D3C0205N
D3C0205N
    ELECTROSWITCH
    旋转开关 28VDC 115VAC
D3C0205N 数据手册
D3 - SERIES SPECIFICATIONS AND ORDERING INFORMATION 1 5/16" DIAMETER 1.5 AMPS @ 28 VDC The D3 Series was originally designed as a high quality military switch, but is ideal for use in both military and commercial equipment applications. The standard features of this hill and valley design are glass epoxy insulation and a 30° index, with options of ceramic and diallyl insulation and a 60° index. SPECIFICATIONS D ELECTRICAL MECHANICAL Current and Voltage Rating: Make and break resistive load 1.5 amps @ 28 VDC; 0.5 amp @ 115 VAC. Current Carrying Capacity: 9 amps. Dielectric Strength: 1,000 VAC between current carrying parts and ground. Contact Resistance: Average initial 3.5 milliohms. Insulation Resistance: Glass in excess of 750,000 megohms. Ceramic in excess of 1,000,000 megohms. Diallyl in excess of 900,000 megohms. Hardware: Mounting nut and lockwasher are shipped assembled. Materials and Finishes: All parts utilize non-corrosive materials. Clips and Rotors: Silver alloy standard on ceramic. Brass with silver plate standard on glass. Insulation: Glass epoxy, ceramic, or diallyl phthalate. Index: Single-ball, hill and valley. Index Life: 25,000 cycles minimum. Index Torque: Switches have lowest practical torque consistent with crisp detenting and smooth, reliable operation. Index Angles: Positive 30° standard, 60° available. Index Stops: Adjustable standard, fixed or continuous. Stop Strength: 25 in. lbs. minimum. STANDARD PART NUMBER EPOXY GLASS INSULATION - BRASS SILVER PLATE CERAMIC INSULATION - SILVER ALLOY - 2.6 AMPS @ 28 VDC SWITCHES - SOLDER LUG TERMINALS - 30° INDEX - ADJUSTABLE STOPS SET @ 2 POS. SWITCHES - SOLDER LUG TERMINALS - 30° INDEX - ADJUSTABLE STOPS SET @ 2 POS. ACTIVE POLES/ POLES POSITIONS SECTION 01 02 02 03 03 04 06 06 02-11 02-11 02-05 02-11 02-03 02-05 02-03 02-05 NO. OF SHORTING NONSECTIONS SHORTING 1 1 2 1 3 2 3 2 1 2 1 3 1 2 2 3 D3G0111S D3G0211S D3G0205S D3G0311S D3G0303S D3G0405S D3G0603S D3G0605S D3G0111N D3G0211N D3G0205N D3G0311N D3G0303N D3G0405N D3G0603N D3G0605N FIG. * DA DA DH DA DM DH DM DH ACTIVE POLES/ POLES POSITIONS SECTION 01 02 02 03 03 04 06 06 02-11 02-11 02-05 02-11 02-03 02-05 02-03 02-05 1 1 2 1 3 2 3 2 NO. OF SHORTING NONSECTIONS SHORTING 1 2 1 3 1 2 2 3 D3C0111S D3C0211S D3C0205S D3C0311S D3C0303S D3C0405S D3C0603S D3C0605S D3C0111N D3C0211N D3C0205N D3C0311N D3C0303N D3C0405N D3C0603N D3C0605N FIG. * DA DA DH DA DM DH DM DH * FIGURES ARE SHOWN ON PAGES 55 AND 56. DIMENSIONS STANDARD CONSTRUCTION D3G - GLASS EPOXY CONSTRUCTION • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 22 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 ADDITIONAL OPTIONS AND ORDERING INFORMATION D3 - SERIES How to Order Additional Options: 2 DIGIT SERIES INSULATION TYPE TOTAL POLES D3 G - GLASS 01 - MIN. C - CERAMIC (SILVER ALLOY) D - DIALLYL ACTIVE POSITIONS 12 - MAX @ 30° 06 - MAX @ 60° CONTACT TYPE N - NON SHORTING S - SHORTING TERMINAL TYPE L - SOLDER LUG R - REAR P.C. INDEX ANGLE STOP TYPE 30° 60° A - ADJ. F - FIXED C - CONT. CUSTOMERS SPECIFIED ORDER NUMBER FOR STANDARD OPTIONS D SHAFT/ BUSHING SHAFT FLAT SEE CHART “A” SEE CHART “B” (SPECIFY) (SPECIFY) (SPECIFY) ADDITIONAL OPTIONS 3 (SPECIFY) (SPECIFY) (SPECIFY) (SPECIFY) (SPECIFY) SHAFT, BUSHING, AND FLAT OPTIONS D SHAFT AS VIEWED WITH NON-TURN LUG AT 9 O'CLOCK AND SHAFT IN EXTREME CCW POSITION AND STRUT BOLTS ORIENTED VERTICALLY. U W Y Z INSULATION AND PRINTED CIRCUIT BOARD TERMINAL OPTIONS D3C - CERAMIC CONSTRUCTION D3D -DIALLYL PHTHALATE CONSTRUCTION P.C. BOARD MOUNTING PATTERN R CUSTOM SWITCHES ARE AVAILABLE. CONTACT THE FACTORY WITH YOUR COMPLETE SPECIFICATIONS. • ELECTRONIC PRODUCTS UNIT OF ELECTRO SWITCH CORP. 2010 Yonkers Road Raleigh, NC 27604 Telephone: (888) ROTARYS or (919) 833-0707 Fax: (800) 909-9171 or (919) 833-8016 23
D3C0205N 价格&库存
很抱歉,暂时无法提供与“D3C0205N”相匹配的价格&库存,您可以联系我们找货
