C7 - SERIES
51.6 mm DIAMETER
C
SPECIFICATIONS AND ORDERING INFORMATION
1.0 AMP @ 28 VDC
The C7 Series provides a fully enclosed, modular design that enables
switching up to 24 positions. Our standard design offers 15° indexing,
and solder lug terminals.
M
E
T
R
I
C
SPECIFICATIONS
ELECTRICAL
Current and Voltage Rating: Make and break resistive load
1.0 amp @ 28 VDC; 0.5 amp @ 125 VAC.
Current Carrying Capacity: 25 amps.
Dielectric Strength: 1,000 VAC between current carrying parts and
ground.
Contact Resistance: Average initial 3 milliohms.
Insulation Resistance:
In excess of 10,000 megohms.
MECHANICAL
Materials and Finishes: All parts utilize non-corrosive materials
as standard.
Terminals and Contacts: Brass with silver plate as standard.
Insulation: Diallyl phthalate.
Index: Single-ball, hill and valley.
Index Life: 25,000 cycles minimum.
Index Torque: Switches have lowest practical torque consistent
with crisp detenting and smooth, reliable operation.
Index Angles: 15° standard, 30°, 60°, and 90° available.
Index Stops: Fixed standard, or continuous available.
Stop Strength: 2.82 Nm minimum.
Hardware: Mounting nut and lockwasher are shipped assembled.
STANDARD PART NUMBER
15 ° INDEXING - FIXED STOPS
15° INDEXING - CONTINUOUS ROTATION
SOLDER LUG TERMINALS
ACTIVE
POLES POSITIONS
01
23
02
23
03
23
04
23
30° INDEXING
01
12
02
12
03
12
POLES/
DECK
NO. OF
DECKS
SHORTING
NONSHORTING
FIG.
1
1
1
1
1
2
3
4
C7D0123S
C7D0223S
C7D0323S
C7D0423S
C7D0123N
C7D0223N
C7D0323N
C7D0423N
CF
CF
CF
CF
1
1
1
1
2
3
C7D0112S -30
C7D0212S -30
C7D0312S -30
C7D0112N -30
C7D0212N -30
C7D0312N -30
CA
CA
CA
ACTIVE
POLES POSITIONS
01
24
02
24
03
24
04
24
30 ° INDEXING
01
12
02
12
03
12
POLES/
DECK
NO. OF
DECKS
1
1
1
1
1
2
3
4
1
1
1
1
2
3
SHORTING
C7D0124S - C
C7D0224S - C
C7D0324S - C
C7D0424S - C
NONSHORTING
C7D0124N - C
C7D0224N - C
C7D0324N - C
C7D0424N - C
FIG.
CG
CG
CG
CG
C7D0112S -30C C7D0112N -30C CA
C7D0212S -30C C7D0212N -30C CA
C7D0312S -30C C7D0312N -30C CA
* FIGURES ARE SHOWN ON PAGE 55.
DIMENSIONS
STANDARD CONSTRUCTION - 15 ° INDEX ANGLE (3 WAFER DECK)
• ELECTRONIC PRODUCTS
UNIT OF ELECTRO SWITCH CORP.
14
Q
.187 QUICK CONNECT
2010 Yonkers Road, Raleigh, NC 27604
ADDITIONAL OPTIONS AND ORDERING INFORMATION
C7 - SERIES
How to Order Additional Options:
2 DIGIT
SERIES
INSULATION
TYPE
TOTAL
POLES
ACTIVE
POSITIONS
C7
D - DIALLYL
01 - MIN.
24 - MAX @ 15°
CONTACT
TYPE
S - SHORTING
N - NON
SHORTING
TERMINAL
TYPE
L - SOLDER LUG
Q - QUICK
CONNECT
INDEX
ANGLE
STOP
TYPE
15°
SHAFT/
BUSHING
C
F - FIXED
23 - POS. MAX.
C - CONT.
SEE
CHART
"A"
SEE
CHART
"B"
(SPECIFY) (SPECIFY)
(SPECIFY)
24 - POS. MAX.
C7
D - DIALLYL
01 - MIN.
12 - MAX @ 30°
06 - MAX @ 60°
04 - MAX @ 90°
S - SHORTING
N - NON
SHORTING
L - SOLDER LUG
Q - QUICK
CONNECT
CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS
C
7
SHAFT
FLAT
30°
60°
90°
F - FIXED
C - CONT.
M
E
T
R
I
C
ADDITIONAL OPTIONS
D
(SPECIFY)
(SPECIFY)
(SPECIFY)
(SPECIFY)
(SPECIFY)
SHAFT AND FLAT OPTIONS
SHORTING AND
NON-SHORTING
SWITCHING IS
NOT GUARANTEED
ON THE 15° INDEXING
C7 SERIES.
SHAFT AS VIEWED
WITH NON-TURN LUG
AT 9 O'CLOCK AND
SHAFT IN EXTREME
CCW POSITION .
U
W
Y
Z
DIMENSIONS
STANDARD CONSTRUCTION - 30 ° INDEX ANGLE (2 WAFER DECK)
CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS.
15
很抱歉,暂时无法提供与“C7D0123S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3+323.772513+41.93430
- 50+234.2573950+30.34050
