D6D0112N
D6D0112N
    ELECTROSWITCH
    旋转开关 28VDC 115VAC
D6D0112N 数据手册
D6 - SERIES SPECIFICATIONS AND ORDERING INFORMATION 1.687" DIAMETER 1.5 AMPS @ 28 VDC The D6 Series is one of our more versatile rotary switches. A 30° index angle, solder lug terminals, and diallyl phthalate insulation are standard. However, additional indexes of 36°, 45°, and 60° and insulation sections of glass epoxy and ceramic are available. Adjustable stops are available on indexes of 30° and 60°. SPECIFICATIONS D ELECTRICAL MECHANICAL Current and Voltage Rating: Make and break resistive load 1.5 amps @ 28 VDC; 0.5 amp @ 115 VAC. Current Carrying Capacity: 9 amps. Dielectric Strength: 1,500 VAC between current carrying parts and ground. Contact Resistance: Average initial 3.5 milliohms. Insulation Resistance: Diallyl in excess of 900,000 megohms Glass in excess of 750,000 megohms. Ceramic in excess of 1,000,000 megohms. Hardware: Mounting nut and lockwasher are shipped assembled. Materials and Finishes: All parts utilize non-corrosive materials as standard. Clips and Rotors: Brass with silver plate as standard. Insulation: Diallyl phthalate, glass, or ceramic. Index: Dual-ball, side thrust design. Index Life: 25,000 cycles minimum. Index Torque: Switches have lowest practical torque consistent with crisp detenting and smooth, reliable operation. Index Angles: Positive 30° standard, 36°, 45°, and 60° available. Index Stops: Adjustable standard, fixed or continuous. Stop Strength: 25 in. lbs. minimum. STANDARD PART NUMBER DIALLYL PHTHALATE INSULATION SWITCHES - 30° INDEX - ADJUSTABLE STOPS - SOLDER LUG TERMINALS ACTIVE POLES/ NO. OF POLES POSITIONS SECTION SECTIONS 01 02 02 03 03 04 04 05 02-12 02-12 02-06 02-12 02-05 02-12 02-06 02-12 1 1 2 1 3 1 2 1 1 2 1 3 1 4 2 5 SHORTING NONSHORTING FIG. D6D0112S D6D0212S D6D0206S D6D0312S D6D0305S D6D0412S D6D0406S D6D0512S D6D0112N D6D0212N D6D0206N D6D0312N D6D0305N D6D0412N D6D0406N D6D0512N DD DD DL DD DO DD DL DD * ACTIVE POLES/ NO. OF POLES POSITIONS SECTION SECTIONS 05 06 06 06 08 09 10 10 02-03 02-12 02-06 02-05 02-06 02-05 02-03 02-06 5 1 2 3 2 3 5 2 1 6 3 2 4 3 2 5 SHORTING NONSHORTING FIG. D6D0503S D6D0612S D6D0606S D6D0605S D6D0806S D6D0905S D6D1003S D6D1006S D6D0503N D6D0612N D6D0606N D6D0605N D6D0806N D6D0905N D6D1003N D6D1006N DR DD DL DO DL DO DR DL * * FIGURES ARE SHOWN ON PAGES 55 AND 56. DIMENSIONS STANDARD CONSTRUCTION D6D - DIALLYL PHTHALATE CONSTRUCTION .4 3 7 • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 28 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 ADDITIONAL OPTIONS AND ORDERING INFORMATION D6 - SERIES How to Order Additional Options: 2 DIGIT SERIES INSULATION TYPE TOTAL POLES ACTIVE POSITIONS D6 D - DIALLYL 01 - MIN. 12 - MAX @ 30° 10 - MAX @ 36° 08 - MAX @ 45° 06 - MAX @ 60° S - SHORTING N - NON SHORTING 12 - MAX @ 30° 06 - MAX @ 60° S - SHORTING N - NON SHORTING (30°,45°,60°) G - GLASS (30°,36°,45°,60°) D6 C - CERAMIC 01 - MIN. (30°,60°) CONTACT TYPE TERMINAL TYPE L - SOLDER LUG R - REAR P.C. (NO 36°) L - SOLDER LUG CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS D INDEX ANGLE 30° 36° 45° 60° STOP TYPE SHAFT/ BUSHING SHAFT FLAT SEE CHART “A” SEE CHART “B” (SPECIFY) (SPECIFY) (SPECIFY) A - ADJ. (30°,60° ONLY) F - FIXED C - CONT. 30° 60° A - ADJ. F - FIXED C - CONT. ADDITIONAL OPTIONS 6 (SPECIFY) PRINTED BOARD MOUNTING PATTERN (SPECIFY) (SPECIFY) (SPECIFY) (SPECIFY) SHAFT, BUSHING, AND FLAT OPTIONS D SHAFT AS VIEWED WITH NON-TURN LUG AT 9 O'CLOCK AND SHAFT IN EXTREME CCW POSITION AND STRUT BOLTS ORIENTED VERTICALLY. W U Y Z INSULATION OPTIONS D6G - GLASS EPOXY INSULATION R REAR P.C. D6C - CERAMIC CONSTRUCTION CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS. • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 29
D6D0112N 价格&库存
很抱歉,暂时无法提供与“D6D0112N”相匹配的价格&库存,您可以联系我们找货
