PRODUCT
P/N:
GVT1H107M0810CNVC
DATA
SHEET
Page: 1/2
GVT, 50v, 100uF, 8x10.5
■ Description 产品描述:
Al-Ecap, 100uF, 50v, ±20%, D8H10.5mm, 2000Hrs@105℃, -55~+105℃, SMD.
■ Features 特长/用途:
■ Dimension& Marking 印刷及尺寸:
·105℃, 2,000 hours assured 宽温长寿命
· Designed for surface mounting on high
density PC board 适合高密度表面安装
■ Serie Expansion 系列拓展
Items
Case
Φ8x10.5
A
B
C
D
P
L
α
W
H
8.3
8.3
9
8.0
3.1
10.5
±0.5
0.8~1.1
0.5max.
Items 项目
Performance 性能
Rated Voltage 额定电压(VR)
50 V
Capacitance 额定容量(CR)
100 uF
Category Temperance Range
类别温度范围
Capacitance Tolerance
容量误差
-55℃ ~ +105℃
-20% ~ +20%
Surge Voltage 浪涌电压(VS)
(120Hz, 20℃)
57.5 VDC
Leakage Current 泄漏电流(ILC)
ILC≤ 50 uA
Dissipation Factor (Tanδ)
损失角正切值
After 2 minutes
≤ 0.14
Ripple Current 纹波电流(IRC, rms)
(120Hz, 20℃)
140 mA
Low Temperature Characteristics
温度特性(120Hz)
Impedance ratio
阻抗比(Max.)
Endurance and Shelf Life
耐久性及高温无负荷特性
Items
项目
Test Time
测试时长
Cap. Change
容量变化率
Tanδ
损失角正切值
Leakage Current
漏电流
Ripple Current and Frequency
Multipliers 纹波电流频率系数
(120Hz, 20℃)
Z(-25℃)/ Z(+20℃)
2
Z(-55℃)/ Z(+20℃)
3
(120Hz, 105℃)
Endurance
耐久性
Shelf Life Test
高温无负荷
2,000 Hrs at 105℃; VR
1,000 Hrs at 105℃
Within ±20% of initial Value
≤初始值的±20%
Less than 200% of specified Value
≤初始规格值的±200%
Whitin specified Value
≤初始规格值
≤初始值的±20%
≤初始规格值的±200%
≤初始规格值
Frequency (Hz)
50, 60
120
1k
10k up
Multiplier
0.80
1.00
1.20
1.30
Standards 参考标准
JIS C 5101-1, -18, IEC 60384-4
Remarks 附注
RoHS Compliance, Halogen-free
* Please refer to “Precautions and Guidelines for Aluminum Electrolytic Capacitors” section in catalog for further details 详细信息请参
阅目录中的“铝电解电容器注意事项和指南”
Publication Date
发行日期
Revision Date
修订日期
2022-02-15
Version No.
DR-RE-RD006.A1, 220215
1.0
Approved
批 准
Checked
复 核
Designed
设 计
Lei Yang
Chao Yu
Series:
GVT
PRODUCT
DATA
SHEET
Dimension and Permissible Ripple Current 尺寸及纹波电流速查表:
Page: 1/2
很抱歉,暂时无法提供与“GVT1H107M0810CNVC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.59508
- 50+0.48725
- 150+0.43339
- 500+0.36537
- 2500+0.33304
- 5000+0.31683
