GVT1H106M0506CNVC
GVT1H106M0506CNVC
    HRK(鸿瑞凯)
    SMD,D5xL5.7mm
    10UF ±20% 50V
GVT1H106M0506CNVC 数据手册
PRODUCT P/N: GVT1H106M0506CNVC DATA SHEET Page: 1/2 GVT, 50v, 10uF, 5x5.7 ■ Description 产品描述: Al-Ecap, 10uF, 50v, ±20%, D5H5.7mm, 2000Hrs@105℃, -55~+105℃, SMD. ■ Features 特长/用途: ■ Dimension& Marking 印刷及尺寸: ·105℃, 2,000 hours assured 宽温长寿命 · Designed for surface mounting on high density PC board 适合高密度表面安装 ■ Serie Expansion 系列拓展 Items Case Φ5x5.7 A B C D P L α W H 5.3 5.3 6 5.0 1.5 5.7 ±0.3 0.5~0.8 0.5max. Items 项目 Performance 性能 Rated Voltage 额定电压(VR) 50 V Capacitance 额定容量(CR) 10 uF Category Temperance Range 类别温度范围 Capacitance Tolerance 容量误差 -55℃ ~ +105℃ -20% ~ +20% Surge Voltage 浪涌电压(VS) (120Hz, 20℃) 57.5 VDC Leakage Current 泄漏电流(ILC) ILC≤ 5 uA Dissipation Factor (Tanδ) 损失角正切值 After 2 minutes ≤ 0.14 Ripple Current 纹波电流(IRC, rms) (120Hz, 20℃) 18 mA Low Temperature Characteristics 温度特性(120Hz) Impedance ratio 阻抗比(Max.) Endurance and Shelf Life 耐久性及高温无负荷特性 Items 项目 Test Time 测试时长 Cap. Change 容量变化率 Tanδ 损失角正切值 Leakage Current 漏电流 Ripple Current and Frequency Multipliers 纹波电流频率系数 (120Hz, 20℃) (120Hz, 105℃) Z(-25℃)/ Z(+20℃) 2 Z(-55℃)/ Z(+20℃) 3 Endurance 耐久性 Shelf Life Test 高温无负荷 2,000 Hrs at 105℃; VR 1,000 Hrs at 105℃ Within ±20% of initial Value ≤初始值的±20% Less than 200% of specified Value ≤初始规格值的±200% Whitin specified Value ≤初始规格值 Within ±20% of initial Value ≤初始值的±20% Less than 200% of specified Value ≤初始规格值的±200% Whitin specified Value ≤初始规格值 Frequency (Hz) 50, 60 120 1k 10k up Multiplier 0.70 1.00 1.35 1.50 Standards 参考标准 JIS C 5101-1, -18, IEC 60384-4 Remarks 附注 RoHS Compliance, Halogen-free * Please refer to “Precautions and Guidelines for Aluminum Electrolytic Capacitors” section in catalog for further details 详细信息请参 阅目录中的“铝电解电容器注意事项和指南” Publication Date 发行日期 Revision Date 修订日期 2022-02-15 Version No. DR-RE-RD006.A1, 220215 1.0 Approved 批 准 Checked 复 核 Designed 设 计 Lei Yang Chao Yu Series: GVT PRODUCT DATA SHEET Dimension and Permissible Ripple Current 尺寸及纹波电流速查表: Page: 1/2
GVT1H106M0506CNVC 价格&库存
很抱歉,暂时无法提供与“GVT1H106M0506CNVC”相匹配的价格&库存,您可以联系我们找货
GVT1H106M0506CNVC
    • 20+0.26225
    • 200+0.21229
    • 1000+0.16252
    • 2000+0.14590
    • 10000+0.13143
    • 20000+0.12363
    库存:476
