D8G0117N
D8G0117N
    ELECTROSWITCH
    旋转开关 28VDC 115VAC
D8G0117N 数据手册
D8 - SERIES 2 5/16" DIAMETER SPECIFICATIONS AND ORDERING INFORMATION 2.25 AMPS @ 28 VDC The D8 Series switches are heavy duty, 18 position, 20° index, and glass epoxy insulation. Double eyelet construction is standard to assist in supporting larger wiring harness applications. Positive indexing is provided by a dual-ball, hill and valley index assembly. SPECIFICATIONS ELECTRICAL MECHANICAL Current and Voltage Rating: Make and break resistive load 2.25 amps @ 28 VDC; 1.0 amp @ 115 VAC. Current Carrying Capacity: 9 amps. Dielectric Strength: 1,000 VAC between current carrying parts and ground. Contact Resistance: Average initial 5 milliohms. Insulation Resistance: In excess of 750,000 megohms. Materials and Finishes: All parts utilize non-corrosive materials as standard. Clips and Rotors: Brass with silver plate as standard. Insulation: Glass epoxy. Index: Dual-ball, hill and valley. Index Life: 25,000 cycles minimum. Index Torque: Switches have lowest practical torque consistent with crisp detenting and smooth, reliable operation. Index Angles: Positive 20° standard. Index Stops: Adjustable standard, fixed or continuous. Stop Strength: 25 in. lbs. minimum. Hardware: Mounting nut and lockwasher are shipped assembled. D STANDARD PART NUMBER GLASS EPOXY INSULATION SWITCHES - 20° INDEXING ADJUSTABLE STOPS SET @ 2 POS. - SOLDER LUG TERMINALS ACTIVE POLES/ POLES POSITIONS SECTION 01 02 03 04 05 06 07 08 02-17 02-17 02-17 02-17 02-17 02-17 02-17 02-17 NO. OF SHORTING NONSECTIONS SHORTING 1 1 1 1 1 1 1 1 1 2 3 4 5 6 7 8 D8G0117S D8G0217S D8G0317S D8G0417S D8G0517S D8G0617S D8G0717S D8G0817S D8G0117N D8G0217N D8G0317N D8G0417N D8G0517N D8G0617N D8G0717N D8G0817N FIG. * DT DT DT DT DT DT DT DT * FIGURES ARE SHOWN ON PAGE 57. DIMENSIONS STANDARD CONSTRUCTION D8G - GLASS EPOXY CONSTRUCTION • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 32 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 ADDITIONAL OPTIONS AND ORDERING INFORMATION D8 - SERIES How to Order Additional Options: 2 DIGIT SERIES INSULATION TYPE D8 G - GLASS TOTAL POLES ACTIVE POSITIONS 01 - MIN. 18 - MAX @ 20° CONTACT TYPE TERMINAL TYPE N - NON SHORTING S - SHORTING 8 STOP TYPE SHAFT/ BUSHING SHAFT FLAT SEE CHART “A” SEE CHART “B” (SPECIFY) (SPECIFY) (SPECIFY) A - ADJ. F - FIXED C - CONT. CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS D INDEX ANGLE ADDITIONAL OPTIONS G (SPECIFY) (SPECIFY) (SPECIFY) SHAFT, BUSHING, AND FLAT OPTIONS D SHAFT AS VIEWED WITH NON-TURN LUG AT 9 O'CLOCK AND SHAFT IN EXTREME CCW POSITION AND STRUT BOLTS ORIENTED VERTICALLY. U W Y Z CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS. • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 33
D8G0117N 价格&库存
很抱歉,暂时无法提供与“D8G0117N”相匹配的价格&库存,您可以联系我们找货
