276028MV
276028MV
    EECO
    2700 Series Single Pole Binary 10 Position Through Hole BCD 1-2-4-8 Switch
276028MV 数据手册
® 2700 SERIES STRIPSWITCH® PRINTED CIRCUIT BOARD SWITCHES The 2700 Series STRIPSWITCH® combines the many advanced features of the original 2100 Series into a compact, fully sealed switch design suitable for wave soldiering and automated cleaning processes. The 2700 Series features legends located on both the top and side of the thumbwheel for maximum design flexibility and user convenience. Available options for the 2700 Series include ¼” and ½” extended shafts, black or white thumbwheels, stops, and a wide variety of 10 and 16 position binary and decimal coded outputs. Custom rotor markings are also available in all 2700 Series versions. The 2700 Series STRIPSWITCH is covered by EECO’s exclusive Lifetime Warranty. All 2700 Series products are Lead-Free and fully RoHS compliant. LEAD-FREE! SPECIFICATIONS MECHANICAL No. of Switching Positions Life Rotational Torque (Initial) Weight 10 And 16 100,000 Detents At +250C 2.5 – 8.5 Inch/Ounces 0.173 Oz (4.9 Gr.) ELECTRICAL Maximum Electrical Current, Non-Switching 3A Maximum Rated Load, Switching 125 mA at 28 VDC Resistive Switch Circuit Resistance (Initial) 100 mΩ Maximum Insulation Resistance 1,000 MΩ Minimum At 100 VDC Dielectric Withstanding Voltage 250 VAC (RMS) All 2 Pole And 16 Position 500 VAC (RMS) All Others ENVIRONMENTAL Storage Temperature -650C To +1250C Operating Temperature -650C To +850C Vibration 15 G, 10 to 2,000 Hz, Method 204 Of Mil-Std 202, Test Condition B Moisture Resistance Method 106, Mil-Std 202, 50 VDC Humidity Method 103B, Mil-Std 202, Test Condition A, 50 VDC Solvent Resistance Method 215, Mil-Std 202 Seal Top: O-Ring Bottom: Epoxy MATERIALS Housing and Thumbwheel Contact Terminal O-Ring Circuit Disc Base Material Plating Glass Reinforced Polyester, UL 94 V0 Copper Alloy Base, Gold Over Nickel Plate Matte Tin With Whisker Inhibitors Over Nickel Plate Silicone Rubber Per ZZ-R-765B Glass Epoxy Laminate Gold Over Nickel Plate 2700 Series OUTLINE DIMENSIONS RoHS COMPLIANCE EECO Switch is fully committed to complying with the European Lead-Free and RoHS directives. All EECO 2700 Series switches marked with the “Pb-Free” logo on the body of the part are 100% lead-free and comply with the relevant RoHS requirements. 2700 Series ORIENTATION DESIGNATORS AND PCB LAYOUT DATA Refer to EECO Switch document “Soldering and Cleaning Specifications” for processing information. 2700 Series PART NUMBERS AND FEATURES PART NUMBER SWITCH DESCRIPTION NUMBER OF POSITIONS 27XX01M Decimal 27XX02M 27XX12M 27XX17M 27XX19M 27XX28M 27XX29M 27XX31M 27XX33M 27XX34M 27XX41M 27XX85M BCD 1-2-4-8 BCD 1-2-4-8 Complement Complement of 9’s Complement 9’s Complement 1-2-4-8 BCD 1-2-4-8 With Complement BCH 1-2-4-8 W With Complement, 0-15 Marking BCH 1-2-4-8 Complement, 0-15 Marking BCH 1-2-4-8 0-15 Marking BCH 1-2-4-8 0-9-A-F Marking BCH 1-2-4-8 Complement, 0-9-A-F Marking BCH 1-2-4-8 W With Complement, 0-9-A-F Marking 27XX56M 27XX57M BCD 1-2-4-8 W/Separate Common to Not True Bits BCD 1-2-4-8 W/Separate Common to Not True Bits 0-15 Marking BCD 1-2-4-8 W/Separate Common to Not True Bits 0-9-A-F Marking TRUTH TABLE SINGLE POLE DECIMAL 10 A02 10 10 10 10 10 16 16 16 16 16 16 B02 C12 C02 C15 C02 C06 C16 B07 B07 C16 C06 10 16 D02 D06 16 D06 SINGLE POLE BINARY DOUBLE POLE BINARY 27XX58M SPECIAL PURPOSE CODES 27XX11M 27XX64M 2 Pole Repeating, + / 2 Pole 4 Position Decimal Repeating 10 10 S01 A09 ORDERING INFORMATION EECO Switch 880 Columbia St. Brea, CA 92821-2916 Tel: (714) 835-6000 Fax: (714) 482-9429 E-Mail: sales@eecoswitch.com ® A Transico Company 8/22/12 EECO EUROPE Unit 5, Hazlewell Court Bar Road, Lolworth Cambridgeshire, CB23 8DS England TEL: +44 (0) 1954-781818 FAX: +44 (0) 1954-789305 E-mail: sales@eecoswitch.co.uk
276028MV 价格&库存
很抱歉,暂时无法提供与“276028MV”相匹配的价格&库存,您可以联系我们找货
