C6P0112N-A
C6P0112N-A
    ELECTROSWITCH
    旋转开关 28VDC 125VAC
C6P0112N-A 数据手册
C5/C6 - SERIES 0.92" DIAMETER SPECIFICATIONS AND ORDERING INFORMATION 1.0 AMP @ 28 VDC The C5 Series offers a very economical and lightweight design. Standard features include 30° indexing up to 12 positions, solder lug terminals, fixed stops, and both internal and external seals for washability. The C6 Series offers the same features in an unsealed design. C SPECIFICATIONS ELECTRICAL MECHANICAL Current and Voltage Rating: Make and break resistive load 1 amp @ 28 VDC; 1 amp @ 125 VAC. Current Carrying Capacity: 5 amps. Dielectric Strength: 1,000 VAC between current carrying parts and ground. Contact Resistance: Average initial 20 milliohms. Insulation Resistance: In excess of 10,000 megohms. Materials and Finishes: All parts utilize non-corrosive materials as standard. Terminals and Contacts: Brass with silver plate as standard. Insulation: Polyester. Index: Molded live spring detent. Index Life: 10,000 cycles minimum. Index Torque: Switches have lowest practical torque consistent with crisp detenting and smooth, reliable operation. Index Angles: Positive 30° standard. Index Stops: Fixed standard, adjustable, or continuous available. Stop Strength: 4.5 in. lbs. minimum. Hardware: Mounting nut and lockwasher are shipped assembled. STANDARD PART NUMBER C5 - SOLDER LUG TERMINALS C5 - P.C. TERMINALS SWITCHES - 30° INDEX - ADJUSTABLE STOPS - SET @ 2 POS. - SEALED SWITCHES - 30° INDEX - ADJUSTABLE STOPS - SET @ 2 POS. - SEALED ACTIVE POLES/ POLES POSITIONS SECTION 01 02-12 02 02-06 03 02-04 04 02-03 C6 - UNSEALED 01 02-12 02 02-06 03 02-04 04 02-03 NO. OF SECTIONS NONSHORTING FIG. * 1 2 3 4 1 1 1 1 C5P0112N - A C5P0206N - A C5P0304N - A C5P0403N - A CE CJ CL CM 1 2 3 4 1 1 1 1 C6P0112N - A C6P0206N - A C6P0304N - A C6P0403N - A CE CJ CL CM ACTIVE POLES/ POLES POSITIONS SECTION 01 02-12 02 02-06 03 02-04 04 02-03 C6 - UNSEALED 01 02-12 02 02-06 03 02-04 04 02-03 NO. OF SECTIONS NONSHORTING FIG. * 1 2 3 4 1 1 1 1 C5P0112N - RA C5P0206N - RA C5P0304N - RA C5P0403N - RA CE CJ CL CM 1 2 3 4 1 1 1 1 C6P0112N - RA CE C6P0206N - RA CJ C6P0304N - RA CL C6P0403N - RA CM * FIGURES ARE SHOWN ON PAGE 55. DIMENSIONS STANDARD CONSTRUCTION • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 12 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 C5/C6 - SERIES ADDITIONAL OPTIONS AND ORDERING INFORMATION How to Order Additional Options: 2 DIGIT SERIES INSULATION TYPE C5 P - POLYESTER SEALED C6 TOTAL POLES P - POLYESTER UNSEALED ACTIVE POSITIONS CONTACT TYPE 01 02 03 04 12 06 04 03 - MAX - MAX - MAX - MAX N - NON SHORTING 01 02 03 04 12 06 04 03 - N - NON SHORTING TERMINAL TYPE INDEX ANGLE STOP TYPE L - SOLDER LUG R - REAR P.C. SHAFT/ BUSHING SHAFT FLAT SEE CHART "A" SEE CHART "B" (SPECIFY) (SPECIFY) (SPECIFY) F - FIXED A - ADJ. C - CONT. MAX MAX MAX MAX CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS C ADDITIONAL OPTIONS N P (SPECIFY) (SPECIFY) (SPECIFY) (SPECIFY) SHAFT AND FLAT OPTIONS TERMINAL TYPES L SHAFT AS VIEWED WITH NON-TURN LUG AT 9 O'CLOCK AND SHAFT IN EXTREME CCW POSITION . 14 15 R 1 1/2 SLOTTED Y PRINTED CIRCUIT BOARD TERMINAL PATTERNS 1-POLE 2-POLE 3-POLE 1 1 1 4-POLE 1 1 1 1 1 1 1 1 = 1ST POSITION CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS. • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 13
C6P0112N-A 价格&库存
很抱歉,暂时无法提供与“C6P0112N-A”相匹配的价格&库存,您可以联系我们找货
