480002G
480002G
    EECO
480002G 数据手册
 4800 SERIES MICRO-DIP SMT PRINTED CIRCUIT BOARD SWITCHES The 4800 Series MICRO-DIP® is a true SURFACE MOUNT version of our popular MICRO-DIP family. Like all EECO MICRO-DIPS, the 4800 Series permits direct setting of binary-coded values for PROMs and other user-addressable devices. All materials used in the 4800 Series were carefully selected to withstand the rigors of the surfacemount process, then engineered into an ultra low profile, fully sealed package. The compact dimensions of the 4800 Series require minimal board space and permit closely stacked PCB designs. The ultra low profile design allows unrestricted heat flow during installation, eliminating the possibility of shadowing adjacent components. The 4800 Series is covered by a one year warranty. All 4800 Series products are Lead-Free and RoHS compliant. LEAD-FREE! SPECIFICATIONS MECHANICAL No. of Switching Positions Life (Electrical) (Mechanical) Rotational Torque (Initial) 10 16 10,000 Detents Min at Rated Load 20,000 Detents Min. At No Load 2.75 Inch/Ounce Max ELECTRICAL Minimum Rated Load Maximum Rated Load, Switching Contact Resistance (Initial) Insulation Resistance Dielectric Withstanding Voltage 1µA At 1 mV, AC/DC 40 mA at 20 VDC 100 mΩ Maximum At 10 mA, 2.0 VDC 1,000 MΩ Minimum At 250 VDC 250 VAC, 1 Minute ENVIRONMENTAL -300C To +850C -450C To +1000C Full Process Seal Operating Temperature Storage Temperature Seal MATERIALS Housing and Base Rotor O-Ring Contact and Terminal Detent Polyphenylene Sulfide UL-94 V0 46 Nylon UL-94V0 Silicon Rubber Beryllium Copper, Gold Over Nickel Plate Stainless Steel RoHS COMPLIANCE EECO Switch is fully committed to complying with the European Lead-Free and RoHS directives. The 4800 Series is Lead-Free and RoHS compliant. Refer to EECO Switch document “Soldering and Cleaning Specifications” for processing information 4800 Series PART NUMBERS AND DIMENSIONS 4800 SERIES STANDARD SWITCHES FLUSH EXTENDED ROTOR CODE NO. OF TRUTH SHAFT SHAFT COLOR DESCRIPTION POSITIONS TABLE 480002G 480102G Red 1 Pole BCD 10 B02 480012G 480112G Orange 1 Pole BCD Complement 10 C12 480035G 480135G Green 1 Pole BCH 16 B07 16 C16 480041G 480141G White 1 Pole BCH Complement Tape and Reel packaging available. Add “R” to part number to specify, ex. 480002GR. Consult factory for additional ordering information and packaging details. EECO SWITCH 880 Columbia St. Brea, CA 92821-2916 Tel: (714) 835-6000 Fax: (714) 482-9429 E-Mail: sales@eecoswitch.com ® A Transico Company 11/24/09 EECO EUROPE Unit 5, Hazlewell Court Bar Road, Lolworth Cambridgeshire, CB23 8DS England TEL: +44 (0) 1954-781818 FAX: +44 (0) 1954-789305 E-mail: sales@eecoswitch.co.uk
480002G 价格&库存
很抱歉,暂时无法提供与“480002G”相匹配的价格&库存,您可以联系我们找货
