350034GS
350034GS
    EECO
    插件
350034GS 数据手册
3500 SERIES MICRO-DIP PRINTED CIRCUIT BOARD SWITCHES  The 3500 Series MICRO-DIP® is a low profile, fully sealed rotary DIP switch designed for today’s automated soldering and cleaning processes! Featuring direct decimal to binary conversion, the 3500 Series Micro-DIP is a user friendly means of addressing PROM’s or setting microprocessor controlled devices. The 3500 Series is offered in six binary and decimal codes, with extended shafts and right angle orientations for maximum design flexibility. The 3500 Series is covered by EECO’s exclusive Lifetime Warranty. All 3500 Series products are Lead-Free and fully RoHS compliant. LEAD-FREE! SPECIFICATIONS MECHANICAL No. of Switching Positions Life Rotational Torque (Initial) Terminal Strength 8, 10 16 20,000 Detents at +250C 1.0-4.5 Inch/Ounces Pull 3 Pounds, Push 3 Pounds, for 15 Seconds ELECTRICAL Minimum Switching Current Minimum Switching Voltage Maximum Electrical Current, Non-Switching Maximum Rated Load, Switching Contact Resistance (Initial) Insulation Resistance Dielectric Withstanding Voltage 1µA 30 mVDC 1A 100 mA at 28 VDC Resistive 100 mΩ Maximum 1,000 MΩ Minimum At 100 VDC 250 VAC (RMS) ENVIRONMENTAL Operating Temperature Storage Temperature Vibration Moisture Resistance Seal Solderability Solvent Resistance Humidity -650C To +850C -650C To +1250C 15g, 10 to 2,000 Hz, Method 204, Condition B of Mil-Std 202 Method 106, Mil-Std 202, 50 VDC Polarizing Voltage Top: O-Ring Bottom: Epoxy Method 208 of Mil-Std 202, 95% Coverage Method 215 of Mil-Std 202 Method 103B of Mil-Std 202, Test Condition A 50 VDC Polarizing Voltage MATERIALS Housing and Base Rotor O-Ring Contact Terminal Weight Knobs Type B Type K Type V Glass Reinforced High Temperature 4/6 Nylon, UL 94 V0 Glass Reinforced 6/6 Nylon UL 94 V0 Silicon Rubber Copper Alloy Base, Gold Over Nickel Plate Matte Tin With Whisker Inhibitors Over Nickel Plate 0.03 Oz (.86G) ABS, UL 94 V0 (Black) Glass Reinforced Polyester, 94 V0 (White) Glass Reinforced 6/6 Nylon, 94 V0 (Black) 3500 Series NOTE: “B” and “V” Knobs are Black, “K” Knob is White 3500 Series PCB DESIGN INFORMATION Refer to EECO Switch document “Soldering and Cleaning Specifications” for processing information. RoHS COMPLIANCE EECO Switch is fully committed to complying with the European Lead-Free and RoHS directives. All EECO 3500 Series switches marked with the “Pb-Free” logo on the body of the part are Lead-Free and RoHS compliant. 3500 Series ORDERING INFORMATION EECO SWITCH 880 Columbia St. Brea, CA 92821-2916 Tel: (714) 835-6000 Fax: (714) 482-9429 E-Mail: sales@eecoswitch.com ® A Transico Company 8/12/08 EECO EUROPE Unit 5, Hazlewell Court Bar Road, Lolworth Cambridgeshire, CB23 8DS England TEL: +44 (0) 1954-781818 FAX: +44 (0) 1954-789305 E-mail: sales@eecoswitch.co.uk
350034GS 价格&库存
很抱歉,暂时无法提供与“350034GS”相匹配的价格&库存,您可以联系我们找货
