3500 SERIES
MICRO-DIP PRINTED
CIRCUIT BOARD SWITCHES
The 3500 Series MICRO-DIP® is a low profile,
fully sealed rotary DIP switch designed for
today’s automated soldering and cleaning
processes!
Featuring direct decimal to binary conversion,
the 3500 Series Micro-DIP is a user friendly
means of addressing PROM’s or setting microprocessor controlled devices. The 3500 Series is
offered in six binary and decimal codes, with
extended shafts and right angle orientations for
maximum design flexibility. The 3500 Series is
covered by EECO’s exclusive Lifetime Warranty.
All 3500 Series products are Lead-Free and fully
RoHS compliant.
LEAD-FREE!
SPECIFICATIONS
MECHANICAL
No. of Switching Positions
Life
Rotational Torque (Initial)
Terminal Strength
8, 10 16
20,000 Detents at +250C
1.0-4.5 Inch/Ounces
Pull 3 Pounds, Push 3 Pounds, for 15 Seconds
ELECTRICAL
Minimum Switching Current
Minimum Switching Voltage
Maximum Electrical Current, Non-Switching
Maximum Rated Load, Switching
Contact Resistance (Initial)
Insulation Resistance
Dielectric Withstanding Voltage
1µA
30 mVDC
1A
100 mA at 28 VDC Resistive
100 mΩ Maximum
1,000 MΩ Minimum At 100 VDC
250 VAC (RMS)
ENVIRONMENTAL
Operating Temperature
Storage Temperature
Vibration
Moisture Resistance
Seal
Solderability
Solvent Resistance
Humidity
-650C To +850C
-650C To +1250C
15g, 10 to 2,000 Hz, Method 204, Condition B of
Mil-Std 202
Method 106, Mil-Std 202, 50 VDC Polarizing Voltage
Top: O-Ring Bottom: Epoxy
Method 208 of Mil-Std 202, 95% Coverage
Method 215 of Mil-Std 202
Method 103B of Mil-Std 202, Test Condition A
MATERIALS
Housing and Base
Rotor
O-Ring
Contact
Terminal
Weight
Knobs
Type B
Type K
Type V
Glass Reinforced High Temperature 4/6 Nylon, UL 94 V0
Glass Reinforced 6/6 Nylon UL 94 V0
Silicon Rubber
Copper Alloy Base, Gold Over Nickel Plate
Matte Tin With Whisker Inhibitors Over Nickel Plate
0.03 Oz (.86G)
ABS, UL 94 V0 (Black)
Glass Reinforced Polyester, 94 V0 (White)
Glass Reinforced 6/6 Nylon, 94 V0 (Black)
3500 Series
NOTE: “B” and “V” Knobs are Black, “K” Knob is White
3500 Series
PCB DESIGN INFORMATION
Refer to EECO Switch document “Soldering and Cleaning Specifications” for processing information.
RoHS COMPLIANCE
EECO Switch is fully committed to complying with the European Lead-Free and RoHS directives. All EECO
3500 Series switches marked with the “Pb-Free” logo on the body of the part are Lead-Free and RoHS
compliant.
3500 Series
ORDERING INFORMATION
EECO SWITCH
880 Columbia St.
Brea, CA 92821-2916
Tel: (714) 835-6000
Fax: (714) 482-9429
E-Mail: sales@eecoswitch.com
A Transico Company
8/12/08
EECO EUROPE
Unit 5, Hazlewell Court
Bar Road, Lolworth
Cambridgeshire, CB23 8DS England
TEL: +44 (0) 1954-781818
FAX: +44 (0) 1954-789305
E-mail: sales@eecoswitch.co.uk
很抱歉,暂时无法提供与“350035GS”相匹配的价格&库存,您可以联系我们找货
