anti-crime equipment, and/or safety equipment), it is necessary to verify whether the specifications of our products fit to such applications. Please ensure that you will ask and check with our inquiry desk as to whether the specifications of our products fit to such applications use before you use our products. ■ The quality and performance of our products as described in this online catalog only apply to our products when used in isolation. Therefore, please ensure you evaluate and verify our products under the specific circumstances in which our products are assembled in your own products and in which our products will actually be used. ■ If you use our products in equipment that requires a high degree of reliability, regardless of the application, it is recommended that you set up protection circuits and redundancy circuits in order to ensure safety of your equipment. ■ The products and product specifications described in this online catalog are subject to change for improvement without prior notice. Therefore, please be sure to request and confirm the latest product specifications which explain the specifications of our products in detail, before you finalize the design of your applications, purchase, or use our products. ■ The technical information in this online catalog provides examples of our products' typical operations and application circuits. We do not guarantee the non-infringement of third party's intellectual property rights and we do not grant any license, right, or interest in our intellectual property. ■ If any of our products, product specifications and/or technical information in this online catalog is to be exported or provided to non-residents, the laws and regulations of the exporting country, especially with regard to security and export control, shall be observed. ■ The switchover date for compliance with the RoHS Directive/REACH Regulations varies depending on the part number or series of our products. ■ When you use the inventory of our products for which it is unclear whether those products are compliant with the RoHS Directive/REACH Regulation, please select "Sales Inquiry" in the website inquiry form and contact us. We do not take any responsibility for the use of our products outside the scope of the specifications, descriptions, guidelines and precautions described in this online catalog. 01-Apr-19
100SXV27M 价格&库存
很抱歉,暂时无法提供与“100SXV27M”相匹配的价格&库存,您可以联系我们找货
100SXV27M
  • 400+14.65008400+1.90084
  • 800+13.83581800+1.79519
  • 1200+13.425091200+1.74190
  • 2000+12.967302000+1.68250
  • 2800+12.698372800+1.64761
  • 4000+12.438554000+1.61390
库存:1374
100SXV27M
  • 1+35.166711+4.56286
  • 10+23.7940110+3.08726
  • 50+19.0825350+2.47595
  • 100+17.59583100+2.28305
库存:1374
