ARJ22A4H
ARJ22A4H
    OTHER
ARJ22A4H 数据手册
Microwave Devices RJ RELAYS Product Catalog 2022.4 Microwave Devices RJ RELAYS 8 GHz max. capable, 1 W carrying power ( at 5 GHz ), 50 Ω impedance and 2 Form C relays FEATURES Protective construction:Sealed type Excellent high frequency characteristics (50 Ω, up to 5 GHz) Surface-mount type also available Small size: 9(W) × 14(L) × 8.2 (H) mm 9 14 8.2 9 14 TYPICAL APPLICATIONS 8.2 Communication and measurement equipment Medical instrument equipment Note: If you consider using applications with low level loads or with high frequency switching, please consult us. (Unit:mm) HIGH FREQUENCY CHARACTERISTICS 50 Ω (Initial) Frequency Up to 5 GHz V.S.W.R. (Max.) 1.25 Insertion loss (dB, Max.) 0.5* Isolation (dB, Min.) Between open contacts 35 Between contact sets 30 *Not included PC board loss ORDERING INFORMATION (PART NO.) ARJ 2 Operating function 0:Single side stable 2:2 coil latching Contact arrangement 2:2 Form C Rated coil voltage(DC) 03:3V, 4H:4.5V, 12:12V, 24:24V (H=0.5) Terminal shape Nil :Standard PC board terminal A :Surface-mount terminal Packing style Nil:Carton packing X :Tape and reel packing (picked from 1/2/3-pin side) Z :Tape and reel packing (picked from 6/7/8-pin side) Note:Packing style symbol“X”,“Z”is not marked on the relay. Panasonic Industry Co., Ltd. Electromechanical Control Business Division industrial.panasonic.com/ac/e/ ー1ー Panasonic Industry Co., Ltd. 2022 ASCTB105E 202204 Microwave Devices RJ RELAYS TYPES PC board terminal Carton packing Contact arrangement 2 Form C Rated coil voltage Part No. Standard packing Single side stable 2 coil latching 3 V DC ARJ2003 ARJ2203 4.5 V DC ARJ204H ARJ224H 12 V DC ARJ2012 ARJ2212 24 V DC ARJ2024 ARJ2224 Inner carton Outer carton 50 pcs. 500 pcs. Surface mount terminal Carton packing Contact arrangement 2 Form C Rated coil voltage Part No. Standard packing 2 coil latching Single side stable 3 V DC ARJ20A03 ARJ22A03 4.5 V DC ARJ20A4H ARJ22A4H 12 V DC ARJ20A12 ARJ22A12 24 V DC ARJ20A24 ARJ22A24 Inner carton Outer carton 50 pcs. 500 pcs. Tape and reel packing Z Part No. Contact arrangement 2 Form C Rated coil voltage Standard packing Single side stable 2 coil latching 3 V DC ARJ20A03Z ARJ22A03Z 4.5 V DC ARJ20A4HZ ARJ22A4HZ 12 V DC ARJ20A12Z ARJ22A12Z 24 V DC ARJ20A24Z ARJ22A24Z Inner carton (1-reel) Outer carton 500 pcs. 1,000 pcs. RATING Coil data • Operating characteristics such as ‘Operate voltage’ and ‘Release voltage’ are influenced by mounting conditions, ambient temperature, etc. Therefore, please use the relay within ±5% of rated coil voltage. • ‘Initial’ means the condition of products at the time of delivery. Single side stable Rated coil voltage 3 V DC 4.5 V DC 12 V DC 24 V DC Operate voltage* (at 20 °C) Release voltage* (at 20 °C) Max. 75% V of rated coil voltage (Initial) Min. 10% V of rated coil voltage (Initial) Set voltage* (at 20 °C) Reset voltage* (at 20 °C) Max. 75% V of rated coil voltage (Initial) Max. 75% V of rated coil voltage (Initial) Rated operating current (±10%, at 20 °C) Coil resistance (±10%, at 20 °C) 66.7 mA 45 Ω 44.4 mA 101.2 Ω 16.7 mA 720 Ω 8.3 mA 2,880 Ω Rated operating current (±10%, at 20 °C) Coil resistance (±10%, at 20 °C) Rated operating power Max. allowable voltage (at 70 °C) 200 mW 110% V of rated coil voltage Rated operating power Max. allowable voltage (at 70 °C) 150 mW 110% V of rated coil voltage *square, pulse drive 2 coil latching Rated coil voltage 3 V DC 4.5 V DC 12 V DC 24 V DC 50 mA 60 Ω 33.3 mA 135 Ω 12.5 mA 960 Ω 6.3 mA 3,840 Ω *square, pulse drive Panasonic Industry Co., Ltd. Electromechanical Control Business Division industrial.panasonic.com/ac/e/ ー2ー Panasonic Industry Co., Ltd. 2022 ASCTB105E 202204 Microwave Devices RJ RELAYS Specifications Item Contact data Specifications Contact arrangement 2 Form C Contact resistance (initial) Max. 150 mΩ (by voltage drop 10 V C 10 mA) Contact material Au plating Contact rating 1 W (5 GHz, 50 Ω, V.S.W.R.: Max. 1.25), 10 mA 10 V DC (resistive) Contact input power (CW) Max. 1 W (1 GHz, 50 Ω, V.S.W.R.: Max. 1.25) Max. switching voltage 30 V DC Max. switching current 0.3 A (DC) 500 MΩ (at 500 V DC, Measured portion is the same as the case of dielectric strength.) Insulation resistance (initial) Between open contacts 500 Vrms for 1 min (detection current:10 mA) Dielectric strength (initial) Time characteristics (initial) Between contact and coil 500 Vrms for 1 min (detection current:10 mA) Between contact sets 500 Vrms for 1 min (detection current:10 mA) Between contact and ground 500 Vrms for 1 min (detection current:10 mA) Operate (Set) time Max. 5 ms at rated coil voltage (at 20 °C, without bounce) [Max. 5 ms (at 20 °C, without bounce)] Release (Reset) time Max. 5 ms at rated coil voltage (at 20 °C, without bounce, without diode) [Max. 5 ms (at 20 °C, without bounce)] Shock resistance Functional 500 m/s2 (half-sine shock pulse:6 ms, detection time:10 μs) Destructive 1,000 m/s2 (half-sine shock pulse:11 ms) Vibration resistance Functional 10 to 55 Hz (at double amplitude of 3 mm, detection time:10 μs) Destructive 10 to 55 Hz (at double amplitude of 5 mm) Expected life Mechanical life (Cold switch) Min. 10 x 106 (Switching frequency: 180 times/min) Conditions Conditions for usage, transport and storage* Ambient temperature: -30 to +70 °C (Allowable temperature is from -30 to +60 °C at our standard packing condition.) Humidity:5 to 85% RH (Avoid icing and condensation) Approx. 3 g Unit weight *For ambient temperature, please read “GUIDELINES FOR RELAY USAGE”. Electrical life (Hot switch) Conditions: Resistive load, switching frequency 20 times/min Type 2 Form C Load Switching capacity Number of operations High frequency load 1 W (5 GHz, 50 Ω, V.S.W.R.: Max. 1.25) Min. 106 Resistive load 10 mA 10 V DC Min. 106 REFERENCE DATA 1.High frequency characteristics (50 Ω, Surface mount terminal) Sample:ARJ20A12 Measuring method:See“Measuring method”under“NOTES”. V.S.W.R. characteristics Insertion loss characteristics Isolation characteristics (without D.U.T. board’s loss) 0 0 2 1.9 0.5 1.7 1.6 1.5 1.4 20 Isolation, dB Insertion loss, dB 1.8 V.S.W.R. 10 1 1.5 Between open contact 60 1.2 2.5 70 1.1 1 Between contact sets 40 50 2 1.3 30 45MHz 5GHz Frequency 8GHz 3 45MHz 5GHz Frequency 8GHz 80 45MHz Panasonic Industry Co., Ltd. Electromechanical Control Business Division industrial.panasonic.com/ac/e/ ー3ー Panasonic Industry Co., Ltd. 2022 5GHz Frequency 8GHz ASCTB105E 202204 Microwave Devices RJ RELAYS MEASURING METHOD OF HIGH FREQUENCY CHARACTERISTICS Unit: mm 50 Ω Measuring method ① Network B analyzer A R B S parameter A test set R HP 8710C PORT2 ① HP 85015A No. Product name Contents 1 HP85131-60013 3.5 mm Test port, Extension cable 2 HP83059 3.5 mm Coaxial adapter 1) Connect connectors 1 and 2 respectively to PORT1 and PORT2. Perform calibration using the 3.5 mm calibration kit (HP 85052B). 2) After calibration, connect the D.U.T board and measure. However, connectors other than those for measurement should be connected with 50 Ω termination resistor. ② PORT1 RF IN RF OUT ② Notes: 1. All bottom surface of the base should be touched closely or soldered with PC board ground. 2. 4 ribs should be soldered with PC board ground. D.U.T board Material Glass PTFE double-sided through hole PC board R-4737 (manufactured by our company) Board thickness t = 0.8 mm Copper planting thickness 18 μm PC board terminal Surface mount terminal 8.35 6-1.76 0.8 14.5 0.4 0.4 7.22 3.81 7.62 1 10 4-0.6 dia. Calibration board 45° 6-1.7 dia. 6-0.7 dia. 12.7 0.4 0.4 8.89 12.04 17 6-1.86 0.9 0.4 or 0.5 1.76 or 1.86 78-0.4 dia. 4-1.6 dia. 17 0.4 0.4 Through hole 86-0.4 dia. 1 20 6.72 20 6.62 8.35 0.5 45° 0.5 8.89 11.7 30 30 Connector (SMA type Connector) Product name Correction of insertion loss The insertion loss of relay itself is given by subtracting the insertion loss of short-circuit the COM and the N.C. or N.O. R125 510 (RADIALL) Panasonic Industry Co., Ltd. Electromechanical Control Business Division industrial.panasonic.com/ac/e/ ー4ー Panasonic Industry Co., Ltd. 2022 ASCTB105E 202204 Microwave Devices RJ RELAYS DIMENSIONS Unit: mm CAD The CAD data of the products with a “CAD” mark can be downloaded from our Website. PC board terminal 10.6 Recommended PC board pattern (BOTTOM VIEW) ②4 ribs should be soldered with PC board ground. + 12.7 0 to 0.2 14 9 Tolerance : ±0.1 (Typical:0.1) 0.2 11.4 4 5 + ①All bottom surface of the base 0.5 - 7 6 Direction indication should be touched closely or soldered with PC board ground. 0.15 6.36 3 2 coil latching (Reset) 7.62 0.2 8.89 12.7 2 9 8 characteristics may be obtained when A this portion is soldered with 0.5 3.81 PC board ground. 0.4 1 10 ③Better HF 8.2 3.5 0.5 Schematic (BOTTOM VIEW) Single side stable (De-energize) Direction indication 6-0.7 dia. 12.2 4-0.6 dia. 7.62 Expansion of A 10.4 8.89 3.81 External dimensions CAD 1 2 3 - 10 4 9 5 General tolerance : ±0.3 + 8 7 6 - Surface mount terminal 1.5 14 (Typical:0.1) 0.2 8.2 ③Better HF 10 11.4 A characteristics may be obtained when this portion is soldered with PC board ground. ①All bottom surface of the base should be touched closely or soldered with PC board ground. 0.5 6.36 13.5 11.4 10.4 8.89 1.1 General tolerance : ±0.3 2 3.81 8.2 7.02 6.4 9 15 0.9 1.5 Expansion of A: Coplanarity of terminals & ribs & base 1.7 with PC board ground. 0 to 0.2 0.4 8.89 12.2 ②4 ribs should be soldered 3.81 10.4 0.5 10.6 0.5 Recommended PC board pattern (TOP VIEW) 0.8 0.9 9 12.1 Schematic (TOP VIEW) Single side stable (De-energize) Direction indication 1.3 External dimensions CAD 8 9 5 4 + 1 2 3 - 1.7 2 coil latching (Reset) Tolerance : ±0.1 Relay terminals. Ground. Note that soldering is required. Ground. Note that you must determine the necessity of solder based on effect of heat when soldering. Ground. Note that some extra work is required due to the effect of lifting when soldering. Panasonic Industry Co., Ltd. Electromechanical Control Business Division ー5ー 6 10 Direction indication + Panasonic Industry Co., Ltd. 2022 8 7 6 - 9 5 10 4 + industrial.panasonic.com/ac/e/ 7 1 2 3 - ASCTB105E 202204 Microwave Devices RJ RELAYS PACKING SPECIFICATION Unit: mm Tape and reel packing 1) Tape dimensions 2) Dimensions of plastic reel Z type 9.4 RJ relay 21±0.8 dia. 0.4 2±0.5 16 380±2 dia. X type 8.8 80±1 dia. 4 2 1.5+0.1 0 dia. 14.4 11.5 1.75 24±0.3 Relay polarity bar 24.4+ 20 2±0.2 8.5 Tape coming out direction Relay polarity bar General tolerance : ±0.1 13±0.2 dia. 3) Ambient temperature when transporting and during storage with the product in its our standard packaging: -30 to +60 °C EXAMPLE FOR RECOMMENDED SOLDERING CONDITION For cautions for use, please read “Relay Soldering and Cleaning Guidelines” and “SMT Soldering Guidelines”. PC board terminal In case of hand soldering, the following conditions should be observed. The effect on the relay depends on the PC board used. Please verify the actual PC board to be used. Automatic soldering (Flow) Manual soldering Recommended condition Time Measurement area Recommended condition Temperature Temperature Time Measurement area Preheating Max. 120 °C Within 120 seconds Solder surface terminal Soldering Max. 350 °C Within 3 seconds Tip temperature Soldering 260 ± 5 °C Within 6 seconds Solder temperature Surface mount terminal In case of automatic soldering (reflow), the following conditions should be observed. IRS (infrared reflow soldering method) heating conditions Recommended condition The number of reflow operation 1 time Measurement area Surface of PC board where relay is mounted. t4 T3 T2 T1 t1 t2 t3 t 1=60s to 120s t 2=within 20s t 3=within 30s C) t 4=within 10s(245 to 250° T1=150 to 180° C C and higher T2=230° C max T3=250° Mounting cautions Cautions to observe when mounting temperature increases in the relay are greatly dependent on the way different parts are located a PC board and the heating method of the reflow device. Therefore, please conduct testing on the actual device beforehand after making sure the parts soldered on the relay terminals and the top of the relay case are within the temperature conditions. Measuring position of temperature profile Note Note:The soldering temperature profile indicates the pad temperature. In some cases, the ambient temperature may be greatly increased. Check for the specific mounting condition. Other things to observe • Exceeding the stipulated conditions when soldering may affect coaxial switch performance. Be sure to consult us beforehand. • Since thermal stress on a relay will depend on the PC board and process conditions, please be sure to test using the actual PC board. • Creep-up, wettability and solder strength will differ depending on changes in the mounting conditions and type of solder. Please evaluate based on actual production conditions. • Only apply coating after the relay has returned to room temperature. Panasonic Industry Co., Ltd. Electromechanical Control Business Division industrial.panasonic.com/ac/e/ ー6ー Panasonic Industry Co., Ltd. 2022 ASCTB105E 202204 Microwave Devices RJ RELAYS GUIDELINES FOR USAGE  or cautions for use, please read “GUIDELINES FOR MICROWAVE DEVICES USAGE” and “GUIDELINES FOR F RELAY USAGE” Cautions for usage of RJ relays Latching • We recommend latching type when using in applications which involve lengthy duty cycles. • Regarding the set and reset pulse time, for the purpose of reliable operation under ambient temperature fluctuations and different operating conditions, we recommend setting the coil applied set and reset pulse time to 20 ms or more at the rated coil voltage. • The latching type relay is shipped in the reset position. But jolts during transport or impacts during installation can change the reset position. It is, therefore, advisable to build a circuit in which the relay can be initialized (set and reset) just after turning on the power. External magnetic field • Since RJ relays are highly sensitive polarized relays, their characteristics will be affected by a strong external magnetic field. Avoid using the relay under that condition. CONDITIONS FOR USE Conditions for use, transport and storage conditions During usage, storage, or transportation, avoid locations subject to direct sunlight and maintain normal temperature, humidity, and pressure conditions. Temperature and humidity When transporting or storing relays while they are tube packaged, there are cases when the temperature may differ from the allowable range. In this situation, be sure to consult the individual specifications. The humidity range varies with the temperature. Use within the range indicated in the graph. (The allowable temperature depends on the relays.) Humidity(%RH) 85 Allowable range Avoid icing when used at temperatures lower than 0℃ Avoid condensation when used at temperatures higher than 0℃ 5 0 70 Ambient temperature(℃) ー30 Panasonic Industry Co., Ltd. Electromechanical Control Business Division industrial.panasonic.com/ac/e/ ー7ー Panasonic Industry Co., Ltd. 2022 ASCTB105E 202204 GUIDELINES FOR MICROWAVE DEVICES USAGE For cautions for use, please read “GUIDELINES FOR RELAY USAGE”. https://industrial.panasonic.com/ac/e/control/relay/cautions_use/index.jsp Precautions for Coil Input Long term current carrying A circuit that will be carrying a current continuously for long periods without relay or microwave device switching operation. (circuits for emergency lamps, alarm devices and error inspection that, for example, revert only during malfunction and output warnings with form B contacts) Continuous, long-term current to the coil will facilitate deterioration of coil insulation and characteristics due to heating of the coil itself. For circuits such as these, please use a magnetic-hold type latching relay. If you need to use a single stable relay, use a sealed type relay that is not easily affected by ambient conditions and make a failsafe circuit design that considers the possibility of contact failure or disconnection. DC Coil operating power Maximum allowable voltage and temperature rise Proper usage requires that the rated coil voltage be impressed on the coil. Note, however, that if a voltage greater than or equal to the maximum continuous voltage is impressed on the coil, the coil may burn or its layers short due to the temperature rise. Furthermore, do not exceed the usable ambient temperature range listed in the catalog. Maximum allowable voltage for coil In addition to being a requirement for relay operation stability, the maximum continuous impressed coil voltage is an important constraint for the prevention of such problems as thermal deterioration or deformity of the insulation material, or the occurrence of fire hazards. Operate voltage change due to coil temperature rise   (Hot start) In DC relays, after continuous passage of current in the coil, if the current is turned OFF, then immediately turned ON again, due to the temperature rise in the coil, the operate voltage will become somewhat higher. Also, it will be the same as using it in a higher temperature atmosphere. The resistance/temperature relationship for copper wire is about 0.4% for 1 °C, and with this ratio the coil resistance increases. That is, in order to operate of the relay, it is necessary that the voltage be higher than the operate voltage and the operate voltage rises in accordance with the increase in the resistance value. However, for some polarized relays, this rate of change is considerably smaller. Steady state DC current should be applied to the coil. The wave form should be rectangular. If it includes ripple, the ripple factor should be less than 5%. However, please check with the actual circuit since the electrical characteristics may vary. The rated coil voltage should be applied to the coil and the set/reset pulse time of latching type relay differs for each relays, please refer to the relay's individual specifications. Coil connection When connecting coils of polarized relays, please check coil polarity (+,-) at the internal connection diagram (Schematic). If any wrong connection is made, it may cause unexpected malfunction, like abnormal heat, fire and so on, and circuit do not work. Avoid impressing voltages to the set coil and reset coil at the same time. Ambient Environment Dew condensation Condensation occurs when the ambient temperature drops suddenly from a high temperature and humidity, or the relay and microwave device is suddenly transferred from a low ambient temperature to a high temperature and humidity. Condensation causes the failures like insulation deterioration, wire disconnection and rust etc. Panasonic Industry Co., Ltd. does not guarantee the failures caused by condensation. The heat conduction by the equipment may accelerate the cooling of device itself, and the condensation may occur. Please conduct product evaluations in the worst condition of the actual usage. (Special attention should be paid when high temperature heating parts are close to the device. Also please consider the condensation may occur inside of the device.) Icing Condensation or other moisture may freeze on relays when the temperature become lower than 0 °C.This icing causes the sticking of movable portion, the operation delay and the contact conduction failure etc. Panasonic Industry Co., Ltd. does not guarantee the failures caused by the icing. The heat conduction by the equipment may accelerate the cooling of relay itself and the icing may occur. Please conduct product evaluations in the worst condition of the actual usage. Low temperature and low humidity The plastic becomes brittle if the switch is exposed to a low temperature, low humidity environment for long periods of time. High temperature and high humidity Storage for extended periods of time (including transportation periods) at high temperature or high humidity levels or in atmospheres with organic gases or sulfide gases may cause a sulfide film or oxide film to form on the surfaces of the contacts and/or it may interfere with the functions. Check out the atmosphere in which the units are to be stored and transported. Package In terms of the packing format used, make every effort to keep the effects of moisture, organic gases and sulfide gases to the absolute minimum. Panasonic Industry Co., Ltd. Electromechanical Control Business Division industrial.panasonic.com/ac/e/ ー8ー Panasonic Industry Co., Ltd. 2022 ASCTB403E 202204 GUIDELINES FOR MICROWAVE DEVICES USAGE Storage requirements Since the surface-mount terminal type is sensitive to humidity it is packaged with tightly sealed anti-humidity packaging. However, when storing, please be careful of the following. 1) Please use promptly once the anti-humidity pack is opened.(within 72 hours, Max. 30 °C/70% RH). If left with the pack open, the relay will absorb moisture which will cause thermal stress when reflow mounting and thus cause the case to expand. As a result, the seal may break. *For RE relays, after this bag is opened, the product must be used within 24 hours. 2) If relays will not be used within 72 hours, please store relays in a humidity controlled desiccator or in an anti-humidity bag to which silica gel has been added. *If the relay is to be soldered after it has been exposed to excessive humidity atmosphere, cracks and leaks can occur. Be sure to mount the relay under the required mounting conditions *For RE relays, after this bag is opened, the product must be used within 24 hours. 3) The following cautionary label is affixed to the anti-humidity pack. Silicon When a source of silicone substances (silicone rubber, silicone oil, silicone coating materials and silicone filling materials etc.) is used around the relay, the silicone gas (low molecular siloxane etc.) may be produced. This silicone gas may penetrate into the inside of the relay. When the relay is kept and used in this condition, silicone compound may adhere to the relay contacts which may cause the contact failure. Do not use any sources of silicone gas around the relay (Including plastic seal types). NOx Generation When relay is used in an atmosphere high in humidity to switch a load which easily produces an arc, the NOx created by the arc and the water absorbed from outside the relay combine to produce nitric acid. This corrodes the internal metal parts and adversely affects operation. Avoid use at an ambient humidity of 85%RH or higher (at 20 °C). If use at high humidity is unavoidable, please contact our sales representative. *RE Relays only Others Cleaning 1) Although the environmentally sealed type relay (plastic sealed type, etc.) can be cleaned, avoid immersing the relay into cold liquid (such as cleaning solvent) immediately after soldering. Doing so may deteriorate the sealing performance. 2) Surface-mount terminal type relay is sealed type and it can be cleaned by immersion. Use pure water or alcohol-based cleaning solvent. 3) Cleaning with the boiling method is recommended (The temperature of cleaning liquid should be 40°C or lower). Avoid ultrasonic cleaning on relays. Use of ultrasonic cleaning may cause breaks in the coil or slight sticking of the contacts due to the ultrasonic energy. Please refer to "the latest product specifications" when designing your product. •Requests to customers: https://industrial.panasonic.com/ac/e/salespolicies/ Panasonic Industry Co., Ltd. Electromechanical Control Business Division industrial.panasonic.com/ac/e/ ー9ー Panasonic Industry Co., Ltd. 2022 ASCTB403E 202204 Electromechanical Control Business Division 1006, Oaza Kadoma, Kadoma-shi, Osaka 571-8506, Japan industral.panasonic.com/ac/e/ ©Panasonic Industry Co., Ltd. 2022 Specifications are subject to change without notice. ASCTB105E 202204 2022.4
ARJ22A4H 价格&库存
很抱歉,暂时无法提供与“ARJ22A4H”相匹配的价格&库存,您可以联系我们找货
